Public Types | Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ossimGeoAnnotationPolyObject Class Reference
#include <ossimGeoAnnotationPolyObject.h>
Inheritance diagram for ossimGeoAnnotationPolyObject:
ossimGeoAnnotationObject ossimAnnotationObject ossimObject ossimReferenced
Public Types
enum  ossimPolyType { OSSIM_POLY_EXTERIOR_RING = 0, OSSIM_POLY_INTERIOR_RING = 1 }
 ossimGeoAnnotationPolyObject (bool enableFill=false, ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1)
 ossimGeoAnnotationPolyObject (const std::vector< ossimGpt > &groundPts, bool enableFill=false, ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1)
 ossimGeoAnnotationPolyObject (const ossimGeoAnnotationPolyObject &rhs)
virtual void applyScale (double x, double y)
virtual void transform (ossimImageGeometry *projection)
 Generic print method. More...
virtual void draw (ossimRgbImage &anImage) const
virtual ossimAnnotationObjectgetNewClippedObject (const ossimDrect &rect) const
virtual bool intersects (const ossimDrect &rect) const
virtual void getBoundingRect (ossimDrect &rect) const
virtual void computeBoundingRect ()
virtual const std::vector< ossimGpt > & getPolygon () const
virtual void setPolygon (const std::vector< ossimGpt > &poly)
virtual void setFillFlag (bool flag)
virtual void setColor (ossim_uint8 r, ossim_uint8 g, ossim_uint8 b)
virtual void setThickness (ossim_uint8 thickness)
 Saves the current state of this object. More...
virtual std::vector< ossimGptgetPoints ()
virtual ossimPolyType getPolyType ()
virtual void setPolyType (ossimPolyType polyType)
- Public Member Functions inherited from ossimGeoAnnotationObject
 ossimGeoAnnotationObject (unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1)
 ossimGeoAnnotationObject (const ossimGeoAnnotationObject &rhs)
- Public Member Functions inherited from ossimAnnotationObject
virtual ~ossimAnnotationObject ()
 ossimAnnotationObject (ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1)
virtual void applyScale (const ossimDpt &scale)
virtual ossimDrect getBoundingRect () const
void getColor (ossim_uint8 &r, ossim_uint8 &g, ossim_uint8 &b) const
ossim_uint8 getThickness () const
virtual bool isPointWithin (const ossimDpt &imagePoint) const
virtual ossimString getName () const
virtual void setName (const ossimString &name)
ossim_uint32 getId () const
virtual ossim_uint32 setId ()
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
virtual ~ossimGeoAnnotationPolyObject ()
- Protected Member Functions inherited from ossimGeoAnnotationObject
virtual ~ossimGeoAnnotationObject ()
virtual ~ossimReferenced ()
std::vector< ossimGptthePolygon
ossimRefPtr< ossimAnnotationPolyObjecttheProjectedPolyObject
ossimPolyType m_PolyType
- Protected Attributes inherited from ossimAnnotationObject
ossim_uint8 theRed
ossim_uint8 theGreen
ossim_uint8 theBlue
ossim_uint8 theThickness
ossimString theName
ossim_uint32 theId
Additional Inherited Members
- Static Public Member Functions inherited from ossimAnnotationObject
static ossim_uint32 getNextId ()
static void restIdCounter ()
- Static Protected Attributes inherited from ossimAnnotationObject
static ossim_uint32 theIdCounter = 0
Detailed Description
Definition at line 18 of file ossimGeoAnnotationPolyObject.h.
◆ ossimPolyType
◆ ossimGeoAnnotationPolyObject() [1/3]
ossimGeoAnnotationPolyObject::ossimGeoAnnotationPolyObject ( bool  enableFill = false,
ossim_uint8  r = 255,
ossim_uint8  g = 255,
ossim_uint8  b = 255,
ossim_uint8  thickness = 1
Referenced by dup().
◆ ossimGeoAnnotationPolyObject() [2/3]
ossimGeoAnnotationPolyObject::ossimGeoAnnotationPolyObject ( const std::vector< ossimGpt > &  groundPts,
Definition at line 43 of file ossimGeoAnnotationPolyObject.cpp.
References thePolygon, and theProjectedPolyObject.
50  :ossimGeoAnnotationObject(r, g, b, thickness),
51  thePolygon(),
54 {
55
56  thePolygon = groundPts;
57
58  // we will initialize the projected polygon's size
59  // so we don't have to reset it every time we do a
60  // projection
61  //
62  std::vector<ossimDpt> projectedPoints(thePolygon.size());
63
65  enableFill,
66  r,
67  g,
68  b,
69  thickness);
70 }
ossimRefPtr< ossimAnnotationPolyObject > theProjectedPolyObject
ossimGeoAnnotationObject(unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1)
◆ ossimGeoAnnotationPolyObject() [3/3]
ossimGeoAnnotationPolyObject::ossimGeoAnnotationPolyObject ( const ossimGeoAnnotationPolyObject rhs)
Definition at line 72 of file ossimGeoAnnotationPolyObject.cpp.
78 {
79 }
bool valid() const
Definition: ossimRefPtr.h:75
◆ ~ossimGeoAnnotationPolyObject()
ossimGeoAnnotationPolyObject::~ossimGeoAnnotationPolyObject ( )
protectedvirtual
Definition at line 81 of file ossimGeoAnnotationPolyObject.cpp.
References theProjectedPolyObject.
82 {
84 }
Member Function Documentation
◆ applyScale()
void ossimGeoAnnotationPolyObject::applyScale ( double  x,
double  y
virtual
Implements ossimAnnotationObject.
Definition at line 91 of file ossimGeoAnnotationPolyObject.cpp.
References ossimAnnotationPolyObject::applyScale(), thePolygon, theProjectedPolyObject, ossimRefPtr< T >::valid(), x, and y.
93 {
94  for(int i = 0; i < (int)thePolygon.size(); ++i)
95  {
96  thePolygon[i].lond(thePolygon[i].lond()*x);
97  thePolygon[i].latd(thePolygon[i].latd()*y);
98  }
100  {
102  }
103
104 }
ossim_uint32 x
ossim_uint32 y
bool valid() const
virtual void applyScale(double x, double y)
◆ computeBoundingRect()
void ossimGeoAnnotationPolyObject::computeBoundingRect ( )
virtual
◆ draw()
void ossimGeoAnnotationPolyObject::draw ( ossimRgbImage anImage) const
virtual
Definition at line 142 of file ossimGeoAnnotationPolyObject.cpp.
References ossimAnnotationPolyObject::draw(), theProjectedPolyObject, and ossimRefPtr< T >::valid().
Referenced by ossimGdalOgrVectorAnnotation::drawAnnotations().
143 {
145  {
146  theProjectedPolyObject->draw(anImage);
147  }
148 }
virtual void draw(ossimRgbImage &anImage) const
bool valid() const
◆ dup()
ossimObject * ossimGeoAnnotationPolyObject::dup ( ) const
virtual
Definition at line 86 of file ossimGeoAnnotationPolyObject.cpp.
References ossimGeoAnnotationPolyObject().
87 {
88  return new ossimGeoAnnotationPolyObject(*this);
89 }
ossimGeoAnnotationPolyObject(bool enableFill=false, ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1)
◆ getBoundingRect()
void ossimGeoAnnotationPolyObject::getBoundingRect ( ossimDrect rect) const
virtual
Definition at line 171 of file ossimGeoAnnotationPolyObject.cpp.
References ossimAnnotationPolyObject::getBoundingRect(), ossimDrect::makeNan(), theProjectedPolyObject, and ossimRefPtr< T >::valid().
172 {
173  rect.makeNan();
175  {
177  }
178 }
void makeNan()
Definition: ossimDrect.h:388
virtual void getBoundingRect(ossimDrect &rect) const
bool valid() const
◆ getNewClippedObject()
ossimAnnotationObject * ossimGeoAnnotationPolyObject::getNewClippedObject ( const ossimDrect rect) const
virtual
Will allocate a new object that is clipped to the passed. in rect. Look at derived classes to see if the object is actually clipped or not. A new object is returned if it clips to the rect else NULL should be returned it doesn't clip.
Definition at line 150 of file ossimGeoAnnotationPolyObject.cpp.
References ossimAnnotationPolyObject::getNewClippedObject(), theProjectedPolyObject, and ossimRefPtr< T >::valid().
152 {
154  {
156  }
157
158  return (ossimAnnotationObject*)0;
159 }
bool valid() const
virtual ossimAnnotationObject * getNewClippedObject(const ossimDrect &rect) const
◆ getPoints()
virtual std::vector<ossimGpt> ossimGeoAnnotationPolyObject::getPoints ( )
inlinevirtual
Definition at line 86 of file ossimGeoAnnotationPolyObject.h.
Referenced by ossimTilingPoly::parseShpFile().
86 { return thePolygon; }
◆ getPolygon()
const std::vector< ossimGpt > & ossimGeoAnnotationPolyObject::getPolygon ( ) const
virtual
Definition at line 188 of file ossimGeoAnnotationPolyObject.cpp.
References thePolygon.
189 {
190  return thePolygon;
191 }
◆ getPolyType()
virtual ossimPolyType ossimGeoAnnotationPolyObject::getPolyType ( )
inlinevirtual
Definition at line 88 of file ossimGeoAnnotationPolyObject.h.
◆ intersects()
bool ossimGeoAnnotationPolyObject::intersects ( const ossimDrect rect) const
virtual
Definition at line 161 of file ossimGeoAnnotationPolyObject.cpp.
References ossimAnnotationPolyObject::intersects(), theProjectedPolyObject, and ossimRefPtr< T >::valid().
162 {
164  {
165  return theProjectedPolyObject->intersects(rect);
166  }
167
168  return false;
169 }
bool valid() const
virtual bool intersects(const ossimDrect &rect) const
◆ loadState()
bool ossimGeoAnnotationPolyObject::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Reimplemented from ossimGeoAnnotationObject.
Definition at line 251 of file ossimGeoAnnotationPolyObject.cpp.
References ossimString::c_str(), ossimKeywordlist::find(), ossimKeywordlist::getNumberOfSubstringKeys(), ossimGeoAnnotationObject::loadState(), ossimAnnotationObject::setColor(), ossimAnnotationPolyObject::setPolygon(), ossimAnnotationObject::setThickness(), status, ossimAnnotationObject::theBlue, ossimAnnotationObject::theGreen, thePolygon, theProjectedPolyObject, ossimAnnotationObject::theRed, ossimAnnotationObject::theThickness, and ossimString::toString().
253 {
255  {
256  return false;
257  }
258
259  //---
260  // Base class state must be called first to pick up colors...
261  //---
262  bool status = ossimGeoAnnotationObject::loadState(kwl, prefix);
263
264  ossim_uint32 index = 0;
265  ossimString copyPrefix = prefix;
266  ossim_uint32 count = kwl.getNumberOfSubstringKeys(copyPrefix+"v[0-9]*");
267
268  ossim_uint32 numberOfMatches = 0;
269  const ossim_uint32 MAX_INDEX = count + 100;
270
271  while(numberOfMatches < count)
272  {
273  ossimString key = "v";
274  key += ossimString::toString(index);
275
276  const char* lookup = kwl.find(prefix, key.c_str());
277  if (lookup)
278  {
279  ++numberOfMatches;
280  ossimGpt gpt;
281
282  std::istringstream is(lookup);
283  is >> gpt;
284  thePolygon.push_back(gpt);
285  }
286
287  ++index;
288
289  if (index > MAX_INDEX) // Avoid infinite loop...
290  {
291  break;
292  }
293  }
294
295  // Set up the annotator.
298
299  std::vector<ossimDpt> projectedPoints(thePolygon.size());
300  theProjectedPolyObject->setPolygon(projectedPoints);
301
302  if (traceDebug())
303  {
305  << "ossimGeoAnnotationPolyObject::loadState DEBUG:" << std::endl;
306  for (ossim_uint32 i=0; i<thePolygon.size(); ++i)
307  {
309  << "thePolygon[" << i << "]: " << thePolygon[i] << std::endl;
310  }
311  }
312
313  return status;
314 }
ossim_uint32 getNumberOfSubstringKeys(const ossimString &regularExpression) const
virtual void setThickness(ossim_uint8 thickness)
Numeric to string methods.
unsigned int ossim_uint32
virtual void setColor(ossim_uint8 r, ossim_uint8 g, ossim_uint8 b)
return status
const char * c_str() const
Definition: ossimString.h:396
std::basic_istringstream< char > istringstream
Class for char input memory streams.
Definition: ossimIosFwd.h:32
virtual void setPolygon(const vector< ossimDpt > &imagePoints)
◆ print()
std::ostream & ossimGeoAnnotationPolyObject::print ( std::ostream &  out) const
virtual
Derived classes should re-implement as they see fit.
Returns
std::ostream&
Reimplemented from ossimAnnotationObject.
Definition at line 126 of file ossimGeoAnnotationPolyObject.cpp.
References ossimAnnotationPolyObject::print(), thePolygon, and theProjectedPolyObject.
127 {
128  out << "number_of_points: " << thePolygon.size() << std::endl;
129  if(thePolygon.size() > 0)
130  {
131  for(long index =0; index < (long)(thePolygon.size()-1); ++index)
132  {
133  out << thePolygon[index] << std::endl;
134  }
135  out << thePolygon[thePolygon.size()-1] << std::endl;
136  }
137  out << "Projected Polygon" << std::endl;
139  return out;
140 }
◆ saveState()
bool ossimGeoAnnotationPolyObject::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 233 of file ossimGeoAnnotationPolyObject.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimGeoAnnotationObject::saveState(), thePolygon, and ossimString::toString().
235 {
236  ossim_uint32 vIdx = 0;
237
238  for(ossim_uint32 i = 0; i < thePolygon.size(); ++i)
239  {
240  ossimString key = "v";
241  key += ossimString::toString(vIdx);
242
243  kwl.add(prefix, key.c_str(), thePolygon[i].toString().c_str());
244
245  ++vIdx;
246  }
247
248  return ossimGeoAnnotationObject::saveState(kwl, prefix);
249 }
◆ setColor()
void ossimGeoAnnotationPolyObject::setColor ( ossim_uint8  r,
ossim_uint8  g,
ossim_uint8  b
virtual
Definition at line 213 of file ossimGeoAnnotationPolyObject.cpp.
References ossimAnnotationObject::setColor(), theProjectedPolyObject, and ossimRefPtr< T >::valid().
216 {
219  {
221  }
222 }
bool valid() const
◆ setFillFlag()
void ossimGeoAnnotationPolyObject::setFillFlag ( bool  flag)
virtual
◆ setPolygon()
void ossimGeoAnnotationPolyObject::setPolygon ( const std::vector< ossimGpt > &  poly)
virtual
Definition at line 193 of file ossimGeoAnnotationPolyObject.cpp.
References ossimAnnotationPolyObject::setPolygon(), thePolygon, theProjectedPolyObject, and ossimRefPtr< T >::valid().
194 {
195  thePolygon = poly;
196  std::vector<ossimDpt> projectedPoints(thePolygon.size());
198  {
199  theProjectedPolyObject->setPolygon(projectedPoints);
200  }
201
202 }
bool valid() const
◆ setPolyType()
virtual void ossimGeoAnnotationPolyObject::setPolyType ( ossimPolyType  polyType)
inlinevirtual
◆ setThickness()
void ossimGeoAnnotationPolyObject::setThickness ( ossim_uint8  thickness)
virtual
Definition at line 224 of file ossimGeoAnnotationPolyObject.cpp.
References ossimAnnotationObject::setThickness(), theProjectedPolyObject, and ossimRefPtr< T >::valid().
225 {
228  {
230  }
231 }
bool valid() const
◆ transform()
void ossimGeoAnnotationPolyObject::transform ( ossimImageGeometry projection)
virtual
Add the projection interface to all geographically defined objects.
Implements ossimGeoAnnotationObject.
Definition at line 106 of file ossimGeoAnnotationPolyObject.cpp.
References ossimAnnotationPolyObject::computeBoundingRect(), ossimAnnotationPolyObject::getPolygon(), thePolygon, theProjectedPolyObject, and ossimImageGeometry::worldToLocal().
Referenced by ossimGdalOgrVectorAnnotation::loadPolygon().
107 {
108  // make sure it's not null
109  if(!projection)
110  {
111  return;
112  }
114  const std::vector<ossimGpt>::size_type BOUNDS = thePolygon.size();
115
116  for(std::vector<ossimGpt>::size_type index=0; index < BOUNDS; ++index)
117  {
118  projection->worldToLocal(thePolygon[(int)index], poly[(int)index]);
119  }
120
121  // update the bounding rect
122  //
124 }
const ossimPolygon & getPolygon() const
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
Member Data Documentation
◆ m_PolyType
ossimPolyType ossimGeoAnnotationPolyObject::m_PolyType
protected
Definition at line 97 of file ossimGeoAnnotationPolyObject.h.
◆ thePolygon
std::vector<ossimGpt> ossimGeoAnnotationPolyObject::thePolygon
protected
◆ theProjectedPolyObject
ossimRefPtr<ossimAnnotationPolyObject> ossimGeoAnnotationPolyObject::theProjectedPolyObject
protected
