ossimIndexToRgbLutFilter.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: LGPL
4 //
5 // See LICENSE.txt file in the top level directory for more details.
6 //
7 // Author: Oscar Kramer
8 //
9 //*************************************************************************
10 // $Id: ossimIndexToRgbLutFilter.cpp 23242 2015-04-08 17:31:35Z dburken $
15 #include <ossim/base/ossimCommon.h>
17 #include <ossim/base/ossimTrace.h>
21
22 RTTI_DEF1(ossimIndexToRgbLutFilter, "ossimIndexToRgbLutFilter", ossimImageSourceFilter);
23
24 static const char* MIN_VALUE_KW = "min_value";
25 static const char* MAX_VALUE_KW = "max_value";
26 static const char* MODE_KW = "mode";
27 static const char* LUT_FILE_KW = "lut_file";
28
31  theMinValue(ossim::nan()),
32  theMaxValue(ossim::nan()),
33  theMinValueOverride(false),
34  theMaxValueOverride(false),
35  theMode(REGULAR),
36  theTile(0),
37  theLutFile("")
38 {
39  setDescription("Look-up-table remapper from single-band index image to 24-bit RGB.");
40 }
41
43 {
44 }
45
47  ossim_uint32 resLevel)
48 {
49  if(!theInputConnection || (theLut.size() == 0))
50  return 0;
51
52  ossimRefPtr<ossimImageData> tile = theInputConnection->getTile(tileRect, resLevel);
53  if (!tile || !tile->getBuf())
54  return 0;
55  if(!theTile)
56  {
57  allocate();
58  if (!theTile)
59  return 0;
60  }
61
62  theTile->setImageRectangle(tileRect);
63  theTile->makeBlank();
64
65  // Quick handling special case of empty input tile:
66  if (tile->getDataObjectStatus() == OSSIM_EMPTY)
67  return theTile;
68
69  ossim_uint8* outBuf[3];
70  outBuf[0] = (ossim_uint8*)(theTile->getBuf(0));
71  outBuf[1] = (ossim_uint8*)(theTile->getBuf(1));
72  outBuf[2] = (ossim_uint8*)(theTile->getBuf(2));
73
74  ossim_uint32 maxLength = tile->getWidth()*tile->getHeight();
75  ossimRgbVector color;
76  const ossimRgbVector null_color (theTile->getNullPix(0), theTile->getNullPix(1), theTile->getNullPix(2));
77  double index;
78  std::map<double, ossimRgbVector>::const_iterator lut_entry;
79  double null_index = theInputConnection->getNullPixelValue();
80
81  for (ossim_uint32 pixel=0; pixel<maxLength; ++pixel)
82  {
83  // Convert input pixel to a double index value:
84  switch(tile->getScalarType())
85  {
86  case OSSIM_DOUBLE:
87  index = ((double*) tile->getBuf())[pixel];
88  break;
89  case OSSIM_SSHORT16:
90  index = (double)(((ossim_sint16*) tile->getBuf())[pixel]);
91  break;
92  case OSSIM_FLOAT:
94  index = (double)(((float*) tile->getBuf())[pixel]);
95  break;
96  case OSSIM_UCHAR:
97  index = (double)(((ossim_uint8*) tile->getBuf())[pixel]);
98  break;
99  case OSSIM_USHORT16:
100  case OSSIM_USHORT11:
101  case OSSIM_USHORT12:
102  case OSSIM_USHORT13:
103  case OSSIM_USHORT14:
104  case OSSIM_USHORT15:
105  index = (double)(((ossim_uint16*) tile->getBuf())[pixel]);
106  break;
107  default:
108  break;
109  }
110
111  // Do not remap null pixels, leave the output pixel "blank" which is null-pixel value:
112  if (index == null_index)
113  continue;
114
115  // REGULAR mode needs to clamp the indices to min max for non-null pixels:
116  if (theMode == REGULAR)
117  {
118  if (index < theMinValue)
119  index = theMinValue;
120  else if (index > theMaxValue)
121  index = theMaxValue;
122  }
123
124  // Now perform look-up depending on mode:
125  if (theMode == LITERAL)
126  {
127  lut_entry = theLut.find(index);
128  if (lut_entry == theLut.end())
129  color = null_color;
130  else
131  color = lut_entry->second;
132  }
133  else
134  {
135  // Vertices and Regular mode perform same interpolation here between the line segments
136  // vertices:
137  lut_entry = theLut.find(index);
138  if (lut_entry != theLut.end())
139  {
140  // Got exact match, no interpolation needed:
141  color = lut_entry->second;
142  }
143  else
144  {
145  lut_entry = theLut.upper_bound(index);
146  if ((lut_entry == theLut.end()) || (lut_entry == theLut.begin()))
147  color = null_color;
148  else
149  {
150  // Need to linearly interpolate:
151  double index_hi = lut_entry->first;
152  ossimRgbVector color_hi (lut_entry->second);
153  --lut_entry;
154  double index_lo = lut_entry->first;
155  ossimRgbVector color_lo (lut_entry->second);
156  double w_lo = (index_hi - index)/(index_hi - index_lo);
157  double w_hi = 1.0 - w_lo;
158  color.setR(ossim::round<ossim_uint8, double>( color_hi.getR()*w_hi + color_lo.getR()*w_lo ));
159  color.setG(ossim::round<ossim_uint8, double>( color_hi.getG()*w_hi + color_lo.getG()*w_lo ));
160  color.setB(ossim::round<ossim_uint8, double>( color_hi.getB()*w_hi + color_lo.getB()*w_lo ));
161  }
162  }
163  }
164
165  // Assign this output pixel:
166  outBuf[0][pixel] = color.getR();
167  outBuf[1][pixel] = color.getG();
168  outBuf[2][pixel] = color.getB();
169
170  } // end loop over tile's pixels
171
172  theTile->validate();
173  return theTile;
174 }
175
177 {
178  if(!theInputConnection) return;
179
180  theTile = ossimImageDataFactory::instance()->create(this, 3, this);
181  if(theTile.valid())
182  {
183  theTile->initialize();
184  }
185 }
186
188 {
189  // This assigns theInputConnection if one is there.
191
192  // theTile will get allocated on first getTile call.
193  theTile = 0;
194
195  if ( theInputConnection )
196  {
197  // Initialize the chain on the left hand side of us.
204  swap(theMinValue, theMaxValue);
205  }
206 }
207
208 bool ossimIndexToRgbLutFilter::saveState(ossimKeywordlist& kwl, const char* prefix)const
209 {
211  kwl.add(prefix, MIN_VALUE_KW, theMinValue, true);
212
214  kwl.add(prefix, MAX_VALUE_KW, theMaxValue, true);
215
216  ossimString value;
217  switch (theMode)
218  {
219  case LITERAL:
220  value = "literal";
221  break;
222  case VERTICES:
223  value = "vertices";
224  break;
225  default:
226  value = "regular";
227  }
228  kwl.add(prefix, MODE_KW, value.c_str(), true);
229
230  bool rtn_stat = true;
231
232  // Save the actual LUT:
233  const ossimString entry_kw ("entry");
234  ossimString color_keyword, base_keyword;
235  ossimRgbVector rgbVector;
236  ossimString blank(" ");
237
238  ossim_uint32 entry = 0;
239  std::map<double, ossimRgbVector>::const_iterator iter = theLut.begin();
240  while (iter != theLut.end())
241  {
242  base_keyword = entry_kw + ossimString::toString(entry);
243  if ((theMode == LITERAL) || (theMode == VERTICES))
244  {
245  // Index and color are sub-entries for these modes:
246  kwl.add(prefix, (base_keyword+".index").chars(), iter->first);
247  color_keyword = base_keyword + ".color";
248  }
249  else
250  {
251  color_keyword = base_keyword;
252  }
253
254  rgbVector = iter->second;
255  value = ossimString::toString((int)rgbVector.getR()) + blank +
256  ossimString::toString((int)rgbVector.getG()) + blank +
257  ossimString::toString((int)rgbVector.getB());
258  kwl.add(prefix, color_keyword.chars(), value.chars());
259  ++iter;
260  ++entry;
261  }
262
263  rtn_stat &= ossimImageSourceFilter::saveState(kwl, prefix);
264  return rtn_stat;
265 }
266
267 bool ossimIndexToRgbLutFilter::loadState(const ossimKeywordlist& orig_kwl, const char* prefix)
268 {
269  bool return_state = true;
270  ossimKeywordlist* kwl = new ossimKeywordlist(orig_kwl); // need non-const copy
271
272  // First look for a LUT filename, and add its contents to the original KWL:
273  theLutFile = kwl->find(prefix, LUT_FILE_KW);
274  if (!theLutFile.empty())
275  {
276  // Need new (non const) KWL to hold merged contents, maintaining proper prefix if any:
277  ossimKeywordlist lut_kwl;
278  if (lut_kwl.addFile(theLutFile))
279  kwl->add(prefix, lut_kwl, false); // appends all entries of lut_kwl with prefix before adding
280  }
281
282  theMinValueOverride = false;
283  ossimString lookup = kwl->find(prefix, MIN_VALUE_KW);
284  if(!lookup.empty())
285  {
286  theMinValue =lookup.toDouble();
287  theMinValueOverride = true;
288  }
289
290  theMaxValueOverride = false;
291  lookup = kwl->find(prefix, MAX_VALUE_KW);
292  if(!lookup.empty())
293  {
294  theMaxValue = lookup.toDouble();
295  theMaxValueOverride = true;
296  }
297
298  lookup = kwl->find(prefix, MODE_KW);
299  if (lookup.contains("literal"))
300  theMode = LITERAL;
301  else if (lookup.contains("vertices"))
302  theMode = VERTICES;
303  else
304  theMode = REGULAR;
305
306  return_state &= initializeLut(kwl, prefix);
307  return_state &= ossimImageSourceFilter::loadState(orig_kwl, prefix);
308
309  delete kwl;
310  return return_state;
311 }
312
313 bool ossimIndexToRgbLutFilter::initializeLut(const ossimKeywordlist* kwl, const char* prefix)
314 {
315  theLut.clear();
316
317  const ossimString entry_kw ("entry");
318  ossimString keyword, base_keyword;
319  ossimString indexStr, rgbStr;
320  ossimString blank(" ");
321  std::vector<ossimString> rgbList;
322  double index;
323  ossimRgbVector rgbVector (0,0,0);
324  bool rtn_state = true;
325
326  ossim_uint32 numEntries=0;
327  while (true)
328  {
329  base_keyword = entry_kw + ossimString::toString(numEntries);
330  if ((theMode == LITERAL) || (theMode == VERTICES))
331  {
332  // Index and color are subentries for this mode:
333  keyword = base_keyword + ".index";
334  indexStr = kwl->find(prefix, keyword.chars());
335  if (indexStr.empty())
336  break;
337
338  index = indexStr.toDouble();
339  keyword = base_keyword + ".color";
340  rgbStr = kwl->find(prefix, keyword.chars());
341  }
342  else
343  {
344  // REGULAR mode: index is computed later to arrive at equally-spaced vertices. For now,
345  // just store entry number as index:
346  index = (double) numEntries;
347  keyword = base_keyword;
348  rgbStr = kwl->find(prefix, keyword.chars());
349  if (rgbStr.empty())
350  {
351  // Perhaps old bloated form with separate keywords for R, G, B
352  rgbStr = kwl->find(prefix, (keyword + ".r").chars());
353  rgbStr += " ";
354  rgbStr += kwl->find(prefix, (keyword + ".g").chars());
355  rgbStr += " ";
356  rgbStr += kwl->find(prefix, (keyword + ".b").chars());
357  if (rgbStr.length() < 5)
358  break;
359  }
360  }
361
362  rgbStr.split(rgbList, blank, true);
363  if (rgbList.size() != 3)
364  {
365  ossimNotify(ossimNotifyLevel_WARN)<<"ossimIndexToRgbLutFilter::initializeLut() -- "
366  "Bad color specification in LUT KWL. LUT is not properly initialized."<<endl;
367  return false;
368  }
369
370  rgbVector.setR(rgbList[0].toUInt8());
371  rgbVector.setG(rgbList[1].toUInt8());
372  rgbVector.setB(rgbList[2].toUInt8());
373  theLut.insert(std::pair<double, ossimRgbVector>(index, rgbVector));
374  rgbList.clear();
375  ++numEntries;
376  }
377
378  // For REGULAR mode, need to adjust the indices to reflect a piecewise linear LUT with equally
379  // spaced vertices:
380  if (theMode == REGULAR)
381  {
382  std::map<double, ossimRgbVector> orig_lut = theLut;
383  std::map<double, ossimRgbVector>::iterator iter = orig_lut.begin();
384  theLut.clear();
385
386  if (numEntries == 1)
387  {
388  // Insert the implied start index at black and endpoint at specified color:
389  theLut.insert(std::pair<double, ossimRgbVector>(theMinValue, ossimRgbVector (1, 1, 1)));
390  theLut.insert(std::pair<double, ossimRgbVector>(theMaxValue, iter->second));
391  }
392  else
393  {
394  // Loop to create equally-spaced vertices between min and max index values:
395  double interval = (theMaxValue - theMinValue) / (numEntries - 1);
396  while (iter != orig_lut.end())
397  {
398  index = theMinValue + iter->first*interval;
399  theLut.insert(std::pair<double, ossimRgbVector>(index, iter->second));
400  ++iter;
401  }
402  }
403  }
404
405  return rtn_state;
406 }
407
409 {
410  if(isSourceEnabled())
411  {
412  return 3;
413  }
415 }
416
418 {
419  if(isSourceEnabled())
420  {
421  return OSSIM_UCHAR;
422  }
423
425 }
426
428 {
429  theLutFile = file;
430  if(file.exists())
431  {
433  loadState(kwl);
434  }
435 }
436
438 {
439  return theMinValue;
440 }
441
443 {
444  return theMaxValue;
445 }
446
448 {
449  theMinValue = value;
450 }
451
453 {
454  theMaxValue = value;
455 }
456
458 {
459  return 0.0;
460 }
461
463 {
464  return 1.0;
465 }
466
468 {
469  return 255.0;
470 }
471
472
ossim_uint32 getNumberOfOutputBands() const
virtual void setDescription(const ossimString &description)
unsigned char getR() const
void allocate()
Called on first getTile, will initialize all data needed.
bool addFile(const char *file)
bool valid() const
Definition: ossimRefPtr.h:75
double nan()
Definition: ossimCommon.h:135
This code was derived from https://gist.github.com/mshockwave.
Definition: Barrier.h:8
void setR(unsigned char R)
virtual bool saveState(ossimKeywordlist &kwl, const char *prefix=NULL) const
bool contains(char aChar) const
Definition: ossimString.h:58
Numeric to string methods.
bool initializeLut(const ossimKeywordlist *kwl, const char *prefix=0)
unsigned short ossim_uint16
virtual void initialize()
Initialize the data buffer.
void setB(unsigned char B)
bool exists() const
virtual bool loadState(const ossimKeywordlist &kwl, const char *prefix=NULL)
std::string::size_type length() const
Definition: ossimString.h:408
signed short ossim_sint16
void setLut(const ossimFilename &file)
Set lookup table(lut) method.
unsigned int ossim_uint32
virtual const ossim_float64 * getNullPix() const
const char * chars() const
For backward compatibility.
Definition: ossimString.h:77
double toDouble() const
unsigned char getB() const
void setG(unsigned char G)
ossimScalarType
unsigned char getG() const
virtual void makeBlank()
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &origin, ossim_uint32 resLevel=0)
const char * c_str() const
Definition: ossimString.h:396
bool empty() const
Definition: ossimString.h:411
std::map< double, ossimRgbVector > theLut
virtual void initialize()=0
32 bit floating point
16 bit unsigned iteger
64 bit floating point
16 bit signed integer
unsigned char ossim_uint8
8 bit unsigned iteger
