#include <ossimElevImageSource.h>
ossimElevImageSource () | |
ossimElevImageSource (ossimObject *owner) | |
ossimElevImageSource (ossimObject *owner, const ossimGpt &tie, double latSpacing, double lonSpacing, ossim_uint32 numberLines, ossim_uint32 numberSamples) | |
ossimElevImageSource (ossimObject *owner, const ossimKeywordlist &kwl, const char *prefix=0) | |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &rect, ossim_uint32 resLevel=0) |
virtual bool | getImageGeometry (ossimKeywordlist &kwl, const char *prefix=0) |
virtual ossim_uint32 | getNumberOfOutputBands () const |
virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
virtual ossimIrect | getBoundingRect (ossim_uint32 resLevel=0) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
bool | canConnectMyInputTo (ossim_int32, const ossimConnectableObject *) const |
required to be overriden by derived classes More... | |
virtual void | initialize () |
virtual void | getDecimationFactor (ossim_uint32 resLevel, ossimDpt &result) const |
virtual void | getDecimationFactors (vector< ossimDpt > &decimations) const |
virtual ossim_uint32 | getNumberOfDecimationLevels () const |
Will return the number of resolution levels. More... | |
virtual ossim_uint32 | getNumberOfInputBands () const |
virtual ossimScalarType | getOutputScalarType () const |
This will be used to query the output pixel type of the tile source. More... | |
virtual ossim_uint32 | getTileWidth () const |
Returns the default processing tile width. More... | |
virtual ossim_uint32 | getTileHeight () const |
Returns the default processing tile height. More... | |
virtual void | changeTileSize (const ossimIpt &size) |
virtual ossimGpt | getTiePoint () const |
virtual ossim_float64 | getLatitudeSpacing () const |
virtual ossim_float64 | getLongitudeSpacing () const |
virtual ossim_uint32 | getNumberOfLines (ossim_uint32 reduced_res_level=0) const |
virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 reduced_res_level=0) const |
virtual double | getMinPixelValue (ossim_uint32 band=0) const |
Returns the min pixel of the band. More... | |
virtual double | getMaxPixelValue (ossim_uint32 band=0) const |
Returns the max pixel of the band. More... | |
virtual void | setTiePoint (const ossimGpt &gpt) |
virtual void | setLatitudeSpacing (ossim_float64 sp) |
virtual void | setLongitudeSpacing (ossim_float64 sp) |
virtual void | setNumberOfLines (ossim_uint32 lines) |
virtual void | setNumberOfSamples (ossim_uint32 samps) |
virtual void | setMinPixelValue (ossim_float64 min_pix) |
virtual void | setMaxPixelValue (ossim_float64 max_pix) |
ossimImageSource (ossimObject *owner=0) | |
ossimImageSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimImageSource () |
virtual ossimRefPtr< ossimImageData > | getTile (const ossimIpt &origin, ossim_uint32 resLevel=0) |
virtual bool | getTile (ossimImageData *result, ossim_uint32 resLevel=0) |
Method to get a tile. More... | |
virtual ossimObject * | getObject () |
For RTTI support. More... | |
virtual const ossimObject * | getObject () const |
virtual void | getDecimationFactors (std::vector< ossimDpt > &decimations) const |
Will return an array of all decimations for each resolution level. More... | |
virtual void | getOutputBandList (std::vector< ossim_uint32 > &bandList) const |
Initializes bandList. More... | |
virtual double | getNullPixelValue (ossim_uint32 band=0) const |
Each band has a null pixel associated with it. More... | |
virtual void | getBoundingRect (ossimIrect &rect, ossim_uint32 resLevel=0) const |
Gets the bounding rectangle of the source. More... | |
virtual void | getValidImageVertices (std::vector< ossimIpt > &validVertices, ossimVertexOrdering ordering=OSSIM_CLOCKWISE_ORDER, ossim_uint32 resLevel=0) const |
ordering specifies how the vertices should be arranged. More... | |
virtual ossimRefPtr< ossimImageGeometry > | getImageGeometry () |
Returns the image geometry object associated with this tile source or NULL if not defined. More... | |
virtual void | setImageGeometry (const ossimImageGeometry *geom) |
Default implementation sets geometry of the first input to the geometry specified. More... | |
virtual void | saveImageGeometry () const |
Default method to call input's saveImageGeometry. More... | |
virtual void | saveImageGeometry (const ossimFilename &geometry_file) const |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
virtual bool | isIndexedData () const |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual std::ostream & | print (std::ostream &out) const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimObject * | dup () const |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
virtual | ~ossimElevImageSource () |
ossimImageSource (const ossimImageSource &rhs) | |
const ossimImageSource & | operator= (const ossimImageSource &) |
ossimSource (const ossimSource &rhs) | |
const ossimSource & | operator= (const ossimSource &rhs) |
ossimConnectableObject * | findObjectOfType (ConnectableObjectList *connectableList, ossimVisitor &visitor) |
virtual | ~ossimReferenced () |
ossimListenerManager (const ossimListenerManager &rhs) | |
enum | ossimConnectableObjectDirectionType { CONNECTABLE_DIRECTION_NONE = 0, CONNECTABLE_DIRECTION_INPUT = 1, CONNECTABLE_DIRECTION_OUTPUT = 2 } |
typedef std::vector< ossimRefPtr< ossimConnectableObject > > | ConnectableObjectList |
Definition at line 25 of file ossimElevImageSource.h.
ossimElevImageSource::ossimElevImageSource | ( | ) |
Definition at line 30 of file ossimElevImageSource.cpp.
ossimElevImageSource::ossimElevImageSource | ( | ossimObject * | owner | ) |
Definition at line 46 of file ossimElevImageSource.cpp.
ossimElevImageSource::ossimElevImageSource | ( | ossimObject * | owner, |
const ossimGpt & | tie, | ||
double | latSpacing, | ||
double | lonSpacing, | ||
ossim_uint32 | numberLines, | ||
ossim_uint32 | numberSamples | ||
Definition at line 62 of file ossimElevImageSource.cpp.
References initialize().
const ossimKeywordlist & | kwl, | ||
const char * | prefix = 0 |
Definition at line 85 of file ossimElevImageSource.cpp.
References loadState(), and ossimErrorStatusInterface::setErrorStatus().
protectedvirtual |
Definition at line 108 of file ossimElevImageSource.cpp.
inlinevirtual |
Implements ossimConnectableObject.
Definition at line 94 of file ossimElevImageSource.h.
Definition at line 684 of file ossimElevImageSource.cpp.
inlinevirtual |
Returns the absolute bounding rectangle of the image. The upper left corner may be non-zero if this is a subimage.
Definition at line 75 of file ossimElevImageSource.h.
References getImageRectangle().
Satisfy pure virtuals from base classes...
Definition at line 635 of file ossimElevImageSource.cpp.
References ossimDpt::line, and ossimDpt::samp.
Definition at line 648 of file ossimElevImageSource.cpp.
Populates the keyword list with image geometry information. This method is used to relay projection/model information to users. Returns true if geometry info is present, false if not.
Definition at line 617 of file ossimElevImageSource.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, ossimLlxyProjection::saveState(), theLatSpacing, theLonSpacing, theNumberOfLines, and theTiePoint.
Returns the zero-based (relative) image rectangle for the reduced resolution data set (rrds) passed in. Note that rrds 0 is the highest resolution rrds.
Definition at line 604 of file ossimElevImageSource.cpp.
References theNumberOfLines, and theNumberOfSamps.
Referenced by getBoundingRect(), and getTile().
inlinevirtual |
Definition at line 116 of file ossimElevImageSource.h.
References theLatSpacing.
inlinevirtual |
Definition at line 117 of file ossimElevImageSource.h.
References theLonSpacing.
Definition at line 761 of file ossimElevImageSource.cpp.
References ossimRefPtr< T >::get(), ossimElevSource::getMaxHeightAboveMSL(), ossimImageData::getMaxPix(), theElevManager, and theTile.
Referenced by saveState().
Definition at line 739 of file ossimElevImageSource.cpp.
References ossimRefPtr< T >::get(), ossimElevSource::getMinHeightAboveMSL(), ossimImageData::getMinPix(), theElevManager, and theTile.
Note: resolution level 0 is included in the return count.
Definition at line 655 of file ossimElevImageSource.cpp.
Returns the number of bands available from the input.
Implements ossimImageSource.
Definition at line 660 of file ossimElevImageSource.cpp.
Definition at line 713 of file ossimElevImageSource.cpp.
References theNumberOfLines.
inlinevirtual |
Returns the number of bands in the image. Alway one for this source.
Definition at line 61 of file ossimElevImageSource.h.
Definition at line 726 of file ossimElevImageSource.cpp.
References theNumberOfSamps.
Definition at line 665 of file ossimElevImageSource.cpp.
References OSSIM_FLOAT.
inlinevirtual |
Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. Satisfies pure virtual from TileSource class.
Definition at line 112 of file ossimElevImageSource.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimImageData::getHeight(), ossimElevSource::getHeightAboveMSL(), getImageRectangle(), ossimElevSource::getMaxHeightAboveMSL(), ossimElevSource::getMinHeightAboveMSL(), ossimImageData::getWidth(), ossimIrect::height(), ossimImageData::initialize(), ossimIrect::intersects(), ossimSource::isSourceEnabled(), ossimGpt::latd(), ossimGpt::lond(), ossimIrect::lr(), ossimImageData::makeBlank(), ossimImageData::setHeight(), ossimImageData::setMaxPix(), ossimImageData::setMinPix(), ossimImageData::setOrigin(), ossimImageData::setWidth(), theElevManager, theLatSpacing, theLonSpacing, theTiePoint, theTile, ossimIrect::ul(), ossimImageData::validate(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
Definition at line 677 of file ossimElevImageSource.cpp.
References ossimRefPtr< T >::get(), ossimImageData::getHeight(), and theTile.
Definition at line 670 of file ossimElevImageSource.cpp.
References ossimRefPtr< T >::get(), ossimImageData::getWidth(), and theTile.
Definition at line 494 of file ossimElevImageSource.cpp.
Referenced by ossimElevImageSource().
Definition at line 324 of file ossimElevImageSource.cpp.
References ossimKeywordlist::find(), ossimErrorStatusInterface::getErrorStatus(), ossimGpt::latd(), ossimImageSource::loadState(), ossimErrorCodes::OSSIM_ERROR, theTiePoint, and ossimKeywordNames::TIE_POINT_LAT_KW.
Definition at line 262 of file ossimElevImageSource.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::DECIMAL_DEGREES_PER_PIXEL_LAT, ossimKeywordNames::DECIMAL_DEGREES_PER_PIXEL_LON, ossimErrorStatusInterface::getErrorStatus(), getMaxPixelValue(), getMinPixelValue(), ossimGpt::latd(), ossimGpt::lond(), ossimKeywordNames::MAX_VALUE_KW, ossimKeywordNames::MIN_VALUE_KW, ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, ossimErrorCodes::OSSIM_ERROR, ossimImageSource::saveState(), theLatSpacing, theLonSpacing, theNumberOfLines, theNumberOfSamps, theTiePoint, ossimKeywordNames::TIE_POINT_LAT_KW, and ossimKeywordNames::TIE_POINT_LON_KW.
inlinevirtual |
Definition at line 125 of file ossimElevImageSource.h.
inlinevirtual |
Definition at line 126 of file ossimElevImageSource.h.
Definition at line 803 of file ossimElevImageSource.cpp.
References ossimRefPtr< T >::get(), ossimImageData::setMaxPix(), and theTile.
Definition at line 783 of file ossimElevImageSource.cpp.
References ossimRefPtr< T >::get(), ossimImageData::setMinPix(), and theTile.
inlinevirtual |
Definition at line 127 of file ossimElevImageSource.h.
inlinevirtual |
Definition at line 128 of file ossimElevImageSource.h.
inlinevirtual |
protected |
Definition at line 135 of file ossimElevImageSource.h.
Referenced by getMaxPixelValue(), getMinPixelValue(), and getTile().
protected |
Definition at line 138 of file ossimElevImageSource.h.
Referenced by getImageGeometry(), getLatitudeSpacing(), getTile(), saveState(), and setLatitudeSpacing().
protected |
Definition at line 139 of file ossimElevImageSource.h.
Referenced by getImageGeometry(), getLongitudeSpacing(), getTile(), saveState(), and setLongitudeSpacing().
protected |
Definition at line 140 of file ossimElevImageSource.h.
Referenced by getImageGeometry(), getImageRectangle(), getNumberOfLines(), saveState(), and setNumberOfLines().
protected |
Definition at line 141 of file ossimElevImageSource.h.
Referenced by getImageRectangle(), getNumberOfSamples(), saveState(), and setNumberOfSamples().
protected |
Definition at line 137 of file ossimElevImageSource.h.
Referenced by getImageGeometry(), getTiePoint(), getTile(), loadState(), saveState(), and setTiePoint().
protected |
Definition at line 136 of file ossimElevImageSource.h.
Referenced by getMaxPixelValue(), getMinPixelValue(), getTile(), getTileHeight(), getTileWidth(), setMaxPixelValue(), and setMinPixelValue().
