ossimUsgsDemTileSource Class Reference
#include <ossimUsgsDemTileSource.h>
Inheritance diagram for ossimUsgsDemTileSource:
ossimImageHandler ossimImageSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimUsgsDemTileSource ()
virtual bool open ()
 Returns true if the "theImageFile can be opened. More...
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &tile_rect, ossim_uint32 resLevel=0)
 Method to get a tile. More...
 Returns the number of bands in the image. More...
virtual ossim_uint32 getNumberOfLines (ossim_uint32 reduced_res_level=0) const
 Returns the number of lines in the image. More...
virtual ossim_uint32 getNumberOfSamples (ossim_uint32 reduced_res_level=0) const
 Returns the number of samples in the image. More...
virtual ossimIrect getImageRectangle (ossim_uint32 reduced_res_level=0) const
 Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. More...
 Returns the output pixel type of the tile source. More...
 Returns the width of the output tile. More...
 Returns the height of the output tile. More...
virtual bool isOpen () const
 Override base-class method to make sure the internal geometry is explored before extending. More...
 ossimImageHandler ()
virtual ~ossimImageHandler ()
virtual void initialize ()
virtual bool openOverview ()
virtual void closeOverview ()
 Opens the image file. More...
virtual void close ()
 Deletes the overview and clears the valid image vertices. More...
 Sets the filename. More...
 Returns the filename. More...
virtual bool isValidRLevel (ossim_uint32 resLevel) const
 Connection rule. More...
virtual bool hasLut () const
virtual void loadMetaData ()
bool useEntryIndex () const
 Fetches the image ID. More...
template<class T >
template<class T >
virtual ~ossimImageSource ()
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
Protected Member Functions
 Initializes theGeometry from USGS DEM header. More...
virtual ~ossimUsgsDemTileSource ()
const ossimUsgsDemTileSourceoperator= (const ossimUsgsDemTileSource &rhs)
 ossimUsgsDemTileSource (const ossimUsgsDemTileSource &)
template<class T >
bool fillBuffer (T, const ossimIrect &tile_rect, const ossimIrect &clip_rect, ossimImageData *tile)
 Returns true on success, false on error. More...
void gatherStatistics ()
virtual void completeOpen ()
virtual ~ossimReferenced ()
Protected Attributes
ossimDemGridtheDem
ossim_float64 theNullValue
ossim_float64 theMinHeight
ossim_float64 theMaxHeight
bool theFeetFlag
bool theIsDemFlag
ossimScalarType theScalarType
 This can be either OSSIM_SINT16 or OSSIM_FLOAT32. More...
ossimFilename theImageFile
ossimFilename theOverviewFile
ossimString theImageID
bool theOpenOverviewFlag
ossimPixelType thePixelType
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Additional Inherited Members
Detailed Description
Definition at line 24 of file ossimUsgsDemTileSource.h.
◆ ossimUsgsDemTileSource() [1/2]
ossimUsgsDemTileSource::ossimUsgsDemTileSource ( )
Definition at line 43 of file ossimUsgsDemTileSource.cpp.
44  :
46  theDem(0),
47  theTile(0),
48  theNullValue(0.0),
49  theMinHeight(0.0),
50  theMaxHeight(0.0),
51  theFeetFlag(false),
52  theIsDemFlag(false),
54 {
55  // Construction not complete. Users should call "open" method.
56 }
16 bit signed integer
ossimImageHandler()
Constructor (default):
◆ ~ossimUsgsDemTileSource()
ossimUsgsDemTileSource::~ossimUsgsDemTileSource ( )
protectedvirtual
Definition at line 58 of file ossimUsgsDemTileSource.cpp.
References theDem, and theTile.
59 {
60  if (theDem)
61  {
62  delete theDem;
63  theDem = 0;
64  }
65  theTile = 0;
66 }
◆ ossimUsgsDemTileSource() [2/2]
ossimUsgsDemTileSource::ossimUsgsDemTileSource ( const ossimUsgsDemTileSource )
protected
Definition at line 560 of file ossimUsgsDemTileSource.cpp.
561 {
562 }
Member Function Documentation
◆ fillBuffer()
template<class T >
bool ossimUsgsDemTileSource::fillBuffer ( ,
const ossimIrect tile_rect,
const ossimIrect clip_rect,
ossimImageData tile
protected
Definition at line 173 of file ossimUsgsDemTileSource.cpp.
References ossimImageData::getBuf(), ossimDemGrid::getElevation(), ossimDemGrid::getHeader(), ossimDemHeader::getSpatialResZ(), ossimImageData::getWidth(), ossimIrect::lr(), MTRS_PER_FT, theDem, theFeetFlag, theNullValue, ossimIrect::ul(), ossimIpt::x, and ossimIpt::y.
Referenced by getTile().
177 {
178  const ossim_uint32 TILE_WIDTH = tile->getWidth();
179
180  T* d = static_cast<T*>(tile->getBuf());
181
182  ossim_float32 spatialResZ = theDem->getHeader().getSpatialResZ();
183  if (spatialResZ == 0.0) spatialResZ = 1.0;
184
185  // Compute the starting offset.
186  ossim_uint32 offset = (clip_rect.ul().y - tile_rect.ul().y) * TILE_WIDTH +
187  clip_rect.ul().x - tile_rect.ul().x;
188
189  for (ossim_int32 line = clip_rect.ul().y; line <= clip_rect.lr().y; ++line)
190  {
191  // Loop in the longitude or sample direction.
192  int samp_offset = 0;
193  for (ossim_int32 samp = clip_rect.ul().x; samp <= clip_rect.lr().x; ++samp)
194  {
195  ossim_float32 p = theDem->getElevation(samp, line);
196  if (p != theNullValue)
197  {
198  p *= spatialResZ;
199  if (theFeetFlag) p = p * MTRS_PER_FT;
200  }
201  d[offset + samp_offset] = static_cast<T>(p);
202  ++samp_offset;
203  }
204  offset += TILE_WIDTH;
205  }
206
207  return true;
208 }
float ossim_float32
const ossimIpt & ul() const
Definition: ossimIrect.h:274
unsigned int ossim_uint32
const ossimIpt & lr() const
Definition: ossimIrect.h:276
#define MTRS_PER_FT
double getSpatialResZ() const
ossim_int32 y
Definition: ossimIpt.h:142
ossimDemHeader const & getHeader() const
ossim_int32 x
Definition: ossimIpt.h:141
ossim_float32 getElevation(long x, long y) const
int ossim_int32
◆ gatherStatistics()
void ossimUsgsDemTileSource::gatherStatistics ( )
protected
◆ getImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimUsgsDemTileSource::getImageGeometry ( )
virtual
Definition at line 369 of file ossimUsgsDemTileSource.cpp.
References ossimImageGeometryRegistry::extendGeometry(), ossimRefPtr< T >::get(), ossimImageHandler::getExternalImageGeometry(), getInternalImageGeometry(), ossimImageGeometry::getProjection(), ossimImageHandler::initImageParameters(), ossimImageGeometryRegistry::instance(), and ossimImageHandler::theGeometry.
370 {
371  if ( !theGeometry )
372  {
373  // Check for external geom:
375
376  if ( !theGeometry )
377  {
378  // Check the internal geometry first to avoid a factory call.
380
381  // At this point it is assured theGeometry is set.
382
383  //---
384  // WARNING:
385  // Must create/set theGeometry at this point or the next call to
386  // ossimImageGeometryRegistry::extendGeometry will put us in an infinite loop
387  // as it does a recursive call back to ossimImageHandler::getImageGeometry().
388  //---
389
390  // Check for set projection.
391  if ( !theGeometry->getProjection() )
392  {
393  // Try factories for projection.
395  }
396  }
397
398  // Set image things the geometry object should know about.
400  }
401
402  return theGeometry;
403 }
static ossimImageGeometryRegistry * instance()
virtual ossimRefPtr< ossimImageGeometry > getInternalImageGeometry() const
ossimRefPtr< ossimImageGeometry > theGeometry
virtual bool extendGeometry(ossimImageHandler *handler) const
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
virtual ossimRefPtr< ossimImageGeometry > getExternalImageGeometry() const
Returns the image geometry object associated with this tile source or NULL if non defined...
◆ getImageRectangle()
ossimIrect ossimUsgsDemTileSource::getImageRectangle ( ossim_uint32  reduced_res_level = 0) const
virtual
Note that rrds 0 is the highest resolution rrds.
Definition at line 211 of file ossimUsgsDemTileSource.cpp.
References getNumberOfLines(), and getNumberOfSamples().
212 {
213  return ossimIrect(0,
214  0,
215  getNumberOfSamples(reduced_res_level) - 1,
216  getNumberOfLines(reduced_res_level) - 1);
217 }
virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level=0) const
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level=0) const
◆ getImageTileHeight()
ossim_uint32 ossimUsgsDemTileSource::getImageTileHeight ( ) const
virtual
Implements ossimImageHandler.
Definition at line 502 of file ossimUsgsDemTileSource.cpp.
503 {
504  return 0;
505 }
◆ getImageTileWidth()
ossim_uint32 ossimUsgsDemTileSource::getImageTileWidth ( ) const
virtual
Definition at line 497 of file ossimUsgsDemTileSource.cpp.
498 {
499  return 0;
500 }
◆ getInternalImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimUsgsDemTileSource::getInternalImageGeometry ( ) const
protectedvirtual
This is called by base ossimImageHandler::getImageGeometry if theGeometry is not set. External callers should not go through this method but call "getImageGeometry" instead for efficiency reasons.
Returns
Pointer to geometry or null if header not found.
Definition at line 406 of file ossimUsgsDemTileSource.cpp.
References ossimDemGrid::getHeader(), and theDem.
Referenced by getImageGeometry().
407 {
409
410  if (theDem)
411  {
412  const ossimDemHeader HDR = theDem->getHeader();
413  if (traceDebug())
414  {
416  << "ossimUsgsDemTileSource::getInternalImageGeometry DEBUG:"
417  << "\nDEM Header:"
418  << std::endl;
420  }
421
422  // The DEM's image geometry is a map projection, obtained here via KWL:
423  ossimKeywordlist proj_kwl;
424  if ( HDR.getImageGeometry(proj_kwl) )
425  {
426  if (traceDebug())
427  {
429  << "ossimUsgsDemTileSource::getInternalImageGeometry DEBUG:"
430  << "keyword list:\n" << proj_kwl
431  << std::endl;
432  }
433
434  // Capture for next time.
437  createProjection(proj_kwl);
438  if ( proj.valid() )
439  {
440  geom->setProjection(proj.get());
441  }
442  }
443  }
444
445  return geom;
446 }
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
bool valid() const
Definition: ossimRefPtr.h:75
static ossimProjectionFactoryRegistry * instance()
std::ostream & print(std::ostream &out) const
Print method.
bool getImageGeometry(ossimKeywordlist &kwl, const char *prefix=NULL) const
◆ getLongName()
ossimString ossimUsgsDemTileSource::getLongName ( ) const
virtual
Definition at line 512 of file ossimUsgsDemTileSource.cpp.
513 {
514  return ossimString("usgs dem reader");
515 }
◆ getMaxPixelValue()
double ossimUsgsDemTileSource::getMaxPixelValue ( ossim_uint32  band = 0) const
virtual
Definition at line 541 of file ossimUsgsDemTileSource.cpp.
References ossimImageMetaData::getMaxPix(), ossimImageMetaData::getNumberOfBands(), theMaxHeight, and ossimImageHandler::theMetaData.
542 {
544  {
545  return theMetaData.getMaxPix(band);
546  }
547  return theMaxHeight;
548 }
double getMaxPix(ossim_uint32 band) const
ossim_uint32 getNumberOfBands() const
ossimImageMetaData theMetaData
◆ getMinPixelValue()
double ossimUsgsDemTileSource::getMinPixelValue ( ossim_uint32  band = 0) const
virtual
Retuns the min pixel value.
If there was an external eta data file then use the meta data from that file. If not given then we will return the default min
Definition at line 532 of file ossimUsgsDemTileSource.cpp.
References ossimImageMetaData::getMinPix(), ossimImageMetaData::getNumberOfBands(), ossimImageHandler::theMetaData, and theMinHeight.
533 {
534  if(band < theMetaData.getNumberOfBands())
535  {
536  return theMetaData.getMinPix(band);
537  }
538  return theMinHeight;
539 }
double getMinPix(ossim_uint32 band) const
◆ getNullPixelValue()
double ossimUsgsDemTileSource::getNullPixelValue ( ossim_uint32  band = 0) const
virtual
Definition at line 527 of file ossimUsgsDemTileSource.cpp.
References theNullValue.
528 {
529  return theNullValue;
530 }
◆ getNumberOfInputBands()
ossim_uint32 ossimUsgsDemTileSource::getNumberOfInputBands ( ) const
virtual
Satisfies pure virtual requirement from ImageHandler class.
Implements ossimImageSource.
Definition at line 517 of file ossimUsgsDemTileSource.cpp.
518 {
519  return 1;
520 }
◆ getNumberOfLines()
ossim_uint32 ossimUsgsDemTileSource::getNumberOfLines ( ossim_uint32  reduced_res_level = 0) const
virtual
Definition at line 463 of file ossimUsgsDemTileSource.cpp.
References ossimDemGrid::getHeight(), ossimImageHandler::getNumberOfLines(), theDem, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by getImageRectangle().
464 {
465  ossim_uint32 result = 0;
466  if (reduced_res_level == 0)
467  {
468  if (theDem)
469  {
470  result = theDem->getHeight();
471  }
472  }
473  else if (theOverview.valid())
474  {
475  result = theOverview->getNumberOfLines(reduced_res_level);
476  }
477  return result;
478 }
bool valid() const
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
long getHeight() const
ossimRefPtr< ossimImageHandler > theOverview
◆ getNumberOfOutputBands()
ossim_uint32 ossimUsgsDemTileSource::getNumberOfOutputBands ( ) const
virtual
Definition at line 522 of file ossimUsgsDemTileSource.cpp.
523 {
524  return 1;
525 }
◆ getNumberOfSamples()
ossim_uint32 ossimUsgsDemTileSource::getNumberOfSamples ( ossim_uint32  reduced_res_level = 0) const
virtual
Definition at line 480 of file ossimUsgsDemTileSource.cpp.
References ossimImageHandler::getNumberOfSamples(), ossimDemGrid::getWidth(), theDem, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
481 {
482  ossim_uint32 result = 0;
483  if (reduced_res_level == 0)
484  {
485  if (theDem)
486  {
487  result = theDem->getWidth();
488  }
489  }
490  else if (theOverview.valid())
491  {
492  result = theOverview->getNumberOfSamples(reduced_res_level);
493  }
494  return result;
495 }
long getWidth() const
bool valid() const
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
◆ getOutputScalarType()
ossimScalarType ossimUsgsDemTileSource::getOutputScalarType ( ) const
virtual
Definition at line 448 of file ossimUsgsDemTileSource.cpp.
References theScalarType.
449 {
450  return theScalarType;
451 }
◆ getShortName()
ossimString ossimUsgsDemTileSource::getShortName ( ) const
virtual
Definition at line 507 of file ossimUsgsDemTileSource.cpp.
508 {
509  return ossimString("usgs dem");
510 }
◆ getTile() [1/2]
ossimRefPtr< ossimImageData > ossimUsgsDemTileSource::getTile ( const ossimIrect rect,
ossim_uint32  resLevel = 0
virtual
Returns
Definition at line 68 of file ossimUsgsDemTileSource.cpp.
References ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), theTile, and ossimRefPtr< T >::valid().
70 {
71  if (theTile.valid())
72  {
73  // Image rectangle must be set prior to calling getTile.
74  theTile->setImageRectangle(tile_rect);
75
76  if ( getTile( theTile.get(), resLevel ) == false )
77  {
79  {
80  theTile->makeBlank();
81  }
82  }
83  }
84
85  return theTile;
86 }
bool valid() const
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tile_rect, ossim_uint32 resLevel=0)
virtual void makeBlank()
◆ getTile() [2/2]
bool ossimUsgsDemTileSource::getTile ( ossimImageData result,
virtual
Parameters
resultThe tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands()
Returns
true on success false on error. If return is false, result is undefined so caller should handle appropriately with makeBlank or whatever.
Definition at line 88 of file ossimUsgsDemTileSource.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), fillBuffer(), getImageRectangle(), ossimImageData::getImageRectangle(), ossimImageData::getMaxPix(), ossimImageData::getMinPix(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), ossimIrect::intersects(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), ossimImageData::makeBlank(), OSSIM_FLOAT32, ossimReferenced::ref(), ossimImageData::setMaxPix(), ossimImageData::setMinPix(), ossimImageData::setNullPix(), status, theScalarType, theTile, ossimReferenced::unref(), and ossimImageData::validate().
90 {
91  bool status = false;
92
93  //---
94  // Not open, this tile source bypassed, or invalid res level,
95  // return a blank tile.
96  //---
97  if( isOpen() && isSourceEnabled() && isValidRLevel(resLevel) &&
98  result && (result->getNumberOfBands() == getNumberOfOutputBands()) )
99  {
100  result->ref(); // Increment ref count.
101
102  //---
103  // Check for overview tile. Some overviews can contain r0 so always
104  // call even if resLevel is 0. Method returns true on success, false
105  // on error.
106  //---
107  status = getOverviewTile(resLevel, result);
108
109  if (status) // From old code. Not sure if still needed.
110  {
114  }
115
116  if (!status) // Did not get an overview tile.
117  {
118  status = true;
119
120  ossimIrect tile_rect = result->getImageRectangle();
121
122  ossimIrect image_rect = getImageRectangle(resLevel);
123
124  //---
125  // See if any point of the requested tile is in the image.
126  //---
127  if ( tile_rect.intersects(image_rect) )
128  {
129  ossimIrect clip_rect = tile_rect.clipToRect(image_rect);
130
131  if ( !tile_rect.completely_within(clip_rect) )
132  {
133  // Start with a blank tile.
134  result->makeBlank();
135  }
136
137  // Load the tile buffer with data from the dem cell.
139  {
141  tile_rect,
142  clip_rect,
143  result);
144  }
145  else
146  {
148  tile_rect,
149  clip_rect,
150  result);
151  }
152  if (status == true)
153  {
154  result->validate();
155  }
156  }
157  else // No intersection: if ( tile_rect.intersects(image_rect) )
158  {
159  result->makeBlank();
160  }
161  }
162
163  result->unref(); // Decrement ref count.
164  }
165
166  return status;
167 }
virtual const ossim_float64 * getMaxPix() const
float ossim_float32
32 bit floating point
bool intersects(const ossimIrect &rect) const
Definition: ossimIrect.cpp:183
void ref() const
increment the reference count by one, indicating that this object has another pointer which is refere...
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
virtual bool isOpen() const
bool completely_within(const ossimIrect &rect) const
Definition: ossimIrect.cpp:425
virtual void setNullPix(ossim_float64 null_pix)
virtual bool getOverviewTile(ossim_uint32 resLevel, ossimImageData *result)
Method to get an overview tile.
signed short ossim_sint16
virtual const ossim_float64 * getNullPix() const
virtual ossimIrect getImageRectangle() const
void unref() const
decrement the reference count by one, indicating that a pointer to this object is referencing it...
virtual const ossim_float64 * getMinPix() const
return status
virtual void setMaxPix(ossim_float64 max_pix)
bool fillBuffer(T, const ossimIrect &tile_rect, const ossimIrect &clip_rect, ossimImageData *tile)
virtual ossimIrect getImageRectangle(ossim_uint32 reduced_res_level=0) const
Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in...
virtual void setMinPix(ossim_float64 min_pix)
◆ getTileHeight()
ossim_uint32 ossimUsgsDemTileSource::getTileHeight ( ) const
virtual
Definition at line 458 of file ossimUsgsDemTileSource.cpp.
References ossimImageData::getHeight(), theTile, and ossimRefPtr< T >::valid().
459 {
460  return ( theTile.valid() ? theTile->getHeight() : 0 );
461 }
bool valid() const
◆ getTileWidth()
ossim_uint32 ossimUsgsDemTileSource::getTileWidth ( ) const
virtual
Definition at line 453 of file ossimUsgsDemTileSource.cpp.
References ossimImageData::getWidth(), theTile, and ossimRefPtr< T >::valid().
454 {
455  return ( theTile.valid() ? theTile->getWidth() : 0 );
456 }
bool valid() const
◆ isOpen()
bool ossimUsgsDemTileSource::isOpen ( ) const
virtual
Returns
true if open, false if not.
Definition at line 550 of file ossimUsgsDemTileSource.cpp.
References theDem.
551 {
552  return (theDem ? true : false );
553 }
◆ loadState()
bool ossimUsgsDemTileSource::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Keywords picked up by this method: dem_type: usgs_dem scalar_type: ossim_sint16 (default) or scalar_type: ossim_float32
Definition at line 313 of file ossimUsgsDemTileSource.cpp.
References ossimKeywordlist::find(), and ossimImageHandler::loadState().
315 {
316  if (ossimImageHandler::loadState(kwl, prefix))
317  {
318  //***
319  // Look for "dem_type: usgs_dem" key value pair.
320  // Note: If not in the keyword list the "open" will look for it on
321  // disk.
322  //***
323  const char* lookup = kwl.find(prefix, DEM_TYPE_KW);
324  if (lookup)
325  {
326  ossimString s = lookup;
327  s.downcase();
328  if (s == USGS_DEM_KW) theIsDemFlag = true;
329  }
330
331  //---
332  // Look for scalar type override.
333  //
334  // Note: We only allow float or signed 16 bit.
335  //---
336  lookup = kwl.find(prefix, ossimKeywordNames::SCALAR_TYPE_KW);
337  if (lookup)
338  {
339  ossimScalarType st =
341  getEntryNumber(lookup));
342  if ( (st == OSSIM_FLOAT32) || (st == OSSIM_SINT16))
343  {
344  theScalarType = st;
345  }
346  else
347  {
348  if (traceDebug())
349  {
351  << "ossimUsgsDemTileSource::loadState WARNING:"
352  << "\nInvalid scalar type: "
354  getEntryString(st)
355  << std::endl;
356  }
357  }
358  }
359
360  if (open())
361  {
362  return true;
363  }
364  }
365
366  return false;
367 }
virtual bool open()
static ossimScalarTypeLut * instance()
Returns the static instance of an ossimScalarTypeLut object.
ossimScalarType
static const char * SCALAR_TYPE_KW
◆ open()
bool ossimUsgsDemTileSource::open ( )
virtual
If the extension is not equal to ".dem" this will attempt to look for an ".omd" file with the keyword pair "dem_type: usgs_dem" in it.
Optionally users can change the scalar type from signed 16 bit to float with the keyword pair "scalar_type: ossim_float32"
Definition at line 219 of file ossimUsgsDemTileSource.cpp.
220 {
221  static const char MODULE[] = "ossimUsgsDemTileSource::open";
222
223  if (traceDebug())
224  {
225  CLOG << "DEBUG:"
226  << "\nAttempting to parse file: " << theImageFile.c_str()
227  << std::endl;
228  }
229
231
232  if (theIsDemFlag)
233  {
234  // Open up the file for reading.
236  std::ios_base::in | std::ios_base::binary);
237  if (is.good())
238  {
239  // Start out with a fresh dem.
240  if (theDem) delete theDem;
241
242  //---
243  // Set the null to -32768. This will also be the missing data values.
244  //---
246
247  //---
248  // Read the dem.
249  //
250  // NOTE: This defines the missing data value. It should be the
251  // same as null for mosaicing and min/max calculations.
252  //---
254  theDem->read(is);
255
256  is.close();
257  }
258  else
259  {
260  theIsDemFlag = false;
261  }
262  }
263
264  if (theIsDemFlag)
265  {
267  true : false;
268
273
274  completeOpen();
275
276  //---
277  // Set up the tiles. Note the blank tile will not get initialized to
278  // save memory. This includes setting the min and max pixel value
279  // gathered from the statistics.
280  //---
282  theTile->initialize();
283
284  if (traceDebug())
285  {
286  CLOG << setiosflags(ios::fixed) << setprecision(5) << "DEBUG:"
287  << "\nNull pix: " << (theTile->getNullPix(0))
288  << "\nMin pix: " << (theTile->getMinPix(0))
289  << "\nMax pix: " << (theTile->getMaxPix(0))
290  << "\nlines: " << theDem->getHeight()
291  << "\nsamples: " << theDem->getWidth()
292  << std::endl;
293  }
294  }
295
296  return theIsDemFlag;
297 }
ossim_int32 getElevationUnits() const
#define CLOG
Definition: ossimTrace.h:23
std::basic_ifstream< char > ifstream
Class for char input file streams.
Definition: ossimIosFwd.h:44
#define OSSIM_DEFAULT_NULL_PIX_SINT16
double getMinimumElev() const
virtual void initialize()
Initialize the data buffer.
static bool isUsgsDem(const ossimFilename &file)
Does basic sanity checks to see if file is a dem.
long read(ossim::istream &dem, bool incrementalRead=false)
#define MTRS_PER_FT
virtual void completeOpen()
Will complete the opening process.
const char * c_str() const
Definition: ossimString.h:396
double getMaximumElev() const
◆ operator=()
const ossimUsgsDemTileSource & ossimUsgsDemTileSource::operator= ( const ossimUsgsDemTileSource rhs)
protected
Definition at line 555 of file ossimUsgsDemTileSource.cpp.
556 {
557  return rhs;
558 }
◆ saveState()
bool ossimUsgsDemTileSource::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 299 of file ossimUsgsDemTileSource.cpp.
References ossimKeywordlist::add().
301 {
302  // Save of the dem type keyword.
303  kwl.add(prefix, DEM_TYPE_KW, USGS_DEM_KW, true);
304
305  // Save the scalar type.
306  kwl.add(prefix,
308  ossimScalarTypeLut::instance()->getEntryString(theScalarType));
309
310  return ossimImageHandler::saveState(kwl, prefix);
311 }
Member Data Documentation
◆ theDem
ossimDemGrid* ossimUsgsDemTileSource::theDem
protected
◆ theFeetFlag
bool ossimUsgsDemTileSource::theFeetFlag
protected
Definition at line 182 of file ossimUsgsDemTileSource.h.
Referenced by fillBuffer().
◆ theIsDemFlag
bool ossimUsgsDemTileSource::theIsDemFlag
protected
Definition at line 183 of file ossimUsgsDemTileSource.h.
◆ theMaxHeight
ossim_float64 ossimUsgsDemTileSource::theMaxHeight
protected
Definition at line 181 of file ossimUsgsDemTileSource.h.
Referenced by getMaxPixelValue().
◆ theMinHeight
ossim_float64 ossimUsgsDemTileSource::theMinHeight
protected
Definition at line 180 of file ossimUsgsDemTileSource.h.
Referenced by getMinPixelValue().
◆ theNullValue
ossim_float64 ossimUsgsDemTileSource::theNullValue
protected
Definition at line 179 of file ossimUsgsDemTileSource.h.
Referenced by fillBuffer(), and getNullPixelValue().
◆ theScalarType
ossimScalarType ossimUsgsDemTileSource::theScalarType
protected
Default = OSSIM_SINT16 Can be changed via ".omd" file keyword:
Definition at line 189 of file ossimUsgsDemTileSource.h.
Referenced by getOutputScalarType(), and getTile().
◆ theTile
ossimRefPtr<ossimImageData> ossimUsgsDemTileSource::theTile
protected
