Functions | Variables
ossimWebPluginInit.cpp File Reference
#include <ossim/plugin/ossimPluginConstants.h>
#include <ossim/plugin/ossimSharedPluginRegistry.h>
#include <ossim/base/ossimString.h>
#include <ossim/base/ossimKeywordlist.h>
#include <ossim/base/ossimWebRequestFactoryRegistry.h>
#include "ossimWebPluginRequestFactory.h"
#include <ossim/base/ossimStreamFactoryRegistry.h>
#include "CurlStreamDefaults.h"
#include "ossimCurlStreamFactory.h"
Go to the source code of this file.
Functions
const char * getWebDescription ()
int getWebNumberOfClassNames ()
const char * getWebClassName (int idx)
OSSIM_PLUGINS_DLL void ossimSharedLibraryInitialize (ossimSharedObjectInfo **info, const char *options)
OSSIM_PLUGINS_DLL void ossimSharedLibraryFinalize ()
Variables
ossimSharedObjectInfo myWebInfo
ossimString theWebDescription
std::vector< ossimStringtheWebObjList
Function Documentation
◆ getWebClassName()
const char* getWebClassName ( int  idx)
Definition at line 45 of file ossimWebPluginInit.cpp.
References theWebObjList.
Referenced by ossimSharedLibraryInitialize().
46  {
47  if(idx < (int)theWebObjList.size())
48  {
49  return theWebObjList[idx].c_str();
50  }
51  return (const char*)0;
52  }
std::vector< ossimString > theWebObjList
◆ getWebDescription()
const char* getWebDescription ( )
Definition at line 35 of file ossimWebPluginInit.cpp.
References ossimString::c_str(), and theWebDescription.
36  {
37  return theWebDescription.c_str();
38  }
const char * c_str() const
Definition: ossimString.h:396
◆ getWebNumberOfClassNames()
int getWebNumberOfClassNames ( )
Definition at line 40 of file ossimWebPluginInit.cpp.
41  {
42  return (int)theWebObjList.size();
43  }
◆ ossimSharedLibraryFinalize()
OSSIM_PLUGINS_DLL void ossimSharedLibraryFinalize ( )
Definition at line 89 of file ossimWebPluginInit.cpp.
90  {
91  }
◆ ossimSharedLibraryInitialize()
OSSIM_PLUGINS_DLL void ossimSharedLibraryInitialize ( ossimSharedObjectInfo **  info,
const char *  options
Definition at line 55 of file ossimWebPluginInit.cpp.
References ossimKeywordlist::find(), ossimSharedObjectInfo::getClassName, ossimSharedObjectInfo::getDescription, ossimSharedObjectInfo::getNumberOfClassNames, getWebClassName(), getWebDescription(), getWebNumberOfClassNames(), ossimWebPluginRequestFactory::instance(), ossimWebRequestFactoryRegistry::instance(), ossim::CurlStreamFactory::instance(), ossim::StreamFactoryRegistry::instance(), ossim::CurlStreamDefaults::loadDefaults(), myWebInfo, and ossimKeywordlist::parseString().
58  {
62
63  *info = &myWebInfo;
64  ossimKeywordlist kwl;
65  kwl.parseString(ossimString(options));
66
68  /* Register our stream factory... */
70  registerFactory( ossim::CurlStreamFactory::instance() );
71
72  if(ossimString(kwl.find("reader_factory.location")).downcase() == "front")
73  {
74  /* Register the readers... */
76  registerFactoryToFront(ossimWebPluginRequestFactory::instance());
77  }
78  else
79  {
80  /* Register the readers... */
82  registerFactory(ossimWebPluginRequestFactory::instance());
83  }
84  setWebDescription(theWebDescription);
86  }
static CurlStreamFactory * instance()
ossimSharedLibraryGetNumberOfClassNamesPtr getNumberOfClassNames
static ossimWebPluginRequestFactory * instance()
virtual void getTypeNameList(std::vector< ossimString > &typeList) const
static StreamFactoryRegistry * instance()
static ossimWebRequestFactoryRegistry * instance()
ossimSharedLibraryGetDescriptionPtr getDescription
virtual bool parseString(const std::string &inString)
ossimSharedLibraryGetClassNamesPtr getClassName
const char * getWebClassName(int idx)
int getWebNumberOfClassNames()
const char * getWebDescription()
Variable Documentation
◆ myWebInfo
Definition at line 31 of file ossimWebPluginInit.cpp.
◆ theWebDescription
Definition at line 32 of file ossimWebPluginInit.cpp.
Referenced by getWebDescription().
◆ theWebObjList
std::vector<ossimString> theWebObjList
Definition at line 33 of file ossimWebPluginInit.cpp.
Referenced by getWebClassName(), and getWebNumberOfClassNames().
