11 #ifndef ossimJpeg12ReaderFactory_HEADER 12 #define ossimJpeg12ReaderFactory_HEADER 1 52 const char* prefix=0)
const;
68 const char* prefix=0)
const;
static ossimJpeg12ReaderFactory * instance()
static method to return instance (the only one) of this class.
virtual void getSupportedExtensions(ossimImageHandlerFactoryBase::UniqueStringList &extensionList) const
Method to add supported extension to the list, like "jp2".
virtual ossimRefPtr< ossimImageHandler > openOverview(const ossimFilename &file) const
Open overview that takes a file name.
virtual void getImageHandlersByMimeType(ossimImageHandlerFactoryBase::ImageHandlerList &result, const ossimString &mimeType) const
Will add to the result list and handler that supports the passed in mime type.
bool hasExcludedExtension(const ossimFilename &file) const
Method to weed out extensions that this plugin knows it does not support.
virtual void getTypeNameList(std::vector< ossimString > &typeList) const
Adds ossimJpeg12Writer to the typeList.
virtual ~ossimJpeg12ReaderFactory()
virtual destructor
void operator=(const ossimJpeg12ReaderFactory &)
hidden from use copy constructor
virtual ossimImageHandler * open(const ossimFilename &fileName, bool openOverview=true) const
open that takes a file name.
virtual void getImageHandlersBySuffix(ossimImageHandlerFactoryBase::ImageHandlerList &result, const ossimString &ext) const
Will add to the result list any handler that supports the passed in extensions.
This class defines an abstract Handler which all image handlers(loaders) should derive from...
std::vector< ossimRefPtr< ossimImageHandler > > ImageHandlerList
virtual ossimObject * createObject(const ossimString &typeName) const
createObject that takes a class name (ossimJpeg12Reader)
Factory for image reader.
hidden from use default constructor
