Public Member Functions | Static Public Member Functions | Static Protected Attributes | List of all members
ossim2dTo2dTransformFactory Class Reference
#include <ossim2dTo2dTransformFactory.h>
Inheritance diagram for ossim2dTo2dTransformFactory:
ossim2dTo2dTransformFactoryBase ossimObjectFactory ossimObject ossimReferenced
 ossim2dTo2dTransformFactory ()
virtual ossim2dTo2dTransformcreateTransform (const ossimString &name) const
 Take a transform type name. More...
virtual ossim2dTo2dTransformcreateTransform (const ossimKeywordlist &kwl, const char *prefix) const
 Take a keywordlist. More...
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
- Public Member Functions inherited from ossim2dTo2dTransformFactoryBase
virtual ossimObjectcreateObject (const ossimString &typeName) const
 Creates an object given a type name. More...
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
 Creates and object given a keyword list. More...
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossim2dTo2dTransformFactoryinstance ()
static ossim2dTo2dTransformFactorym_instance = 0
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 16 of file ossim2dTo2dTransformFactory.h.
◆ ossim2dTo2dTransformFactory()
ossim2dTo2dTransformFactory::ossim2dTo2dTransformFactory ( )
inline
Definition at line 19 of file ossim2dTo2dTransformFactory.h.
Referenced by instance().
19 {}
Member Function Documentation
◆ createTransform() [1/2]
ossim2dTo2dTransform * ossim2dTo2dTransformFactory::createTransform ( const ossimString name) const
virtual
Implements ossim2dTo2dTransformFactoryBase.
Definition at line 29 of file ossim2dTo2dTransformFactory.cpp.
References STATIC_TYPE_NAME.
Referenced by createTransform().
30 {
31  ossim2dTo2dTransform* result = 0;
33  {
34  result = new ossim2dBilinearTransform();
35  }
37  {
38  result = new ossim2dTo2dShiftTransform();
39  }
41  {
42  result = new ossim2dTo2dIdentityTransform();
43  }
44
45  return result;
46 }
This is the identity transform and just passes the input to the output.
#define STATIC_TYPE_NAME(T)
Definition: ossimRtti.h:325
ossim2dBilinearTransform allows one to specify a set of input points and output points and will fit a...
◆ createTransform() [2/2]
ossim2dTo2dTransform * ossim2dTo2dTransformFactory::createTransform ( const ossimKeywordlist kwl,
const char *  prefix
) const
virtual
Take a keywordlist.
Definition at line 48 of file ossim2dTo2dTransformFactory.cpp.
References createTransform(), ossimKeywordlist::find(), ossim2dTo2dTransform::loadState(), ossimRefPtr< T >::release(), ossimKeywordNames::TYPE_KW, and ossimRefPtr< T >::valid().
50 {
51  ossimString type = kwl.find(prefix, ossimKeywordNames::TYPE_KW);
53  if(result.valid()&&!result->loadState(kwl, prefix))
54  {
55  result = 0;
56  }
57
58  return result.release();
59 }
virtual ossim2dTo2dTransform * createTransform(const ossimString &name) const
bool valid() const
Definition: ossimRefPtr.h:75
static const char * TYPE_KW
T * release()
Definition: ossimRefPtr.h:93
◆ getTypeNameList()
void ossim2dTo2dTransformFactory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Implements ossimObjectFactory.
Definition at line 61 of file ossim2dTo2dTransformFactory.cpp.
62 {
63  typeList.push_back(STATIC_TYPE_NAME(ossim2dBilinearTransform));
64  typeList.push_back(STATIC_TYPE_NAME(ossim2dTo2dShiftTransform));
66 }
◆ instance()
ossim2dTo2dTransformFactory * ossim2dTo2dTransformFactory::instance ( )
static
Definition at line 20 of file ossim2dTo2dTransformFactory.cpp.
References m_instance, and ossim2dTo2dTransformFactory().
Referenced by ossim2dTo2dTransformRegistry::instance().
21 {
22  if(!m_instance)
23  {
25  }
26  return m_instance;
27 }
static ossim2dTo2dTransformFactory * m_instance
Member Data Documentation
◆ m_instance
ossim2dTo2dTransformFactory * ossim2dTo2dTransformFactory::m_instance = 0
staticprotected
Definition at line 41 of file ossim2dTo2dTransformFactory.h.
