ossimEnviTileSource.cpp
Go to the documentation of this file.
1 //---
2 //
3 // License: MIT
4 //
5 // Author: David Burken
6 //
7 // Description:
8 //
9 // Image handler class for a raster files with an ENVI header file.
10 //
11 //---
12 // $Id$
13
17 #include <ossim/base/ossimTrace.h>
23
24
26  "ossimEnviTileSource",
28
29 static ossimTrace traceDebug("ossimEnviTileSource:debug");
30
32  :
34  m_enviHdr()
35 {
36 }
37
39 {
40 }
41
43 {
44  static const char MODULE[] = "ossimEnviTileSource::open";
45  if ( traceDebug() )
46  {
48  << MODULE << " entered..."
49  << "\nimage file: " << theImageFile << std::endl;
50  }
51
52  bool result = false;
53
54  if(isOpen())
55  {
56  close();
57  }
58
59  // Look for a header file:
60  ossimFilename hdr = theImageFile;
61  hdr.setExtension("hdr"); // image.hdr
62  if ( !hdr.exists() )
63  {
64  hdr = theImageFile;
65  hdr.string() += ".hdr"; // image.ras.hdr
66  }
67
68  if ( hdr.exists() )
69  {
70  if ( traceDebug() )
71  {
72  ossimNotify(ossimNotifyLevel_DEBUG) << "header file: " << hdr << std::endl;
73  }
74
75  if ( m_enviHdr.open( hdr ) )
76  {
77  if ( m_rasterInfo.initializeFromEnviHdr( m_enviHdr ) )
78  {
79  // Set image file for initializeHandler method.
80  m_rasterInfo.setImageFile( theImageFile );
81
82  // Look for an omd file:
83  ossimFilename omd = theImageFile;
84  omd.setExtension("omd"); // image.omd
85  if ( !omd.exists() )
86  {
87  omd.setExtension("kwl"); // image.kwl
88  }
89
90  if ( omd.exists() )
91  {
92  if ( traceDebug() )
93  {
94  ossimNotify(ossimNotifyLevel_DEBUG) << "omd file: " << omd << std::endl;
95  }
96
97  // Pick up adjusted min / max values if present.
98  ossimKeywordlist kwl( omd );
99  m_rasterInfo.getImageMetaData().updateMetaData( kwl, std::string("") );
100  }
101
102  theMetaData = m_rasterInfo.getImageMetaData();
103
104  result = initializeHandler();
105  if ( result )
106  {
107  completeOpen();
108
109  //---
110  // This will set default output band list if we are a band selector and
111  // "default bands" key is found in the envi header. If "default bands"
112  // is not found it will set to identity(input = output).
113  //---
114  setDefaultBandList();
115  }
116  }
117  }
118  }
119
120  if ( traceDebug() )
121  {
123  << MODULE << " Exit status: " << (result?"true":"false") << std::endl;
124  }
125
126  return result;
127 }
128
129 //************************************************************************************************
132 //************************************************************************************************
134 {
135  if ( !theGeometry )
136  {
137  // Check for external geom:
138  theGeometry = getExternalImageGeometry();
139
140  if ( !theGeometry )
141  {
142  // Check the internal geometry first to avoid a factory call.
143  theGeometry = getInternalImageGeometry();
144
145  // At this point it is assured theGeometry is set.
146
147  //---
148  // WARNING:
149  // Must create/set theGeometry at this point or the next call to
150  // ossimImageGeometryRegistry::extendGeometry will put us in an infinite loop
151  // as it does a recursive call back to ossimImageHandler::getImageGeometry().
152  //---
153
154  // Check for set projection.
155  if ( theGeometry.valid()&&!theGeometry->getProjection() )
156  {
157  // Try factories for projection.
159  }
160  }
161
162  // Set image things the geometry object should know about.
163  initImageParameters( theGeometry.get() );
164  }
165
166  return theGeometry;
167 }
168
170 {
171  static const char MODULE[] = "ossimEnviTileSource::getInternalImageGeometry";
172  if (traceDebug())
173  {
174  ossimNotify(ossimNotifyLevel_DEBUG) << MODULE << " entered...\n";
175  }
177
178 // debugging to turn off model load
179 // return geom;
180
181  geom = new ossimImageGeometry();
182
184  if ( supData->readSupportFiles( m_enviHdr ) )
185  {
186  if (supData->isHSI())
187  {
189  if ( sensor->initialize( *(supData.get()) ) )
190  {
191  geom->setProjection( sensor.get() );
192  }
193  }
194  else
195  {
197  if ( sensor->initialize( *(supData.get()) ) )
198  {
199  geom->setProjection( sensor.get() );
200  }
201  }
202
203  } // Matches: if ( supData->readSupportFiles( m_enviHdr ) )
204  else
205  {
206  geom = 0;
207  }
208
209  return geom;
210 }
211
213  const char* prefix)const
214 {
215  return ossimGeneralRasterTileSource::saveState(kwl,prefix);
216 }
217
219  const char* prefix)
220 {
221  return ossimGeneralRasterTileSource::loadState(kwl, prefix);
222 }
223
225  const ossimString& name)const
226 {
227  if(name == "file_type")
228  {
229  return new ossimStringProperty(name, getShortName());
230  }
231
232  return ossimImageHandler::getProperty(name);
233 }
234
236  std::vector<ossimString>& propertyNames)const
237 {
239  propertyNames.push_back("file_type");
240 }
241
243 {
244  return ossimString("ENVI");
245 }
246
248 {
249  return ossimString("ENVI reader");
250 }
251
252 bool ossimEnviTileSource::getRgbBandList(std::vector<ossim_uint32>& bandList) const
253 {
254  bool result = false;
255
256  bandList.clear();
257
258  // Look in ENVI header for "default bands":
259  result = m_enviHdr.getDefaultBands( bandList );
260
261  if ( !result && ( getNumberOfInputBands() > 2 ) )
262  {
263  // Try to derive RGB from wavelengths if found in ENVI header.
264  ossimWavelength wl;
265  if ( wl.initialize( m_enviHdr ) )
266  {
267  result = wl.getRgbBands( bandList );
268  }
269  }
270
271  if ( bandList.size() != 3 )
272  {
273  result = false;
274  }
275
276  return result;
277 }
278
280 {
281  if ( isBandSelector() )
282  {
283  std::vector<ossim_uint32> bandList;
284  if ( getRgbBandList( bandList ) )
285  {
286  if ( bandList.size() )
287  {
288  ossimImageHandler::setOutputBandList(bandList, m_outputBandList);
289  }
290  }
291  }
292
293  if ( m_outputBandList.empty() )
294  {
295  // Initialized to identity (input = output):
296  ossimImageSource::getOutputBandList( m_outputBandList );
297  }
298 }
virtual bool readSupportFiles(const ossimFilename &hdrFile)
static ossimImageGeometryRegistry * instance()
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
virtual ossimString getLongName() const
void setDefaultBandList()
Sets default output band list if we are a band selector and "default bands" is found in the header fi...
virtual bool loadState(const ossimKeywordlist &kwl, const char *prefix=NULL)
Adds property names to array.
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
virtual bool extendGeometry(ossimImageHandler *handler) const
Gets a property.
virtual void getOutputBandList(std::vector< ossim_uint32 > &bandList) const
Initializes bandList.
bool getRgbBands(std::vector< ossim_uint32 > &bands) const
Gets rgb bands if "wavelength" keyword is present.
bool exists() const
ossimEnviTileSource()
default constructor
virtual bool open()
open method.
virtual bool initialize(const ossimAlphaSensorSupportData &supData)
Initializes model from support data and calls update Model on success.
virtual ~ossimEnviTileSource()
Hidden from use destructor.
ossimRefPtr< ossimImageGeometry > getInternalImageGeometry() const
Creates geometry from known support data, i.e.
virtual ossimString getShortName() const
#define RTTI_DEF1(cls, name, b1)
Definition: ossimRtti.h:485
ossimFilename & setExtension(const ossimString &e)
Sets the extension of a file name.
virtual bool setOutputBandList(const std::vector< ossim_uint32 > &band_list)
If the image handler "isBandSeletor()" then the band selection of the output chip can be controlled...
virtual bool getRgbBandList(std::vector< ossim_uint32 > &bandList) const
Get the zero based rgb output band list from envi header.
const std::string & string() const
Definition: ossimString.h:414
bool initialize(const ossimEnviHeader &hdr)
Initializes map from ENVI header class.
