37 static const ossimIpt DEFAULT_TILE_SIZE(1024, 1024);
52 static const char OSSIM_ID[] =
"$Id: ossimKakaduJp2Writer.cpp 23121 2015-01-30 01:24:56Z dburken $";
59 m_ownsStreamFlag(false)
64 <<
"ossimKakaduJp2Writer::ossimKakaduJp2Writer entered" 147 static const char MODULE[] =
"ossimKakaduJp2Writer::writeStream";
152 << MODULE <<
" entered..." << endl;
173 << MODULE <<
" DEBUG:" 174 <<
"\noutputTilesWide: " << outputTilesWide
175 <<
"\noutputTilesHigh: " << outputTilesHigh
176 <<
"\nnumberOfTiles: " << numberOfTiles
226 << MODULE <<
" ERROR:" 227 <<
"Error returned writing tile: " 236 << MODULE <<
" ERROR:" 237 <<
"Error returned writing tile: " <<
tileNumber 276 << MODULE <<
" exit status = " << (result?
"true":
"false\n")
297 tmpFile +=
"-tmp.tif";
331 const char* prefix)
const 378 <<
"ossimKakaduJp2Writer::open()\n" 379 <<
"File " <<
theFilename << (result ?
" opened" :
" not opened")
419 (imageType ==
"image/jp2") )
428 if ( property.
valid() )
452 std::vector<ossimString>& propertyNames)
const virtual bool loadState(const ossimKeywordlist &kwl, const char *prefix=0)
virtual ossimString getLongName() const
virtual void slaveProcessTiles()
virtual void setOutputImageType(ossim_int32 type)
virtual ossimString getShortName() const
virtual void create(ossim::ostream *os, ossimScalarType scalar, ossim_uint32 bands, const ossimIrect &imageRect, const ossimIpt &tileSize, ossim_uint32 tilesToWrite, bool jp2)
Create method.
virtual void computeAlphaChannel()
Computes the alpha channel.
bool needsAborting() const
virtual bool isMaster() const
Pushes this's names onto the list of property names.
ossimRefPtr< ossimProperty > getProperty(const ossimString &name) const
virtual void setToStartOfSequence()
static const ossimErrorCode OSSIM_OK
bool writeGmlBox(const ossimImageGeometry *geom, const ossimIrect &rect)
Writes the GML box to the jp2.
virtual void finish()
Finish method.
ossimKakaduJp2Writer()
default constructor
virtual bool writeStream()
Method to write the image to a stream.
ossim_int64 getNumberOfTiles() const
virtual ~ossimKakaduJp2Writer()
virtual ossimRefPtr< ossimImageData > getNextTile(ossim_uint32 resLevel=0)
virtual ossimString getExtension() const
Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for...
Pure virtual base class for image file writers.
Will set the property whose name matches the argument "property->getName()".
void getPropertyNames(std::vector< ossimString > &propertyNames) const
saves the state of the object.
bool saveState(ossimKeywordlist &kwl, const char *prefix=0) const
virtual const char * what() const
Returns the error message.
std::string::size_type size() const
ossimRefPtr< ossimImageSourceSequencer > theInputConnection
virtual bool setOutputStream(std::ostream &stream)
Sets the output stream to write to.
ossimFilename theFilename
This will return the bounding rect of the source.
unsigned int ossim_uint32
virtual ossimString getClassName() const
void openJp2Codestream()
Calls "open_codestream" on the m_jp2Target.
bool getAlphaChannelFlag() const
Retrieve the writer's setting for whether or not to add an alpha channel to the output png image...
virtual ossimPixelType getPixelType() const
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if not defined...
bool writeGeotiffBox(const ossimImageGeometry *geom, const ossimIrect &rect, const ossimFilename &tmpFile, ossimPixelType pixelType)
Writes the geotiff box to the jp2.
virtual bool isOpen() const
virtual bool setProperty(ossimRefPtr< ossimProperty > property)
virtual bool writeTile(ossimImageData &srcTile)
Write tile method.
virtual void getImageTypeList(std::vector< ossimString > &imageTypeList) const
Appends this writer image types to list "imageTypeList".
ossim_int64 getNumberOfTilesHorizontal() const
virtual ossimErrorCode getErrorStatus() const
bool writeGeotiffBox(ossimKakaduCompressor *compressor)
Writes geotiff box if input has good geometry.
ossimFilename fileNoExtension() const
const char * c_str() const
Returns a pointer to a null-terminated array of characters representing the string's contents...
bool hasImageType(const ossimString &imageType) const
bool hasImageType(const ossimString& imageType) const
virtual bool writeFile()
Writes the file to disk or a stream.
std::ostream * m_outputStream
const ossimIrect & getAreaOfInterest() const
std::basic_ofstream< char > ofstream
Class for char output file streams.
#define RTTI_DEF1(cls, name, b1)
virtual void setPercentComplete(double percentComplete)
bool writeGmlBox(ossimKakaduCompressor *compressor)
Writes GML box if input has good geometry.
virtual void setTileSize(const ossimIpt &tileSize)
ossim_int64 getNumberOfTilesVertical() const
std::basic_ostream< char > ostream
Base class for char output streams.
ossimKakaduCompressor * m_compressor
virtual bool getOutputHasInternalOverviews(void) const
Examples of writers that always generate internal overviews are ossim_kakadu_jp2 and ossim_kakadu_nit...
