25 "ossimJpeg12ReaderFactory",
41 static const char* M =
"ossimJpeg12ReaderFactory::open(filename) -- ";
53 if(reader->
open(fileName))
break;
71 const char* prefix)
const 76 <<
"ossimJpeg12ReaderFactory::open(kwl, prefix) DEBUG: entered..." 96 if(reader->
loadState(kwl, prefix) ==
false)
106 <<
"ossimJpeg12ReaderFactory::open(kwl, prefix) DEBUG: leaving..." 117 if(typeName ==
"ossimJpeg12NitfReader")
126 const char* prefix)
const 128 return this->
open(kwl, prefix);
132 std::vector<ossimString>& typeList)
const 134 typeList.push_back(
ossimString(
"ossimJpeg12NitfReader"));
148 if ( (ext ==
"tif") ||
167 if( (testExt ==
"ntf") || (testExt ==
"nitf") )
184 if(mimeTypeTest ==
"nitf")
static ossimJpeg12ReaderFactory * instance()
static method to return instance (the only one) of this class.
virtual bool open()=0
Pure virtual open.
void setOpenOverviewFlag(bool flag)
Sets theOpenOverviewFlag.
virtual void getSupportedExtensions(ossimImageHandlerFactoryBase::UniqueStringList &extensionList) const
Method to add supported extension to the list, like "jp2".
virtual ossimRefPtr< ossimImageHandler > openOverview(const ossimFilename &file) const
Open overview that takes a file name.
RTTI_DEF1(ossimJpeg12ReaderFactory, "ossimJpeg12ReaderFactory", ossimImageHandlerFactoryBase)
ossimJpeg12NitfReader class for reading NITF images with 12 bit jpeg compressed blocks using libjpeg-...
virtual void getImageHandlersByMimeType(ossimImageHandlerFactoryBase::ImageHandlerList &result, const ossimString &mimeType) const
Will add to the result list and handler that supports the passed in mime type.
std::string::iterator end()
virtual bool openOverview()
Searches for an overview.
bool hasExcludedExtension(const ossimFilename &file) const
Method to weed out extensions that this plugin knows it does not support.
void push_back(char c)
Equivalent to insert(end(), c).
virtual void getTypeNameList(std::vector< ossimString > &typeList) const
Adds ossimJpeg12Writer to the typeList.
virtual ~ossimJpeg12ReaderFactory()
virtual destructor
std::string::iterator begin()
void operator=(const ossimJpeg12ReaderFactory &)
hidden from use copy constructor
virtual ossimImageHandler * open(const ossimFilename &fileName, bool openOverview=true) const
open that takes a file name.
virtual void getImageHandlersBySuffix(ossimImageHandlerFactoryBase::ImageHandlerList &result, const ossimString &ext) const
Will add to the result list any handler that supports the passed in extensions.
This class defines an abstract Handler which all image handlers(loaders) should derive from...
std::vector< ossimRefPtr< ossimImageHandler > > ImageHandlerList
virtual ossimObject * createObject(const ossimString &typeName) const
createObject that takes a class name (ossimJpeg12Reader)
static const char * IMAGE_FILE_KW
static const char * FILENAME_KW
Factory for image reader.
hidden from use default constructor
