#include <ossimElevSource.h>
virtual double | getHeightAboveMSL (const ossimGpt &)=0 |
Height access methods: More... | |
virtual double | getHeightAboveEllipsoid (const ossimGpt &) |
virtual ossimObject * | dup () const =0 |
bool | intersectRay (const ossimEcefRay &ray, ossimGpt &gpt, double defaultElevValue=0.0) |
METHOD: intersectRay() More... | |
virtual double | getMinHeightAboveMSL () const |
Access methods for the bounding elevations: More... | |
virtual double | getMaxHeightAboveMSL () const |
double | getNullHeightValue () const |
Special numeric quantities as defined by this source: More... | |
double | getSeaLevelValue () const |
virtual bool | pointHasCoverage (const ossimGpt &) const =0 |
METHOD: pointHasCoverage(gpt) Returns TRUE if coverage exists over gpt: More... | |
virtual double | getMeanSpacingMeters () const =0 |
METHOD: meanSpacingMeters() This method returns the post spacing in the region of gpt: More... | |
virtual bool | getAccuracyInfo (ossimElevationAccuracyInfo &info, const ossimGpt &gpt) const =0 |
virtual const ossimGrect & | getBoundingGndRect () const |
METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence) in the region of gpt: More... | |
virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
required to be overriden by derived classes More... | |
virtual void | initialize () |
Implement ossimSource base-class pure virtuals: More... | |
virtual bool | getComputeStatisticsFlag () const |
Opens a stream to an elevation cell. More... | |
virtual void | setComputeStatisticsFlag (bool flag) |
Sets the flag which controls whether or not statistics will be computed upon opening a cell and not finding a corresponding statistics file. More... | |
virtual std::ostream & | print (std::ostream &out) const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
virtual | ~ossimElevSource () |
ossimElevSource () | |
Constructors/Destructors: More... | |
ossimElevSource (const ossimElevSource &src) | |
ossimSource (const ossimSource &rhs) | |
const ossimSource & | operator= (const ossimSource &rhs) |
ossimConnectableObject * | findObjectOfType (ConnectableObjectList *connectableList, ossimVisitor &visitor) |
virtual | ~ossimReferenced () |
ossimListenerManager (const ossimListenerManager &rhs) | |
enum | ossimConnectableObjectDirectionType { CONNECTABLE_DIRECTION_NONE = 0, CONNECTABLE_DIRECTION_INPUT = 1, CONNECTABLE_DIRECTION_OUTPUT = 2 } |
typedef std::vector< ossimRefPtr< ossimConnectableObject > > | ConnectableObjectList |
Definition at line 31 of file ossimElevSource.h.
protectedvirtual |
Definition at line 94 of file ossimElevSource.cpp.
protected |
Definition at line 40 of file ossimElevSource.cpp.
protected |
Definition at line 83 of file ossimElevSource.cpp.
Implements ossimConnectableObject.
Reimplemented in ossimElevCellHandler.
Definition at line 245 of file ossimElevSource.cpp.
pure virtual |
Implemented in ossimElevManager, ossimDtedHandler, ossimTiledElevationDatabase, ossimGeneralRasterElevHandler, ossimImageElevationHandler, ossimSrtmHandler, ossimImageElevationDatabase, ossimDtedElevationDatabase, ossimGeneralRasterElevationDatabase, and ossimSrtmElevationDatabase.
Referenced by ossimElevManager::addDatabase(), and ossimElevManager::getNextElevDbList().
pure virtual |
METHOD: getBoundingGndRect
Definition at line 240 of file ossimElevSource.cpp.
References theGroundRect.
Referenced by ossimImageElevationDatabase::createCell(), and ossimImageElevationDatabase::getBoundingRect().
Definition at line 255 of file ossimElevSource.cpp.
References theComputeStatsFlag.
Reimplemented in ossimTiledElevationDatabase, ossimImageElevationDatabase, ossimGeneralRasterElevationDatabase, ossimElevManager, ossimDtedElevationDatabase, and ossimSrtmElevationDatabase.
Definition at line 97 of file ossimElevSource.cpp.
References ossimNotify(), ossimNotifyLevel_FATAL, and theNullHeightValue.
pure virtual |
Implemented in ossimDtedHandler, ossimGeneralRasterElevHandler, ossimTiledElevationDatabase, ossimImageElevationDatabase, ossimGeneralRasterElevationDatabase, ossimElevManager, ossimSrtmHandler, ossimDtedElevationDatabase, ossimImageElevationHandler, and ossimSrtmElevationDatabase.
Referenced by ossimSrtmElevationDatabase::getHeightAboveMSL(), ossimDtedElevationDatabase::getHeightAboveMSL(), ossimGeneralRasterElevationDatabase::getHeightAboveMSL(), ossimImageElevationDatabase::getHeightAboveMSL(), and ossimElevImageSource::getTile().
Definition at line 225 of file ossimElevSource.cpp.
References theMaxHeightAboveMSL.
Referenced by ossimElevImageSource::getMaxPixelValue(), and ossimElevImageSource::getTile().
pure virtual |
Implemented in ossimElevManager, ossimElevCellHandler, and ossimElevationDatabase.
Referenced by ossimElevLess::operator()().
Definition at line 220 of file ossimElevSource.cpp.
References theMinHeightAboveMSL.
Referenced by ossimElevImageSource::getMinPixelValue(), and ossimElevImageSource::getTile().
double ossimElevSource::getNullHeightValue | ( | ) | const |
Definition at line 230 of file ossimElevSource.cpp.
References theNullHeightValue.
double ossimElevSource::getSeaLevelValue | ( | ) | const |
Definition at line 251 of file ossimElevSource.cpp.
bool ossimElevSource::intersectRay | ( | const ossimEcefRay & | ray, |
ossimGpt & | gpt, | ||
double | defaultElevValue = 0.0 |
Service method for intersecting a ray with the elevation surface to arrive at a ground point. The ray is expected to originate ABOVE the surface and pointing down.
NOTE: the gpt argument is expected to be initialized with the desired datum, including ellipsoid, for the proper intersection point to be computed.
LIMITATION: This release supports only single valued solutions, i.e., it is possible a ray passing through one side of a mountain and out the other will return an intersection with the far side. Eventually, a more robust algorithm will be employed.
Returns true if good intersection found.
Definition at line 122 of file ossimElevSource.cpp.
Referenced by ossimSkyBoxLearSensor::lineSampeToWorld(), ossimPpjFrameSensor::lineSampleToWorld(), ossimRsmModel::lineSampleToWorld(), ossimSonomaSensor::lineSampleToWorld(), ossimRpcModel::lineSampleToWorld(), and ossimAlphaSensor::lineSampToWorld().
pure virtual |
Implemented in ossimGeneralRasterElevHandler, ossimTiledElevationDatabase, ossimImageElevationDatabase, ossimImageElevationHandler, ossimElevCellHandler, ossimElevManager, ossimGeneralRasterElevationDatabase, ossimDtedElevationDatabase, and ossimSrtmElevationDatabase.
Reimplemented in ossimElevManager, ossimImageElevationDatabase, ossimTiledElevationDatabase, ossimElevationCellDatabase, ossimElevCellHandler, ossimElevationDatabase, ossimGeneralRasterElevationDatabase, and ossimDtedElevationDatabase.
Definition at line 265 of file ossimElevSource.cpp.
References ossimSource::print(), theGroundRect, theMaxHeightAboveMSL, theMinHeightAboveMSL, theNullHeightValue, and theSeaLevelValue.
Referenced by ossimElevManager::print().
flag | true to enable, false to disable. |
Definition at line 260 of file ossimElevSource.cpp.
protected |
Definition at line 174 of file ossimElevSource.h.
Referenced by getComputeStatisticsFlag(), and setComputeStatisticsFlag().
protected |
Definition at line 171 of file ossimElevSource.h.
Referenced by ossimTiledElevationDatabase::close(), getBoundingGndRect(), ossimSrtmHandler::getHeightAboveMSLMemoryTemplate(), ossimTiledElevationDatabase::mapRegion(), ossimImageElevationHandler::open(), ossimSrtmHandler::open(), ossimTiledElevationDatabase::ossimTiledElevationDatabase(), ossimElevCellHandler::pointHasCoverage(), ossimTiledElevationDatabase::pointHasCoverage(), print(), and ossimGeneralRasterElevHandler::setFilename().
protected |
Definition at line 168 of file ossimElevSource.h.
Referenced by getMaxHeightAboveMSL(), and print().
protected |
Data members:
Definition at line 167 of file ossimElevSource.h.
Referenced by getMinHeightAboveMSL(), and print().
protected |
Definition at line 169 of file ossimElevSource.h.
Referenced by getHeightAboveEllipsoid(), ossimSrtmHandler::getHeightAboveMSLFileTemplate(), ossimSrtmHandler::getHeightAboveMSLMemoryTemplate(), getNullHeightValue(), ossimSrtmHandler::getPostValue(), ossimSrtmHandler::open(), print(), and ossimGeneralRasterElevHandler::setFilename().
protected |
Definition at line 170 of file ossimElevSource.h.
Referenced by getSeaLevelValue(), and print().
