Public Member Functions | Static Public Member Functions | Protected Member Functions | List of all members
ossimJpeg12ReaderFactory Class Reference
Factory for image reader. More...
#include <ossimJpeg12ReaderFactory.h>
Inheritance diagram for ossimJpeg12ReaderFactory:
ossimImageHandlerFactoryBase ossimObjectFactory ossimObject ossimReferenced
virtual ~ossimJpeg12ReaderFactory ()
 virtual destructor More...
virtual ossimImageHandleropen (const ossimFilename &fileName, bool openOverview=true) const
 open that takes a file name. More...
virtual ossimImageHandleropen (const ossimKeywordlist &kwl, const char *prefix=0) const
 Open overview that takes a file name. More...
virtual ossimObjectcreateObject (const ossimString &typeName) const
 createObject that takes a class name (ossimJpeg12Reader) More...
virtual ossimObjectcreateObject (const ossimKeywordlist &kwl, const char *prefix=0) const
 Creates and object given a keyword list and prefix. More...
virtual void getTypeNameList (std::vector< ossimString > &typeList) const
 Adds ossimJpeg12Writer to the typeList. More...
virtual void getSupportedExtensions (ossimImageHandlerFactoryBase::UniqueStringList &extensionList) const
 Method to add supported extension to the list, like "jp2". More...
virtual void getImageHandlersBySuffix (ossimImageHandlerFactoryBase::ImageHandlerList &result, const ossimString &ext) const
 Will add to the result list any handler that supports the passed in extensions. More...
virtual void getImageHandlersByMimeType (ossimImageHandlerFactoryBase::ImageHandlerList &result, const ossimString &mimeType) const
 Will add to the result list and handler that supports the passed in mime type. More...
- Public Member Functions inherited from ossimImageHandlerFactoryBase
virtual ossimRefPtr< ossimImageHandleropen (std::shared_ptr< ossim::istream > &str, const std::string &connectionString, bool openOverview=true) const
 Open method that takes a stream. More...
virtual ossimRefPtr< ossimImageHandleropen (std::shared_ptr< ossim::ImageHandlerState > state) const
virtual ossimRefPtr< ossimImageHandleropenOverview (const ossimFilename &file) const
virtual ossimRefPtr< ossimImageHandleropenOverview (std::shared_ptr< ossim::istream > &str, const ossimString &connectionString) const
- Public Member Functions inherited from ossimObjectFactory
virtual ~ossimObjectFactory ()
 ossimObject ()
virtual ~ossimObject ()
 Generic print method. More...
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
static ossimJpeg12ReaderFactoryinstance ()
 static method to return instance (the only one) of this class. More...
bool hasExcludedExtension (const ossimFilename &file) const
 Method to weed out extensions that this plugin knows it does not support. More...
 hidden from use default constructor More...
 ossimJpeg12ReaderFactory (const ossimJpeg12ReaderFactory &)
 hidden from use copy constructor More...
void operator= (const ossimJpeg12ReaderFactory &)
virtual ~ossimReferenced ()
Additional Inherited Members
- Public Types inherited from ossimImageHandlerFactoryBase
typedef UniqueList< ossimStringUniqueStringList
typedef std::vector< ossimRefPtr< ossimImageHandler > > ImageHandlerList
Detailed Description
Definition at line 21 of file ossimJpeg12ReaderFactory.h.
◆ ~ossimJpeg12ReaderFactory()
ossimJpeg12ReaderFactory::~ossimJpeg12ReaderFactory ( )
virtual
virtual destructor
Definition at line 28 of file ossimJpeg12ReaderFactory.cpp.
29 {
30 }
◆ ossimJpeg12ReaderFactory() [1/2]
ossimJpeg12ReaderFactory::ossimJpeg12ReaderFactory ( )
protected
Definition at line 192 of file ossimJpeg12ReaderFactory.cpp.
192 {}
◆ ossimJpeg12ReaderFactory() [2/2]
ossimJpeg12ReaderFactory::ossimJpeg12ReaderFactory ( const ossimJpeg12ReaderFactory )
protected
Definition at line 194 of file ossimJpeg12ReaderFactory.cpp.
194 {}
Member Function Documentation
◆ createObject() [1/2]
ossimObject * ossimJpeg12ReaderFactory::createObject ( const ossimString typeName) const
virtual
Parameters
typeNameShould be "ossimJpeg12Reader".
Returns
pointer to image writer on success, NULL on failure.
Implements ossimObjectFactory.
Definition at line 113 of file ossimJpeg12ReaderFactory.cpp.
References ossimRefPtr< T >::release().
115 {
116  ossimRefPtr<ossimObject> result = 0;
117  if(typeName == "ossimJpeg12NitfReader")
118  {
119  result = new ossimJpeg12NitfReader;
120  }
121  return result.release();
122 }
ossimJpeg12NitfReader class for reading NITF images with 12 bit jpeg compressed blocks using libjpeg-...
T * release()
Definition: ossimRefPtr.h:93
◆ createObject() [2/2]
ossimObject * ossimJpeg12ReaderFactory::createObject ( const ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Parameters
kwlThe keyword list.
prefixthe keyword list prefix.
Returns
pointer to image handler on success, NULL on failure.
Definition at line 124 of file ossimJpeg12ReaderFactory.cpp.
References open().
127 {
128  return this->open(kwl, prefix);
129 }
virtual ossimImageHandler * open(const ossimFilename &fileName, bool openOverview=true) const
◆ getImageHandlersByMimeType()
void ossimJpeg12ReaderFactory::getImageHandlersByMimeType ( ossimImageHandlerFactoryBase::ImageHandlerList result,
const ossimString mimeType
) const
virtual
Reimplemented from ossimImageHandlerFactoryBase.
Definition at line 176 of file ossimJpeg12ReaderFactory.cpp.
References ossimString::begin(), ossimString::end(), and ossimString::push_back().
179 {
180  ossimString test(mimeType.begin(), mimeType.begin()+6);
181  if(test == "image/")
182  {
183  ossimString mimeTypeTest(mimeType.begin() + 6, mimeType.end());
184  if(mimeTypeTest == "nitf")
185  {
186  result.push_back(new ossimJpeg12NitfReader);
187  }
188  }
189 }
std::string::iterator end()
Definition: ossimString.h:423
void push_back(char c)
Equivalent to insert(end(), c).
Definition: ossimString.h:905
std::string::iterator begin()
Definition: ossimString.h:420
◆ getImageHandlersBySuffix()
void ossimJpeg12ReaderFactory::getImageHandlersBySuffix ( ossimImageHandlerFactoryBase::ImageHandlerList result,
const ossimString ext
) const
virtual
Definition at line 162 of file ossimJpeg12ReaderFactory.cpp.
References ossimString::downcase(), and ossimString::push_back().
165 {
166  ossimString testExt = ext.downcase();
167  if( (testExt == "ntf") || (testExt == "nitf") )
168  {
169  result.push_back(new ossimJpeg12NitfReader);
170  }
171 }
◆ getSupportedExtensions()
void ossimJpeg12ReaderFactory::getSupportedExtensions ( ossimImageHandlerFactoryBase::UniqueStringList extensionList) const
virtual
Parameters
extensionListThe list to add to.
Implements ossimImageHandlerFactoryBase.
Definition at line 137 of file ossimJpeg12ReaderFactory.cpp.
139 {
140  /* Nothing to do here. */
141 }
◆ getTypeNameList()
void ossimJpeg12ReaderFactory::getTypeNameList ( std::vector< ossimString > &  typeList) const
virtual
Parameters
typeListList to add to.
Definition at line 131 of file ossimJpeg12ReaderFactory.cpp.
133 {
134  typeList.push_back(ossimString("ossimJpeg12NitfReader"));
135 }
◆ hasExcludedExtension()
bool ossimJpeg12ReaderFactory::hasExcludedExtension ( const ossimFilename file) const
protected
This is to avoid a costly open on say a tiff or jpeg that is not handled by this plugin.
Returns
true if extension, false if not.
Definition at line 143 of file ossimJpeg12ReaderFactory.cpp.
References ossimString::downcase(), and ossimFilename::ext().
145 {
146  bool result = false;
147  ossimString ext = file.ext().downcase();
148  if ( (ext == "tif") ||
149  (ext == "tiff") ||
150  (ext == "jpg") ||
151  (ext == "jpeg") ||
152  (ext == "png") )
153  {
154  result = true;
155  }
156  return result;
157 }
ossimString ext() const
◆ instance()
ossimJpeg12ReaderFactory * ossimJpeg12ReaderFactory::instance ( )
static
Returns
pointer to instance of this class.
Definition at line 32 of file ossimJpeg12ReaderFactory.cpp.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
33 {
34  static ossimJpeg12ReaderFactory inst;
35  return &inst;
36 }
◆ open() [1/2]
ossimImageHandler * ossimJpeg12ReaderFactory::open ( const ossimFilename fileName,
bool  openOverview = true
) const
virtual
Parameters
fileThe file to open.
openOverviewIf true image handler will attempt to open overview. default = true
Returns
Definition at line 38 of file ossimJpeg12ReaderFactory.cpp.
Referenced by createObject().
40 {
41  static const char* M = "ossimJpeg12ReaderFactory::open(filename) -- ";
42  if(traceDebug())
43  ossimNotify(ossimNotifyLevel_DEBUG)<<M<<"Entered with filename <"<<fileName<<">" ;
44
46  while (true)
47  {
48  if (hasExcludedExtension(fileName)) break;
49
50  if (traceDebug()) ossimNotify(ossimNotifyLevel_DEBUG)<<M<< "Trying ossimJpeg12NitfReader...";
51  reader = new ossimJpeg12NitfReader;
53  if(reader->open(fileName)) break;
54
55  reader = 0;
56  break;
57  }
58
59  if (traceDebug())
60  {
61  if (reader.valid())
62  ossimNotify(ossimNotifyLevel_DEBUG)<<M<< " SUCCESS" << std::endl;
63  else
64  ossimNotify(ossimNotifyLevel_DEBUG)<<M<< " Open FAILED" << std::endl;
65  }
66
67  return reader.release();
68 }
virtual bool open()=0
Pure virtual open.
void setOpenOverviewFlag(bool flag)
Sets theOpenOverviewFlag.
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossimRefPtr< ossimImageHandler > openOverview(const ossimFilename &file) const
bool hasExcludedExtension(const ossimFilename &file) const
T * release()
◆ open() [2/2]
ossimImageHandler * ossimJpeg12ReaderFactory::open ( const ossimKeywordlist kwl,
) const
virtual
Parameters
fileFile to open.
Returns
ossimRefPtr to image handler on success or null on failure.
Definition at line 70 of file ossimJpeg12ReaderFactory.cpp.
72 {
73  if(traceDebug())
74  {
76  << "ossimJpeg12ReaderFactory::open(kwl, prefix) DEBUG: entered..."
77  << std::endl;
78  }
79
81
82  // To save time check the file name first.
83  const char* lookup = kwl.find(prefix, ossimKeywordNames::FILENAME_KW);
84  if (!lookup)
85  {
86  // Deprecated...
87  lookup = kwl.find(prefix, ossimKeywordNames::IMAGE_FILE_KW);
88  }
89
90  if (lookup)
91  {
92  ossimFilename f = lookup;
93  if ( hasExcludedExtension(f) == false )
94  {
95  reader = new ossimJpeg12NitfReader;
96  if(reader->loadState(kwl, prefix) == false)
97  {
98  reader = 0;
99  }
100  }
101  }
102
103  if(traceDebug())
104  {
106  << "ossimJpeg12ReaderFactory::open(kwl, prefix) DEBUG: leaving..."
107  << std::endl;
108  }
109
110  return reader.release();
111 }
T * release()
static const char * IMAGE_FILE_KW
static const char * FILENAME_KW
◆ operator=()
void ossimJpeg12ReaderFactory::operator= ( const ossimJpeg12ReaderFactory )
protected
Definition at line 196 of file ossimJpeg12ReaderFactory.cpp.
196 {}
