ossimGdalOgrVectorAnnotation.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 // License: See top level LICENSE.txt file.
3 //
4 // Author: Garrett Potts
5 //
6 //*******************************************************************
7 // $Id: ossimGdalOgrVectorAnnotation.cpp 22897 2014-09-25 16:16:13Z dburken $
8
10 #include <ossimOgcWktTranslator.h>
11 #include <ossimGdalType.h>
12 #include <ossimOgcWktTranslator.h>
13 #include <ossim/base/ossimTrace.h>
19 #include <ossim/base/ossimNotify.h>
20 #include <ossim/base/ossimIpt.h>
21 #include <ossim/base/ossimDpt.h>
36 #include <ossim/base/ossimCommon.h>
46 #include <ogr_api.h>
47 #include <sstream>
48
50  "ossimGdalOgrVectorAnnotation",
53
54 static ossimOgcWktTranslator wktTranslator;
55 static ossimTrace traceDebug("ossimGdalOgrVectorAnnotation:debug");
56
57 static const char SHAPEFILE_COLORS_AUTO_KW[] =
58  "shapefile_colors_auto";
59
60 static const char NORMALIZED_RGB_BRUSH_COLOR_KW[] =
61  "shapefile_normalized_rgb_brush_color";
62
63 static const char NORMALIZED_RGB_PEN_COLOR_KW[] =
64  "shapefile_normalized_rgb_pen_color";
65
66 static const char POINT_SIZE_KW[] =
67  "shapefile_point_size";
68
69
70 bool doubleLess(double first, double second, double epsilon, bool orequal = false)
71 {
72  if (fabs(first - second) < epsilon)
73  {
74  return (orequal);
75  }
76  return (first < second);
77 }
78
79 bool doubleGreater(double first, double second, double epsilon, bool orequal = false)
80 {
81  if (fabs(first - second) < epsilon)
82  {
83  return (orequal);
84  }
85  return (first > second);
86 }
87
90 {
91 public:
93  ossimRgbColor() : r(1), g(255), b(1) {}
94
97  : r(r), g(g), b(b) {}
98
102 };
103
104 // The index of the current color.
105 static ossim_uint32 currentAutoColorArrayIndex = 0;
106
107 // Array count of colors.
108 static const ossim_uint32 AUTO_COLOR_ARRAY_COUNT = 9;
109
110 // Static array to index for auto colors.
111 static const ossimRgbColor autoColorArray[AUTO_COLOR_ARRAY_COUNT] =
112 {
113  ossimRgbColor(255, 1, 1), // red
114  ossimRgbColor( 1, 255, 1), // green
115  ossimRgbColor( 1, 1, 255), // blue
116
117  ossimRgbColor(1, 255, 255), // cyan
118  ossimRgbColor(255, 1, 255), // magenta
119  ossimRgbColor(255, 255, 1), // yellow
120
121  ossimRgbColor(255, 165, 1), // orange
122  ossimRgbColor(160, 32, 240), // purple
123  ossimRgbColor(238, 130, 238) // violet
124 };
125
127 {
128 public:
130  const ossimDrect& rect)
131  :theId(id),
132  theBoundingRect(rect)
133  {
134  }
135
136  bool intersects(const ossimDrect& rect)const
137  {
138  return theBoundingRect.intersects(rect);
139  }
140  bool intersects(double minX, double minY,
141  double maxX, double maxY)const
142  {
143  return theBoundingRect.intersects(ossimDrect(minX, minY, maxX, maxY));
144  }
145  long theId;
147 };
148
150 {
151 public:
153  : theBoundingRect(bounds)
154  {
155  }
156  bool intersects(const ossimDrect& rect)const
157  {
158  return theBoundingRect.intersects(rect);
159  }
160  bool intersects(double minX, double minY,
161  double maxX, double maxY)const
162  {
163  return theBoundingRect.intersects(ossimDrect(minX, minY, maxX, maxY));
164  }
165  void getIdList(std::list<long>& idList,
166  const ossimDrect& aoi)const;
167  std::vector<ossimOgrGdalFeatureNode> theFeatureList;
168
170 };
171 void ossimOgrGdalLayerNode::getIdList(std::list<long>& idList,
172  const ossimDrect& aoi)const
173 {
174  if(!intersects(aoi))
175  {
176  return;
177  }
179  {
180  for(ossim_uint32 i = 0; i < theFeatureList.size(); ++i)
181  {
182  idList.push_back(theFeatureList[i].theId);
183  }
184  }
185  else
186  {
187  for(ossim_uint32 i = 0; i < theFeatureList.size(); ++i)
188  {
189  if(theFeatureList[i].intersects(aoi))
190  {
191  idList.push_back(theFeatureList[i].theId);
192  }
193  }
194  }
195 }
196
198  :ossimAnnotationSource(inputSource),
200  theDataSource(0),
201  theDriver(0),
202  theFilename(),
203  theBoundingExtent(),
204  theLayersToRenderFlagList(),
205  theLayerTable(),
206  thePenColor(255,255,255),
207  theBrushColor(255,255,255),
208  theFillFlag(false),
209  theThickness(1),
210  thePointWidthHeight(1, 1),
211  theBorderSize(0.0),
212  theBorderSizeUnits(OSSIM_DEGREES),
213  theImageBound(),
214  theIsExternalGeomFlag(false),
215  m_query(""),
216  m_needPenColor(false),
217  m_geometryDistance(0.0),
218  m_geometryDistanceType(OSSIM_UNIT_UNKNOWN),
219  m_layerName("")
220 {
221  // Pick up colors from preference file if set.
222  getDefaults();
223
224  theObject = this;
227 }
228
230 {
232  close();
233 }
234
236 {
237  deleteTables();
238  if(theDataSource)
239  {
240  delete theDataSource;
241  theDataSource = 0;
242  }
243  if (theImageGeometry.valid())
244  {
245  theImageGeometry = 0;
246  }
247 }
249 {
250  return theFilename;
251 }
252
254 {
255  m_query = query;
256  open(theFilename);
257 }
258
260 {
262  m_geometryDistanceType = type;
263 }
264
266 {
267  const char* MODULE = "ossimGdalOgrVectorAnnotation::open";
268  if(traceDebug())
269  {
270  ossimNotify(ossimNotifyLevel_NOTICE) << MODULE << " entered...\nfile: " << file << "\n";
271  }
272
273  if(isOpen())
274  {
275  close();
276  }
277  m_layerNames.clear();
278  if(file == "") return false;
279
280 #if 0 /* Commented out but please leave until I test. drb - 15 July 2011 */
281  ossimString ext = file.ext().downcase();
282  if ( ext != "shp" )
283  {
284  //---
285  // OGRSFDriverRegistrar::Open very touchy and crashes if given a file it cannot handle.
286  // Only allow one type of extension to open file.
287  //---
288  return false;
289  }
290 #endif
291
292  // theDataSource = OGRSFDriverRegistrar::Open( file.c_str(), false, &theDriver );
293  theDataSource = (OGRDataSource*) OGROpen( file.c_str(), false, NULL );
294  if ( theDataSource )
295  {
296  theDriver = (OGRSFDriver*) theDataSource->GetDriver();
297  }
298
299  if ( !theDataSource || !theDriver )
300  {
301  if(traceDebug())
302  {
303  ossimNotify(ossimNotifyLevel_NOTICE) << "OGRSFDriverRegistrar::Open failed...\n";
304  }
305  return false;
306  }
307
308  // Capture the file. Need here for loadExternalGeometryFile method.
309  theFilename = file;
310
311  // This will set theViewProjection if "file.geom" is present and valid.
313
314  // This will load external pen, brush and point attributes.
315  loadOmdFile();
316
318  vector<ossimGpt> points;
319  if(isOpen())
320  {
321  int i = 0;
322  int layerCount = 0;
323  if (!m_query.empty())
324  {
325  layerCount = 1;
326  }
327  else if (!m_layerName.empty())
328  {
329  layerCount = 1;
330  }
331  else
332  {
333  layerCount = theDataSource->GetLayerCount();
334  }
335
336  bool successfulTest = true;
337  if(layerCount)
338  {
339  theLayersToRenderFlagList.resize(layerCount);
340  for(i = 0; (i < layerCount)&&successfulTest; ++i)
341  {
342  OGRLayer* layer = NULL;
343  if (!m_query.empty())
344  {
345  layer = theDataSource->ExecuteSQL(m_query, NULL, NULL);
346  }
347  else if (!m_layerName.empty())
348  {
349  layer = theDataSource->GetLayerByName(m_layerName.c_str());
350  }
351  else
352  {
353  layer = theDataSource->GetLayer(i);
354  }
355
356  if(layer)
357  {
358  OGRSpatialReference* spatialReference = layer->GetSpatialRef();
359  theLayersToRenderFlagList[i] = true;
360  m_layerNames.push_back(ossimString(layer->GetLayerDefn()->GetName()));
361
362  if(!spatialReference)
363  {
364  //try xml file
365  if (!theImageGeometry.valid())
366  {
368  }
369
370  if(traceDebug())
371  {
373  << MODULE
374  << " No spatial reference given, assuming geographic"
375  << endl;
376  }
377  }
378  else if(spatialReference->IsLocal())
379  {
380  if(traceDebug())
381  {
383  << MODULE
384  << " Only geographic vectors and projected vectors "
385  << "are supported, layer " << i << " is local" << endl;
386  }
387  successfulTest = false;
388  }
389
390  }
391  else
392  {
393
394  if(traceDebug())
395  {
397
398  << MODULE
399  << " layer " << i << " is null." << endl;
400  }
401  successfulTest = false;
402  }
403
404  if(successfulTest&&layer)
405  {
406  if (!theImageGeometry.valid())
407  {
408  ossimRefPtr<ossimProjection> proj = createProjFromReference(layer->GetSpatialRef());
409  if(proj.valid())
410  {
411  theImageGeometry = new ossimImageGeometry(0, proj.get());
412  }
413  }
414  ossimMapProjection* mapProj = 0;
415  if(theImageGeometry.valid())
416  {
418  }
419  if (!mapProj)
420  {
421  theImageGeometry = 0;
422  }
423
424  if(i == 0)
425  {
426  layer->GetExtent(&theBoundingExtent, true);
427  if(mapProj)
428  {
429  if (layer->GetSpatialRef())
430  {
431  double unitValue = layer->GetSpatialRef()->GetLinearUnits();
432  theBoundingExtent.MinX = theBoundingExtent.MinX * unitValue;
433  theBoundingExtent.MaxY = theBoundingExtent.MaxY * unitValue;
434  theBoundingExtent.MaxX = theBoundingExtent.MaxX * unitValue;
435  theBoundingExtent.MinY = theBoundingExtent.MinY * unitValue;
436  }
437
438  ossimDrect rect(theBoundingExtent.MinX,
439  theBoundingExtent.MaxY,
440  theBoundingExtent.MaxX,
441  theBoundingExtent.MinY,
443
444  ossimGpt g1 = mapProj->inverse(rect.ul());
445  ossimGpt g2 = mapProj->inverse(rect.ur());
446  ossimGpt g3 = mapProj->inverse(rect.lr());
447  ossimGpt g4 = mapProj->inverse(rect.ll());
448  ossimDrect rect2 = ossimDrect(ossimDpt(g1),
449  ossimDpt(g2),
450  ossimDpt(g3),
451  ossimDpt(g4));
452
453  theBoundingExtent.MinX = rect2.ul().x;
454  theBoundingExtent.MinY = rect2.ul().y;
455  theBoundingExtent.MaxX = rect2.lr().x;
456  theBoundingExtent.MaxY = rect2.lr().y;
457
458  //insert the bounding values to points to convert to bounding rect
459  points.push_back(g1);
460  points.push_back(g2);
461  points.push_back(g3);
462  points.push_back(g4);
463  }
464  }
465  else
466  {
467  OGREnvelope extent;
468  layer->GetExtent(&extent, true);
469  if(mapProj)
470  {
471  ossimDrect rect(extent.MinX,
472  extent.MaxY,
473  extent.MaxX,
474  extent.MinY,
476
477  ossimGpt g1 = mapProj->inverse(rect.ul());
478  ossimGpt g2 = mapProj->inverse(rect.ur());
479  ossimGpt g3 = mapProj->inverse(rect.lr());
480  ossimGpt g4 = mapProj->inverse(rect.ll());
481  ossimDrect rect2 = ossimDrect(ossimDpt(g1),
482  ossimDpt(g2),
483  ossimDpt(g3),
484  ossimDpt(g4));
485  extent.MinX = rect2.ul().x;
486  extent.MinY = rect2.ul().y;
487  extent.MaxX = rect2.lr().x;
488  extent.MaxY = rect2.lr().y;
489
490  //compare the current values of points with the first layer to
491  //get the MBR of the datasource
492  if (points.size() == 4)
493  {
494  if (doubleLess(g1.lon, points[0].lon, 0.0001))
495  {
496  points[0].lon = g1.lon;
497  }
498  if (doubleGreater(g1.lat, points[0].lat, 0.0001))
499  {
500  points[0].lat = g1.lat;
501  }
502  if (doubleGreater(g2.lon, points[1].lon, 0.0001))
503  {
504  points[1].lon = g2.lon;
505  }
506  if (doubleGreater(g2.lat, points[1].lat, 0.0001))
507  {
508  points[1].lat = g2.lat;
509  }
510  if (doubleGreater(g3.lon, points[2].lon, 0.0001))
511  {
512  points[2].lon = g3.lon;
513  }
514  if (doubleLess(g3.lat, points[2].lat, 0.0001))
515  {
516  points[2].lat = g3.lat;
517  }
518  if (doubleLess(g4.lon, points[3].lon, 0.0001))
519  {
520  points[3].lon = g4.lon;
521  }
522  if (doubleLess(g4.lat, points[3].lat, 0.0001))
523  {
524  points[3].lat = g4.lat;
525  }
526  }
527  }
528  theBoundingExtent.MinX = std::min(extent.MinX,
529  theBoundingExtent.MinX);
530  theBoundingExtent.MinY = std::min(extent.MinY,
531  theBoundingExtent.MinY);
532  theBoundingExtent.MaxX = std::max(extent.MaxX,
533  theBoundingExtent.MaxX);
534  theBoundingExtent.MaxY = std::max(extent.MaxY,
535  theBoundingExtent.MaxY);
536  }
537  }
538
539  //if an OGRLayer pointer representing a results set from the query, this layer is
540  //in addition to the layers in the data store and must be destroyed with
541  //OGRDataSource::ReleaseResultSet() before the data source is closed (destroyed).
542  if (!m_query.empty() && layer != NULL)
543  {
544  theDataSource->ReleaseResultSet(layer);
545  }
546  }
547  }
548  if(!successfulTest)
549  {
550  delete theDataSource;
551  theDataSource = NULL;
553
554  return false;
555  }
556  }
557  if(traceDebug())
558  {
559  CLOG << "Extents = "
560  << theBoundingExtent.MinX << ", "
561  << theBoundingExtent.MinY << ", "
562  << theBoundingExtent.MaxX << ", "
563  << theBoundingExtent.MaxY << endl;
564  }
565  if(!theImageGeometry.valid())
566  {
568  }
569  else
570  {
572  }
573
574  //initialize the bounding rect
575  initializeBoundingRec(points);
576
577  //only initializeTables when need to draw features. This eliminate the memory allocate problem
578  //when only do ossim-info for a large shape file
579  //initializeTables();
580
581  if (traceDebug())
582  {
584  << MODULE << " DEBUG:"
585  << "\ntheViewProjection:"
586  << endl;
587  if(theImageGeometry.valid())
588  {
590  }
592  }
593
594  return (theDataSource!=NULL);
595 }
596
598 {
600
601  //if the projection is default or geographic, uses the bounding of the OGR Layer
602  if (points.size() == 0)
603  {
604  points.push_back(ossimGpt(theBoundingExtent.MaxY, theBoundingExtent.MinX));
605  points.push_back(ossimGpt(theBoundingExtent.MaxY, theBoundingExtent.MaxX));
606  points.push_back(ossimGpt(theBoundingExtent.MinY, theBoundingExtent.MaxX));
607  points.push_back(ossimGpt(theBoundingExtent.MinY, theBoundingExtent.MinX));
608  }
609
610  if(theImageGeometry.valid())
611  {
612  std::vector<ossimDpt> rectTmp;
613  rectTmp.resize(points.size());
614  for(std::vector<ossimGpt>::size_type index=0; index < points.size(); ++index)
615  {
616  theImageGeometry->worldToLocal(points[(int)index], rectTmp[(int)index]);
617  }
618
619  if (rectTmp.size() > 3)
620  {
621  ossimDrect rect2 = ossimDrect(rectTmp[0],
622  rectTmp[1],
623  rectTmp[2],
624  rectTmp[3]);
625
626  theImageBound = rect2;
627  }
628  }
629 }
630
632 {
633  bool result = false;
634
635  if(baseObject)
636  {
637  // Test for projection...
638  ossimProjection* p = PTR_CAST(ossimProjection, baseObject);
639  if (p)
640  {
641  if(!theImageGeometry)
642  {
644  }
645  else
646  {
648  }
649
650  // Reproject the points to the current new projection.
652  result = true;
653
654  }
655  else
656  {
657  ossimImageGeometry* geom = dynamic_cast<ossimImageGeometry*> (baseObject);
658  if(geom)
659  {
660  theImageGeometry = geom;
661  // Reproject the points to the current new projection.
663  result = true;
664  }
665  }
666  } // if (baseObject)
667
668  return result;
669 }
670
672 {
673  return theImageGeometry.get();
674 }
675
679 {
680  return theImageGeometry;
681 }
682
684 {
685  if (theImageGeometry.valid())
686  return;
687
688  if(!isOpen())
689  return;
690
691  // double horizontal = fabs(theBoundingExtent.MinX - theBoundingExtent.MaxX);
692  // double vertical = fabs(theBoundingExtent.MinY - theBoundingExtent.MaxY);
693
694  // if((horizontal > 0.0) && (vertical > 0.0))
696
697  ossim_float64 centerLat = (theBoundingExtent.MaxY + theBoundingExtent.MinY ) / 2.0;
698  ossim_float64 centerLon = (theBoundingExtent.MaxX + theBoundingExtent.MinX ) / 2.0;
699  ossim_float64 deltaLat = theBoundingExtent.MaxY - theBoundingExtent.MinY;
700
701  // Scale that gives 1024 pixel in the latitude direction.
702  ossim_float64 scaleLat = deltaLat / 1024.0;
703  ossim_float64 scaleLon = scaleLat*ossim::cosd(std::fabs(centerLat));
704  ossimGpt origin(centerLat, centerLon, 0.0);
705  ossimDpt scale(scaleLon, scaleLat);
706
707  // Set the origin.
708  proj->setOrigin(origin);
709
710  // Set the tie point.
711  proj->setUlGpt( ossimGpt(theBoundingExtent.MaxY,
712  theBoundingExtent.MinX) );
713
714  // Set the scale. Note this will handle computing meters per pixel.
715  proj->setDecimalDegreesPerPixel(scale);
716
717  // Capture the projection.
718  theImageGeometry = new ossimImageGeometry(0, proj);
719 }
720
722 {
723  return theImageBound;
724 }
725
727 {
728  std::multimap<long, ossimAnnotationObject*>::iterator iter = theFeatureCacheTable.begin();
729
731  while(iter != theFeatureCacheTable.end())
732  {
734  (*iter).second);
735
736  if(obj)
737  {
738  ossimDrect rect;
739  obj->getBoundingRect(rect);
740
741  if(theImageBound.hasNans())
742  {
743  theImageBound = rect;
744  }
745  else
746  {
747  if(!rect.hasNans())
748  {
750  }
751  }
752  }
753
754  ++iter;
755  }
756
758 }
759
762 {
763  if (theFeatureCacheTable.size() == 0)
764  {
766  }
767
768  if( theImageGeometry.valid())
769  {
770  list<long> featuresToRender;
771  ossimIrect tileRect = tile->getImageRectangle();
772
773  getFeatures(featuresToRender, tileRect);
774
775  list<long>::iterator current = featuresToRender.begin();
776
778
779  image->setCurrentImageData(tile);
780  vector<ossimAnnotationObject*> objectList;
781
782  while(current!=featuresToRender.end())
783  {
784  getFeature(objectList, *current);
785  ++current;
786  }
787
788  for(ossim_uint32 i = 0; i < objectList.size();++i)
789  {
790  objectList[i]->draw(*image.get());
791
792  if (theFillFlag && m_needPenColor) //need to draw both the brush and line (pen) for a polygon
793  {
794  ossimObject* objectDup = objectList[i]->dup();
796  if (polyObject)//check if it is the polygon object
797  {
799  polyObject->setThickness(theThickness);
800  polyObject->setFillFlag(false);
801  polyObject->draw(*image.get());
802  }
803  delete objectDup;
804  }
805  }
806
807  tile->validate();
808  }
809 }
810
812 {
813  std::multimap<long, ossimAnnotationObject*>::iterator iter = theFeatureCacheTable.begin();
814
815  while(iter != theFeatureCacheTable.end())
816  {
817  iter->second->setThickness(theThickness);
818
819  iter->second->setColor(thePenColor.getR(),
820  thePenColor.getG(),
821  thePenColor.getB());
822
823  if(PTR_CAST(ossimGeoAnnotationPolyObject, iter->second))
824  {
826  (ossimGeoAnnotationPolyObject*)(iter->second);
827  poly->setFillFlag(theFillFlag);
828  }
829  else if(PTR_CAST(ossimGeoAnnotationMultiPolyObject, iter->second))
830  {
832  (ossimGeoAnnotationMultiPolyObject*)(iter->second);
833  poly->setFillFlag(theFillFlag);
834  }
835  else if(PTR_CAST(ossimGeoAnnotationEllipseObject, iter->second))
836  {
838
840  ell->setFillFlag(theFillFlag);
842  }
843  if(theFillFlag)
844  {
845  iter->second->setColor(theBrushColor.getR(),
847  theBrushColor.getB());
848  }
849  ++iter;
850  }
851 }
852
854 {
855  if(!property.valid()) return;
856
857  ossimString name = property->getName();
858  ossimString value = property->valueToString();
859
861  {
862  int r;
863  int g;
864  int b;
865  std::istringstream in(value);
866  in >> r >> g >> b;
867  thePenColor.setR((unsigned char)r);
868  thePenColor.setG((unsigned char)g);
869  thePenColor.setB((unsigned char)b);
871  }
872  else if(name == ossimKeywordNames::BRUSH_COLOR_KW)
873  {
874  int r;
875  int g;
876  int b;
877  std::istringstream in(value);
878  in >> r >> g >> b;
879  theBrushColor.setR((unsigned char)r);
880  theBrushColor.setG((unsigned char)g);
881  theBrushColor.setB((unsigned char)b);
883  }
884  else if(name == ossimKeywordNames::FILL_FLAG_KW)
885  {
886  theFillFlag = value.toBool();
888  }
889  else if(name == ossimKeywordNames::THICKNESS_KW)
890  {
891  setThickness(value.toInt32());
893  }
894  else if(name == ossimKeywordNames::BORDER_SIZE_KW)
895  {
896  }
898  {
899  std::istringstream in(value);
900  in >> thePointWidthHeight.x;
901  in >> thePointWidthHeight.y;
903  }
904  else
905  {
907  }
908 }
909
911 {
914  {
915  result = new ossimColorProperty(name,
916  thePenColor);
917  result->setCacheRefreshBit();
918  }
919  else if(name == ossimKeywordNames::BRUSH_COLOR_KW)
920  {
921  result = new ossimColorProperty(name,
922  theBrushColor);
923  result->setCacheRefreshBit();
924  }
925  else if(name == ossimKeywordNames::FILL_FLAG_KW)
926  {
927  result = new ossimBooleanProperty(name,
928  theFillFlag);
929  result->setCacheRefreshBit();
930
931  }
932  else if(name == ossimKeywordNames::THICKNESS_KW)
933  {
934  ossimNumericProperty* prop =
935  new ossimNumericProperty(name,
937  1.0,
938  255.0);
940  result = prop;
941  result->setFullRefreshBit();
942  }
943  else if(name == ossimKeywordNames::BORDER_SIZE_KW)
944  {
945  }
947  {
948  result = new ossimTextProperty(name,
950  " " +
952  result->setFullRefreshBit();
953  }
954  else
955  {
956  result = ossimAnnotationSource::getProperty(name);
957  }
958
959  return result;
960 }
961
962 void ossimGdalOgrVectorAnnotation::getPropertyNames(std::vector<ossimString>& propertyNames)const
963 {
964
965  propertyNames.push_back(ossimKeywordNames::PEN_COLOR_KW);
966  propertyNames.push_back(ossimKeywordNames::BRUSH_COLOR_KW);
967  propertyNames.push_back(ossimKeywordNames::FILL_FLAG_KW);
968  propertyNames.push_back(ossimKeywordNames::THICKNESS_KW);
969  propertyNames.push_back(ossimKeywordNames::BORDER_SIZE_KW);
970  propertyNames.push_back(ossimKeywordNames::POINT_WIDTH_HEIGHT_KW);
971 }
972
973
975  const char* prefix)const
976 {
977  ossimString s;
978
979  kwl.add(prefix,
981  theFilename.c_str(),
982  true);
983
984
985  s = ossimString::toString((int)thePenColor.getR()) + " " +
986  ossimString::toString((int)thePenColor.getG()) + " " +
988
989  kwl.add(prefix,
991  s.c_str(),
992  true);
993
994  s = ossimString::toString((int)theBrushColor.getR()) + " " +
997
998  kwl.add(prefix,
1000  s.c_str(),
1001  true);
1002
1003  kwl.add(prefix,
1005  (int)theFillFlag,
1006  true);
1007
1008  kwl.add(prefix,
1010  getThickness(),
1011  true);
1012
1013  ossimString border;
1015  border += " degrees";
1016  kwl.add(prefix,
1018  border,
1019  true);
1020
1021  kwl.add(prefix,
1023  "."+
1024  ossimKeywordNames::UNITS_KW).c_str(),
1026  true);
1027
1028  s = ossimString::toString((int)thePointWidthHeight.x) + " " +
1030
1031  kwl.add(prefix,
1033  s.c_str(),
1034  true);
1035
1036  if (!m_query.empty())
1037  {
1038  kwl.add(prefix,
1040  m_query.c_str(),
1041  true);
1042  }
1043
1044  if(theImageGeometry.valid())
1045  {
1046  ossimString newPrefix = prefix;
1047  newPrefix += "view_proj.";
1049  newPrefix.c_str());
1050  }
1051
1052  return ossimAnnotationSource::saveState(kwl, prefix);
1053 }
1054
1056  const char* prefix)
1057 {
1058  const char* filename = kwl.find(prefix, ossimKeywordNames::FILENAME_KW);
1059  const char* penColor = kwl.find(prefix, ossimKeywordNames::PEN_COLOR_KW);
1060  const char* brushColor = kwl.find(prefix, ossimKeywordNames::BRUSH_COLOR_KW);
1061  const char* fillFlag = kwl.find(prefix, ossimKeywordNames::FILL_FLAG_KW);
1062  const char* thickness = kwl.find(prefix, ossimKeywordNames::THICKNESS_KW);
1063  const char* pointWh = kwl.find(prefix, ossimKeywordNames::POINT_WIDTH_HEIGHT_KW);
1064  const char* border_size = kwl.find(prefix, ossimKeywordNames::BORDER_SIZE_KW);
1065  const char* query = kwl.find(prefix, ossimKeywordNames::QUERY_KW);
1066
1067  deleteTables();
1068  if(thickness)
1069  {
1070  setThickness(ossimString(thickness).toInt32());
1071  }
1072
1073  if(penColor)
1074  {
1075  int r = 0;
1076  int g = 0;
1077  int b = 0;
1078  ossimString penColorStr = ossimString(penColor);
1079  if (penColorStr.split(",").size() == 3)
1080  {
1081  r = penColorStr.split(",")[0].toInt();
1082  g = penColorStr.split(",")[1].toInt();
1083  b = penColorStr.split(",")[2].toInt();
1084  if (r == 0 && g == 0 && b == 0)
1085  {
1086  r = 1;
1087  g = 1;
1088  b = 1;
1089  }
1090  }
1092  m_needPenColor = true;
1093  }
1094
1095  if(brushColor)
1096  {
1097  int r = 0;
1098  int g = 0;
1099  int b = 0;
1100  ossimString brushColorStr = ossimString(brushColor);
1101  if (brushColorStr.split(",").size() == 3)
1102  {
1103  r = brushColorStr.split(",")[0].toInt();
1104  g = brushColorStr.split(",")[1].toInt();
1105  b = brushColorStr.split(",")[2].toInt();
1106  if (r == 0 && g == 0 && b == 0)
1107  {
1108  r = 1;
1109  g = 1;
1110  b = 1;
1111  }
1112  }
1113
1115  }
1116  if(pointWh)
1117  {
1118  double w, h;
1119  std::istringstream s(pointWh);
1120  s>>w>>h;
1121  thePointWidthHeight = ossimDpt(w, h);
1122  }
1123
1124  if(fillFlag)
1125  {
1126  theFillFlag = ossimString(fillFlag).toBool();
1127  }
1128  theBorderSize = 0.0;
1129  if(border_size)
1130  {
1131  theBorderSize = ossimString(border_size).toDouble();
1132  ossimString unitPrefix = ossimString(prefix) +
1134  ossimString(".");
1135
1137  getEntryNumber(kwl,
1138  unitPrefix.c_str());
1140  {
1143
1144  theBorderSize = unitConvert.getValue(OSSIM_DEGREES);
1146  }
1147  else // assume degrees
1148  {
1150  }
1151  }
1152  else
1153  {
1154  theBorderSize = 0.0;
1156  }
1157
1158  if(filename)
1159  {
1160  if(!open(ossimFilename(filename)))
1161  {
1162  return false;
1163  }
1164  }
1165
1166  if (query)
1167  {
1168  setQuery(query);
1169  }
1170
1171  bool status = ossimAnnotationSource::loadState(kwl, prefix);
1172
1173  initializeTables();
1174
1175  return status;
1176 }
1177
1179 {
1180  out << "ossimGdalOgrVectorAnnotation::print"
1181  << "\ntheLayersToRenderFlagList.size(): "
1182  << theLayersToRenderFlagList.size()
1183  << "\ntheLayerTable.size(): " << theLayerTable.size();
1184
1185  ossim_uint32 i;
1186  for(i=0; i<theLayersToRenderFlagList.size(); ++i)
1187  {
1188  out << "layer[" << i << "]:"
1189  << (theLayersToRenderFlagList[i]?"enabled":"disabled")
1190  << std::endl;
1191  }
1192  return ossimAnnotationSource::print(out);
1193 }
1194
1196 {
1197  if (theImageGeometry.valid())
1198  {
1199  if (theFeatureCacheTable.size() == 0)
1200  {
1201  initializeTables();
1202  }
1203  std::multimap<long, ossimAnnotationObject*>::iterator iter =
1204  theFeatureCacheTable.begin();
1205
1206  while(iter != theFeatureCacheTable.end())
1207  {
1209  (*iter).second);
1210
1211  if(obj&&theImageGeometry.valid())
1212  {
1213  obj->transform(theImageGeometry.get());
1214  }
1215  ++iter;
1216  }
1218  }
1219 }
1220
1221 void ossimGdalOgrVectorAnnotation::getFeatures(std::list<long>& result,
1222  const ossimIrect& rect)
1223 {
1224  if (isOpen())
1225  {
1226  ossimGpt gp1;
1227  ossimGpt gp2;
1228  ossimGpt gp3;
1229  ossimGpt gp4;
1230  ossimDpt dp1 = rect.ul();
1231  ossimDpt dp2 = rect.ur();
1232  ossimDpt dp3 = rect.lr();
1233  ossimDpt dp4 = rect.ll();
1234
1235  if (theImageGeometry.valid())
1236  {
1237  theImageGeometry->localToWorld(dp1, gp1);
1238  theImageGeometry->localToWorld(dp2, gp2);
1239  theImageGeometry->localToWorld(dp3, gp3);
1240  theImageGeometry->localToWorld(dp4, gp4);
1241
1242  double maxX = std::max( gp1.lond(), std::max( gp2.lond(), std::max(gp3.lond(), gp4.lond())));
1243  double minX = std::min( gp1.lond(), std::min( gp2.lond(), std::min(gp3.lond(), gp4.lond())));
1244  double maxY = std::max( gp1.latd(), std::max( gp2.latd(), std::max(gp3.latd(), gp4.latd())));
1245  double minY = std::min( gp1.latd(), std::min( gp2.latd(), std::min(gp3.latd(), gp4.latd())));
1246
1247  ossimDrect bounds(minX, minY, maxX, maxY);
1248
1249  for(ossim_uint32 layerI = 0;
1250  layerI < theLayersToRenderFlagList.size();
1251  ++layerI)
1252  {
1253  if(theLayersToRenderFlagList[layerI])
1254  {
1255  if(theLayerTable[layerI])
1256  {
1257  theLayerTable[layerI]->getIdList(result, bounds);
1258  }
1259  }
1260  }
1261  }
1262  }
1263 }
1264
1266 {
1267  if(traceDebug())
1268  {
1269  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimGdalOgrVectorAnnotation::initializeTables(): entered.........." << std::endl;
1270  }
1271  if(theLayerTable.size())
1272  {
1273  deleteTables();
1274  }
1275
1276  if(isOpen())
1277  {
1278  int upper = theLayersToRenderFlagList.size();
1279  theLayerTable.resize(upper);
1280
1281  for(int i = 0; i < upper; ++i)
1282  {
1284  {
1285  OGREnvelope extent;
1286  OGRLayer* layer = NULL;
1287  if (!m_query.empty())
1288  {
1289  layer = theDataSource->ExecuteSQL(m_query, NULL, NULL);
1290  }
1291  else if (!m_layerName.empty())
1292  {
1293  layer = theDataSource->GetLayerByName(m_layerName.c_str());
1294  }
1295  else
1296  {
1297  layer = theDataSource->GetLayer(i);
1298  }
1299
1302  {
1303  proj = theImageGeometry->getProjection();
1304  }
1305  else
1306  {
1307  proj = createProjFromReference(layer->GetSpatialRef());
1308  }
1309
1310  ossimMapProjection* mapProj = PTR_CAST(ossimMapProjection, proj.get());
1311
1312  layer->ResetReading();
1313  layer->GetExtent(&extent, true);
1314  layer->ResetReading();
1315
1316  OGRFeature* feature = NULL;
1317  if(mapProj)
1318  {
1319  ossimDrect rect(extent.MinX,
1320  extent.MaxY,
1321  extent.MaxX,
1322  extent.MinY,
1324  ossimGpt g1 = mapProj->inverse(rect.ul());
1325  ossimGpt g2 = mapProj->inverse(rect.ur());
1326  ossimGpt g3 = mapProj->inverse(rect.lr());
1327  ossimGpt g4 = mapProj->inverse(rect.ll());
1328
1329  ossimDrect rect2 = ossimDrect(ossimDpt(g1),
1330  ossimDpt(g2),
1331  ossimDpt(g3),
1332  ossimDpt(g4));
1333  theLayerTable[i] = new ossimOgrGdalLayerNode(rect2);
1334  }
1335  else
1336  {
1337  theLayerTable[i] = new ossimOgrGdalLayerNode(ossimDrect(extent.MinX,
1338  extent.MinY,
1339  extent.MaxX,
1340  extent.MaxY));
1341  }
1342
1343  while( (feature = layer->GetNextFeature()) != NULL)
1344  {
1345  if(feature)
1346  {
1347  OGRGeometry* geom = feature->GetGeometryRef();
1348
1349  if(geom)
1350  {
1351  switch(geom->getGeometryType())
1352  {
1353  case wkbMultiPoint:
1354  case wkbMultiPoint25D:
1355  {
1356  if(traceDebug())
1357  {
1358  ossimNotify(ossimNotifyLevel_DEBUG) << "Loading multi point" << std::endl;
1359  }
1360  loadMultiPoint(feature->GetFID(),
1361  (OGRMultiPoint*)geom,
1362  mapProj);
1363  break;
1364  }
1365  case wkbPolygon25D:
1366  case wkbPolygon:
1367  {
1368  if(traceDebug())
1369  {
1370  ossimNotify(ossimNotifyLevel_DEBUG) << "Loading polygon" << std::endl;
1371  }
1372  if (m_geometryDistance > 0.0)
1373  {
1374  OGRPolygon* poly = (OGRPolygon*)geom;
1375  OGRLinearRing* ring = poly->getExteriorRing();
1376  int numPoints = ring->getNumPoints();
1377  OGRGeometry* bufferGeom = geom->Buffer(m_geometryDistance, numPoints);
1378  loadPolygon(feature->GetFID(),
1379  (OGRPolygon*)bufferGeom,
1380  mapProj);
1381  }
1382  else
1383  {
1384  loadPolygon(feature->GetFID(),
1385  (OGRPolygon*)geom,
1386  mapProj);
1387  }
1388
1389  break;
1390  }
1391  case wkbLineString25D:
1392  case wkbLineString:
1393  {
1394  if(traceDebug())
1395  {
1396  ossimNotify(ossimNotifyLevel_DEBUG) << "Loading line string" << std::endl;
1397  }
1398  loadLineString(feature->GetFID(),
1399  (OGRLineString*)geom,
1400  mapProj);
1401  break;
1402  }
1403  case wkbPoint:
1404  case wkbPoint25D:
1405  {
1406  if(traceDebug())
1407  {
1408  ossimNotify(ossimNotifyLevel_DEBUG) << "Loading point" << std::endl;
1409  }
1410  loadPoint(feature->GetFID(),
1411  (OGRPoint*)geom,
1412  mapProj);
1413  break;
1414  }
1415  case wkbMultiPolygon25D:
1416  case wkbMultiPolygon:
1417  {
1418  if(traceDebug())
1419  {
1420  ossimNotify(ossimNotifyLevel_DEBUG) << "Loading multi polygon" << std::endl;
1421  }
1422  if (m_geometryDistance > 0.0)
1423  {
1424  OGRGeometry* bufferGeom = geom->Buffer(m_geometryDistance);
1425  loadMultiPolygon(feature->GetFID(),
1426  (OGRMultiPolygon*)bufferGeom,
1427  mapProj);
1428  }
1429  else
1430  {
1431  loadMultiPolygon(feature->GetFID(),
1432  (OGRMultiPolygon*)geom,
1433  mapProj);
1434  }
1435  break;
1436
1437  }
1438  case wkbMultiLineString:
1439  {
1440  if(traceDebug())
1441  {
1442  ossimNotify(ossimNotifyLevel_DEBUG) << "Loading line string" << std::endl;
1443  }
1444  loadMultiLineString(feature->GetFID(),
1445  (OGRMultiLineString*)geom,
1446  mapProj);
1447  break;
1448  }
1449  default:
1450  {
1451  if(traceDebug())
1452  {
1454  << "ossimGdalOgrVectorAnnotation::initializeTables WARNING\n"
1455
1456  << OGRGeometryTypeToName(geom->getGeometryType())
1457  <<" NOT SUPPORTED!"
1458  << endl;
1459  }
1460  break;
1461  }
1462  }
1463  geom->getEnvelope(&extent);
1464  if(mapProj)
1465  {
1466  ossimDrect rect(extent.MinX,
1467  extent.MaxY,
1468  extent.MaxX,
1469  extent.MinY,
1471  ossimGpt g1 = mapProj->inverse(rect.ul());
1472  ossimGpt g2 = mapProj->inverse(rect.ur());
1473  ossimGpt g3 = mapProj->inverse(rect.lr());
1474  ossimGpt g4 = mapProj->inverse(rect.ll());
1475
1476  theLayerTable[i]->theFeatureList.push_back(ossimOgrGdalFeatureNode(feature->GetFID(),
1477  ossimDrect(ossimDpt(g1),
1478  ossimDpt(g2),
1479  ossimDpt(g3),
1480  ossimDpt(g4))));
1481
1482  }
1483  else
1484  {
1485  theLayerTable[i]->theFeatureList.push_back(ossimOgrGdalFeatureNode(feature->GetFID(),
1486  ossimDrect(extent.MinX,
1487  extent.MinY,
1488  extent.MaxX,
1489  extent.MaxY)));
1490  }
1491  }
1492  }
1493  delete feature;
1494  }
1495
1496  //if an OGRLayer pointer representing a results set from the query, this layer is
1497  //in addition to the layers in the data store and must be destroyed with
1498  //OGRDataSource::ReleaseResultSet() before the data source is closed (destroyed).
1499  if (!m_query.empty() && layer != NULL)
1500  {
1501  theDataSource->ReleaseResultSet(layer);
1502  }
1503  }
1504  else
1505  {
1506  theLayerTable[i] = NULL;
1507  }
1508  }
1509  }
1512  if(traceDebug())
1513  {
1515  << "ossimGdalOgrVectorAnnotation::initializeTables(): leaving..."
1516  << std::endl;
1517  }
1518 }
1519
1521 {
1522  for(ossim_uint32 i = 0; i < theLayerTable.size(); ++i)
1523  {
1524  if(theLayerTable[i])
1525  {
1526  delete theLayerTable[i];
1527  }
1528  }
1529
1530  theLayerTable.clear();
1531  std::multimap<long, ossimAnnotationObject*>::iterator current = theFeatureCacheTable.begin();
1532
1533  while(current != theFeatureCacheTable.end())
1534  {
1535  ((*current).second)->unref();
1536  ++current;
1537  }
1538
1539  theFeatureCacheTable.clear();
1540 }
1541
1542
1543 void ossimGdalOgrVectorAnnotation::getFeature(vector<ossimAnnotationObject*>& featureList,
1544  long id)
1545 {
1546  std::multimap<long, ossimAnnotationObject*>::iterator iter = theFeatureCacheTable.find(id);
1547
1548  while( (iter != theFeatureCacheTable.end()) && ((*iter).first == id) )
1549  {
1550  featureList.push_back((*iter).second);
1551  ++iter;
1552  }
1553 }
1554
1556 {
1557  if(traceDebug())
1558  {
1559  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimGdalOgrVectorAnnotation::createProjFromReference: entered........" << std::endl;
1560  }
1561  if(!reference)
1562  {
1563  if(traceDebug())
1564  {
1565  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimGdalOgrVectorAnnotation::createProjFromReference: leaving 1........" << std::endl;
1566  }
1567  return NULL;
1568  }
1569  if(reference->IsGeographic()||reference->IsLocal())
1570  {
1571  if(traceDebug())
1572  {
1573  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimGdalOgrVectorAnnotation::createProjFromReference: leaving 2........" << std::endl;
1574  }
1575  return NULL;
1576  }
1577  char* wktString = NULL;
1578  ossimKeywordlist kwl;
1579  reference->exportToWkt(&wktString);
1580  wktTranslator.toOssimKwl(wktString,
1581  kwl);
1582  if(traceDebug())
1583  {
1584  ossimNotify(ossimNotifyLevel_DEBUG) << "wktString === " << wktString << std::endl;
1585  ossimNotify(ossimNotifyLevel_DEBUG) << "KWL === " << kwl << std::endl;
1586  }
1587  OGRFree(wktString);
1588  if(traceDebug())
1589  {
1590  ossimNotify(ossimNotifyLevel_DEBUG) << "ossimGdalOgrVectorAnnotation::createProjFromReference: returning........" << std::endl;
1591  }
1593 }
1594
1595 void ossimGdalOgrVectorAnnotation::loadPolygon(long id, OGRPolygon* poly, ossimMapProjection* mapProj)
1596 {
1597  OGRLinearRing* ring = poly->getExteriorRing();
1598
1599  ossimGpt origin;
1600
1602  {
1603  origin = theImageGeometry->getProjection()->origin();
1604  }
1605
1606  ossimRgbVector color;
1607
1608  if(theFillFlag)
1609  {
1610  color = theBrushColor;
1611  }
1612  else
1613  {
1614  color = thePenColor;
1615  }
1616
1617  if(ring)
1618  {
1619  int upper = ring->getNumPoints();
1620  vector<ossimGpt> points(upper);
1621  for(int i = 0; i < upper; ++i)
1622  {
1623  OGRPoint ogrPt;
1624  ring->getPoint(i, &ogrPt);
1625  if(mapProj)
1626  {
1627  points[i] = mapProj->inverse(ossimDpt(ogrPt.getX(),
1628  ogrPt.getY()));
1629
1630  }
1631  else
1632  {
1633  points[i] = ossimGpt(ogrPt.getY(),
1634  ogrPt.getX(),
1635  ogrPt.getZ(),
1636  origin.datum());
1637  }
1638  }
1639  ossimGeoAnnotationObject* annotation =
1640  new ossimGeoAnnotationPolyObject(points,
1641  theFillFlag,
1642  color.getR(),
1643  color.getG(),
1644  color.getB(),
1645  theThickness);
1646  if(theImageGeometry.valid())
1647  {
1648  annotation->transform(theImageGeometry.get());
1649  }
1650
1651  theFeatureCacheTable.insert(make_pair(id,
1652  annotation));
1653  }
1654  int bound = poly->getNumInteriorRings();
1655  if(bound)
1656  {
1657  for(int i = 0; i < bound; ++i)
1658  {
1659  ring = poly->getInteriorRing(i);
1660  if(ring)
1661  {
1662  int j = 0;
1663  int upper = ring->getNumPoints();
1664  vector<ossimGpt> points(upper);
1665  for(j = 0; j < upper; ++j)
1666  {
1667  OGRPoint ogrPt;
1668  ring->getPoint(j, &ogrPt);
1669  if(mapProj)
1670  {
1671  ossimDpt eastingNorthing(ogrPt.getX(),
1672  ogrPt.getY());
1673
1674  points[j] = mapProj->inverse(eastingNorthing);
1675
1676  }
1677  else
1678  {
1679  points[j] = ossimGpt(ogrPt.getY(),
1680  ogrPt.getX(),
1681  ogrPt.getZ(),
1682  origin.datum());
1683  }
1684  }
1685  ossimGeoAnnotationPolyObject* annotation =
1686  new ossimGeoAnnotationPolyObject(points,
1687  theFillFlag,
1688  color.getR(),
1689  color.getG(),
1690  color.getB(),
1691  theThickness);
1693
1694  if(theImageGeometry.valid())
1695  {
1696  annotation->transform(theImageGeometry.get());
1697  }
1698
1699  theFeatureCacheTable.insert(make_pair(id,
1700  annotation));
1701
1702  }
1703  }
1704  }
1705 }
1706
1707 void ossimGdalOgrVectorAnnotation::loadLineString(long id, OGRLineString* lineString,
1708  ossimMapProjection* mapProj)
1709 {
1710  int upper = lineString->getNumPoints();
1711  ossimGpt origin;
1713  {
1714  origin = theImageGeometry->getProjection()->origin();
1715  }
1716
1717  ossimRgbVector color;
1718
1719  if(theFillFlag)
1720  {
1721  color = theBrushColor;
1722  }
1723  else
1724  {
1725  color = thePenColor;
1726  }
1727  vector<ossimGpt> polyLine(upper);
1728  for(int i = 0; i < upper; ++i)
1729  {
1730  OGRPoint ogrPt;
1731
1732  lineString->getPoint(i, &ogrPt);
1733
1734  if(mapProj)
1735  {
1736  ossimDpt eastingNorthing(ogrPt.getX(),
1737  ogrPt.getY());
1738
1739  polyLine[i] = mapProj->inverse(eastingNorthing);
1740  }
1741  else
1742  {
1743  polyLine[i] = ossimGpt(ogrPt.getY(),
1744  ogrPt.getX(),
1745  ogrPt.getZ(),
1746  origin.datum());
1747  }
1748  }
1749
1750  ossimGeoAnnotationPolyLineObject* annotation =
1751  new ossimGeoAnnotationPolyLineObject(polyLine,
1752  color.getR(),
1753  color.getG(),
1754  color.getB(),
1755  theThickness);
1756  if(theImageGeometry.valid())
1757  {
1758  annotation->transform(theImageGeometry.get());
1759  }
1760
1761  theFeatureCacheTable.insert(make_pair(id,
1762  annotation));
1763 }
1764
1765 void ossimGdalOgrVectorAnnotation::loadMultiLineString(long id, OGRMultiLineString* multiLineString,
1766  ossimMapProjection* mapProj)
1767 {
1768  ossimRgbVector color;
1769
1770  if(theFillFlag)
1771  {
1772  color = theBrushColor;
1773  }
1774  else
1775  {
1776  color = thePenColor;
1777  }
1778
1779  ossim_uint32 numGeometries = multiLineString->getNumGeometries();
1780  ossimGpt origin;
1782  {
1783  origin = theImageGeometry->getProjection()->origin();
1784  }
1785
1786  vector<ossimGeoPolygon> geoPoly;
1787  for(ossim_uint32 geomIdx = 0; geomIdx < numGeometries; ++geomIdx)
1788  {
1789  OGRGeometry* geomRef = multiLineString->getGeometryRef(geomIdx);
1790  OGRLineString* lineString = (OGRLineString*)geomRef;
1791  if (lineString)
1792  {
1793  int upper = lineString->getNumPoints();
1794  vector<ossimGpt> polyLine(upper);
1795  for(int i = 0; i < upper; ++i)
1796  {
1797  OGRPoint ogrPt;
1798
1799  lineString->getPoint(i, &ogrPt);
1800
1801  if(mapProj)
1802  {
1803  ossimDpt eastingNorthing(ogrPt.getX(),
1804  ogrPt.getY());
1805
1806  polyLine[i] = mapProj->inverse(eastingNorthing);
1807  }
1808  else
1809  {
1810  polyLine[i] = ossimGpt(ogrPt.getY(),
1811  ogrPt.getX(),
1812  ogrPt.getZ(),
1813  origin.datum());
1814  }
1815  }
1816
1817  ossimGeoAnnotationPolyLineObject* annotation =
1818  new ossimGeoAnnotationPolyLineObject(polyLine,
1819  color.getR(),
1820  color.getG(),
1821  color.getB(),
1822  theThickness);
1823  if(theImageGeometry.valid())
1824  {
1825  annotation->transform(theImageGeometry.get());
1826  }
1827
1828  theFeatureCacheTable.insert(make_pair(id,
1829  annotation));
1830  }
1831  }
1832 }
1833
1834 void ossimGdalOgrVectorAnnotation::loadPoint(long id, OGRPoint* point, ossimMapProjection* mapProj)
1835 {
1836  ossimGpt origin;
1837  ossimRgbVector color;
1838
1839  if(theFillFlag)
1840  {
1841  color = theBrushColor;
1842  }
1843  else
1844  {
1845  color = thePenColor;
1846  }
1848  {
1849  origin = theImageGeometry->getProjection()->origin();
1850  }
1851
1852  ossimGpt gpt;
1853  if(mapProj)
1854  {
1855  ossimDpt eastingNorthing(point->getX(),
1856  point->getY());
1857
1858  gpt = mapProj->inverse(eastingNorthing);
1859  }
1860  else
1861  {
1862  gpt = ossimGpt(point->getY(),
1863  point->getX(),
1864  point->getZ(),
1865  origin.datum());
1866  }
1867
1868
1869  ossimGeoAnnotationEllipseObject* annotation =
1872  theFillFlag,
1873  color.getR(),
1874  color.getG(),
1875  color.getB(),
1876  theThickness);
1877  if(theImageGeometry.valid())
1878  {
1879  annotation->transform(theImageGeometry.get());
1880  }
1881  theFeatureCacheTable.insert(make_pair(id, annotation));
1882 }
1883
1885  OGRMultiPoint* multiPoint,
1886  ossimMapProjection* mapProj)
1887 {
1888  ossim_uint32 numGeometries = multiPoint->getNumGeometries();
1889  ossimRgbVector color;
1890
1891  if(theFillFlag)
1892  {
1893  color = theBrushColor;
1894  }
1895  else
1896  {
1897  color = thePenColor;
1898  }
1899
1902  theFillFlag,
1903  color.getR(),
1904  color.getG(),
1905  color.getB(),
1906  theThickness);
1907  ossimGpt origin;
1909  {
1910  origin = theImageGeometry->getProjection()->origin();
1911  }
1912  for(ossim_uint32 i = 0; i < numGeometries; ++i)
1913  {
1914  OGRGeometry* geomRef = multiPoint->getGeometryRef(i);
1915  if( geomRef &&
1916  ( (geomRef->getGeometryType()==wkbPoint) ||
1917  (geomRef->getGeometryType()==wkbPoint25D) ) )
1918  {
1919  OGRPoint* point = (OGRPoint*)geomRef;
1920
1921  if(mapProj)
1922  {
1923  ossimDpt eastingNorthing(point->getX(),
1924  point->getY());
1925
1926  annotation->addPoint(mapProj->inverse(eastingNorthing));
1927  }
1928  annotation->addPoint(ossimGpt(point->getY(),
1929  point->getX(),
1930  point->getZ(),
1931  origin.datum()));
1932  }
1933  }
1934  if(theImageGeometry.valid())
1935  {
1936  annotation->transform(theImageGeometry.get());
1937  }
1938
1939  theFeatureCacheTable.insert(make_pair(id, annotation));
1940 }
1941
1942
1944  long id,
1945  OGRMultiPolygon* multiPolygon,
1946  ossimMapProjection* mapProj)
1947 {
1948  ossimRgbVector color;
1949
1950  if(theFillFlag)
1951  {
1952  color = theBrushColor;
1953  }
1954  else
1955  {
1956  color = thePenColor;
1957  }
1958  ossimGpt origin;
1959  ossim_uint32 numGeometries = multiPolygon->getNumGeometries();
1960
1962  {
1963  origin = theImageGeometry->getProjection()->origin();
1964  }
1965
1966  vector<ossimGeoPolygon> geoPoly;
1967  for(ossim_uint32 geomIdx = 0; geomIdx < numGeometries; ++geomIdx)
1968  {
1969  OGRGeometry* geomRef = multiPolygon->getGeometryRef(geomIdx);
1970  if( geomRef &&
1971  ( (geomRef->getGeometryType()==wkbPolygon) ||
1972  (geomRef->getGeometryType()==wkbPolygon25D) ) )
1973  {
1974  geoPoly.push_back(ossimGeoPolygon());
1975  OGRPolygon* poly = (OGRPolygon*)geomRef;
1976  OGRLinearRing* ring = poly->getExteriorRing();
1977  ossim_uint32 currentPoly = geoPoly.size()-1;
1978
1979  if(ring)
1980  {
1981  ossim_uint32 upper = ring->getNumPoints();
1982
1983  for(ossim_uint32 ringPointIdx = 0;
1984  ringPointIdx < upper;
1985  ++ringPointIdx)
1986  {
1987  OGRPoint ogrPt;
1988  ring->getPoint(ringPointIdx, &ogrPt);
1989  if(mapProj)
1990  {
1991  geoPoly[currentPoly].addPoint(
1992  mapProj->inverse(ossimDpt(ogrPt.getX(), ogrPt.getY())));
1993  }
1994  else
1995  {
1996  geoPoly[currentPoly].addPoint(ogrPt.getY(),
1997  ogrPt.getX(),
1998  ogrPt.getZ(),
1999  origin.datum());
2000  }
2001  }
2002  }
2003
2004  ossim_uint32 bound = poly->getNumInteriorRings();
2005
2006  if(bound)
2007  {
2008  for(ossim_uint32 interiorRingIdx = 0;
2009  interiorRingIdx < bound;
2010  ++interiorRingIdx)
2011  {
2012  ring = poly->getInteriorRing(interiorRingIdx);
2013
2014  if(ring)
2015  {
2016  geoPoly.push_back(ossimGeoPolygon());
2017  currentPoly = geoPoly.size()-1;
2018
2019  ossim_uint32 upper = ring->getNumPoints();
2020
2021  for(ossim_uint32 interiorRingPointIdx = 0;
2022  interiorRingPointIdx < upper;
2023  ++interiorRingPointIdx)
2024  {
2025  OGRPoint ogrPt;
2026  ring->getPoint(interiorRingPointIdx, &ogrPt);
2027  if(mapProj)
2028  {
2029  geoPoly[currentPoly].addPoint(
2030  mapProj->inverse(ossimDpt(ogrPt.getX(),
2031  ogrPt.getY())));
2032  }
2033  else
2034  {
2035  geoPoly[currentPoly].addPoint(ogrPt.getY(),
2036  ogrPt.getX(),
2037  ogrPt.getZ(),
2038  origin.datum());
2039  }
2040  }
2041  }
2042  }
2043  }
2044  }
2045  }
2046
2047  if(geoPoly.size())
2048  {
2049  ossimGeoAnnotationMultiPolyObject* annotation =
2051  theFillFlag,
2052  color.getR(),
2053  color.getG(),
2054  color.getB(),
2055  theThickness);
2056  if(theImageGeometry.valid())
2057  {
2058  annotation->transform(theImageGeometry.get());
2059  }
2060
2061  theFeatureCacheTable.insert(make_pair(id, annotation));
2062  }
2063 }
2064
2066 {
2067  return open(theFilename);
2068 }
2069
2071 {
2072  return (theDataSource!=NULL);
2073 }
2074
2076 {
2077  return theImageGeometry.get();
2078 }
2079
2081 {
2082  theBrushColor = brushColor;
2083 }
2084
2086 {
2087  thePenColor = penColor;
2088 }
2089
2091 {
2092  return thePenColor;
2093 }
2094
2096 {
2097  return theBrushColor;
2098 }
2099
2101 {
2102  return thePointWidthHeight.x/2.0;
2103 }
2104
2106 {
2107  thePointWidthHeight = ossimDpt(fabs(r)*2, fabs(r)*2);
2108 }
2109
2111 {
2112  return theFillFlag;
2113 }
2114
2116 {
2117  theFillFlag=flag;
2118 }
2119
2121 {
2122  if ( (thickness > 0) && (thickness < 256) )
2123  {
2124  theThickness = static_cast<ossim_uint8>(thickness);
2125  }
2126  else
2127  {
2129  << "ossimGdalOgrVectorAnnotation::setThickness range error: "
2130  << thickness
2131  << "\nValid range: 1 to 255"
2132  << std::endl;
2133  }
2134 }
2135
2137 {
2138  return static_cast<ossim_int32>(theThickness);
2139 }
2140
2142 {
2143  ossimFilename filename = theFilename;
2144  filename.setExtension(".geom");
2145  if(!filename.exists())
2146  {
2147  filename.setExtension(".GEOM");
2148  if(!filename.exists())
2149  {
2150  return;
2151  }
2152  }
2153
2154  ossimKeywordlist kwl;
2155  if(kwl.addFile(filename))
2156  {
2158  geom->loadState(kwl);
2159  if(geom->getProjection())
2160  {
2161  theImageGeometry = geom;
2163  if (mapProj)
2164  {
2165  // drb...
2166  //mapProj->setUlGpt(mapProj->origin());
2167  theIsExternalGeomFlag = true;
2168
2169  if (traceDebug())
2170  {
2172  << "ossimGdalOgrVectorAnnotation::loadExternalGeometryFile"
2173  << " DEBUG:"
2174  << "\nExternal projection loaded from geometry file."
2175  << "\nProjection dump:" << std::endl;
2177  }
2178  }
2179  }
2180  }
2181 }
2182
2184 {
2185  ossimFilename filename = theFilename;
2186  ossimString fileBase = filename.noExtension();
2187  ossimFilename xmlFile = ossimString(fileBase + ".xml");
2188  if (!xmlFile.exists())//try the xml file which includes the entire source file name
2189  {
2190  xmlFile = theFilename + ".xml";
2191  }
2192  if (!xmlFile.exists())
2193  {
2194  return;
2195  }
2196  ossimFgdcXmlDoc* fgdcXmlDoc = new ossimFgdcXmlDoc;
2197  if ( fgdcXmlDoc->open(xmlFile) )
2198  {
2199  ossimRefPtr<ossimProjection> proj = fgdcXmlDoc->getProjection();
2200  if ( proj.valid() )
2201  {
2203  theImageGeometry->setProjection( proj.get() );
2204  theIsExternalGeomFlag = true;
2205  }
2206  }
2207  delete fgdcXmlDoc;
2208  fgdcXmlDoc = 0;
2209 }
2210
2212 {
2213  ossimFilename filename = theFilename;
2214  filename.setExtension(".omd");
2215  if(!filename.exists())
2216  {
2217  filename.setExtension(".OMD");
2218  }
2219
2220  if( filename.exists() )
2221  {
2222  ossimKeywordlist kwl;
2223  if( kwl.addFile(filename) )
2224  {
2225  //---
2226  // Because loadState can call open() we will not call it here to
2227  // avoid a circuliar loop. This duplicates some code but is safer.
2228  //---
2229  const char* lookup = 0;
2230
2231  // Border:
2233  if (lookup)
2234  {
2235  theBorderSize = ossimString(lookup).toDouble();
2237  ossimString(".");
2238
2240  getEntryNumber(kwl, unitPrefix.c_str());
2242  {
2245
2246  theBorderSize = unitConvert.getValue(OSSIM_DEGREES);
2248  }
2249  else // assume degrees
2250  {
2252  }
2253  }
2254
2255  // Brush color:
2257  if (lookup)
2258  {
2259  int r, g, b;
2260  std::istringstream s(lookup);
2261  s>>r>>g>>b;
2263  (ossim_uint8)g,
2264  (ossim_uint8)b);
2265  }
2266  else
2267  {
2268  lookup = kwl.find(NORMALIZED_RGB_BRUSH_COLOR_KW);
2269  if (lookup)
2270  {
2271  ossim_float64 r;
2272  ossim_float64 g;
2273  ossim_float64 b;
2274
2275  std::istringstream in(lookup);
2276  in >> r >> g >> b;
2277
2278  if ( (r >= 0.0) && (r <=1.0) )
2279  {
2280  theBrushColor.setR(static_cast<ossim_uint8>(r*255.0+0.5));
2281  }
2282  if ( (g >= 0.0) && (g <=1.0) )
2283  {
2284  theBrushColor.setG(static_cast<ossim_uint8>(g*255.0+0.5));
2285  }
2286  if ( (b >= 0.0) && (b <=1.0) )
2287  {
2288  theBrushColor.setB(static_cast<ossim_uint8>(b*255.0+0.5));
2289  }
2290  }
2291  }
2292
2293  // Fill:
2294  lookup = kwl.find(ossimKeywordNames::FILL_FLAG_KW);
2295  if (lookup)
2296  {
2297  theFillFlag = ossimString(lookup).toBool();
2298  }
2299
2300  // Pen color:
2301  lookup = kwl.find(ossimKeywordNames::PEN_COLOR_KW);
2302  if (lookup)
2303  {
2304  int r, g, b;
2305  std::istringstream s(lookup);
2306  s>>r>>g>>b;
2308  (ossim_uint8)g,
2309  (ossim_uint8)b);
2310  }
2311  else
2312  {
2313  lookup = kwl.find(NORMALIZED_RGB_PEN_COLOR_KW);
2314  if (lookup)
2315  {
2316  ossim_float64 r;
2317  ossim_float64 g;
2318  ossim_float64 b;
2319
2320  std::istringstream in(lookup);
2321  in >> r >> g >> b;
2322
2323  if ( (r >= 0.0) && (r <=1.0) )
2324  {
2325  thePenColor.setR(static_cast<ossim_uint8>(r * 255.0 + 0.5));
2326  }
2327  if ( (g >= 0.0) && (g <=1.0) )
2328  {
2329  thePenColor.setG(static_cast<ossim_uint8>(g * 255.0 + 0.5));
2330  }
2331  if ( (b >= 0.0) && (b <=1.0) )
2332  {
2333  thePenColor.setB(static_cast<ossim_uint8>(b * 255.0 + 0.5));
2334  }
2335  }
2336  }
2337
2338  // Point size:
2340  if (!lookup)
2341  {
2342  lookup = kwl.find(POINT_SIZE_KW);
2343  }
2344  if (lookup)
2345  {
2346  ossim_float64 x;
2347  ossim_float64 y;
2348
2349  std::istringstream in(lookup);
2350  in >> x >> y;
2351
2352  if ( (x > 0.0) && (y > 0.0) )
2353  {
2356  }
2357  }
2358
2359  // Thickness:
2360  lookup = kwl.find(ossimKeywordNames::THICKNESS_KW);
2361  if (lookup)
2362  {
2363  setThickness(ossimString(lookup).toInt32());
2364  }
2365
2366  // Update the feature table.
2368
2369  } // matches: if( kwl.addFile(filename) )
2370
2371  } // matches: if(filename.exists())
2372 }
2373
2375 {
2376  const char* lookup;
2377
2378  // Look for auto color flag:
2379  bool autocolors = false;
2380  lookup = ossimPreferences::instance()->
2381  findPreference(SHAPEFILE_COLORS_AUTO_KW);
2382  if (lookup)
2383  {
2384  autocolors = ossimString::toBool(ossimString(lookup));
2385  }
2386
2387  if (autocolors)
2388  {
2389  // Ensure the static index is within bounds of the array.
2390  if (currentAutoColorArrayIndex >= AUTO_COLOR_ARRAY_COUNT)
2391  {
2392  currentAutoColorArrayIndex = 0;
2393  }
2394
2395  thePenColor.setR(autoColorArray[currentAutoColorArrayIndex].r);
2396  thePenColor.setG(autoColorArray[currentAutoColorArrayIndex].g);
2397  thePenColor.setB(autoColorArray[currentAutoColorArrayIndex].b);
2398
2399  theBrushColor.setR(autoColorArray[currentAutoColorArrayIndex].r);
2400  theBrushColor.setG(autoColorArray[currentAutoColorArrayIndex].g);
2401  theBrushColor.setB(autoColorArray[currentAutoColorArrayIndex].b);
2402
2403  ++currentAutoColorArrayIndex;
2404  if (currentAutoColorArrayIndex >= AUTO_COLOR_ARRAY_COUNT)
2405  {
2406  currentAutoColorArrayIndex = 0;
2407  }
2408
2409  } // End of: if (autocolors)
2410  else
2411  {
2412  // Look for pen color.
2413  lookup = ossimPreferences::instance()->
2414  findPreference(NORMALIZED_RGB_PEN_COLOR_KW);
2415  if (lookup)
2416  {
2417  ossim_float64 r;
2418  ossim_float64 g;
2419  ossim_float64 b;
2420
2421  std::istringstream in(lookup);
2422  in >> r >> g >> b;
2423
2424  if ( (r >= 0.0) && (r <=1.0) )
2425  {
2426  thePenColor.setR(static_cast<ossim_uint8>(r * 255.0 + 0.5));
2427  }
2428  if ( (g >= 0.0) && (g <=1.0) )
2429  {
2430  thePenColor.setG(static_cast<ossim_uint8>(g * 255.0 + 0.5));
2431  }
2432  if ( (b >= 0.0) && (b <=1.0) )
2433  {
2434  thePenColor.setB(static_cast<ossim_uint8>(b * 255.0 + 0.5));
2435  }
2436  }
2437
2438  // Look for brush color.
2439  lookup = ossimPreferences::instance()->
2440  findPreference(NORMALIZED_RGB_BRUSH_COLOR_KW);
2441  if (lookup)
2442  {
2443  ossim_float64 r;
2444  ossim_float64 g;
2445  ossim_float64 b;
2446
2447  std::istringstream in(lookup);
2448  in >> r >> g >> b;
2449
2450  if ( (r >= 0.0) && (r <=1.0) )
2451  {
2452  theBrushColor.setR(static_cast<ossim_uint8>(r * 255.0 + 0.5));
2453  }
2454  if ( (g >= 0.0) && (g <=1.0) )
2455  {
2456  theBrushColor.setG(static_cast<ossim_uint8>(g * 255.0 + 0.5));
2457  }
2458  if ( (b >= 0.0) && (b <=1.0) )
2459  {
2460  theBrushColor.setB(static_cast<ossim_uint8>(b * 255.0 + 0.5));
2461  }
2462  }
2463
2464  } // End of: if (autocolors){...}else{
2465
2466  // Look for point size.
2467  lookup = ossimPreferences::instance()->
2468  findPreference(POINT_SIZE_KW);
2469  if (lookup)
2470  {
2471  ossim_float64 x;
2472  ossim_float64 y;
2473
2474  std::istringstream in(lookup);
2475  in >> x >> y;
2476
2477  if ( (x > 0.0) && (y > 0.0) )
2478  {
2481  }
2482  }
2483 }
2484
2486 {
2487  if (!theImageGeometry.valid())
2488  {
2489  return;
2490  }
2491
2494  if (!proj)
2495  {
2496  return;
2497  }
2498
2499  ossimGpt ulGpt = proj->getUlGpt();
2500  if ( ulGpt.isLatNan() || ulGpt.isLonNan() )
2501  {
2502  proj->setUlGpt( ossimGpt(theBoundingExtent.MaxY,
2503  theBoundingExtent.MinX) );
2504  }
2505
2506  if (proj->isGeographic())
2507  {
2508  ossimDpt pt = proj->getDecimalDegreesPerPixel();
2509  if( pt.hasNans() )
2510  {
2511  // roughly... 10 meters per pixel in decimal degrees.
2512  ossim_float64 d = 1.0 / 11131.49079;
2513  proj->setDecimalDegreesPerPixel(ossimDpt(d, d));
2514  }
2515
2516  }
2517  else
2518  {
2519  ossimDpt pt = proj->getMetersPerPixel();
2520  if (pt.hasNans())
2521  {
2522  proj->setMetersPerPixel(ossimDpt(10.0, 10.0));
2523  }
2524  }
2525 }
2526
2527 std::multimap<long, ossimAnnotationObject*> ossimGdalOgrVectorAnnotation::getFeatureTable()
2528 {
2529  if (theFeatureCacheTable.size() == 0)
2530  {
2531  initializeTables();
2532  }
2533  return theFeatureCacheTable;
2534 }
2535
2537 {
2538  if (entryIdx < m_layerNames.size())
2539  {
2540  m_layerName = m_layerNames[entryIdx];
2541  return open(theFilename);
2542  }
2543  return false;
2544 }
void setQuery(const ossimString &query)
void makeNan()
Definition: ossimDrect.h:388
ossim_uint32 x
virtual const ossimDpt & getDecimalDegreesPerPixel() const
Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing...
ossimObject * theObject
void loadOmdFile()
Looks for "file.omd" and loads pen, brush and point settings if present.
std::multimap< long, ossimAnnotationObject * > theFeatureCacheTable
void loadExternalGeometryFile()
Will set theViewProjection if geometry file is present with projection.
bool doubleGreater(double first, double second, double epsilon, bool orequal=false)
virtual void setPenColor(const ossimRgbVector &penColor)
void loadExternalImageGeometryFromXml()
Will set theViewProjection if xml file is present with projection.
double getValue(ossimUnitType unitType=OSSIM_METERS) const
static const char * BRUSH_COLOR_KW
ossimFilename noExtension() const
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
ossimGdalOgrVectorAnnotation(ossimImageSource *inputSource=0)
unsigned char getR() const
virtual void setWidthHeight(const ossimDpt &pt)
Sets the width and height of point.
#define CLOG
Definition: ossimTrace.h:23
ossimRefPtr< ossimImageGeometry > theImageGeometry
std::vector< ossimOgrGdalFeatureNode > theFeatureList
double lond() const
Will convert the radian measure to degrees.
Definition: ossimGpt.h:97
virtual void draw(ossimRgbImage &anImage) const
ossimRgbColor(ossim_uint8 r, ossim_uint8 g, ossim_uint8 b)
Constructor that takes an rgb.
ossimUnitType
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry() const
Returns the image geometry object associated with this tile source or NULL if non defined...
bool addFile(const char *file)
bool isLonNan() const
Definition: ossimGpt.h:140
ossim_uint32 y
virtual void transform(ossimImageGeometry *projection)
bool valid() const
Definition: ossimRefPtr.h:75
Attempts to initialize a transform and a projection given the KWL.
void loadPolygon(long id, OGRPolygon *polygon, ossimMapProjection *mapProj)
void loadPoint(long id, OGRPoint *point, ossimMapProjection *mapProj)
std::ostream & print(std::ostream &out) const
Prints contents to output stream.
void setR(unsigned char R)
const ossimDpt & ul() const
Definition: ossimDrect.h:339
double y
Definition: ossimDpt.h:165
void loadLineString(long id, OGRLineString *lineString, ossimMapProjection *mapProj)
bool doubleLess(double first, double second, double epsilon, bool orequal=false)
Numeric to string methods.
ossimOgrGdalLayerNode(const ossimDrect &bounds)
virtual bool isGeographic() const
virtual void setColor(ossim_uint8 r, ossim_uint8 g, ossim_uint8 b)
virtual void transform(ossimImageGeometry *projection)=0
const ossimIpt & ul() const
Definition: ossimIrect.h:274
ossimRgbColor()
Default constructor (green)
RTTI_DEF2(ossimGdalOgrVectorAnnotation, "ossimGdalOgrVectorAnnotation", ossimAnnotationSource, ossimViewInterface)
virtual void setDecimalDegreesPerPixel(const ossimDpt &gsd)
void loadMultiPoint(long id, OGRMultiPoint *multiPoint, ossimMapProjection *mapProj)
ossimDrect combine(const ossimDrect &rect) const
Definition: ossimDrect.h:826
double latd() const
Definition: ossimGpt.h:87
const ossimIpt & ll() const
Definition: ossimIrect.h:277
bool isLatNan() const
Definition: ossimGpt.h:139
virtual void setNumberOfBands(ossim_uint32 bands)
virtual ossimGpt inverse(const ossimDpt &projectedPoint) const =0
virtual void setBrushColor(const ossimRgbVector &brushColor)
virtual void drawAnnotations(ossimRefPtr< ossimImageData > tile)
bool intersects(const ossimDrect &rect) const
virtual void getBoundingRect(ossimDrect &rect) const =0
virtual void setUlGpt(const ossimGpt &ulGpt)
virtual void setMetersPerPixel(const ossimDpt &gsd)
const ossimDatum * datum() const
datum().
Definition: ossimGpt.h:196
void setFullRefreshBit()
void setB(unsigned char B)
ossim_int32 toInt32() const
virtual void setPolyType(ossimPolyType polyType)
double ossim_float64
void loadMultiLineString(long id, OGRMultiLineString *multiLineString, ossimMapProjection *mapProj)
ossimProjection * createProjection(const ossimFilename &filename, ossim_uint32 entryIdx) const
bool completely_within(const ossimDrect &rect) const
Definition: ossimDrect.cpp:321
virtual void setNumericType(ossimNumericPropertyType type)
ossimOgrGdalFeatureNode(long id, const ossimDrect &rect)
virtual bool setView(ossimObject *baseObject)
bool exists() const
ossim_float64 lon
Definition: ossimGpt.h:266
bool localToWorld(const ossimDpt &local_pt, ossimGpt &world_pt) const
Exposes the 3D projection from image to world coordinates.
virtual ossimFilename getFilename() const
static const char * QUERY_KW
bool toBool() const
String to numeric methods.
void loadMultiPolygon(long id, OGRMultiPolygon *multiPolygon, ossimMapProjection *mapProj)
void getFeature(vector< ossimAnnotationObject *> &featureList, long id)
container class for rgb value.
unsigned int ossim_uint32
static const char * FILL_FLAG_KW
void getDefaults()
Will set thePenColor and theBrushColor if keyword found in preferences.
Class for FGDC XML doc parsing.
double toDouble() const
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
static const char * BORDER_SIZE_KW
virtual ossimIrect getImageRectangle() const
unsigned char getB() const
const ossimIpt & lr() const
Definition: ossimIrect.h:276
virtual void setOrigin(const ossimGpt &origin)
void setGeometryBuffer(ossim_float64 distance, ossimUnitType type)
bool hasNans() const
Definition: ossimDrect.h:396
double cosd(double x)
Definition: ossimCommon.h:259
Definition: ossimDpt.h:67
Definition: ossimDrect.cpp:289
virtual const ossimGpt & getUlGpt() const
virtual ossimRgbVector getBrushColor() const
static ossimPreferences * instance()
const ossimIpt & ur() const
Definition: ossimIrect.h:275
void setG(unsigned char G)
void unref() const
decrement the reference count by one, indicating that a pointer to this object is referencing it...
bool intersects(double minX, double minY, double maxX, double maxY) const
static ossimProjectionFactoryRegistry * instance()
static const char * UNITS_KW
return status
ossimRefPtr< ossimProjection > getProjection()
Gets projection from document.
std::vector< ossimOgrGdalLayerNode * > theLayerTable
unsigned char getG() const
virtual void setThickness(ossim_uint8 thickness)
virtual ossimGpt origin() const =0
#define max(a, b)
Definition: auxiliary.h:76
void verifyViewParams()
Checks for nan scale and tie point.
void getFeatures(std::list< long > &result, const ossimIrect &rect)
void getIdList(std::list< long > &idList, const ossimDrect &aoi) const
const ossimDpt & ur() const
Definition: ossimDrect.h:340
double x
Definition: ossimDpt.h:164
const char * c_str() const
Definition: ossimString.h:396
bool empty() const
Definition: ossimString.h:411
virtual ossimObject * dup() const
Definition: ossimObject.cpp:29
void transformObjectsFromView()
Uses theViewProjection.
std::multimap< long, ossimAnnotationObject * > getFeatureTable()
static const char * PEN_COLOR_KW
ossimString ext() const
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
bool open(const ossimFilename &xmlFileName)
Open method.
Saves the transform (if any) and projection (if any) states to the KWL.
const ossimDpt & ll() const
Definition: ossimDrect.h:342
ossim_float64 lat
Definition: ossimGpt.h:265
bool toOssimKwl(const ossimString &wktString, ossimKeywordlist &kwl, const char *prefix=NULL) const
std::basic_istringstream< char > istringstream
Class for char input memory streams.
Definition: ossimIosFwd.h:32
static const char * POINT_WIDTH_HEIGHT_KW
void setCurrentImageData(ossimRefPtr< ossimImageData > &imageData)
Allows you to change the image data that this RgbImage object operates on.
virtual ossimDpt getMetersPerPixel() const
ossimFilename & setExtension(const ossimString &e)
Sets the extension of a file name.
virtual void setFillFlag(bool flag)
Sets the fill flag.
float distance(double lat1, double lon1, double lat2, double lon2, int units)
static ossimUnitTypeLut * instance()
Returns the static instance of an ossimUnitTypeLut object.
ossimProjection * createProjFromReference(OGRSpatialReference *reference) const
const ossimDpt & lr() const
Definition: ossimDrect.h:341
std::vector< ossimString > m_layerNames
static const char * FILENAME_KW
static const char * THICKNESS_KW
Prints data members to stream.
void initializeBoundingRec(vector< ossimGpt > points)
void stretchOut()
Definition: ossimDrect.cpp:379
unsigned char ossim_uint8
bool setCurrentEntry(ossim_uint32 entryIdx)
std::basic_ostream< char > ostream
Base class for char output streams.
Definition: ossimIosFwd.h:23
void setCacheRefreshBit()
virtual ossimRgbVector getPenColor() const
#define min(a, b)
Definition: auxiliary.h:75
int ossim_int32
virtual void setThickness(ossim_int32 thickness)
