ossimImageStatisticsSource Class Reference
#include <ossimImageStatisticsSource.h>
Inheritance diagram for ossimImageStatisticsSource:
ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimImageStatisticsSource ()
virtual void computeStatistics ()
virtual bool canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const
const std::vector< ossim_float64 > & getMean () const
const std::vector< ossim_float64 > & getMin () const
const std::vector< ossim_float64 > & getMax () const
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
virtual void initialize ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
Protected Member Functions
virtual ~ossimImageStatisticsSource ()
void clearStatistics ()
template<class T >
void computeStatisticsTemplate (T dummyVariable)
void setStatsSize (ossim_uint32 size)
virtual ~ossimReferenced ()
Protected Attributes
std::vector< ossim_float64theMean
std::vector< ossim_float64theMin
std::vector< ossim_float64theMax
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Additional Inherited Members
Detailed Description
Definition at line 5 of file ossimImageStatisticsSource.h.
◆ ossimImageStatisticsSource()
ossimImageStatisticsSource::ossimImageStatisticsSource ( )
Definition at line 15 of file ossimImageStatisticsSource.cpp.
16  :ossimSource(0,
17  1,
18  0,
19  true,
20  false)
21 {
22 }
ossimSource(ossimObject *owner=0)
◆ ~ossimImageStatisticsSource()
ossimImageStatisticsSource::~ossimImageStatisticsSource ( )
protectedvirtual
Definition at line 24 of file ossimImageStatisticsSource.cpp.
25 {
26
27 }
Member Function Documentation
◆ canConnectMyInputTo()
bool ossimImageStatisticsSource::canConnectMyInputTo ( ossim_int32  myInputIndex,
const ossimConnectableObject object
) const
virtual
required to be overriden by derived classes
Implements ossimConnectableObject.
Definition at line 81 of file ossimImageStatisticsSource.cpp.
References PTR_CAST.
83 {
84  return (PTR_CAST(ossimImageSource, object)&&(inputIndex < 1));
85 }
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
◆ clearStatistics()
void ossimImageStatisticsSource::clearStatistics ( )
protected
Definition at line 161 of file ossimImageStatisticsSource.cpp.
References theMax, theMean, and theMin.
Referenced by computeStatistics().
162 {
163  theMean.clear();
164  theMin.clear();
165  theMax.clear();
166 }
std::vector< ossim_float64 > theMean
std::vector< ossim_float64 > theMax
std::vector< ossim_float64 > theMin
◆ computeStatistics()
void ossimImageStatisticsSource::computeStatistics ( )
virtual
Definition at line 29 of file ossimImageStatisticsSource.cpp.
References clearStatistics(), computeStatisticsTemplate(), ossimConnectableObject::getInput(), ossimImageSource::getOutputScalarType(), ossimSource::isSourceEnabled(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, and PTR_CAST.
30 {
32  getInput());
33
34  if(anInterface&&isSourceEnabled())
35  {
37  ossimScalarType outputScalarType = anInterface->getOutputScalarType();
38
39  switch(outputScalarType)
40  {
41  case OSSIM_UCHAR:
42  {
44  break;
45  }
46  case OSSIM_USHORT16:
47  case OSSIM_USHORT11:
48  case OSSIM_USHORT12:
49  case OSSIM_USHORT13:
50  case OSSIM_USHORT14:
51  case OSSIM_USHORT15:
52  {
54  break;
55  }
56  case OSSIM_SSHORT16:
57  {
59  break;
60  }
61  case OSSIM_DOUBLE:
63  {
65  break;
66  }
67  case OSSIM_FLOAT:
69  {
71  break;
72  }
73  default :
74  {
75  break;
76  }
77  }
78  }
79 }
float ossim_float32
unsigned short ossim_uint16
double ossim_float64
signed short ossim_sint16
ossimScalarType
32 bit floating point
16 bit unsigned iteger
64 bit floating point
16 bit signed integer
unsigned char ossim_uint8
8 bit unsigned iteger
void computeStatisticsTemplate(T dummyVariable)
◆ computeStatisticsTemplate()
template<class T >
void ossimImageStatisticsSource::computeStatisticsTemplate ( dummyVariable)
protected
Definition at line 88 of file ossimImageStatisticsSource.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::disconnect(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimConnectableObject::getInput(), ossimImageSourceSequencer::getNextTile(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageSource::getNumberOfOutputBands(), ossimImageData::getWidth(), OSSIM_EMPTY, setStatsSize(), ossimImageSourceSequencer::setToStartOfSequence(), status, theMax, theMean, and theMin.
89 {
91
92  sequencer->connectMyInputTo(getInput());
93  sequencer->setToStartOfSequence();
94  ossim_uint32 bands = sequencer->getNumberOfOutputBands();
95
96  if(bands)
97  {
98  setStatsSize(bands);
99  ossimRefPtr<ossimImageData> dataObject;
100
101  while( (dataObject=sequencer->getNextTile()).valid() )
102  {
103  ossim_uint32 bandIdx = 0;
104  bands = dataObject->getNumberOfBands();
106  if((status != OSSIM_EMPTY)&&
107  (dataObject->getBuf()))
108  {
109  ossim_uint32 offsetMax = dataObject->getWidth()*dataObject->getHeight();
110  for(bandIdx = 0; bandIdx < bands; ++bandIdx)
111  {
112  ossim_float64 pixelCount = 0.0;
113  ossim_uint32 offset = 0;
114  T* dataPtr = static_cast<T*>(dataObject->getBuf(bandIdx));
115  T nullPixel = static_cast<T>(dataObject->getNullPix(bandIdx));
116  for(offset = 0; offset < offsetMax; ++offset)
117  {
118  if((*dataPtr) != nullPixel)
119  {
120  theMean[bandIdx] += *dataPtr;
121  if((*dataPtr) < theMin[bandIdx])
122  {
123  theMin[bandIdx] = (*dataPtr);
124  }
125  if((*dataPtr) > theMax[bandIdx])
126  {
127  theMax[bandIdx] = (*dataPtr);
128  }
129  ++pixelCount;
130  }
131  ++dataPtr;
132  }
133  if(pixelCount > 0)
134  {
135  theMean[bandIdx] /= pixelCount;
136  }
137  }
138  }
139  }
140  }
141
142  sequencer->disconnect();
143  sequencer = 0;
144 }
virtual void disconnect(ossimConnectableObject *object=0)
Will disconnect the object passed in.
virtual ossimRefPtr< ossimImageData > getNextTile(ossim_uint32 resLevel=0)
unsigned int ossim_uint32
virtual const ossim_float64 * getNullPix() const
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
return status
ossimDataObjectStatus
Definitions for data object status.
◆ getMax()
const std::vector< ossim_float64 > & ossimImageStatisticsSource::getMax ( ) const
Definition at line 156 of file ossimImageStatisticsSource.cpp.
References theMax.
157 {
158  return theMax;
159 }
◆ getMean()
const std::vector< ossim_float64 > & ossimImageStatisticsSource::getMean ( ) const
Definition at line 146 of file ossimImageStatisticsSource.cpp.
References theMean.
147 {
148  return theMean;
149 }
◆ getMin()
const std::vector< ossim_float64 > & ossimImageStatisticsSource::getMin ( ) const
Definition at line 151 of file ossimImageStatisticsSource.cpp.
References theMin.
152 {
153  return theMin;
154 }
◆ setStatsSize()
void ossimImageStatisticsSource::setStatsSize ( ossim_uint32  size)
protected
Definition at line 168 of file ossimImageStatisticsSource.cpp.
References OSSIM_DEFAULT_MAX_PIX_DOUBLE, OSSIM_DEFAULT_MIN_PIX_DOUBLE, size, theMax, theMean, and theMin.
Referenced by computeStatisticsTemplate().
169 {
170  theMean.resize(size);
171  theMin.resize(size);
172  theMax.resize(size);
173
174  std::fill(theMean.begin(),
175  theMean.end(),
176  (ossim_float64)0.0);
177  std::fill(theMin.begin(),
178  theMin.end(),
180  std::fill(theMax.begin(),
181  theMax.end(),
183 }
#define OSSIM_DEFAULT_MAX_PIX_DOUBLE
#define OSSIM_DEFAULT_MIN_PIX_DOUBLE
yy_size_t size
Member Data Documentation
◆ theMax
std::vector<ossim_float64> ossimImageStatisticsSource::theMax
protected
◆ theMean
std::vector<ossim_float64> ossimImageStatisticsSource::theMean
protected
◆ theMin
std::vector<ossim_float64> ossimImageStatisticsSource::theMin
protected
