Public Member Functions | Static Public Member Functions | Private Member Functions | Private Attributes | Friends | List of all members
ossimEnviHeader Class Reference
Class for reading and writing an ENVI (The Environment for Visualizing Images) header file. More...
#include <ossimEnviHeader.h>
Inheritance diagram for ossimEnviHeader:
ossimReferenced
 ossimEnviHeader ()
 default construtor More...
virtual ~ossimEnviHeader ()
 virtual destructor More...
virtual void reset ()
const ossimKeywordlistgetMap () const
bool getValue (const ossimString &key, ossimString &value) const
 Gets value for key. More...
bool findCaseInsensitive (const ossimString &key, ossimString &value) const
bool findSubStringCaseInsensitive (const ossimString &key, ossimString &value) const
bool open (const ossimFilename &file)
 Opens an envi header. More...
bool writeFile (const ossimFilename &file)
 Writes header to file in a standard envi format. More...
std::ostream & print (std::ostream &out) const
 Prints header to out in a standard envi format. More...
ossimString getDescription () const
void setDescription (const ossimString &description)
ossim_uint32 getSamples () const
void setSamples (ossim_uint32 samples)
 Sets the number of samples. More...
ossim_uint32 getLines () const
void setLines (ossim_uint32 lines)
 Sets the number of lines. More...
ossim_uint32 getBands () const
void setBands (ossim_uint32 bands)
 Sets the number of bands. More...
bool getDefaultBands (std::vector< ossim_uint32 > &bands) const
 Gets default bands if "default bands" keyword is present. More...
bool getRgbBandsFromWaveLength (std::vector< ossim_uint32 > &bands) const
 Gets rgb bands if "wavelength" keyword is present. More...
ossim_uint32 getHeaderOffset () const
void setHeaderOffset (ossim_uint32 headerOffset)
 Sets the header offset in bytes. More...
ossimString getFileType () const
void setFileType (const ossimString &fileType)
 Sets the file type. More...
ossim_uint32 getDataType () const
ossimScalarType getOssimScalarType () const
void setDataType (ossimScalarType scalar)
 Sets the envi data type based on the ossimScalarType. More...
ossimString getInterleaveType () const
ossimInterleaveType getOssimInterleaveType () const
void setInterleaveType (ossimInterleaveType interleave)
 Sets the envi interleave type string based on the ossimInterleaveType. More...
ossimString getSensorType () const
void setSensorType (const ossimString &sensorType)
 Sets the envi sensor type string. More...
ossimByteOrder getByteOrder () const
void setByteorder (ossimByteOrder byteOrder)
 Sets the envi byte order from the ossimByteOrder. More...
ossim_int32 getXStart () const
void setXStart (ossim_int32 xstart)
 Sets the x start. More...
ossim_int32 getYStart () const
void setYStart (ossim_int32 ystart)
 Sets the y start. More...
ossimString getMapInfo () const
void setMapInfo (const ossimString &mapInfo)
 Sets the envi map info string. More...
void setMapInfo (const ossimKeywordlist &kwl, const char *prefix=0)
 Sets the envi map info string from a keyword list containing geometry information. More...
ossimString getWavelengthUnits () const
void setWavelengthUnits (const ossimString &wavelenghtUnits)
 Sets the envi wavelength units string. More...
void getBandNames (std::vector< ossimString > &bandNames) const
void setBandNames (const std::vector< ossimString > &bandNames)
 Sets the band name string vector. More...
void getWavelengths (std::vector< ossimString > &wavelengths) const
void setWavelengths (const std::vector< ossimString > &wavelengths)
 Sets the envi band name string. More...
bool loadState (const ossimKeywordlist &kwl, const char *prefix=0)
 Method to the load (recreate) the state of the object from a keyword list. More...
const ossimFilenamegetFile () const
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static bool isEnviHeader (const ossimFilename &file)
 Global method to test first line of file for "ENVI". More...
static bool isEnviHeader (std::istream &in)
 Global method to test first line of stream for "ENVI". More...
bool rangeCheckBands (const std::vector< ossim_uint32 > &bands) const
 Check band list to see if any are outside of range of bands. More...
bool readStream (std::istream &in)
 Parses stream. More...
Private Attributes
ossimFilename m_file
ossimKeywordlist m_keywords
Friends
OSSIM_DLL std::ostream & operator<< (std::ostream &out, const ossimEnviHeader &obj)
 friend operator<< More...
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 30 of file ossimEnviHeader.h.
◆ ossimEnviHeader()
ossimEnviHeader::ossimEnviHeader ( )
default construtor
Definition at line 66 of file ossimEnviHeader.cpp.
References m_keywords.
67  :
68  m_file(),
69  m_keywords()
70 {
71  // Start the byte order of with the machine byte order.
72  m_keywords[FILE_TYPE_KW] = "ENVI Standard";
74 }
OSSIM_DLL ossimByteOrder byteOrder()
Definition: ossimCommon.cpp:54
void setByteorder(ossimByteOrder byteOrder)
◆ ~ossimEnviHeader()
ossimEnviHeader::~ossimEnviHeader ( )
virtual
virtual destructor
Definition at line 76 of file ossimEnviHeader.cpp.
77 {
78 }
Member Function Documentation
◆ findCaseInsensitive()
bool ossimEnviHeader::findCaseInsensitive ( const ossimString key,
ossimString value
) const
Gets value for key.
Parameters
key
value
Returns
true if key is in map even if value is empty; false, if not.
◆ findSubStringCaseInsensitive()
bool ossimEnviHeader::findSubStringCaseInsensitive ( const ossimString key,
ossimString value
) const
Gets value for key.
Parameters
key
value
Returns
Definition at line 113 of file ossimEnviHeader.cpp.
References ossimKeywordlist::findValue(), and m_keywords.
115 {
117  value, KwlKeySubStringCaseInsensitive(key));
118 }
bool findValue(ossimString &value, const CompareType &compare) const
This is a generic find method that takes a comparator type and iterates through the map executing t...
◆ getBandNames()
void ossimEnviHeader::getBandNames ( std::vector< ossimString > &  bandNames) const
Parameters
bandNamesVector of strings to initialize with band names.
Definition at line 690 of file ossimEnviHeader.cpp.
References m_keywords, and ossimString::split().
691 {
692  bandNames.clear();
693  ossimString bandNamesString = m_keywords["band names"];
694  bandNamesString.split(bandNames, ",");
695 }
◆ getBands()
ossim_uint32 ossimEnviHeader::getBands ( ) const
Returns
The number of bands.
Definition at line 271 of file ossimEnviHeader.cpp.
References ossimKeywordlist::findKey(), m_keywords, ossimString::size(), and ossimString::toUInt32().
Referenced by ossimGeneralRasterInfo::initializeFromEnviHdr(), rangeCheckBands(), and ossimAlphaSensorSupportData::readHdrFile().
272 {
273  ossim_uint32 result = 0;
274  ossimString value = m_keywords.findKey( std::string("bands") );
275  if( value.size() )
276  {
277  result = value.toUInt32();
278  }
279  return result;
280 }
const std::string & findKey(const std::string &key) const
Find methods that take std::string(s).
ossim_uint32 toUInt32() const
std::string::size_type size() const
Definition: ossimString.h:405
unsigned int ossim_uint32
◆ getByteOrder()
ossimByteOrder ossimEnviHeader::getByteOrder ( ) const
Returns
If key "byte order" found returns the envi byte order; else, system byte order.
Note
(Same as the ossimByteOrder enumeration): 0 = LITTLE_ENDIAN, 1 = BIG_ENDIAN
Definition at line 510 of file ossimEnviHeader.cpp.
References ossim::byteOrder(), m_keywords, OSSIM_BIG_ENDIAN, OSSIM_LITTLE_ENDIAN, and ossimString::toInt32().
Referenced by ossimGeneralRasterInfo::initializeFromEnviHdr().
511 {
512  ossimByteOrder result = ossim::byteOrder(); // System byte order.
513  std::string value = m_keywords["byte order"];
514  if ( value.size() )
515  {
516  // 0 = LITTLE_ENDIAN
517  // 1 = BIG_ENDIAN
518  ossim_int32 order = ossimString(value).toInt32();
519  result = order ? OSSIM_BIG_ENDIAN : OSSIM_LITTLE_ENDIAN;
520  }
521  return result;
522 }
ossim_int32 toInt32() const
ossimByteOrder
int ossim_int32
◆ getDataType()
ossim_uint32 ossimEnviHeader::getDataType ( ) const
Returns
The envi data type..
Definition at line 366 of file ossimEnviHeader.cpp.
References m_keywords, and ossimString::toUInt32().
367 {
368  return ossimString(m_keywords["data type"]).toUInt32();
369 }
◆ getDefaultBands()
bool ossimEnviHeader::getDefaultBands ( std::vector< ossim_uint32 > &  bands) const
Parameters
bandsInitialized by this.
Returns
true on success, false if keyword not found. "bands" will be zeroed out on failure.
Definition at line 287 of file ossimEnviHeader.cpp.
References ossimKeywordlist::findKey(), m_keywords, ossimNotify(), ossimNotifyLevel_WARN, rangeCheckBands(), ossimString::size(), ossimString::split(), and true.
288 {
289  bands.clear();
290
291  // Note: We could do a "m_map.downcaseKeywords()". (drb)
292  ossimString value = m_keywords.findKey( std::string("default bands") );
293  if ( !value.size() )
294  {
295  value = m_keywords.findKey( std::string("Default bands") );
296  if ( !value.size() )
297  {
298  value = m_keywords.findKey( std::string("DEFAULT BANDS") );
299  }
300  }
301
302  if ( value.size() )
303  {
304  std::vector<ossimString> strLst;
305  value.split( strLst, ossimString(","));
306  if ( strLst.size() )
307  {
308  std::vector<ossimString>::const_iterator i = strLst.begin();
309  ossim_uint32 band = 0;
310  while ( i != strLst.end() )
311  {
312  band = (*i).toUInt32();
313  if ( band )
314  {
315  // Assuming "default bands" are one based. Totally a hunch... (drb)
316  --band;
317  bands.push_back(band);
318  }
319  else
320  {
322  << "ossimEnviHeader::getDefaultBands WARN!"
323  << "\nDetected zero based bands in \"default bands\" from header!"
324  << std::endl;
325  }
326
327  ++i;
328  }
329  }
330  }
331
332  if ( rangeCheckBands( bands ) == false )
333  {
334  bands.clear();
335  }
336
337  return (bands.size() ? true : false);
338 }
bool rangeCheckBands(const std::vector< ossim_uint32 > &bands) const
◆ getDescription()
ossimString ossimEnviHeader::getDescription ( ) const
Returns
The description of the file.
Definition at line 229 of file ossimEnviHeader.cpp.
References ossimKeywordlist::findKey(), and m_keywords.
230 {
231  return ossimString( m_keywords.findKey( std::string("description") ) );
232 }
◆ getFile()
const ossimFilename & ossimEnviHeader::getFile ( ) const
Returns
Path to envi header file.
Definition at line 928 of file ossimEnviHeader.cpp.
References m_file.
Referenced by ossimAlphaSensorSupportData::readHdrFile(), and ossimAlphaSensorSupportData::readSupportFiles().
929 {
930  return m_file;
931 }
◆ getFileType()
ossimString ossimEnviHeader::getFileType ( ) const
Returns
The file type
Definition at line 356 of file ossimEnviHeader.cpp.
357 {
358  return m_keywords[FILE_TYPE_KW];
359 }
◆ getHeaderOffset()
ossim_uint32 ossimEnviHeader::getHeaderOffset ( ) const
Returns
The number of header offset in bytes.
Definition at line 340 of file ossimEnviHeader.cpp.
References m_keywords, ossimString::size(), and ossimString::toUInt32().
341 {
342  ossim_uint32 result = 0;
343  ossimString value = m_keywords["header offset"];
344  if( value.size() )
345  {
346  result = value.toUInt32();
347  }
348  return result;
349 }
◆ getInterleaveType()
ossimString ossimEnviHeader::getInterleaveType ( ) const
Returns
The envi interleave type.
Definition at line 454 of file ossimEnviHeader.cpp.
Referenced by getOssimInterleaveType().
455 {
456  return m_keywords["interleave"];
457 }
◆ getLines()
ossim_uint32 ossimEnviHeader::getLines ( ) const
Returns
The number of lines.
Definition at line 255 of file ossimEnviHeader.cpp.
Referenced by ossimGeneralRasterInfo::initializeFromEnviHdr(), and ossimAlphaSensorSupportData::readHdrFile().
256 {
257  ossim_uint32 result = 0;
258  ossimString value = m_keywords.findKey( std::string("lines") );
259  if( value.size() )
260  {
261  result = value.toUInt32();
262  }
263  return result;
264 }
◆ getMap() [1/2]
const ossimKeywordlist & ossimEnviHeader::getMap ( ) const
Returns
Const reference to map.
Definition at line 88 of file ossimEnviHeader.cpp.
Referenced by ossimEnviInfo::print().
89 {
90  return m_keywords;
91 }
◆ getMap() [2/2]
Returns
Reference to map.
Definition at line 93 of file ossimEnviHeader.cpp.
94 {
95  return m_keywords;
96 }
◆ getMapInfo()
ossimString ossimEnviHeader::getMapInfo ( ) const
Returns
The envi map info string.
Definition at line 576 of file ossimEnviHeader.cpp.
577 {
578  return m_keywords["map info"];
579 }
◆ getOssimInterleaveType()
ossimInterleaveType ossimEnviHeader::getOssimInterleaveType ( ) const
Returns
The ossimInterleaveType from the envi interleave..
Definition at line 458 of file ossimEnviHeader.cpp.
References getInterleaveType(), OSSIM_BIL, OSSIM_BIP, OSSIM_BSQ, and OSSIM_INTERLEAVE_UNKNOWN.
459 {
460  ossimString interleave = getInterleaveType();
461  if (interleave == "bsq")
462  {
463  return OSSIM_BSQ;
464  }
465  else if (interleave == "bil")
466  {
467  return OSSIM_BIL;
468  }
469  else if (interleave == "bip")
470  {
471  return OSSIM_BIP;
472  }
473  else
474  {
476  }
477 }
ossimString getInterleaveType() const
◆ getOssimScalarType()
ossimScalarType ossimEnviHeader::getOssimScalarType ( ) const
Returns
The ossimScalarType from the envi data type..
Definition at line 371 of file ossimEnviHeader.cpp.
References m_keywords, OSSIM_CFLOAT32, OSSIM_CFLOAT64, OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_SCALAR_UNKNOWN, OSSIM_SINT16, OSSIM_SINT32, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, and ossimString::toUInt32().
372 {
373  ossim_uint32 dataTypeInt = ossimString(m_keywords["data type"]).toUInt32();
374
376
377  switch( dataTypeInt )
378  {
379  case 1:
380  result = OSSIM_UINT8;
381  break;
382  case 2:
383  result = OSSIM_SINT16;
384  break;
385  case 3:
386  result = OSSIM_SINT32;
387  break;
388  case 4:
389  result = OSSIM_FLOAT32;
390  break;
391  case 5:
392  result = OSSIM_FLOAT64;
393  break;
394  case 6:
395  result = OSSIM_CFLOAT32;
396  break;
397  case 9:
398  result = OSSIM_CFLOAT64;
399  break;
400  case 12:
401  result = OSSIM_UINT16;
402  break;
403  case 13:
404  result = OSSIM_UINT32;
405  break;
406  default:
407  break;
408  }
409
410  return result;
411 }
32 bit complex floating point
64 bit floating point
16 bit unsigned integer
16 bit signed integer
32 bit floating point
32 bit unsigned integer
32 bit signed integer
ossimScalarType
64 bit complex floating point
8 bit unsigned integer
◆ getRgbBandsFromWaveLength()
bool ossimEnviHeader::getRgbBandsFromWaveLength ( std::vector< ossim_uint32 > &  bands) const
Parameters
Returns
◆ getSamples()
ossim_uint32 ossimEnviHeader::getSamples ( ) const
Returns
The number of samples.
Definition at line 239 of file ossimEnviHeader.cpp.
240 {
241  ossim_uint32 result = 0;
242  ossimString value = m_keywords.findKey( std::string("samples") );
243  if( value.size() )
244  {
245  result = value.toUInt32();
246  }
247  return result;
248 }
◆ getSensorType()
ossimString ossimEnviHeader::getSensorType ( ) const
Returns
The sensor type..
Definition at line 500 of file ossimEnviHeader.cpp.
Referenced by ossimAlphaSensorSupportData::readHdrFile().
501 {
502  return m_keywords["sensor type"];
503 }
◆ getValue()
bool ossimEnviHeader::getValue ( const ossimString key,
ossimString value
) const
Gets value for key.
Parameters
keyTo search for.
valueInitialized by this.
Returns
true on success, false on error. This will return true if key is found, even if value is empty.
Definition at line 98 of file ossimEnviHeader.cpp.
References ossimKeywordlist::findKey(), ossimKeywordlist::hasKey(), m_keywords, ossimString::size(), and ossimString::string().
Referenced by ossimWavelength::initialize(), and ossimAlphaSensorSupportData::readHdrFile().
99 {
100  bool result = false;
101  value.string() = m_keywords.findKey( key.string());
102  if( value.size() )
103  {
104  result = true;
105  }
106  else
107  {
108  result = m_keywords.hasKey( key.string() );
109  }
110  return result;
111 }
bool hasKey(const std::string &key) const
Checks for key in map.
const std::string & string() const
Definition: ossimString.h:414
◆ getWavelengths()
void ossimEnviHeader::getWavelengths ( std::vector< ossimString > &  wavelengths) const
Parameters
wavelengthsVector of strings to initialize with wave lengths.
Definition at line 704 of file ossimEnviHeader.cpp.
706 {
707  waveLengths.clear();
708  ossimString bandNamesString = m_keywords[WAVELENGTH_KW];
709  bandNamesString.split(waveLengths, ",");
710 }
◆ getWavelengthUnits()
ossimString ossimEnviHeader::getWavelengthUnits ( ) const
Returns
The env wavelength units..
Definition at line 679 of file ossimEnviHeader.cpp.
680 {
681  return m_keywords["wavelength units"];
682 }
◆ getXStart()
ossim_int32 ossimEnviHeader::getXStart ( ) const
Returns
The x start.
Definition at line 536 of file ossimEnviHeader.cpp.
References ossimKeywordlist::findKey(), m_keywords, and ossimString::toInt32().
537 {
538  ossim_int32 result = 0;
539  std::string s = m_keywords.findKey( std::string("x start") );
540  if ( !s.size() )
541  {
542  s = m_keywords.findKey( std::string("sample start") );
543  }
544  if ( s.size() )
545  {
546  result = ossimString( s ).toInt32();
547  }
548  return result;
549 }
int ossim_int32
◆ getYStart()
ossim_int32 ossimEnviHeader::getYStart ( ) const
Returns
The x start.
Definition at line 556 of file ossimEnviHeader.cpp.
557 {
558  ossim_int32 result = 0;
559  std::string s = m_keywords.findKey( std::string("y start") );
560  if ( !s.size() )
561  {
562  s = m_keywords.findKey( std::string("line start") );
563  }
564  if ( s.size() )
565  {
566  result = ossimString( s ).toInt32();
567  }
568  return result;
569 }
int ossim_int32
◆ isEnviHeader() [1/2]
bool ossimEnviHeader::isEnviHeader ( const ossimFilename file)
static
Returns
Definition at line 900 of file ossimEnviHeader.cpp.
References ossimString::c_str().
Referenced by ossimEnviInfo::open(), and readStream().
901 {
902  bool result = false;
903  std::ifstream in;
904  in.open(file.c_str(), std::ios::in | std::ios::binary);
905  if ( in.is_open() )
906  {
907  result = isEnviHeader( in );
908  in.close();
909  }
910  return result;
911 }
std::basic_ifstream< char > ifstream
Class for char input file streams.
Definition: ossimIosFwd.h:44
static bool isEnviHeader(const ossimFilename &file)
const char * c_str() const
Definition: ossimString.h:396
◆ isEnviHeader() [2/2]
bool ossimEnviHeader::isEnviHeader ( std::istream &  in)
static
Returns
Definition at line 913 of file ossimEnviHeader.cpp.
References ossim::skipws().
914 {
915  bool result = false;
916  ossim::skipws(in);
917  char eh[5];
918  in.read(eh, 4);
919  eh[4] = '\0';
920  std::string s(eh);
921  if ( s == "ENVI" )
922  {
923  result = true;
924  }
925  return result;
926 }
OSSIM_DLL std::istream & skipws(std::istream &in)
Definition: ossimCommon.cpp:38
◆ loadState()
bool ossimEnviHeader::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
Parameters
kwlKeyword list to initialize from.
prefixUsually something like: "object1."
Returns
This method will alway return true as it is intended to be used in conjuction with the set methods.
Keywords picked up by loadState:
description: My_file
number_samples: 1024
number_lines: 512
number_bands: 3
header_offset: 0
file_type: ENVI Standard
data_type: 1
interleave_type: bil
sensor_type: Unknown
(little_endian or big_endian) byte_order: little_endian
map_info: Unknown
wavelength_units:
band_name0: Red band band_name1: Green band band_name2: Blue band
wavelength0: 620.25 wavelength1: 514.5 wavelength2: 470.0
Definition at line 720 of file ossimEnviHeader.cpp.
References ossimKeywordNames::DESCRIPTION_KW, ossimKeywordNames::FILENAME_KW, ossimKeywordlist::findKey(), m_file, m_keywords, ossimKeywordNames::NUMBER_BANDS_KW, ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, reset(), setDescription(), and ossimString::string().
Referenced by ossimEnviHeaderFileWriter::loadState().
722 {
723  std::string lookup;
724  std::string pfx = (prefix ? prefix: "" );
725  ossimString s;
726
727  reset();
728
729  lookup = kwl.findKey(pfx, std::string(ossimKeywordNames::FILENAME_KW));
730  if (lookup.size())
731  {
732  m_file.string() = lookup;
733  }
734
735  lookup = kwl.findKey(pfx, std::string(ossimKeywordNames::DESCRIPTION_KW));
736  if (lookup.size())
737  {
738  setDescription(lookup);
739  }
740
741  lookup = kwl.findKey(pfx, std::string(ossimKeywordNames::NUMBER_SAMPLES_KW));
742  if (lookup.size())
743  {
744  m_keywords["samples"] = lookup;
745  }
746
747  lookup = kwl.findKey(pfx, std::string(ossimKeywordNames::NUMBER_LINES_KW));
748  if (lookup.size())
749  {
750  m_keywords["lines"] = lookup;
751  }
752
753  lookup = kwl.findKey(pfx, std::string(ossimKeywordNames::NUMBER_BANDS_KW));
754  if (lookup.size())
755  {
756  m_keywords["bands"] = lookup;
757  }
758
759  lookup = kwl.findKey(pfx, std::string(HEADER_OFFSET_KW));
760  if (lookup.size())
761  {
762  m_keywords["header offset"] = lookup;
763  }
764
765  lookup = kwl.findKey(pfx, std::string(FILE_TYPE_KW));
766  if (lookup.size())
767  {
768  m_keywords["file_type"] = lookup;
769  }
770
771  lookup = kwl.findKey(pfx, DATA_TYPE_KW);
772  if (lookup.size())
773  {
774  m_keywords["data type"] = lookup;
775  }
776
777  lookup = kwl.findKey(pfx, std::string(ossimKeywordNames::INTERLEAVE_TYPE_KW));
778  if (lookup.size())
779  {
780  m_keywords["interleave"] = lookup;
781  }
782
783  lookup = kwl.findKey(pfx, std::string(SENSOR_TYPE_KW));
784  if (lookup.size())
785  {
786  m_keywords["sensor type"] = lookup;
787  }
788
789  lookup = kwl.findKey(pfx, std::string(ossimKeywordNames::BYTE_ORDER_KW));
790  if (lookup.size())
791  {
792  s = lookup;
793  s.downcase();
794  if (s == "little_endian")
795  {
796  m_keywords["byte order"] = "0";
797  }
798  else if (s == "big_endian")
799  {
800  m_keywords["byte order"] = "1";
801  }
802  else
803  {
804  m_keywords["byte order"] = lookup;
805  }
806  }
807
808  lookup = kwl.findKey(pfx, std::string(X_START_KW));
809  if (lookup.size())
810  {
811  m_keywords["x start"] = lookup;
812  }
813  lookup = kwl.findKey(pfx, std::string(Y_START_KW));
814  if (lookup.size())
815  {
816  m_keywords["y start"] = lookup;
817  }
818
819  lookup = kwl.findKey(pfx, std::string(MAP_INFO_KW));
820  if (lookup.size())
821  {
822  m_keywords["map info"] = lookup;
823  }
824
825  lookup = kwl.findKey(pfx, std::string(WAVELENGTH_UNITS_KW));
826  if (lookup.size())
827  {
828  m_keywords["wavelength units"] = lookup;
829  }
830
831  ossim_uint32 n;
832  ossim_uint32 count;
833  const ossim_uint32 MAX_TRIES = 1024; // Avoid infinate loop.
834
835  // Get the band names.
836  n = kwl.numberOf(prefix, BAND_NAME_KW);
837  if (n)
838  {
839  ossimString value = "";
840  count = 0;
841  while ( (count < n) || (count > MAX_TRIES) )
842  {
843  s = BAND_NAME_KW;
844  s += ossimString::toString(count);
845  lookup = kwl.findKey(pfx, s.string());
846  if (lookup.size())
847  {
848  if(!value.empty())
849  {
850  value += ossimString(lookup);
851  }
852  else
853  {
854  value += (", " + ossimString(lookup));
855
856  }
857
858  }
859  ++count;
860  }
861  m_keywords["band names"] = value.c_str();
862  }
863
864  // Get the band names.
865  n = kwl.numberOf(prefix, WAVELENGTH_KW);
866  if (n)
867  {
868  ossimString value;
869  count = 0;
870  while ( (count < n) || (count > MAX_TRIES) )
871  {
872  s = WAVELENGTH_KW;
873  s += ossimString::toString(count);
874  lookup = kwl.findKey(pfx, s.string());
875  if (lookup.size())
876  {
877  if(!value.empty())
878  {
879  value += ossimString(lookup);
880  }
881  else
882  {
883  value += (", " + ossimString(lookup));
884  }
885  }
886  ++count;
887  }
888  m_keywords["wavelength"] = value.c_str();
889  }
890  if (traceDebug())
891  {
893  << "ossimEnviHeader::loadState DEUG\n";
895  }
896
897  return true;
898 }
static const char * BYTE_ORDER_KW
std::ostream & print(std::ostream &out) const
ossim_uint32 numberOf(const char *str) const
void setDescription(const ossimString &description)
Numeric to string methods.
static const char * NUMBER_LINES_KW
virtual void reset()
os2<< "> n<< " > nendobj n
static const char * NUMBER_BANDS_KW
static const char * INTERLEAVE_TYPE_KW
static const char * DESCRIPTION_KW
bool empty() const
Definition: ossimString.h:411
static const char * FILENAME_KW
static const char * NUMBER_SAMPLES_KW
◆ open()
bool ossimEnviHeader::open ( const ossimFilename file)
Returns
Definition at line 120 of file ossimEnviHeader.cpp.
References ossimString::c_str(), m_file, readStream(), and reset().
Referenced by ossimGeneralRasterInfo::initializeFromEnviHdr(), ossimEnviInfo::print(), ossimAlphaSensorSupportData::readHdrFile(), and ossimAlphaSensorSupportData::readSupportFiles().
121 {
122  bool result = false;
123
124  reset(); // Clear the map, file name.
125
126  std::ifstream in;
127  in.open(file.c_str(), std::ios::in | std::ios::binary);
128  if( in.is_open() )
129  {
130  result = readStream( in );
131  if ( result )
132  {
133  m_file = file;
134  }
135  }
136
137  return result;
138 }
bool readStream(std::istream &in)
Parses stream.
◆ print()
std::ostream & ossimEnviHeader::print ( std::ostream &  out) const
Parameters
outStream to write to.
Returns
Reference to the stream passed.
Definition at line 218 of file ossimEnviHeader.cpp.
Referenced by operator<<(), and writeFile().
219 {
220  out << "ENVI" << "\n" << m_keywords << std::endl;
221  return out;
222 }
◆ rangeCheckBands()
bool ossimEnviHeader::rangeCheckBands ( const std::vector< ossim_uint32 > &  bands) const
private
Bands should be zero base.
Returns
true if all bands are less than number of bands; false, if outside range or if "bands" key is not found.
Definition at line 933 of file ossimEnviHeader.cpp.
References getBands().
Referenced by getDefaultBands().
934 {
935  bool result = false;
936  const ossim_uint32 INPUT_BANDS = getBands();
937  if ( INPUT_BANDS )
938  {
939  result = true;
940  std::vector<ossim_uint32>::const_iterator i = bands.begin();
941  while ( i != bands.end() )
942  {
943  if ( (*i) >= INPUT_BANDS )
944  {
945  result = false;
946  break;
947  }
948  ++i;
949  }
950  }
951  return result;
952 }
ossim_uint32 getBands() const
◆ readStream()
bool ossimEnviHeader::readStream ( std::istream &  in)
private
Parses stream.
Returns
Definition at line 140 of file ossimEnviHeader.cpp.
References ossimKeywordlist::add(), ossimKeywordlist::clear(), ossimKeywordlist::findKey(), isEnviHeader(), m_keywords, reset(), ossim::skipws(), and ossimString::trim().
Referenced by open().
141 {
142  reset();
143  bool result = isEnviHeader( in );
144  if ( result )
145  {
146  m_keywords.clear();
147
148  while(!in.eof()&&in.good())
149  {
150  // read name
151  ossimString name = "";
152  ossimString value = "";
153  ossim::skipws(in);
154  int c = static_cast<char>(in.get());
155  while((c != '=')&&(in.good())&&!in.eof())
156  {
157  name +=static_cast<char>(c);
158  c = in.get();
159  }
160  ossim::skipws(in);
161  c = in.get();
162
163  if(in.good()&&!in.eof())
164  {
165  if(c == '{') // continue til '}'
166  {
167  c = in.get();
168  while((c != '}')&&(in.good())&&!in.eof())
169  {
170  value +=static_cast<char>(c);
171  c = in.get();
172  }
173  }
174  else
175  {
176  while(((c != '\n')&&(c!='\r'))&&(in.good())&&!in.eof())
177  {
178  value +=static_cast<char>(c);
179  c = (in.get());
180  }
181
182  }
183  m_keywords.add(name.trim(), value);
184  }
185  }
186
187  // Test for minimum set of keywords needed.
188  if ( m_keywords.findKey( std::string("samples") ).empty() ||
189  m_keywords.findKey( std::string("lines") ).empty() ||
190  m_keywords.findKey( std::string("bands") ).empty())
191  {
192  result = false;
193  }
194  }
195
196  return result;
197 }
ossimString trim(const ossimString &valueToTrim=ossimString(" \\)) const
this will strip lead and trailing character passed in.
◆ reset()
void ossimEnviHeader::reset ( void  )
virtual
Definition at line 80 of file ossimEnviHeader.cpp.
References ossimKeywordlist::clear(), m_file, m_keywords, and ossimString::string().
Referenced by loadState(), open(), and readStream().
81 {
82  m_file.string().clear();
83  m_keywords.clear();
84  m_keywords[FILE_TYPE_KW] = "ENVI Standard";
86 }
◆ setBandNames()
void ossimEnviHeader::setBandNames ( const std::vector< ossimString > &  bandNames)
Parameters
bandNamesVector of band name strings.
Definition at line 697 of file ossimEnviHeader.cpp.
References ossimString::c_str(), ossimString::join(), and m_keywords.
698 {
699  ossimString value;
700  value.join(bandNames, ",");
701  m_keywords["band names"] = value.c_str();
702 }
const ossimString & join(const std::vector< ossimString > &stringList, const ossimString &separator)
◆ setBands()
void ossimEnviHeader::setBands ( ossim_uint32  bands)
Parameters
bandsThe number of bands.
Definition at line 282 of file ossimEnviHeader.cpp.
References ossimString::c_str(), m_keywords, and ossimString::toString().
Referenced by ossimEnviHeaderFileWriter::writeFile().
283 {
284  m_keywords["bands"] = ossimString::toString(bands).c_str();
285 }
◆ setByteorder()
void ossimEnviHeader::setByteorder ( ossimByteOrder  byteOrder)
Parameters
byteorderThe ossimByteOrder of the image.
Definition at line 524 of file ossimEnviHeader.cpp.
References ossim::byteOrder(), m_keywords, and OSSIM_LITTLE_ENDIAN.
525 {
527  {
528  m_keywords["byte order"] = "0";
529  }
530  else
531  {
532  m_keywords["byte order"] = "1";
533  }
534 }
◆ setDataType()
void ossimEnviHeader::setDataType ( ossimScalarType  scalar)
Parameters
scalarThe ossimScalarType of the image.
Definition at line 413 of file ossimEnviHeader.cpp.
References ossimString::c_str(), ossimString::empty(), m_keywords, OSSIM_CFLOAT32, OSSIM_CFLOAT64, OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_SINT16, OSSIM_SINT32, OSSIM_UINT16, OSSIM_UINT32, and OSSIM_UINT8.
414 {
415  ossimString dataTypeString = "";
416  switch( scalar )
417  {
418  case OSSIM_UINT8:
419  dataTypeString = "1";
420  break;
421  case OSSIM_SINT16:
422  dataTypeString = "2";
423  break;
424  case OSSIM_SINT32:
425  dataTypeString = "3";
426  break;
427  case OSSIM_FLOAT32:
428  dataTypeString = "4";
429  break;
430  case OSSIM_FLOAT64:
431  dataTypeString = "5";
432  break;
433  case OSSIM_CFLOAT32:
434  dataTypeString = "6";
435  break;
436  case OSSIM_CFLOAT64:
437  dataTypeString = "9";
438  break;
439  case OSSIM_UINT16:
440  dataTypeString = "12";
441  break;
442  case OSSIM_UINT32:
443  dataTypeString = "13";
444  break;
445  default:
446  break;
447  }
448
449  if(!dataTypeString.empty())
450  {
451  m_keywords["data type"] = dataTypeString.c_str();
452  }
453 }
bool empty() const
◆ setDescription()
void ossimEnviHeader::setDescription ( const ossimString description)
Parameters
descriptionThe description of the file.
Definition at line 234 of file ossimEnviHeader.cpp.
References ossimString::c_str(), and m_keywords.
Referenced by loadState().
235 {
236  m_keywords["description"] = description.c_str();
237 }
◆ setFileType()
void ossimEnviHeader::setFileType ( const ossimString fileType)
Sets the file type.
Parameters
fileTypeThe sensor type as a string.
Definition at line 361 of file ossimEnviHeader.cpp.
362 {
363  m_keywords[FILE_TYPE_KW] = fileType.c_str();
364 }
◆ setHeaderOffset()
void ossimEnviHeader::setHeaderOffset ( ossim_uint32  headerOffset)
Parameters
headerOffsetThe number of header offset in bytes.
Definition at line 351 of file ossimEnviHeader.cpp.
352 {
353  m_keywords["header offset"] = ossimString::toString(headerOffset).c_str();
354 }
◆ setInterleaveType()
void ossimEnviHeader::setInterleaveType ( ossimInterleaveType  interleave)
Parameters
interleaveThe ossimInterleaveType of the image.
Definition at line 479 of file ossimEnviHeader.cpp.
References m_keywords, OSSIM_BIL, OSSIM_BIP, and OSSIM_BSQ.
480 {
481  std::string interleaveString = "";
482  switch (interleave)
483  {
484  case OSSIM_BIL:
485  interleaveString = "bil";
486  break;
487  case OSSIM_BSQ:
488  interleaveString = "bsq";
489  break;
490  case OSSIM_BIP:
491  interleaveString = "bip";
492  break;
493  default:
494  interleaveString = "Unknown";
495  break;
496  }
497  m_keywords["interleave"] = interleaveString;
498 }
◆ setLines()
void ossimEnviHeader::setLines ( ossim_uint32  lines)
Parameters
linesThe number of lines.
Definition at line 266 of file ossimEnviHeader.cpp.
267 {
268  m_keywords["lines"] = ossimString::toString(lines).c_str();
269 }
◆ setMapInfo() [1/2]
void ossimEnviHeader::setMapInfo ( const ossimString mapInfo)
Parameters
mapInfoenvi map info string.
Definition at line 581 of file ossimEnviHeader.cpp.
582 {
583  m_keywords["map info"] = mapInfo.c_str();
584 }
◆ setMapInfo() [2/2]
void ossimEnviHeader::setMapInfo ( const ossimKeywordlist kwl,
Parameters
kwlKeyword list containing geometry information.
Definition at line 586 of file ossimEnviHeader.cpp.
588 {
589  if (traceDebug())
590  {
592  << "ossimEnviHeader::setMapInfo DEBUG:"
593  << "\nkwl:\n"
594  << kwl
595  << std::endl;
596  }
597  ossimString mapInfoString;
598  const char* lookup;
599
600  // Get the projection type.
601  ossimString projection;
602  lookup = kwl.find(prefix, ossimKeywordNames::TYPE_KW);
603  if (lookup)
604  {
605  projection = lookup;
606  }
607  else
608  {
610  << "ossimEnviHeader::setMapInfo WARNING:"
611  << "\nNo projection type found!\nReturning..."
612  << std::endl;
613
614  return; // Have to have the projection type!
615  }
616
617  // Get the datum.
618  ossimString datum = "WGS-84";
619  lookup = kwl.find(prefix, ossimKeywordNames::DATUM_KW);
620  if (lookup)
621  {
622  ossimString os = lookup;
623  if (os == "WGE")
624  {
625  datum = "WGS-84";
626  }
627  else
628  {
630  << "ossimEnviHeader::setMapInfo WARNING:"
631  << "\nUnhandled ossim -> envi datum: " << datum
632  << "\nAssuming WGS-84!"
633  << std::endl;
634  }
635  }
636
637  if ( (projection == "ossimEquDistCylProjection") ||
638  (projection == "ossimLlxyProjection") )
639  {
640  const char* tieLat = NULL;
641  const char* tieLon = NULL;
642  const char* degLat = NULL;
643  const char* degLon = NULL;
644  tieLat = kwl.find(prefix, ossimKeywordNames::TIE_POINT_LAT_KW);
645  tieLon = kwl.find(prefix, ossimKeywordNames::TIE_POINT_LON_KW);
646  degLat = kwl.find(prefix,
648  degLon = kwl.find(prefix,
650
651  if (!tieLat || !tieLon || !degLat || !degLon)
652  {
653  return;
654  }
655
656  mapInfoString = "{Geographic Lat/Lon, 1.0000, 1.0000, ";
657  mapInfoString += tieLon;
658  mapInfoString += ", ";
659  mapInfoString += tieLat;
660  mapInfoString += ", ";
661  mapInfoString += degLon;
662  mapInfoString += ", ";
663  mapInfoString += degLat;
664  mapInfoString += ", ";
665  mapInfoString += datum;
666  mapInfoString += ", units=degrees}";
667  }
668
669  m_keywords["map info"] = mapInfoString.c_str();
670  if (traceDebug())
671  {
673  << "ossimEnviHeader::setMapInfo DEBUG:"
674  << "\ntheMapInfo: " << mapInfoString
675  << std::endl;
676  }
677 }
static const char * DECIMAL_DEGREES_PER_PIXEL_LAT
static const char * DATUM_KW
static const char * TIE_POINT_LON_KW
static const char * TYPE_KW
static const char * DECIMAL_DEGREES_PER_PIXEL_LON
static const char * TIE_POINT_LAT_KW
◆ setSamples()
void ossimEnviHeader::setSamples ( ossim_uint32  samples)
Parameters
samplesThe number of samples.
Definition at line 250 of file ossimEnviHeader.cpp.
251 {
252  m_keywords[ std::string("samples") ] = ossimString::toString(samples).c_str();
253 }
◆ setSensorType()
void ossimEnviHeader::setSensorType ( const ossimString sensorType)
Parameters
sensorTypeThe sensor type as a string.
Definition at line 505 of file ossimEnviHeader.cpp.
506 {
507  m_keywords["sensor type"] = sensorType.c_str();
508 }
◆ setWavelengths()
void ossimEnviHeader::setWavelengths ( const std::vector< ossimString > &  wavelengths)
Parameters
wavelengthsVector of band name strings.
Definition at line 712 of file ossimEnviHeader.cpp.
References ossimString::join(), and m_keywords.
714 {
715  ossimString value;
716  value.join(wavelengths, ",");
717  m_keywords[WAVELENGTH_KW] = value.c_str();
718 }
◆ setWavelengthUnits()
void ossimEnviHeader::setWavelengthUnits ( const ossimString wavelenghtUnits)
Parameters
wavelengthUnitsenvi wavelength units string.
Definition at line 684 of file ossimEnviHeader.cpp.
685 {
686
687  m_keywords["wavelength units"] = waveLengthUnits.c_str();
688 }
◆ setXStart()
void ossimEnviHeader::setXStart ( ossim_int32  xstart)
Sets the x start.
Parameters
xStart
Definition at line 551 of file ossimEnviHeader.cpp.
552 {
553  m_keywords["x start"] = ossimString::toString(xstart).c_str();
554 }
◆ setYStart()
void ossimEnviHeader::setYStart ( ossim_int32  ystart)
Sets the y start.
Parameters
ystart
Definition at line 571 of file ossimEnviHeader.cpp.
572 {
573  m_keywords["y start"] = ossimString::toString(ystart).c_str();
574 }
◆ writeFile()
bool ossimEnviHeader::writeFile ( const ossimFilename file)
Parameters
fileFile to write to.
Returns
Definition at line 199 of file ossimEnviHeader.cpp.
References ossimString::c_str(), ossimKeywordlist::findKey(), m_keywords, and print().
200 {
201  if (m_keywords.findKey( std::string("description") ).empty())
202  {
203  m_keywords["description"] = file.c_str();
204  }
205
206  std::ofstream out(file.c_str(), std::ios_base::out);
207
208  if (!out)
209  {
210  return false;
211  }
212
213  print(out);
214  out.close();
215  return true;
216 }
std::basic_ofstream< char > ofstream
Class for char output file streams.
Definition: ossimIosFwd.h:47
◆ operator<<
OSSIM_DLL std::ostream& operator<< ( std::ostream &  out,
const ossimEnviHeader obj
friend
friend operator<<
Definition at line 224 of file ossimEnviHeader.cpp.
225 {
226  return obj.print( out );
227 }
Member Data Documentation
◆ m_file
ossimFilename ossimEnviHeader::m_file
private
Definition at line 411 of file ossimEnviHeader.h.
Referenced by getFile(), loadState(), open(), and reset().
◆ m_keywords
ossimKeywordlist ossimEnviHeader::m_keywords
private
