16 #ifndef ossimElevImageSource_HEADER 17 #define ossimElevImageSource_HEADER 39 const char* prefix=0);
56 const char* prefix=0);
85 const char* prefix=0)
const;
92 const char* prefix=0);
ossim_uint32 theNumberOfSamps
virtual void setLongitudeSpacing(ossim_float64 sp)
virtual void changeTileSize(const ossimIpt &size)
virtual ossim_uint32 getNumberOfInputBands() const
virtual void setNumberOfSamples(ossim_uint32 samps)
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
ossim_float64 theLonSpacing
virtual ossimIrect getImageRectangle(ossim_uint32 reduced_res_level=0) const
virtual void getDecimationFactors(vector< ossimDpt > &decimations) const
bool canConnectMyInputTo(ossim_int32, const ossimConnectableObject *) const
required to be overriden by derived classes
virtual void setTiePoint(const ossimGpt &gpt)
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &rect, ossim_uint32 resLevel=0)
virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level=0) const
virtual void setLatitudeSpacing(ossim_float64 sp)
virtual void initialize()
ossimElevSource * theElevManager
unsigned int ossim_uint32
ossim_uint32 theNumberOfLines
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if not defined...
virtual ossim_float64 getLongitudeSpacing() const
virtual ossim_float64 getLatitudeSpacing() const
virtual ~ossimElevImageSource()
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
virtual void setMaxPixelValue(ossim_float64 max_pix)
virtual void setNumberOfLines(ossim_uint32 lines)
virtual void getDecimationFactor(ossim_uint32 resLevel, ossimDpt &result) const
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level=0) const
virtual ossim_uint32 getNumberOfDecimationLevels() const
Will return the number of resolution levels.
virtual ossimGpt getTiePoint() const
virtual void setMinPixelValue(ossim_float64 min_pix)
ossim_float64 theLatSpacing
