Public Types | Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ossimIndexToRgbLutFilter Class Reference
#include <ossimIndexToRgbLutFilter.h>
Inheritance diagram for ossimIndexToRgbLutFilter:
ossimImageSourceFilter ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Types
enum  Mode { LITERAL = 0, VERTICES = 1, REGULAR = 2 }
 ossimIndexToRgbLutFilter ()
virtual ~ossimIndexToRgbLutFilter ()
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &origin, ossim_uint32 resLevel=0)
ossim_uint32 getNumberOfOutputBands () const
void setMode (Mode mode)
Mode getMode () const
void setLut (const ossimFilename &file)
 Set lookup table(lut) method. More...
double getMinValue () const
double getMaxValue () const
void setMinValue (double value)
void setMaxValue (double value)
virtual void initialize ()
virtual bool saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
void allocate ()
 Called on first getTile, will initialize all data needed. More...
bool initializeLut (const ossimKeywordlist *kwl, const char *prefix=0)
virtual ~ossimReferenced ()
std::map< double, ossimRgbVectortheLut
double theMinValue
double theMaxValue
bool theMinValueOverride
bool theMaxValueOverride
Mode theMode
ossimFilename theLutFile
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Detailed Description
Definition at line 103 of file ossimIndexToRgbLutFilter.h.
◆ Mode
◆ ossimIndexToRgbLutFilter()
ossimIndexToRgbLutFilter::ossimIndexToRgbLutFilter ( )
Definition at line 29 of file ossimIndexToRgbLutFilter.cpp.
References ossimConnectableObject::setDescription().
33  theMinValueOverride(false),
34  theMaxValueOverride(false),
36  theTile(0),
37  theLutFile("")
38 {
39  setDescription("Look-up-table remapper from single-band index image to 24-bit RGB.");
40 }
virtual void setDescription(const ossimString &description)
ossimImageSourceFilter(ossimObject *owner=NULL)
double nan()
Definition: ossimCommon.h:135
◆ ~ossimIndexToRgbLutFilter()
ossimIndexToRgbLutFilter::~ossimIndexToRgbLutFilter ( )
virtual
Definition at line 42 of file ossimIndexToRgbLutFilter.cpp.
43 {
44 }
Member Function Documentation
◆ allocate()
void ossimIndexToRgbLutFilter::allocate ( )
protected
Definition at line 176 of file ossimIndexToRgbLutFilter.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimImageSourceFilter::theInputConnection, theTile, and ossimRefPtr< T >::valid().
Referenced by getTile().
177 {
178  if(!theInputConnection) return;
179
180  theTile = ossimImageDataFactory::instance()->create(this, 3, this);
181  if(theTile.valid())
182  {
183  theTile->initialize();
184  }
185 }
bool valid() const
Definition: ossimRefPtr.h:75
virtual void initialize()
Initialize the data buffer.
◆ getMaxPixelValue()
double ossimIndexToRgbLutFilter::getMaxPixelValue ( ossim_uint32  band = 0) const
virtual
Definition at line 467 of file ossimIndexToRgbLutFilter.cpp.
468 {
469  return 255.0;
470 }
◆ getMaxValue()
double ossimIndexToRgbLutFilter::getMaxValue ( ) const
Definition at line 442 of file ossimIndexToRgbLutFilter.cpp.
References theMaxValue.
443 {
444  return theMaxValue;
445 }
◆ getMinPixelValue()
double ossimIndexToRgbLutFilter::getMinPixelValue ( ossim_uint32  band = 0) const
virtual
Definition at line 462 of file ossimIndexToRgbLutFilter.cpp.
463 {
464  return 1.0;
465 }
◆ getMinValue()
double ossimIndexToRgbLutFilter::getMinValue ( ) const
Definition at line 437 of file ossimIndexToRgbLutFilter.cpp.
References theMinValue.
438 {
439  return theMinValue;
440 }
◆ getMode()
Mode ossimIndexToRgbLutFilter::getMode ( ) const
inline
Definition at line 120 of file ossimIndexToRgbLutFilter.h.
◆ getNullPixelValue()
double ossimIndexToRgbLutFilter::getNullPixelValue ( ossim_uint32  band = 0) const
virtual
Definition at line 457 of file ossimIndexToRgbLutFilter.cpp.
458 {
459  return 0.0;
460 }
◆ getNumberOfOutputBands()
ossim_uint32 ossimIndexToRgbLutFilter::getNumberOfOutputBands ( ) const
virtual
Definition at line 408 of file ossimIndexToRgbLutFilter.cpp.
References ossimImageSource::getNumberOfOutputBands(), and ossimSource::isSourceEnabled().
409 {
410  if(isSourceEnabled())
411  {
412  return 3;
413  }
415 }
◆ getOutputScalarType()
ossimScalarType ossimIndexToRgbLutFilter::getOutputScalarType ( ) const
virtual
Definition at line 417 of file ossimIndexToRgbLutFilter.cpp.
References ossimImageSource::getOutputScalarType(), ossimSource::isSourceEnabled(), and OSSIM_UCHAR.
418 {
419  if(isSourceEnabled())
420  {
421  return OSSIM_UCHAR;
422  }
423
425 }
8 bit unsigned iteger
◆ getTile()
ossimRefPtr< ossimImageData > ossimIndexToRgbLutFilter::getTile ( const ossimIrect rect,
ossim_uint32  resLevel = 0
virtual
Returns
Definition at line 46 of file ossimIndexToRgbLutFilter.cpp.
References allocate(), ossimRgbVector::getB(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimRgbVector::getG(), ossimImageData::getHeight(), ossimImageData::getNullPix(), ossimImageSource::getNullPixelValue(), ossimRgbVector::getR(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossimImageData::getWidth(), LITERAL, ossimImageData::makeBlank(), OSSIM_DOUBLE, OSSIM_EMPTY, OSSIM_FLOAT, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, REGULAR, ossimRgbVector::setB(), ossimRgbVector::setG(), ossimImageData::setImageRectangle(), ossimRgbVector::setR(), ossimImageSourceFilter::theInputConnection, theLut, theMaxValue, theMinValue, theMode, theTile, and ossimImageData::validate().
48 {
49  if(!theInputConnection || (theLut.size() == 0))
50  return 0;
51
52  ossimRefPtr<ossimImageData> tile = theInputConnection->getTile(tileRect, resLevel);
53  if (!tile || !tile->getBuf())
54  return 0;
55  if(!theTile)
56  {
57  allocate();
58  if (!theTile)
59  return 0;
60  }
61
62  theTile->setImageRectangle(tileRect);
63  theTile->makeBlank();
64
65  // Quick handling special case of empty input tile:
66  if (tile->getDataObjectStatus() == OSSIM_EMPTY)
67  return theTile;
68
69  ossim_uint8* outBuf[3];
70  outBuf[0] = (ossim_uint8*)(theTile->getBuf(0));
71  outBuf[1] = (ossim_uint8*)(theTile->getBuf(1));
72  outBuf[2] = (ossim_uint8*)(theTile->getBuf(2));
73
74  ossim_uint32 maxLength = tile->getWidth()*tile->getHeight();
75  ossimRgbVector color;
76  const ossimRgbVector null_color (theTile->getNullPix(0), theTile->getNullPix(1), theTile->getNullPix(2));
77  double index;
78  std::map<double, ossimRgbVector>::const_iterator lut_entry;
79  double null_index = theInputConnection->getNullPixelValue();
80
81  for (ossim_uint32 pixel=0; pixel<maxLength; ++pixel)
82  {
83  // Convert input pixel to a double index value:
84  switch(tile->getScalarType())
85  {
86  case OSSIM_DOUBLE:
87  index = ((double*) tile->getBuf())[pixel];
88  break;
89  case OSSIM_SSHORT16:
90  index = (double)(((ossim_sint16*) tile->getBuf())[pixel]);
91  break;
92  case OSSIM_FLOAT:
94  index = (double)(((float*) tile->getBuf())[pixel]);
95  break;
96  case OSSIM_UCHAR:
97  index = (double)(((ossim_uint8*) tile->getBuf())[pixel]);
98  break;
99  case OSSIM_USHORT16:
100  case OSSIM_USHORT11:
101  case OSSIM_USHORT12:
102  case OSSIM_USHORT13:
103  case OSSIM_USHORT14:
104  case OSSIM_USHORT15:
105  index = (double)(((ossim_uint16*) tile->getBuf())[pixel]);
106  break;
107  default:
108  break;
109  }
110
111  // Do not remap null pixels, leave the output pixel "blank" which is null-pixel value:
112  if (index == null_index)
113  continue;
114
115  // REGULAR mode needs to clamp the indices to min max for non-null pixels:
116  if (theMode == REGULAR)
117  {
118  if (index < theMinValue)
119  index = theMinValue;
120  else if (index > theMaxValue)
121  index = theMaxValue;
122  }
123
124  // Now perform look-up depending on mode:
125  if (theMode == LITERAL)
126  {
127  lut_entry = theLut.find(index);
128  if (lut_entry == theLut.end())
129  color = null_color;
130  else
131  color = lut_entry->second;
132  }
133  else
134  {
135  // Vertices and Regular mode perform same interpolation here between the line segments
136  // vertices:
137  lut_entry = theLut.find(index);
138  if (lut_entry != theLut.end())
139  {
140  // Got exact match, no interpolation needed:
141  color = lut_entry->second;
142  }
143  else
144  {
145  lut_entry = theLut.upper_bound(index);
146  if ((lut_entry == theLut.end()) || (lut_entry == theLut.begin()))
147  color = null_color;
148  else
149  {
150  // Need to linearly interpolate:
151  double index_hi = lut_entry->first;
152  ossimRgbVector color_hi (lut_entry->second);
153  --lut_entry;
154  double index_lo = lut_entry->first;
155  ossimRgbVector color_lo (lut_entry->second);
156  double w_lo = (index_hi - index)/(index_hi - index_lo);
157  double w_hi = 1.0 - w_lo;
158  color.setR(ossim::round<ossim_uint8, double>( color_hi.getR()*w_hi + color_lo.getR()*w_lo ));
159  color.setG(ossim::round<ossim_uint8, double>( color_hi.getG()*w_hi + color_lo.getG()*w_lo ));
160  color.setB(ossim::round<ossim_uint8, double>( color_hi.getB()*w_hi + color_lo.getB()*w_lo ));
161  }
162  }
163  }
164
165  // Assign this output pixel:
166  outBuf[0][pixel] = color.getR();
167  outBuf[1][pixel] = color.getG();
168  outBuf[2][pixel] = color.getB();
169
170  } // end loop over tile's pixels
171
172  theTile->validate();
173  return theTile;
174 }
unsigned char getR() const
void allocate()
void setR(unsigned char R)
unsigned short ossim_uint16
void setB(unsigned char B)
signed short ossim_sint16
unsigned int ossim_uint32
virtual const ossim_float64 * getNullPix() const
unsigned char getB() const
void setG(unsigned char G)
unsigned char getG() const
virtual void makeBlank()
std::map< double, ossimRgbVector > theLut
32 bit floating point
16 bit unsigned iteger
64 bit floating point
16 bit signed integer
unsigned char ossim_uint8
◆ initialize()
void ossimIndexToRgbLutFilter::initialize ( )
virtual
Definition at line 187 of file ossimIndexToRgbLutFilter.cpp.
References ossimImageSource::getMaxPixelValue(), ossimImageSource::getMinPixelValue(), ossimImageSourceFilter::initialize(), ossimImageSource::initialize(), ossimImageSourceFilter::theInputConnection, theMaxValue, theMaxValueOverride, theMinValue, theMinValueOverride, and theTile.
Referenced by ossimPointCloudTool::execute().
188 {
189  // This assigns theInputConnection if one is there.
191
192  // theTile will get allocated on first getTile call.
193  theTile = 0;
194
195  if ( theInputConnection )
196  {
197  // Initialize the chain on the left hand side of us.
204  swap(theMinValue, theMaxValue);
205  }
206 }
virtual void initialize()=0
◆ initializeLut()
bool ossimIndexToRgbLutFilter::initializeLut ( const ossimKeywordlist kwl,
const char *  prefix = 0
protected
Definition at line 313 of file ossimIndexToRgbLutFilter.cpp.
References ossimString::chars(), ossimString::empty(), ossimKeywordlist::find(), ossimString::length(), LITERAL, ossimNotify(), ossimNotifyLevel_WARN, REGULAR, ossimRgbVector::setB(), ossimRgbVector::setG(), ossimRgbVector::setR(), ossimString::split(), theLut, theMaxValue, theMinValue, theMode, ossimString::toDouble(), ossimString::toString(), and VERTICES.
314 {
315  theLut.clear();
316
317  const ossimString entry_kw ("entry");
318  ossimString keyword, base_keyword;
319  ossimString indexStr, rgbStr;
320  ossimString blank(" ");
321  std::vector<ossimString> rgbList;
322  double index;
323  ossimRgbVector rgbVector (0,0,0);
324  bool rtn_state = true;
325
326  ossim_uint32 numEntries=0;
327  while (true)
328  {
329  base_keyword = entry_kw + ossimString::toString(numEntries);
330  if ((theMode == LITERAL) || (theMode == VERTICES))
331  {
332  // Index and color are subentries for this mode:
333  keyword = base_keyword + ".index";
334  indexStr = kwl->find(prefix, keyword.chars());
335  if (indexStr.empty())
336  break;
337
338  index = indexStr.toDouble();
339  keyword = base_keyword + ".color";
340  rgbStr = kwl->find(prefix, keyword.chars());
341  }
342  else
343  {
344  // REGULAR mode: index is computed later to arrive at equally-spaced vertices. For now,
345  // just store entry number as index:
346  index = (double) numEntries;
347  keyword = base_keyword;
348  rgbStr = kwl->find(prefix, keyword.chars());
349  if (rgbStr.empty())
350  {
351  // Perhaps old bloated form with separate keywords for R, G, B
352  rgbStr = kwl->find(prefix, (keyword + ".r").chars());
353  rgbStr += " ";
354  rgbStr += kwl->find(prefix, (keyword + ".g").chars());
355  rgbStr += " ";
356  rgbStr += kwl->find(prefix, (keyword + ".b").chars());
357  if (rgbStr.length() < 5)
358  break;
359  }
360  }
361
362  rgbStr.split(rgbList, blank, true);
363  if (rgbList.size() != 3)
364  {
365  ossimNotify(ossimNotifyLevel_WARN)<<"ossimIndexToRgbLutFilter::initializeLut() -- "
366  "Bad color specification in LUT KWL. LUT is not properly initialized."<<endl;
367  return false;
368  }
369
370  rgbVector.setR(rgbList[0].toUInt8());
371  rgbVector.setG(rgbList[1].toUInt8());
372  rgbVector.setB(rgbList[2].toUInt8());
373  theLut.insert(std::pair<double, ossimRgbVector>(index, rgbVector));
374  rgbList.clear();
375  ++numEntries;
376  }
377
378  // For REGULAR mode, need to adjust the indices to reflect a piecewise linear LUT with equally
379  // spaced vertices:
380  if (theMode == REGULAR)
381  {
382  std::map<double, ossimRgbVector> orig_lut = theLut;
383  std::map<double, ossimRgbVector>::iterator iter = orig_lut.begin();
384  theLut.clear();
385
386  if (numEntries == 1)
387  {
388  // Insert the implied start index at black and endpoint at specified color:
389  theLut.insert(std::pair<double, ossimRgbVector>(theMinValue, ossimRgbVector (1, 1, 1)));
390  theLut.insert(std::pair<double, ossimRgbVector>(theMaxValue, iter->second));
391  }
392  else
393  {
394  // Loop to create equally-spaced vertices between min and max index values:
395  double interval = (theMaxValue - theMinValue) / (numEntries - 1);
396  while (iter != orig_lut.end())
397  {
398  index = theMinValue + iter->first*interval;
399  theLut.insert(std::pair<double, ossimRgbVector>(index, iter->second));
400  ++iter;
401  }
402  }
403  }
404
405  return rtn_state;
406 }
Numeric to string methods.
std::string::size_type length() const
Definition: ossimString.h:408
const char * chars() const
For backward compatibility.
Definition: ossimString.h:77
double toDouble() const
bool empty() const
Definition: ossimString.h:411
◆ loadState()
bool ossimIndexToRgbLutFilter::loadState ( const ossimKeywordlist kwl,
const char *  prefix = NULL
virtual
Definition at line 267 of file ossimIndexToRgbLutFilter.cpp.
References ossimKeywordlist::find(), and theLutFile.
Referenced by ossimPointCloudTool::execute(), and setLut().
268 {
269  bool return_state = true;
270  ossimKeywordlist* kwl = new ossimKeywordlist(orig_kwl); // need non-const copy
271
272  // First look for a LUT filename, and add its contents to the original KWL:
273  theLutFile = kwl->find(prefix, LUT_FILE_KW);
274  if (!theLutFile.empty())
275  {
276  // Need new (non const) KWL to hold merged contents, maintaining proper prefix if any:
277  ossimKeywordlist lut_kwl;
278  if (lut_kwl.addFile(theLutFile))
279  kwl->add(prefix, lut_kwl, false); // appends all entries of lut_kwl with prefix before adding
280  }
281
282  theMinValueOverride = false;
283  ossimString lookup = kwl->find(prefix, MIN_VALUE_KW);
284  if(!lookup.empty())
285  {
286  theMinValue =lookup.toDouble();
287  theMinValueOverride = true;
288  }
289
290  theMaxValueOverride = false;
291  lookup = kwl->find(prefix, MAX_VALUE_KW);
292  if(!lookup.empty())
293  {
294  theMaxValue = lookup.toDouble();
295  theMaxValueOverride = true;
296  }
297
298  lookup = kwl->find(prefix, MODE_KW);
299  if (lookup.contains("literal"))
300  theMode = LITERAL;
301  else if (lookup.contains("vertices"))
302  theMode = VERTICES;
303  else
304  theMode = REGULAR;
305
306  return_state &= initializeLut(kwl, prefix);
307  return_state &= ossimImageSourceFilter::loadState(orig_kwl, prefix);
308
309  delete kwl;
310  return return_state;
311 }
bool addFile(const char *file)
bool contains(char aChar) const
Definition: ossimString.h:58
bool initializeLut(const ossimKeywordlist *kwl, const char *prefix=0)
bool empty() const
◆ saveState()
bool ossimIndexToRgbLutFilter::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 208 of file ossimIndexToRgbLutFilter.cpp.
References ossimKeywordlist::add(), and theMinValueOverride.
209 {
211  kwl.add(prefix, MIN_VALUE_KW, theMinValue, true);
212
214  kwl.add(prefix, MAX_VALUE_KW, theMaxValue, true);
215
216  ossimString value;
217  switch (theMode)
218  {
219  case LITERAL:
220  value = "literal";
221  break;
222  case VERTICES:
223  value = "vertices";
224  break;
225  default:
226  value = "regular";
227  }
228  kwl.add(prefix, MODE_KW, value.c_str(), true);
229
230  bool rtn_stat = true;
231
232  // Save the actual LUT:
233  const ossimString entry_kw ("entry");
234  ossimString color_keyword, base_keyword;
235  ossimRgbVector rgbVector;
236  ossimString blank(" ");
237
238  ossim_uint32 entry = 0;
239  std::map<double, ossimRgbVector>::const_iterator iter = theLut.begin();
240  while (iter != theLut.end())
241  {
242  base_keyword = entry_kw + ossimString::toString(entry);
243  if ((theMode == LITERAL) || (theMode == VERTICES))
244  {
245  // Index and color are sub-entries for these modes:
246  kwl.add(prefix, (base_keyword+".index").chars(), iter->first);
247  color_keyword = base_keyword + ".color";
248  }
249  else
250  {
251  color_keyword = base_keyword;
252  }
253
254  rgbVector = iter->second;
255  value = ossimString::toString((int)rgbVector.getR()) + blank +
256  ossimString::toString((int)rgbVector.getG()) + blank +
257  ossimString::toString((int)rgbVector.getB());
258  kwl.add(prefix, color_keyword.chars(), value.chars());
259  ++iter;
260  ++entry;
261  }
262
263  rtn_stat &= ossimImageSourceFilter::saveState(kwl, prefix);
264  return rtn_stat;
265 }
const char * c_str() const
Definition: ossimString.h:396
◆ setLut()
void ossimIndexToRgbLutFilter::setLut ( const ossimFilename file)
This opens the keyword list and initializes lut.
CAUTION: Requires theMinValue, theMaxValue, and theMode to be set. Typically a connection is made prior to this call. If not connected to an input, "min", "max" and "mode" keywords should be passed in the keyword list file.
Parameters
fileKeyword list containing lut.
Definition at line 427 of file ossimIndexToRgbLutFilter.cpp.
References ossimFilename::exists(), loadState(), and theLutFile.
428 {
429  theLutFile = file;
430  if(file.exists())
431  {
433  loadState(kwl);
434  }
435 }
bool exists() const
virtual bool loadState(const ossimKeywordlist &kwl, const char *prefix=NULL)
◆ setMaxValue()
void ossimIndexToRgbLutFilter::setMaxValue ( double  value)
Definition at line 452 of file ossimIndexToRgbLutFilter.cpp.
453 {
454  theMaxValue = value;
455 }
◆ setMinValue()
void ossimIndexToRgbLutFilter::setMinValue ( double  value)
Definition at line 447 of file ossimIndexToRgbLutFilter.cpp.
448 {
449  theMinValue = value;
450 }
◆ setMode()
void ossimIndexToRgbLutFilter::setMode ( Mode  mode)
inline
Definition at line 119 of file ossimIndexToRgbLutFilter.h.
Member Data Documentation
◆ theLut
std::map<double, ossimRgbVector> ossimIndexToRgbLutFilter::theLut
protected
Definition at line 158 of file ossimIndexToRgbLutFilter.h.
Referenced by getTile(), and initializeLut().
◆ theLutFile
ossimFilename ossimIndexToRgbLutFilter::theLutFile
protected
Definition at line 166 of file ossimIndexToRgbLutFilter.h.
Referenced by loadState(), and setLut().
◆ theMaxValue
double ossimIndexToRgbLutFilter::theMaxValue
protected
◆ theMaxValueOverride
bool ossimIndexToRgbLutFilter::theMaxValueOverride
protected
Definition at line 163 of file ossimIndexToRgbLutFilter.h.
Referenced by initialize().
◆ theMinValue
double ossimIndexToRgbLutFilter::theMinValue
protected
◆ theMinValueOverride
bool ossimIndexToRgbLutFilter::theMinValueOverride
protected
Definition at line 162 of file ossimIndexToRgbLutFilter.h.
Referenced by initialize(), and saveState().
◆ theMode
Mode ossimIndexToRgbLutFilter::theMode
protected
Definition at line 164 of file ossimIndexToRgbLutFilter.h.
◆ theTile
ossimRefPtr<ossimImageData> ossimIndexToRgbLutFilter::theTile
protected
Definition at line 165 of file ossimIndexToRgbLutFilter.h.
Referenced by allocate(), getTile(), and initialize().
