Public Member Functions | Private Member Functions | Private Attributes | Friends | List of all members
ossimHdf5ImageDataset Class Reference
Class encapsulates a HDF5 Data set that can be loaded as an image. More...
#include <ossimHdf5ImageDataset.h>
Inheritance diagram for ossimHdf5ImageDataset:
ossimReferenced
 ossimHdf5ImageDataset (ossimHdf5ImageHandler *owner=0)
 default constructor More...
 ossimHdf5ImageDataset (const ossimHdf5ImageDataset &obj)
 copy constructor More...
 ~ossimHdf5ImageDataset ()
 destructor More...
void close ()
 Calls H5::DataSet::close then deletes data set. More...
const ossimHdf5ImageDatasetoperator= (const ossimHdf5ImageDataset &rhs)
bool initialize (const H5::DataSet &dataset)
 Opens datasetName and initializes all data members on success. More...
const H5::DataSet * getDataset () const
 Get const pointer to dataset. More...
 Get pointer to dataset. More...
std::string getName () const
ossimScalarType getScalarType () const
ossim_uint32 getNumberOfBands () const
ossim_uint32 getNumberOfLines () const
ossim_uint32 getNumberOfSamples () const
bool getSwapFlag () const
const ossimIptgetSubImageOffset () const
const ossimIrectgetValidImageRect () const
double getMaxPixelValue (ossim_uint32 band=0) const
double getMinPixelValue (ossim_uint32 band=0) const
bool isMinPixelSet () const
bool isMaxPixelSet () const
void getTileBuf (void *buffer, const ossimIrect &rect, ossim_uint32 band, bool scale=true)
 Method to grab a tile(rectangle) from image. More...
std::ostream & print (std::ostream &out) const
 print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
bool determineExtents ()
 Returns true if datasets's endianness differs from this platform. More...
bool scanForValidImageRect ()
bool determineScalarType ()
bool scanForMinMax ()
Private Attributes
ossimRefPtr< ossimHdf5ImageHandlerm_handler
ossimRefPtr< ossimHdf5m_hdf5
H5::DataSet m_dataset
H5::DataSpace m_dataSpace
ossimScalarType m_scalar
ossim_uint32 m_bands
ossim_uint32 m_lines
ossim_uint32 m_samples
ossimEndianm_endian
std::vector< ossim_float32m_minValue
std::vector< ossim_float32m_maxValue
ossimIrect m_validRect
 H5 data can have null rows on the front or end. More...
Friends
OSSIMDLLEXPORT std::ostream & operator<< (std::ostream &out, const ossimHdf5ImageDataset &obj)
Additional Inherited Members
virtual ~ossimReferenced ()
Detailed Description
Definition at line 35 of file ossimHdf5ImageDataset.h.
◆ ossimHdf5ImageDataset() [1/2]
ossimHdf5ImageDataset::ossimHdf5ImageDataset ( ossimHdf5ImageHandler owner = 0)
default constructor
Definition at line 32 of file ossimHdf5ImageDataset.cpp.
References m_hdf5, ossimHdf5ImageHandler::m_hdf5, m_validRect, and ossimIrect::makeNan().
33 : m_handler(owner),
34  m_dataset(0),
36  m_bands(1),
37  m_lines(0),
38  m_samples(0),
39  m_endian(0)
40 {
41  if (owner)
42  m_hdf5 = owner->m_hdf5;
43
45 }
ossimRefPtr< ossimHdf5 > m_hdf5
void makeNan()
Definition: ossimIrect.h:329
ossimRefPtr< ossimHdf5ImageHandler > m_handler
◆ ossimHdf5ImageDataset() [2/2]
ossimHdf5ImageDataset::ossimHdf5ImageDataset ( const ossimHdf5ImageDataset obj)
copy constructor
Definition at line 47 of file ossimHdf5ImageDataset.cpp.
48 : m_handler(obj.m_handler),
49  m_hdf5 (obj.m_hdf5),
50  m_dataset(obj.m_dataset),
51  m_scalar(obj.m_scalar),
52  m_bands(obj.m_bands),
53  m_lines(obj.m_lines),
54  m_samples(obj.m_samples),
55  m_endian( obj.m_endian ? new ossimEndian() : 0 ),
57 {
58 }
◆ ~ossimHdf5ImageDataset()
ossimHdf5ImageDataset::~ossimHdf5ImageDataset ( )
destructor
Definition at line 60 of file ossimHdf5ImageDataset.cpp.
References close().
61 {
62  close();
63 }
void close()
Member Function Documentation
◆ close()
void ossimHdf5ImageDataset::close ( )
Definition at line 493 of file ossimHdf5ImageDataset.cpp.
References m_dataset, and m_endian.
Referenced by initialize(), and ~ossimHdf5ImageDataset().
494 {
495  m_dataset.close();
496  delete m_endian;
497 }
◆ determineExtents()
bool ossimHdf5ImageDataset::determineExtents ( )
private
Definition at line 97 of file ossimHdf5ImageDataset.cpp.
References m_bands, m_dataset, m_lines, m_samples, m_validRect, ossimNotify(), and ossimNotifyLevel_WARN.
Referenced by initialize().
98 {
99  try
100  {
101  // Find the valid image rect. dataset may have null padding:
102  H5::DataSpace imageDataspace = m_dataset.getSpace();
103  int rank = imageDataspace.getSimpleExtentNdims();
104  if (rank < 2)
105  return false;
106
107  // Get the extents. Assuming dimensions are same for lat lon dataset.
108  std::vector<hsize_t> inputSize(rank);
109  imageDataspace.getSimpleExtentDims( &inputSize.front(), 0 );
110  m_lines = inputSize[0];
111  m_samples = inputSize[1];
113  if ( rank >= 3 )
114  m_bands = inputSize[2];
115  else
116  m_bands = 1;
117
118  if ( (m_lines == 0) || (m_samples == 0) )
119  return false;
120  }
121  catch( const H5::Exception& e )
122  {
123  std::cout << "ERROR:" << e.getDetailMsg()<< " \n";
124  ossimNotify(ossimNotifyLevel_WARN)<<e.getDetailMsg();
125  return false;
126  }
127
128  return true;
129 }
◆ determineScalarType()
bool ossimHdf5ImageDataset::determineScalarType ( )
private
Definition at line 519 of file ossimHdf5ImageDataset.cpp.
References ossim::byteOrder(), ossimHdf5::getByteOrder(), m_dataset, m_endian, m_hdf5, m_scalar, OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_SCALAR_UNKNOWN, OSSIM_SINT16, OSSIM_SINT32, OSSIM_SINT64, OSSIM_SINT8, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT64, OSSIM_UINT8, ossimNotify(), and ossimNotifyLevel_WARN.
520 {
522
523  try
524  {
525  H5T_class_t typeClass = m_dataset.getTypeClass();
526  if ( ( typeClass != H5T_INTEGER ) && ( typeClass != H5T_FLOAT ) )
527  return false;
528
529  hid_t mem_type_id = H5Dget_type( m_dataset.getId() );
530  if( mem_type_id < 0 )
531  return false;
532
533  hid_t native_type = H5Tget_native_type(mem_type_id, H5T_DIR_DEFAULT);
534  if( H5Tequal(H5T_NATIVE_CHAR, native_type) )
536  else if ( H5Tequal( H5T_NATIVE_UCHAR, native_type) )
538  else if( H5Tequal( H5T_NATIVE_SHORT, native_type) )
540  else if(H5Tequal(H5T_NATIVE_USHORT, native_type))
542  else if(H5Tequal( H5T_NATIVE_INT, native_type))
544  else if(H5Tequal( H5T_NATIVE_UINT, native_type ) )
546  else if(H5Tequal( H5T_NATIVE_LONG, native_type))
548  else if(H5Tequal( H5T_NATIVE_ULONG, native_type))
550  else if(H5Tequal( H5T_NATIVE_LLONG, native_type))
552  else if(H5Tequal( H5T_NATIVE_ULLONG, native_type))
554  else if(H5Tequal( H5T_NATIVE_FLOAT, native_type))
556  else if(H5Tequal( H5T_NATIVE_DOUBLE, native_type))
558  // See if we need to swap bytes:
560  m_endian = new ossimEndian();
561  }
562  catch( const H5::Exception& e )
563  {
564  ossimNotify(ossimNotifyLevel_WARN)<<e.getDetailMsg();
565  return false;
566  }
567
568  return true;
569 }
8 bit signed integer
64 bit floating point
16 bit unsigned integer
16 bit signed integer
OSSIM_DLL ossimByteOrder byteOrder()
Definition: ossimCommon.cpp:54
32 bit floating point
32 bit unsigned integer
static ossimByteOrder getByteOrder(const H5::AbstractDs *obj)
Definition: ossimHdf5.cpp:337
64 bit signed integer
32 bit signed integer
64 bit unsigned integer
8 bit unsigned integer
◆ getDataset() [1/2]
const H5::DataSet * ossimHdf5ImageDataset::getDataset ( ) const
This can be null if not open.
Returns
Definition at line 499 of file ossimHdf5ImageDataset.cpp.
References m_dataset.
500 {
501  return &m_dataset;
502 }
◆ getDataset() [2/2]
Returns
pointer to dataset.
Definition at line 504 of file ossimHdf5ImageDataset.cpp.
505 {
506  return &m_dataset;
507 }
◆ getMaxPixelValue()
double ossimHdf5ImageDataset::getMaxPixelValue ( ossim_uint32  band = 0) const
Definition at line 780 of file ossimHdf5ImageDataset.cpp.
References ossim::defaultMax(), m_maxValue, and m_scalar.
781 {
782  if (band < m_maxValue.size())
783  return m_maxValue[band];
784
785  return ossim::defaultMax(m_scalar);
786 }
std::vector< ossim_float32 > m_maxValue
OSSIM_DLL double defaultMax(ossimScalarType scalarType)
◆ getMinPixelValue()
double ossimHdf5ImageDataset::getMinPixelValue ( ossim_uint32  band = 0) const
Definition at line 788 of file ossimHdf5ImageDataset.cpp.
References ossim::defaultMin(), m_minValue, and m_scalar.
789 {
790  if (band < m_minValue.size())
791  return m_minValue[band];
792  return ossim::defaultMin(m_scalar);
793 }
OSSIM_DLL double defaultMin(ossimScalarType scalarType)
Definition: ossimCommon.cpp:73
std::vector< ossim_float32 > m_minValue
◆ getName()
string ossimHdf5ImageDataset::getName ( ) const
Returns
The dataset name. This is the full path used for open.
Definition at line 509 of file ossimHdf5ImageDataset.cpp.
510 {
511  return m_dataset.getObjName();
512 }
◆ getNumberOfBands()
ossim_uint32 ossimHdf5ImageDataset::getNumberOfBands ( ) const
Returns
the number of .
Definition at line 571 of file ossimHdf5ImageDataset.cpp.
References m_bands.
572 {
573  return m_bands;
574 }
◆ getNumberOfLines()
ossim_uint32 ossimHdf5ImageDataset::getNumberOfLines ( ) const
Returns
The number of lines.
Definition at line 576 of file ossimHdf5ImageDataset.cpp.
References ossimIrect::height(), and m_validRect.
577 {
578  return m_validRect.height();
579 }
ossim_uint32 height() const
Definition: ossimIrect.h:487
◆ getNumberOfSamples()
ossim_uint32 ossimHdf5ImageDataset::getNumberOfSamples ( ) const
Returns
The number of samples.
Definition at line 581 of file ossimHdf5ImageDataset.cpp.
References m_validRect, and ossimIrect::width().
582 {
583  return m_validRect.width();
584 }
ossim_uint32 width() const
Definition: ossimIrect.h:500
◆ getScalarType()
ossimScalarType ossimHdf5ImageDataset::getScalarType ( ) const
Returns
The output scalar type.
Definition at line 514 of file ossimHdf5ImageDataset.cpp.
References m_scalar.
Referenced by getTileBuf(), scanForMinMax(), and scanForValidImageRect().
515 {
516  return m_scalar;
517 }
◆ getSubImageOffset()
const ossimIpt & ossimHdf5ImageDataset::getSubImageOffset ( ) const
Definition at line 591 of file ossimHdf5ImageDataset.cpp.
References m_validRect, and ossimIrect::ul().
592 {
593  return m_validRect.ul();
594 }
const ossimIpt & ul() const
Definition: ossimIrect.h:274
◆ getSwapFlag()
bool ossimHdf5ImageDataset::getSwapFlag ( ) const
Returns
The swap flag.
Definition at line 586 of file ossimHdf5ImageDataset.cpp.
References m_endian.
587 {
588  return (m_endian ? true: false);
589 }
◆ getTileBuf()
void ossimHdf5ImageDataset::getTileBuf ( void *  buffer,
const ossimIrect rect,
ossim_uint32  band,
bool  scale = true
Parameters
bufferBuffer for data for this method to copy data to. Should be the size of rect * bytes_per_pixel for scalar type.
rectThe zero based rectangle to grab. Rectangle is relative to any sub image offset. E.g. A request for 0,0 is the upper left corner of the valid image rect.
scaleIf true, uses min and max to stretch the data to a UINT16 range.
Definition at line 601 of file ossimHdf5ImageDataset.cpp.
References ossim::almostEqual(), ossimIrect::area(), ossimHdf5ImageHandler::getNullPixelValue(), getScalarType(), ossimIrect::height(), m_bands, m_dataset, m_endian, m_handler, m_maxValue, m_minValue, m_scalar, OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_SINT16, OSSIM_SINT32, OSSIM_SINT8, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, ossimNotify(), ossimNotifyLevel_WARN, ossimEndian::swap(), ossimIrect::ul(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
Referenced by scanForMinMax().
603 {
604  static const char MODULE[] = "ossimHdf5ImageDataset::getTileBuf";
605
606  if (band >= m_bands)
607  return;
608
609  // Shift rectangle by the sub image offse (if any) from the m_validRect.
610  // NOTE: The rect coming in seems to be alreadyt in image space so no need to offset (OLK 09/2016)
611  ossimIrect irect = rect;// + m_validRect.ul();
612
613  try
614  {
615  // Turn off the auto-printing when failure occurs so that we can
616  // handle the errors appropriately
617  // H5::Exception::dontPrint();
618
619  // Get dataspace of the dataset.
620  H5::DataSpace imageDataSpace = m_dataset.getSpace();
621
622  // Number of dimensions of the input dataspace.:
623  const ossim_int32 IN_DIM_COUNT = imageDataSpace.getSimpleExtentNdims();
624
625  // Native type:
626  H5::DataType dataType = m_dataset.getDataType();
627
628  std::vector<hsize_t> inputCount(IN_DIM_COUNT);
629  std::vector<hsize_t> inputOffset(IN_DIM_COUNT);
630
631  if ( IN_DIM_COUNT == 2 )
632  {
633  inputOffset[0] = irect.ul().y;
634  inputOffset[1] = irect.ul().x;
635
636  inputCount[0] = irect.height();
637  inputCount[1] = irect.width();
638  }
639  else
640  {
641  inputOffset[0] = band;
642  inputOffset[1] = irect.ul().y;
643  inputOffset[2] = irect.ul().x;
644
645  inputCount[0] = 1;
646  inputCount[1] = irect.height();
647  inputCount[2] = irect.width();
648  }
649
650  // Define hyperslab in the dataset; implicitly giving strike strike and block NULL.
651  imageDataSpace.selectHyperslab( H5S_SELECT_SET,
652  &inputCount.front(),
653  &inputOffset.front() );
654
655  // Output dataspace dimensions.
656  const ossim_int32 OUT_DIM_COUNT = 3;
657  std::vector<hsize_t> outputCount(OUT_DIM_COUNT);
658  outputCount[0] = 1; // single band
659  outputCount[1] = irect.height(); // lines
660  outputCount[2] = irect.width(); // samples
661
662  // Output dataspace offset.
663  std::vector<hsize_t> outputOffset(OUT_DIM_COUNT);
664  outputOffset[0] = band;
665  outputOffset[1] = 0;
666  outputOffset[2] = 0;
667
668  // Output dataspace.
669  H5::DataSpace bufferDataSpace( OUT_DIM_COUNT, &outputCount.front());
670  bufferDataSpace.selectHyperslab( H5S_SELECT_SET,
671  &outputCount.front(),
672  &outputOffset.front() );
673
674  // Read data from file into the buffer.
675  m_dataset.read( buffer, dataType, bufferDataSpace, imageDataSpace );
676
677  if ( m_endian )
678  {
679  // If the m_endian pointer is initialized(not zero) swap the bytes.
680  m_endian->swap( m_scalar, buffer, irect.area() );
681  }
682
683
684  //#define NEVER
685 #ifdef NEVER
686  if (scale)
687  {
688  const ossim_float32 TOLERANCE = 0.1e-9; // For ossim::almostEqual()
689  // Scale the data:
690 #if 1
691  // Assumes float32 datatype:
692  double gain = 1.0/( m_maxValue[band] - m_minValue[band] );
693  ossim_float32 null_value = m_handler->getNullPixelValue(band);
694  ossim_float32 value;
695  for (ossim_uint32 i=0; i<irect.area(); ++i)
696  {
697  value = ((ossim_float32*)buffer)[i];
698
699  if (!ossim::almostEqual(value,null_value, TOLERANCE))
700  {
701  value = gain*(value - m_minValue[band]);
702  ((ossim_float32*)buffer)[i] =value;
703  }
704  }
705 #else
706  // Does not assume float32:
707  ossimScalarType scalarType = getScalarType();
708  double null_value = m_handler->getNullPixelValue(band);
709  for (ossim_uint32 i=0; i<irect.area(); ++i)
710  {
711  switch (scalarType)
712  {
713  case OSSIM_FLOAT32:
714  if (!ossim::almostEqual(((ossim_float32*)buffer)[i], (ossim_float32)null_value))
715  ((ossim_float32*)buffer)[i] =
716  (ossim_float32)(gain*(((ossim_float32*)buffer)[i] - m_minValue[band]));
717  break;
718  case OSSIM_FLOAT64:
719  if (!ossim::almostEqual(((ossim_float64*)buffer)[i], null_value))
720  ((ossim_float64*)buffer)[i] =
721  (ossim_float64)(gain*(((ossim_float64*)buffer)[i] - m_minValue[band]));
722  break;
723  case OSSIM_UINT8:
724  if (((ossim_uint8*)buffer)[i] != (ossim_uint8)null_value)
725  ((ossim_uint8*)buffer)[i] =
726  (ossim_uint8)(gain*(((ossim_uint8*)buffer)[i] - m_minValue[band]));
727  break;
728  case OSSIM_SINT8:
729  if (((ossim_sint8*)buffer)[i] != (ossim_sint8)null_value)
730  ((ossim_sint8*)buffer)[i] =
731  (ossim_sint8)(gain*(((ossim_sint8*)buffer)[i] - m_minValue[band]));
732  break;
733  case OSSIM_UINT16:
734  if (((ossim_uint16*)buffer)[i] != (ossim_uint16)null_value)
735  ((ossim_uint16*)buffer)[i] =
736  (ossim_uint16)(gain*(((ossim_uint16*)buffer)[i] - m_minValue[band]));
737  break;
738  case OSSIM_SINT16:
739  if (((ossim_sint16*)buffer)[i] != (ossim_sint16)null_value)
740  ((ossim_sint16*)buffer)[i] =
741  (ossim_sint16)(gain*(((ossim_sint16*)buffer)[i] - m_minValue[band]));
742  break;
743  case OSSIM_UINT32:
744  if (((ossim_uint32*)buffer)[i] != (ossim_uint32)null_value)
745  ((ossim_uint32*)buffer)[i] =
746  (ossim_uint32)(gain*(((ossim_uint32*)buffer)[i] - m_minValue[band]));
747  break;
748  case OSSIM_SINT32:
749  if (((ossim_sint32*)buffer)[i] != (ossim_sint32)null_value)
750  ((ossim_sint32*)buffer)[i] =
751  (ossim_sint32)(gain*(((ossim_sint32*)buffer)[i] - m_minValue[band]));
752  break;
753  default:
754  break;
755  }
756  }
757 #endif
758  }
759 #endif
760
761  // Cleanup:
762  bufferDataSpace.close();
763  dataType.close();
764  imageDataSpace.close();
765  }
766  catch( const H5::Exception& error )
767  {
768  ossimNotify(ossimNotifyLevel_WARN) << MODULE << " caught H5 Exception!" << std::endl;
769  error.printError();
770  }
771
772  catch( ... )
773  {
774  ossimNotify(ossimNotifyLevel_WARN)<< MODULE << " caught unknown exception !" << std::endl;
775  }
776
777 } // End: ossimH5ImageDataset::getTileBuf
float ossim_float32
bool almostEqual(T x, T y, T tolerance=FLT_EPSILON)
Definition: ossimCommon.h:53
signed char ossim_sint8
unsigned short ossim_uint16
double ossim_float64
signed short ossim_sint16
unsigned int ossim_uint32
signed int ossim_sint32
ossimScalarType
ossim_int32 y
Definition: ossimIpt.h:142
ossim_uint32 area() const
Definition: ossimIrect.h:396
ossimScalarType getScalarType() const
ossim_int32 x
Definition: ossimIpt.h:141
void swap(ossim_sint8 &)
Definition: ossimEndian.h:26
unsigned char ossim_uint8
int ossim_int32
◆ getValidImageRect()
const ossimIrect & ossimHdf5ImageDataset::getValidImageRect ( ) const
Definition at line 596 of file ossimHdf5ImageDataset.cpp.
References m_validRect.
597 {
598  return m_validRect;
599 }
◆ initialize()
bool ossimHdf5ImageDataset::initialize ( const H5::DataSet &  dataset)
Returns
Definition at line 81 of file ossimHdf5ImageDataset.cpp.
References close(), determineExtents(), determineScalarType(), and m_dataset.
82 {
83  close();
84
85  m_dataset = dataset;
86
88
89 // if (!determineExtents() || !scanForValidImageRect() || !scanForMinMax())
90  if (!determineExtents())// || !scanForMinMax())
91  return false;
92
93  return true;
94
95 } // End: ossimH5ImageDataset::initialize
bool determineExtents()
Returns true if datasets&#39;s endianness differs from this platform.
void close()
◆ isMaxPixelSet()
bool ossimHdf5ImageDataset::isMaxPixelSet ( ) const
Definition at line 800 of file ossimHdf5ImageDataset.cpp.
References m_maxValue.
801 {
802  return (!m_maxValue.empty());
803 }
◆ isMinPixelSet()
bool ossimHdf5ImageDataset::isMinPixelSet ( ) const
Definition at line 795 of file ossimHdf5ImageDataset.cpp.
References m_minValue.
796 {
797  return (!m_minValue.empty());
798 }
◆ operator=()
const ossimHdf5ImageDataset & ossimHdf5ImageDataset::operator= ( const ossimHdf5ImageDataset rhs)
Definition at line 65 of file ossimHdf5ImageDataset.cpp.
References m_bands, m_dataset, m_dataSpace, m_endian, m_lines, m_samples, m_scalar, and m_validRect.
66 {
67  if ( this != &rhs )
68  {
69  m_dataset = rhs.m_dataset;
71  m_scalar = rhs.m_scalar;
72  m_bands = rhs.m_bands;
73  m_lines = rhs.m_lines;
74  m_samples = rhs.m_samples;
76  m_endian = ( rhs.m_endian ? new ossimEndian() : 0 );
77  }
78  return *this;
79 }
◆ print()
std::ostream & ossimHdf5ImageDataset::print ( std::ostream &  out) const
print method.
Returns
std::ostream&
Definition at line 805 of file ossimHdf5ImageDataset.cpp.
References ossimLookUpTable::getEntryString(), ossimScalarTypeLut::instance(), m_bands, m_dataset, m_endian, m_lines, m_samples, m_scalar, m_validRect, ossimNotify(), and ossimNotifyLevel_WARN.
Referenced by operator<<().
806 {
807  try
808  {
809  out << "ossimH5ImageDataset: "
810  << "\nH5::DataSet::id: " << m_dataset.getId()
811  << "\nname: " << m_dataset.getObjName()
812  << "\nscalar: " << ossimScalarTypeLut::instance()->getEntryString( m_scalar )
813  << "\nbands: " << m_bands
814  << "\nlines: " << m_lines
815  << "\nsamples: " << m_samples
816  << "\nvalid rect: " << m_validRect
817  << "\nswap_flage: " << (m_endian?"true":"false")
818  << std::endl;
819  }
820  catch( const H5::Exception& e )
821  {
822  ossimNotify(ossimNotifyLevel_WARN)<<e.getDetailMsg();
823  }
824
825  return out;
826 }
virtual ossimString getEntryString(ossim_int32 entry_number) const
static ossimScalarTypeLut * instance()
Returns the static instance of an ossimScalarTypeLut object.
◆ scanForMinMax()
bool ossimHdf5ImageDataset::scanForMinMax ( )
private
Definition at line 401 of file ossimHdf5ImageDataset.cpp.
References ossimHdf5ImageHandler::getNullPixelValue(), getScalarType(), getTileBuf(), ossimIrect::lr(), m_bands, m_handler, m_maxValue, m_minValue, m_validRect, OSSIM_DEFAULT_MAX_PIX_FLOAT, OSSIM_DEFAULT_MIN_PIX_FLOAT, OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_SCALAR_UNKNOWN, OSSIM_SINT16, OSSIM_SINT32, OSSIM_SINT64, OSSIM_SINT8, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT64, OSSIM_UINT8, ossim::scalarSizeInBytes(), ossimIrect::ul(), ossimIrect::ur(), ossimIrect::width(), x, and y.
402 {
403  // Create buffer to hold the clip rect for a single band.
404  ossimScalarType scalarType = getScalarType();
405
406  if((scalarType == OSSIM_SCALAR_UNKNOWN)||
407  (scalarType == OSSIM_UINT64) ||
408  (scalarType == OSSIM_SINT64)
409  )
410  {
411  return false;
412  }
413  // if ((scalarType != OSSIM_FLOAT32) && (scalarType != OSSIM_FLOAT64) &&
414  // (scalarType != OSSIM_UINT32) && (scalarType != OSSIM_SINT32) &&
415  // (scalarType != OSSIM_UINT8) && (scalarType != OSSIM_SINT8) &&
416  // (scalarType != OSSIM_UINT16) && (scalarType != OSSIM_SINT16))
417  // {
418  // return false;
419  // }
420
421  ossim_uint32 bufSizeInBytes = m_validRect.width()*ossim::scalarSizeInBytes(scalarType);
422  vector<char> dataBuffer(bufSizeInBytes);
423
424  // Get the extents. Assuming dimensions are same for lat lon dataset.
425  ossimIpt ulIpt (m_validRect.ul());
426  ossimIpt lrIpt (m_validRect.lr());
427  const ossim_float32 nullpix = m_handler->getNullPixelValue();
428  ossim_float32 epsilon = (ossim_float32)0.1e-9; // For ossim::almostEqual()
429
430  if (nullpix == 0.0)
431  epsilon = 0;
432
433  m_minValue.clear();
434  m_maxValue.clear();
435
436  ossimIrect clipRect (m_validRect.ul(), m_validRect.ur());
437  for (ossim_uint32 band=0; band<m_bands; ++band)
438  {
441
442  for (int y=ulIpt.y; y<=lrIpt.y; y++)
443  {
444  clipRect.set_uly(y);
445  clipRect.set_lry(y);
446
447  getTileBuf(&dataBuffer.front(), clipRect, band, false);
448
449  // Scan and fix non-standard null value:
450  ossim_float32 value = 0;
451  for ( ossim_uint32 x=0; x<m_validRect.width(); ++x )
452  {
453  switch (scalarType)
454  {
455  case OSSIM_FLOAT32:
456  value = ((ossim_float32*)&dataBuffer.front())[x];
457  break;
458  case OSSIM_FLOAT64:
459  value = (ossim_float32) ((ossim_float64*)&dataBuffer.front())[x];
460  break;
461  case OSSIM_UINT8:
462  case OSSIM_SINT8:
463  value = (ossim_float32) ((char*)&dataBuffer.front())[x];
464  break;
465  case OSSIM_UINT16:
466  case OSSIM_SINT16:
467  value = (ossim_float32) ((ossim_int16*)&dataBuffer.front())[x];
468  break;
469  case OSSIM_UINT32:
470  case OSSIM_SINT32:
471  value = (ossim_float32) ((ossim_int32*)&dataBuffer.front())[x];
472  break;
473  default:
474  break;
475  }
476
477  if (ossim::almostEqual<ossim_float32>(value, nullpix, epsilon))
478  continue;
479  if (value > m_maxValue[band])
480  m_maxValue[band] = value;
481  if (value < m_minValue[band])
482  m_minValue[band] = value;
483  }
484  }
485  }
486
487  //cout<<"ossimHdf5ImageDataset:"<<__LINE__<<"\n\tminValue="<<m_minValue[0]<<
488  // "\n\tmaxValue="<<m_maxValue[0]<<"\n\tnullValue="<<m_handler->getNullPixelValue()<<endl; // TODO REMOVE
489
490  return true;
491 }
ossim_uint32 x
ossim_uint32 y
float ossim_float32
void getTileBuf(void *buffer, const ossimIrect &rect, ossim_uint32 band, bool scale=true)
OSSIM_DLL ossim_uint32 scalarSizeInBytes(ossimScalarType scalarType)
const ossimIpt & lr() const
Definition: ossimIrect.h:276
const ossimIpt & ur() const
Definition: ossimIrect.h:275
ossimScalarType
#define OSSIM_DEFAULT_MAX_PIX_FLOAT
short ossim_int16
#define OSSIM_DEFAULT_MIN_PIX_FLOAT
int ossim_int32
◆ scanForValidImageRect()
bool ossimHdf5ImageDataset::scanForValidImageRect ( )
private
Definition at line 131 of file ossimHdf5ImageDataset.cpp.
References ossim::almostEqual(), ossimLookUpTable::getEntryString(), getScalarType(), ossimScalarTypeLut::instance(), ossimIrect::lr(), m_dataset, m_endian, m_lines, m_samples, m_validRect, OSSIM_FLOAT32, ossimNotify(), ossimNotifyLevel_WARN, ossimIrect::set_lr(), ossimIrect::set_ul(), ossimEndian::swap(), ossimIrect::ul(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
132 {
133 #if 0
134  // THIS IS ORIGINAL BURKEN CODE -- SEEMS TO SCAN TOO MUCH BUT MAYBE NEEDED IN POLAR PROJECTION
135  // CASES SO KEEPING AROUND (OLK 09/2016)
136  bool result = false;
137  H5::DataSpace imageDataspace = m_dataset.getSpace();
138  const ossim_int32 IN_DIM_COUNT = imageDataspace.getSimpleExtentNdims();
139
140  if ( IN_DIM_COUNT == 2 )
141  {
142  // Get the extents. Assuming dimensions are same for lat lon dataset.
143  std::vector<hsize_t> dimsOut(IN_DIM_COUNT);
144  imageDataspace.getSimpleExtentDims( &dimsOut.front(), 0 );
145
146  if ( dimsOut[0] && dimsOut[1] )
147  {
148
149  //---
150  // Capture the rectangle:
151  // dimsOut[0] is height, dimsOut[1] is width:
152  //---
153  m_validRect = ossimIrect( 0, 0,
154  static_cast<ossim_int32>( dimsOut[1]-1 ),
155  static_cast<ossim_int32>( dimsOut[0]-1 ) );
156
157  const ossim_int32 WIDTH = m_validRect.width();
158
159  std::vector<hsize_t> inputCount(IN_DIM_COUNT);
160  std::vector<hsize_t> inputOffset(IN_DIM_COUNT);
161
162  inputOffset[0] = 0;
163  inputOffset[1] = 0;
164
165  inputCount[0] = 1;
166  inputCount[1] = WIDTH;
167
168  // Output dataspace dimensions.
169  const ossim_int32 OUT_DIM_COUNT = 3;
170  std::vector<hsize_t> outputCount(OUT_DIM_COUNT);
171  outputCount[0] = 1; // single band
172  outputCount[1] = 1; // single line
173  outputCount[2] = WIDTH; // whole line
174
175  // Output dataspace offset.
176  std::vector<hsize_t> outputOffset(OUT_DIM_COUNT);
177  outputOffset[0] = 0;
178  outputOffset[1] = 0;
179  outputOffset[2] = 0;
180
181  ossimScalarType scalar = getScalarType();
182  if ( scalar == OSSIM_FLOAT32 )
183  {
184  // Native type:
185  H5::DataType datatype = m_dataset.getDataType();
186
187  // Output dataspace always the same one line.
188  H5::DataSpace bufferDataSpace( OUT_DIM_COUNT, &outputCount.front());
189  bufferDataSpace.selectHyperslab( H5S_SELECT_SET,
190  &outputCount.front(),
191  &outputOffset.front() );
192
193  //---
194  // Dataset sample has NULL lines at the end so scan for valid rect.
195  // Use "<= -999" for test as per NOAA as it seems the NULL value is
196  // fuzzy. e.g. -999.3.
197  //---
198  const ossim_float32 NULL_VALUE = -999.0;
199
200  //---
201  // VIIRS Radiance data has a -1.5e-9 in the first column.
202  // Treat this as a null.
203  //---
204  ossimString name = m_dataset.getObjName();
205  const ossim_float32 NULL_VALUE2 = ( name == "/All_Data/VIIRS-DNB-SDR_All/Radiance" )
206  ? -1.5e-9 : NULL_VALUE;
207  const ossim_float32 TOLERANCE = 0.1e-9; // For ossim::almostEqual()
208
209  // Hold one line:
210  std::vector<ossim_float32> values( WIDTH );
211
212  // Find the ul pixel:
213  ossimIpt ulIpt = m_validRect.ul();
214  bool found = false;
215
216  // Line loop to find upper left pixel:
217  while ( ulIpt.y <= m_validRect.lr().y )
218  {
219  inputOffset[0] = static_cast<hsize_t>(ulIpt.y);
220  imageDataspace.selectHyperslab( H5S_SELECT_SET,
221  &inputCount.front(),
222  &inputOffset.front() );
223
224  // Read data from file into the buffer.
225  m_dataset.read( (void*)&values.front(), datatype, bufferDataSpace, imageDataspace );
226
227  if ( m_endian )
228  {
229  // If the endian pointer is initialized(not zero) swap the bytes.
230  m_endian->swap( scalar, (void*)&values.front(), WIDTH );
231  }
232
233  // Sample loop:
234  ulIpt.x = m_validRect.ul().x;
235  ossim_int32 index = 0;
236  while ( ulIpt.x <= m_validRect.lr().x )
237  {
238  if ( !ossim::almostEqual(values[index], NULL_VALUE2, TOLERANCE) &&
239  ( values[index] > NULL_VALUE ) )
240  {
241  found = true; // Found valid pixel.
242  break;
243  }
244  ++ulIpt.x;
245  ++index;
246
247  } // End: sample loop
248
249  if ( found )
250  {
251  break;
252  }
253
254  ++ulIpt.y;
255
256  } // End line loop to find ul pixel:
257
258  // Find the lower right pixel:
259  ossimIpt lrIpt = m_validRect.lr();
260  found = false;
261
262  // Line loop to find last pixel:
263  while ( lrIpt.y >= m_validRect.ul().y )
264  {
265  inputOffset[0] = static_cast<hsize_t>(lrIpt.y);
266  imageDataspace.selectHyperslab( H5S_SELECT_SET,
267  &inputCount.front(),
268  &inputOffset.front() );
269
270  // Read data from file into the buffer.
271  m_dataset.read( (void*)&values.front(), datatype, bufferDataSpace, imageDataspace );
272
273  if ( m_endian )
274  {
275  // If the endian pointer is initialized(not zero) swap the bytes.
276  m_endian->swap( scalar, (void*)&values.front(), WIDTH );
277  }
278
279  // Sample loop:
280  lrIpt.x = m_validRect.lr().x;
281  ossim_int32 index = WIDTH-1;
282
283  while ( lrIpt.x >= m_validRect.ul().x )
284  {
285  if ( !ossim::almostEqual(values[index], NULL_VALUE2, TOLERANCE) &&
286  ( values[index] > NULL_VALUE ) )
287  {
288  found = true; // Found valid pixel.
289  break;
290  }
291  --lrIpt.x;
292  --index;
293
294  } // End: sample loop
295
296  if ( found )
297  {
298  break;
299  }
300
301  --lrIpt.y;
302
303  } // End line loop to find lower right pixel.
304
305  m_validRect = ossimIrect( ulIpt, lrIpt );
306  result = true;
307
308  }
309  else // Matches: if ( scalar == OSSIM_FLOAT32 ){...}
310  {
312  << "ossimHdf5ImageDataset:"<<__LINE__<<" WARNING!"
313  << "\nUnhandled scalar type: "
315  << std::endl;
316  }
317
318  } // Matches: if ( dimsOut...
319
320  } // Matches: if ( IN_DIM_COUNT == 2 )
321
322  //cout << "ossimHdf5ImageDataset:"<<__LINE__<<" m_validRect = "<<m_validRect<<endl;
323  return true;
324
325 #else
326  // REFACTORED
327  try
328  {
329  // Find the valid image rect. dataset may have null padding:
330  H5::DataSpace imageDataspace = m_dataset.getSpace();
331  H5::DataType dataType = m_dataset.getDataType();
332  ossim_uint32 elem_size = (ossim_uint32)dataType.getSize();
333
334  // Get the extents. Assuming dimensions are same for lat lon dataset.
335  hsize_t rowSize[2] = { 1, m_samples };
336  hsize_t imageOffset[2] = { 0, 0 };
337
338  // Allocate space for read buffer:
339  char *rowBuf = new char[elem_size*m_samples];
340  char *fill_value = new char[elem_size];
341
342  // Output dataspace always the same one line.
343  H5::DataSpace bufferDataSpace( 2, rowSize);
344  bufferDataSpace.selectHyperslab( H5S_SELECT_SET, rowSize, imageOffset ); // offset = (0,0) here
345
346  // Figure out the null pixel value (unswapped since doing byte compare below):
347  H5Pget_fill_value(m_dataset.getId(), dataType.getId(), fill_value);
348
349  // Find the ul pixel. Loop over rows:
350  ossimIpt ulIpt (0,0);
351  bool found_valid = false;
352  for (; (ulIpt.y<(int)m_lines) && !found_valid; ulIpt.y++)
353  {
354  imageOffset[0] = ulIpt.y;
355  imageDataspace.selectHyperslab( H5S_SELECT_SET, rowSize, imageOffset);
356  m_dataset.read(rowBuf, dataType, bufferDataSpace, imageDataspace );
357
358  // Scan row for valid pixel:
359  ossim_int64 rowOffset = 0;
360  for (ulIpt.x=0; (ulIpt.x<(int)m_samples) && !found_valid; ulIpt.x++, rowOffset+=elem_size)
361  found_valid = (memcmp(&rowBuf[rowOffset], fill_value, elem_size) != 0);
362  }
363  if (!found_valid)
364  ulIpt = ossimIpt(0,0);
365
366  // Find the lr pixel. Loop over rows:
367  ossimIpt lrIpt (m_samples-1, m_lines-1);
368  found_valid = false;
369  for (; (lrIpt.y>ulIpt.y) && !found_valid; lrIpt.y--)
370  {
371  imageOffset[0] = lrIpt.y;
372  imageDataspace.selectHyperslab( H5S_SELECT_SET, rowSize, imageOffset);
373  m_dataset.read(rowBuf, dataType, bufferDataSpace, imageDataspace );
374
375  // Scan row for valid pixel:
376  ossim_int64 rowOffset = m_samples*elem_size - 1;
377  for (lrIpt.x=m_samples-1; (lrIpt.x>ulIpt.x) && !found_valid; lrIpt.x-- , rowOffset-=elem_size)
378  found_valid = (memcmp(&rowBuf[rowOffset], fill_value, elem_size) != 0);
379  }
380  if (!found_valid)
381  lrIpt = ossimIpt (m_samples-1, m_lines-1);
382
383  m_validRect.set_ul(ulIpt);
384  m_validRect.set_lr(lrIpt);
385
386  imageDataspace.close();
387
388  delete [] rowBuf;
389  delete [] fill_value;
390  return true;
391  }
392  catch( const H5::Exception& e )
393  {
394  ossimNotify(ossimNotifyLevel_WARN)<<e.getDetailMsg();
395  return false;
396  }
397
398 #endif
399 }
float ossim_float32
void set_ul(const ossimIpt &pt)
Definition: ossimIrect.h:589
ossimScalarType
void set_lr(const ossimIpt &pt)
Definition: ossimIrect.h:623
ossim_int32 y
long long ossim_int64
ossim_int32 x
int ossim_int32
◆ operator<<
OSSIMDLLEXPORT std::ostream& operator<< ( std::ostream &  out,
friend
Definition at line 828 of file ossimHdf5ImageDataset.cpp.
829 {
830  return obj.print( out );
831 }
std::ostream & print(std::ostream &out) const
print method.
Member Data Documentation
◆ m_bands
ossim_uint32 ossimHdf5ImageDataset::m_bands
private
◆ m_dataset
H5::DataSet ossimHdf5ImageDataset::m_dataset
private
◆ m_dataSpace
H5::DataSpace ossimHdf5ImageDataset::m_dataSpace
private
Definition at line 137 of file ossimHdf5ImageDataset.h.
Referenced by operator=().
◆ m_endian
ossimEndian* ossimHdf5ImageDataset::m_endian
private
◆ m_handler
ossimRefPtr<ossimHdf5ImageHandler> ossimHdf5ImageDataset::m_handler
private
Definition at line 134 of file ossimHdf5ImageDataset.h.
Referenced by getTileBuf(), and scanForMinMax().
◆ m_hdf5
ossimRefPtr<ossimHdf5> ossimHdf5ImageDataset::m_hdf5
private
Definition at line 135 of file ossimHdf5ImageDataset.h.
Referenced by determineScalarType(), and ossimHdf5ImageDataset().
◆ m_lines
ossim_uint32 ossimHdf5ImageDataset::m_lines
private
Definition at line 140 of file ossimHdf5ImageDataset.h.
Referenced by determineExtents(), operator=(), print(), and scanForValidImageRect().
◆ m_maxValue
std::vector<ossim_float32> ossimHdf5ImageDataset::m_maxValue
private
◆ m_minValue
std::vector<ossim_float32> ossimHdf5ImageDataset::m_minValue
private
◆ m_samples
ossim_uint32 ossimHdf5ImageDataset::m_samples
private
Definition at line 141 of file ossimHdf5ImageDataset.h.
◆ m_scalar
ossimScalarType ossimHdf5ImageDataset::m_scalar
private
◆ m_validRect
ossimIrect ossimHdf5ImageDataset::m_validRect
private
The valid rect is the scanned rectangle disregarding leading or trailing nulls. This doesn't handle nulls in the middle of image.
Definition at line 149 of file ossimHdf5ImageDataset.h.
Referenced by determineExtents(), getNumberOfLines(), getNumberOfSamples(), getSubImageOffset(), getValidImageRect(), operator=(), ossimHdf5ImageDataset(), print(), scanForMinMax(), and scanForValidImageRect().
