Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Attributes | List of all members
ossimOpjWriterFactory Class Reference
Factory for OpenJPEG image writer. More...
#include <ossimOpjWriterFactory.h>
Inheritance diagram for ossimOpjWriterFactory:
ossimImageWriterFactoryBase ossimObjectFactory ossimObject ossimReferenced
virtual ~ossimOpjWriterFactory ()
 virtual destructor More...
virtual ossimImageFileWritercreateWriterFromExtension (const ossimString &fileExtension) const
 Creates a writer from extension like "jp2". More...
virtual ossimImageFileWritercreateWriter (const ossimKeywordlist &kwl, const char *prefix=0) const
 Create that takes a keyword list and prefix. More...
virtual ossimImageFileWritercreateWriter (const ossimString &typeName) const
 createWriter that takes a class name (ossimOpjWriter) More...
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
 Creates and object given a keyword list. More...
virtual ossimObjectcreateObject (const ossimString &typeName) const
 createObject that takes a class name (ossimOpjWriter) More...
virtual void getExtensions (std::vector< ossimString > &extList) const
 Adds "jp2" to list. More...
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
 Adds "ossimOpjWriter" to list. More...
virtual void getImageTypeList (std::vector< ossimString > &imageTypeList) const
 Adds "ossim_opj_jp2", "ossim_opj_geojp2", and "ossim_opj_gmljp2" to writer list. More...
virtual void getImageFileWritersBySuffix (ossimImageWriterFactoryBase::ImageFileWriterList &result, const ossimString &ext) const
 Adds an ossimOpjJp2Writer instance to writer list. More...
virtual void getImageFileWritersByMimeType (ossimImageWriterFactoryBase::ImageFileWriterList &result, const ossimString &mimeType) const
- Public Member Functions inherited from ossimImageWriterFactoryBase
virtual ~ossimImageWriterFactoryBase ()
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimOpjWriterFactoryinstance ()
 static method to return instance (the only one) of this class. More...
 hidden from use default constructor More...
 ossimOpjWriterFactory (const ossimOpjWriterFactory &)
 hidden from use copy constructor More...
void operator= (const ossimOpjWriterFactory &)
virtual ~ossimReferenced ()
static ossimOpjWriterFactorytheInstance = NULL
 static instance of this class More...
Additional Inherited Members
- Public Types inherited from ossimImageWriterFactoryBase
typedef std::vector< ossimRefPtr< ossimImageFileWriter > > ImageFileWriterList
Detailed Description
Definition at line 20 of file ossimOpjWriterFactory.h.
◆ ~ossimOpjWriterFactory()
ossimOpjWriterFactory::~ossimOpjWriterFactory ( )
virtual
virtual destructor
Definition at line 22 of file ossimOpjWriterFactory.cpp.
References theInstance.
23 {
24  theInstance = 0;
25 }
static ossimOpjWriterFactory * theInstance
◆ ossimOpjWriterFactory() [1/2]
ossimOpjWriterFactory::ossimOpjWriterFactory ( )
protected
Definition at line 143 of file ossimOpjWriterFactory.cpp.
Referenced by instance().
143 {}
◆ ossimOpjWriterFactory() [2/2]
ossimOpjWriterFactory::ossimOpjWriterFactory ( const ossimOpjWriterFactory )
protected
Definition at line 145 of file ossimOpjWriterFactory.cpp.
145 {}
Member Function Documentation
◆ createObject() [1/2]
ossimObject * ossimOpjWriterFactory::createObject ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Parameters
kwlThe keyword list.
prefixthe keyword list prefix.
Returns
pointer to image writer on success, NULL on failure.
Implements ossimObjectFactory.
Definition at line 86 of file ossimOpjWriterFactory.cpp.
References createWriter().
88 {
89  return createWriter(kwl, prefix);
90 }
virtual ossimImageFileWriter * createWriter(const ossimKeywordlist &kwl, const char *prefix=0) const
◆ createObject() [2/2]
ossimObject * ossimOpjWriterFactory::createObject ( const ossimString typeName) const
virtual
Parameters
typeNameShould be "ossimOpjReader".
Returns
Definition at line 92 of file ossimOpjWriterFactory.cpp.
94 {
95  return createWriter(typeName);
96 }
◆ createWriter() [1/2]
ossimImageFileWriter * ossimOpjWriterFactory::createWriter ( const ossimKeywordlist kwl,
) const
virtual
Parameters
Returns
pointer to image handler on success, NULL on failure.
Implements ossimImageWriterFactoryBase.
Definition at line 47 of file ossimOpjWriterFactory.cpp.
References ossimKeywordlist::find(), ossimImageFileWriter::loadState(), ossimRefPtr< T >::release(), ossimKeywordNames::TYPE_KW, and ossimRefPtr< T >::valid().
Referenced by createObject().
49 {
51  const char* type = kwl.find(prefix, ossimKeywordNames::TYPE_KW);
52  if (type)
53  {
54  writer = createWriter(ossimString(type));
55  if (writer.valid())
56  {
57  if (writer->loadState(kwl, prefix) == false)
58  {
59  writer = 0;
60  }
61  }
62  }
63  return writer.release();
64 }
bool valid() const
Definition: ossimRefPtr.h:75
static const char * TYPE_KW
T * release()
Definition: ossimRefPtr.h:93
◆ createWriter() [2/2]
ossimImageFileWriter * ossimOpjWriterFactory::createWriter ( const ossimString typeName) const
virtual
Parameters
Returns
Definition at line 66 of file ossimOpjWriterFactory.cpp.
References ossimImageFileWriter::hasImageType(), and ossimRefPtr< T >::release().
68 {
70  if (typeName == "ossimOpjJp2Writer")
71  {
72  writer = new ossimOpjJp2Writer;
73  }
74  else
75  {
76  // See if the type name is supported by the writer.
77  writer = new ossimOpjJp2Writer(typeName);
78  if ( writer->hasImageType(typeName) == false )
79  {
80  writer = 0;
81  }
82  }
83  return writer.release();
84 }
T * release()
virtual bool hasImageType(const ossimString &imageType) const
bool hasImageType(const ossimString& imageType) const
◆ createWriterFromExtension()
ossimImageFileWriter * ossimOpjWriterFactory::createWriterFromExtension ( const ossimString fileExtension) const
virtual
Parameters
fileExtensione.g. "jpg"
Definition at line 36 of file ossimOpjWriterFactory.cpp.
38 {
39  ossimOpjJp2Writer* writer = 0;
40  if ( (fileExtension == "jp2") || (fileExtension == "JP2") || (fileExtension == "j2k"))
41  {
42  writer = new ossimOpjJp2Writer();
43  }
44  return writer;
45 }
◆ getExtensions()
void ossimOpjWriterFactory::getExtensions ( std::vector< ossimString > &  extList) const
virtual
Adds "jp2" to list.
Parameters
extListList to add to.
Definition at line 98 of file ossimOpjWriterFactory.cpp.
100 {
101  result.push_back("jp2");
102  result.push_back("j2k");
103 }
◆ getImageFileWritersByMimeType()
void ossimOpjWriterFactory::getImageFileWritersByMimeType ( ossimImageWriterFactoryBase::ImageFileWriterList result,
const ossimString mimeType
) const
virtual
Reimplemented from ossimImageWriterFactoryBase.
Definition at line 133 of file ossimOpjWriterFactory.cpp.
136 {
137  if ( (mimeType == "image/jp2") || (mimeType == "image/j2k") )
138  {
139  result.push_back( new ossimOpjJp2Writer() );
140  }
141 }
◆ getImageFileWritersBySuffix()
void ossimOpjWriterFactory::getImageFileWritersBySuffix ( ossimImageWriterFactoryBase::ImageFileWriterList result,
const ossimString ext
) const
virtual
Parameters
resultList to append to.
extfile extension should be either "jp2" or "j2k"
Definition at line 122 of file ossimOpjWriterFactory.cpp.
References ossimString::downcase(), and ossimString::push_back().
125 {
126  ossimString testExt = ext.downcase();
127  if ( (testExt == "jp2") || (testExt == "j2k") )
128  {
129  result.push_back(new ossimOpjJp2Writer);
130  }
131 }
void push_back(char c)
Equivalent to insert(end(), c).
Definition: ossimString.h:905
◆ getImageTypeList()
void ossimOpjWriterFactory::getImageTypeList ( std::vector< ossimString > &  imageTypeList) const
virtual
Parameters
imageTypeListList to append to.
Definition at line 110 of file ossimOpjWriterFactory.cpp.
111 {
112  // include both geotiff and gmljp2 headers
113  imageTypeList.push_back( ossimString("ossim_opj_jp2") );
114
115  // include only a geotiff header
116  imageTypeList.push_back( ossimString("ossim_opj_geojp2") );
117
118  // include only a gmljp2 header
119  imageTypeList.push_back( ossimString("ossim_opj_gmljp2") );
120 }
◆ getTypeNameList()
void ossimOpjWriterFactory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
Parameters
typeListList to add to.
Definition at line 105 of file ossimOpjWriterFactory.cpp.
106 {
107  typeList.push_back(ossimString("ossimOpjJp2Writer"));
108 }
◆ instance()
ossimOpjWriterFactory * ossimOpjWriterFactory::instance ( )
static
Returns
pointer to instance of this class.
Definition at line 27 of file ossimOpjWriterFactory.cpp.
References ossimOpjWriterFactory(), and theInstance.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
28 {
29  if(!theInstance)
30  {
32  }
33  return theInstance;
34 }
◆ operator=()
void ossimOpjWriterFactory::operator= ( const ossimOpjWriterFactory )
protected
Definition at line 147 of file ossimOpjWriterFactory.cpp.
147 {}
Member Data Documentation
◆ theInstance
ossimOpjWriterFactory * ossimOpjWriterFactory::theInstance = NULL
staticprotected
Definition at line 115 of file ossimOpjWriterFactory.h.
Referenced by instance(), and ~ossimOpjWriterFactory().
