ossimImageStatisticsSource.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: LGPL
4 //
5 // See LICENSE.txt file in the top level directory for more details.
6 //
7 // Author: Garrett Potts
8 //
9 //*************************************************************************
14
16  :ossimSource(0,
17  1,
18  0,
19  true,
20  false)
21 {
22 }
23
25 {
26
27 }
28
30 {
32  getInput());
33
34  if(anInterface&&isSourceEnabled())
35  {
37  ossimScalarType outputScalarType = anInterface->getOutputScalarType();
38
39  switch(outputScalarType)
40  {
41  case OSSIM_UCHAR:
42  {
44  break;
45  }
46  case OSSIM_USHORT16:
47  case OSSIM_USHORT11:
48  case OSSIM_USHORT12:
49  case OSSIM_USHORT13:
50  case OSSIM_USHORT14:
51  case OSSIM_USHORT15:
52  {
54  break;
55  }
56  case OSSIM_SSHORT16:
57  {
59  break;
60  }
61  case OSSIM_DOUBLE:
63  {
65  break;
66  }
67  case OSSIM_FLOAT:
69  {
71  break;
72  }
73  default :
74  {
75  break;
76  }
77  }
78  }
79 }
80
82  const ossimConnectableObject* object)const
83 {
84  return (PTR_CAST(ossimImageSource, object)&&(inputIndex < 1));
85 }
86
87 template <class T>
89 {
91
92  sequencer->connectMyInputTo(getInput());
93  sequencer->setToStartOfSequence();
94  ossim_uint32 bands = sequencer->getNumberOfOutputBands();
95
96  if(bands)
97  {
98  setStatsSize(bands);
99  ossimRefPtr<ossimImageData> dataObject;
100
101  while( (dataObject=sequencer->getNextTile()).valid() )
102  {
103  ossim_uint32 bandIdx = 0;
104  bands = dataObject->getNumberOfBands();
106  if((status != OSSIM_EMPTY)&&
107  (dataObject->getBuf()))
108  {
109  ossim_uint32 offsetMax = dataObject->getWidth()*dataObject->getHeight();
110  for(bandIdx = 0; bandIdx < bands; ++bandIdx)
111  {
112  ossim_float64 pixelCount = 0.0;
113  ossim_uint32 offset = 0;
114  T* dataPtr = static_cast<T*>(dataObject->getBuf(bandIdx));
115  T nullPixel = static_cast<T>(dataObject->getNullPix(bandIdx));
116  for(offset = 0; offset < offsetMax; ++offset)
117  {
118  if((*dataPtr) != nullPixel)
119  {
120  theMean[bandIdx] += *dataPtr;
121  if((*dataPtr) < theMin[bandIdx])
122  {
123  theMin[bandIdx] = (*dataPtr);
124  }
125  if((*dataPtr) > theMax[bandIdx])
126  {
127  theMax[bandIdx] = (*dataPtr);
128  }
129  ++pixelCount;
130  }
131  ++dataPtr;
132  }
133  if(pixelCount > 0)
134  {
135  theMean[bandIdx] /= pixelCount;
136  }
137  }
138  }
139  }
140  }
141
142  sequencer->disconnect();
143  sequencer = 0;
144 }
145
146 const std::vector<ossim_float64>& ossimImageStatisticsSource::getMean()const
147 {
148  return theMean;
149 }
150
151 const std::vector<ossim_float64>& ossimImageStatisticsSource::getMin()const
152 {
153  return theMin;
154 }
155
156 const std::vector<ossim_float64>& ossimImageStatisticsSource::getMax()const
157 {
158  return theMax;
159 }
160
162 {
163  theMean.clear();
164  theMin.clear();
165  theMax.clear();
166 }
167
169 {
170  theMean.resize(size);
171  theMin.resize(size);
172  theMax.resize(size);
173
174  std::fill(theMean.begin(),
175  theMean.end(),
176  (ossim_float64)0.0);
177  std::fill(theMin.begin(),
178  theMin.end(),
180  std::fill(theMax.begin(),
181  theMax.end(),
183 }
const std::vector< ossim_float64 > & getMax() const
virtual void disconnect(ossimConnectableObject *object=0)
Will disconnect the object passed in.
#define OSSIM_DEFAULT_MAX_PIX_DOUBLE
float ossim_float32
const std::vector< ossim_float64 > & getMin() const
virtual ossimRefPtr< ossimImageData > getNextTile(ossim_uint32 resLevel=0)
virtual bool canConnectMyInputTo(ossim_int32 inputIndex, const ossimConnectableObject *object) const
required to be overriden by derived classes
unsigned short ossim_uint16
double ossim_float64
const std::vector< ossim_float64 > & getMean() const
#define OSSIM_DEFAULT_MIN_PIX_DOUBLE
yy_size_t size
signed short ossim_sint16
std::vector< ossim_float64 > theMean
unsigned int ossim_uint32
virtual const ossim_float64 * getNullPix() const
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
std::vector< ossim_float64 > theMax
ossimScalarType
return status
std::vector< ossim_float64 > theMin
ossimDataObjectStatus
Definitions for data object status.
32 bit floating point
16 bit unsigned iteger
64 bit floating point
16 bit signed integer
unsigned char ossim_uint8
8 bit unsigned iteger
void computeStatisticsTemplate(T dummyVariable)
int ossim_int32
