23 static const char* MIN_VALUE_KW =
"min_value";
24 static const char* MAX_VALUE_KW =
"max_value";
28 setDescription(
"Remaps input from min-max to full range (0-1) of normalized float..");
45 if (!tile || !tile->
getBuf())
66 for (
int i=0; i<numBands; ++i)
104 if (pixel == null_pixel)
113 outBuf[offset] = pixel;
151 for (
163 bool rtn_stat =
true;
166 if ((numBands == 0) || (numBands !=
m_maxValues.size()))
169 for (
175 kwl.
add(prefix, MIN_VALUE_KW, minstr.str().c_str(),
true);
176 kwl.
add(prefix, MAX_VALUE_KW, maxstr.str().c_str(),
true);
184 bool return_state =
true;
188 vector<ossimString> minimums;
189 vector<ossimString> maximums;
194 minimums = minVals.
split(
195 maximums = maxVals.
split(
196 if (minimums.size() != maximums.size())
199 for (
int i=0; i<minimums.size(); ++i)
virtual void setDescription(const ossimString &description)
virtual bool loadState(const ossimKeywordlist &kwl, const char *prefix=NULL)
virtual bool saveState(ossimKeywordlist &kwl, const char *prefix=NULL) const
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
virtual const ossim_uint16 * getUshortBuf() const
virtual const ossim_uint8 * getUcharBuf() const
double nan()
RTTI_DEF1(ossimLinearStretchRemapper, "ossimLinearRemapper", ossimImageSourceFilter)
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
virtual const ossim_sint16 * getSshortBuf() const
virtual void initialize()
Initialize the data buffer.
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
std::vector< double > m_maxValues
unsigned int ossim_uint32
virtual ~ossimLinearStretchRemapper()
std::vector< double > m_minValues
void setMaxPixelValue(double value, ossim_uint32 band=0)
virtual const ossim_float32 * getFloatBuf() const
virtual void makeBlank()
ossimRefPtr< ossimImageData > m_tile
void allocate()
Called on first getTile, will initialize all data needed.
void setMinPixelValue(double value, ossim_uint32 band=0)
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &origin, ossim_uint32 resLevel=0)
virtual const ossim_float64 * getDoubleBuf() const
