ossimLinearStretchRemapper Class Reference
#include <ossimLinearStretchRemapper.h>
Inheritance diagram for ossimLinearStretchRemapper:
ossimImageSourceFilter ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimLinearStretchRemapper ()
virtual ~ossimLinearStretchRemapper ()
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &origin, ossim_uint32 resLevel=0)
void setMinPixelValue (double value, ossim_uint32 band=0)
void setMaxPixelValue (double value, ossim_uint32 band=0)
virtual void initialize ()
virtual bool saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
Protected Member Functions
void allocate ()
 Called on first getTile, will initialize all data needed. More...
virtual ~ossimReferenced ()
Protected Attributes
std::vector< double > m_minValues
std::vector< double > m_maxValues
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Additional Inherited Members
Detailed Description
Definition at line 34 of file ossimLinearStretchRemapper.h.
◆ ossimLinearStretchRemapper()
ossimLinearStretchRemapper::ossimLinearStretchRemapper ( )
Definition at line 26 of file ossimLinearStretchRemapper.cpp.
References ossimConnectableObject::setDescription().
27 {
28  setDescription("Remaps input from min-max to full range (0-1) of normalized float..");
29 }
virtual void setDescription(const ossimString &description)
◆ ~ossimLinearStretchRemapper()
ossimLinearStretchRemapper::~ossimLinearStretchRemapper ( )
virtual
Definition at line 31 of file ossimLinearStretchRemapper.cpp.
32 {
33 }
Member Function Documentation
◆ allocate()
void ossimLinearStretchRemapper::allocate ( )
protected
Definition at line 120 of file ossimLinearStretchRemapper.cpp.
References ossimImageDataFactory::create(), ossimImageSource::getNumberOfOutputBands(), ossimImageSource::getTileHeight(), ossimImageSource::getTileWidth(), ossimImageData::initialize(), ossimImageDataFactory::instance(), m_tile, OSSIM_NORMALIZED_DOUBLE, ossimImageSourceFilter::theInputConnection, and ossimRefPtr< T >::valid().
Referenced by initialize().
121 {
122  if(!theInputConnection)
123  return;
124
130  if(m_tile.valid())
131  {
132  m_tile->initialize();
133  }
134 }
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
virtual void initialize()
Initialize the data buffer.
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
ossimRefPtr< ossimImageData > m_tile
◆ getMaxPixelValue()
double ossimLinearStretchRemapper::getMaxPixelValue ( ossim_uint32  band = 0) const
virtual
Definition at line 215 of file ossimLinearStretchRemapper.cpp.
References m_maxValues, and ossim::nan().
216 {
217  if (band< m_maxValues.size())
218  return m_maxValues[band];
219  return ossim::nan();
220 }
double nan()
Definition: ossimCommon.h:135
◆ getMinPixelValue()
double ossimLinearStretchRemapper::getMinPixelValue ( ossim_uint32  band = 0) const
virtual
Definition at line 208 of file ossimLinearStretchRemapper.cpp.
References m_minValues, and ossim::nan().
209 {
210  if (band< m_minValues.size())
211  return m_minValues[band];
212  return ossim::nan();
213 }
double nan()
◆ getOutputScalarType()
virtual ossimScalarType ossimLinearStretchRemapper::getOutputScalarType ( ) const
inlinevirtual
Definition at line 56 of file ossimLinearStretchRemapper.h.
References OSSIM_NORMALIZED_DOUBLE.
56 { return OSSIM_NORMALIZED_DOUBLE; }
◆ getTile()
ossimRefPtr< ossimImageData > ossimLinearStretchRemapper::getTile ( const ossimIrect rect,
ossim_uint32  resLevel = 0
virtual
Returns
Definition at line 35 of file ossimLinearStretchRemapper.cpp.
References ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getDoubleBuf(), ossimImageData::getFloatBuf(), ossimImageData::getHeight(), ossimImageSource::getNullPixelValue(), ossimImageSource::getNumberOfOutputBands(), ossimRectilinearDataObject::getScalarType(), ossimImageData::getSshortBuf(), ossimImageSource::getTile(), ossimImageData::getUcharBuf(), ossimImageData::getUshortBuf(), ossimImageData::getWidth(), initialize(), m_maxValues, m_minValues, m_tile, ossimImageData::makeBlank(), OSSIM_DOUBLE, OSSIM_EMPTY, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimImageData::setImageRectangle(), ossimSource::theEnableFlag, ossimImageSourceFilter::theInputConnection, and ossimImageData::validate().
37 {
39  return 0;
40
41  ossimRefPtr<ossimImageData> tile = theInputConnection->getTile(tileRect, resLevel);
42  if ( !theEnableFlag )
43  return tile;
44
45  if (!tile || !tile->getBuf())
46  return 0;
47  if(!m_tile)
48  {
49  initialize();
50  if (!m_tile)
51  return 0;
52  }
53
54  m_tile->setImageRectangle(tileRect);
55  m_tile->makeBlank();
56
57  // Quick handling special case of empty input tile:
58  if (tile->getDataObjectStatus() == OSSIM_EMPTY)
59  return m_tile;
60
61  ossim_uint32 maxLength = tile->getWidth()*tile->getHeight();
62  double pixel;
63  double null_pixel = theInputConnection->getNullPixelValue();
64
66  for (int i=0; i<numBands; ++i)
67  {
68  double delta = m_maxValues[i] - m_minValues[i];
69  if (delta == 0)
70  continue;
71  double* outBuf = m_tile->getDoubleBuf(i);
72  for (ossim_uint32 offset=0; offset<maxLength; ++offset)
73  {
74  // Convert input pixel to a double index value:
75  switch(tile->getScalarType())
76  {
77  case OSSIM_DOUBLE:
79  pixel = tile->getDoubleBuf(i)[offset];
80  break;
81  case OSSIM_SSHORT16:
82  pixel = (double)(tile->getSshortBuf(i)[offset]);
83  break;
84  case OSSIM_FLOAT:
86  pixel = (double)(tile->getFloatBuf(i)[offset]);
87  break;
88  case OSSIM_UCHAR:
89  pixel = (double)(tile->getUcharBuf(i)[offset]);
90  break;
91  case OSSIM_USHORT16:
92  case OSSIM_USHORT11:
93  case OSSIM_USHORT12:
94  case OSSIM_USHORT13:
95  case OSSIM_USHORT14:
96  case OSSIM_USHORT15:
97  pixel = (double)(tile->getUshortBuf(i)[offset]);
98  break;
99  default:
100  break;
101  }
102
103  // Do not remap null pixels, leave the output pixel "blank" which is null-pixel value:
104  if (pixel == null_pixel)
105  continue;
106
107  // Do linear remap:
108  pixel = (pixel-m_minValues[i])/delta;
109  if (pixel < 0.0)
110  pixel = 0.0;
111  if (pixel > 1.0)
112  pixel = 1.0;
113  outBuf[offset] = pixel;
114  }
115  }
116  m_tile->validate();
117  return m_tile;
118 }
virtual const ossim_uint16 * getUshortBuf() const
virtual const ossim_uint8 * getUcharBuf() const
bool theEnableFlag
Definition: ossimSource.h:62
virtual const ossim_sint16 * getSshortBuf() const
unsigned int ossim_uint32
virtual const ossim_float32 * getFloatBuf() const
virtual void makeBlank()
32 bit floating point
16 bit unsigned iteger
64 bit floating point
16 bit signed integer
8 bit unsigned iteger
virtual const ossim_float64 * getDoubleBuf() const
◆ initialize()
void ossimLinearStretchRemapper::initialize ( )
virtual
Definition at line 136 of file ossimLinearStretchRemapper.cpp.
References allocate(), ossimImageSource::getMaxPixelValue(), ossimImageSource::getMinPixelValue(), ossimImageSource::getNumberOfOutputBands(), ossimImageSourceFilter::initialize(), m_maxValues, m_minValues, m_tile, and ossimImageSourceFilter::theInputConnection.
Referenced by getTile().
137 {
138  // This assigns theInputConnection if one is there.
140
141  m_tile = 0;
142  if ( theInputConnection )
143  {
144  // Initialize the chain on the left hand side of us.
145  //theInputConnection->initialize(); This is done by base class
146  int numBands = theInputConnection->getNumberOfOutputBands();
147  if ((m_minValues.size() != numBands) && (m_maxValues.size() != numBands))
148  {
149  m_minValues.resize(numBands);
150  m_maxValues.resize(numBands);
151  for (int i=0; i<numBands; ++i)
152  {
155  }
156  }
157  allocate();
158  }
159 }
void allocate()
◆ loadState()
bool ossimLinearStretchRemapper::loadState ( const ossimKeywordlist kwl,
const char *  prefix = NULL
virtual
Definition at line 182 of file ossimLinearStretchRemapper.cpp.
References ossimKeywordlist::find(), m_maxValues, and m_minValues.
183 {
184  bool return_state = true;
185  m_minValues.clear();
186  m_maxValues.clear();
187
188  vector<ossimString> minimums;
189  vector<ossimString> maximums;
190  ossimString minVals = kwl.find(prefix, MIN_VALUE_KW);
191  ossimString maxVals = kwl.find(prefix, MAX_VALUE_KW);
192  if(!minVals.empty() && !maxVals.empty())
193  {
194  minimums = minVals.split(" ");
195  maximums = maxVals.split(" ");
196  if (minimums.size() != maximums.size())
197  return false;
198
199  for (int i=0; i<minimums.size(); ++i)
200  {
201  m_minValues[i] = minimums[i].toDouble();
202  m_maxValues[i] = maximums[i].toDouble();
203  }
204  }
205  return true;
206 }
bool empty() const
Definition: ossimString.h:411
◆ saveState()
bool ossimLinearStretchRemapper::saveState ( ossimKeywordlist kwl,
) const
virtual
Definition at line 161 of file ossimLinearStretchRemapper.cpp.
References ossimKeywordlist::add(), m_maxValues, and m_minValues.
162 {
163  bool rtn_stat = true;
164  ostringstream minstr, maxstr;
165  int numBands = m_minValues.size();
166  if ((numBands == 0) || (numBands != m_maxValues.size()))
167  rtn_stat = false;
168
169  for (int i=0; i<numBands; ++i)
170  {
171  minstr << " " << m_minValues[i];
172  maxstr << " " << m_maxValues[i];
173  }
174
175  kwl.add(prefix, MIN_VALUE_KW, minstr.str().c_str(), true);
176  kwl.add(prefix, MAX_VALUE_KW, maxstr.str().c_str(), true);
177
178  rtn_stat &= ossimImageSourceFilter::saveState(kwl, prefix);
179  return rtn_stat;
180 }
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
◆ setMaxPixelValue()
void ossimLinearStretchRemapper::setMaxPixelValue ( double  value,
Definition at line 229 of file ossimLinearStretchRemapper.cpp.
References m_maxValues.
230 {
231  if (m_maxValues.size() <= band)
232  m_maxValues.resize(band+1);
233  m_maxValues[band] = value;
234 }
◆ setMinPixelValue()
void ossimLinearStretchRemapper::setMinPixelValue ( double  value,
Definition at line 222 of file ossimLinearStretchRemapper.cpp.
References m_minValues.
223 {
224  if (m_minValues.size() <= band)
225  m_minValues.resize(band+1);
226  m_minValues[band] = value;
227 }
Member Data Documentation
◆ m_maxValues
std::vector<double> ossimLinearStretchRemapper::m_maxValues
protected
◆ m_minValues
std::vector<double> ossimLinearStretchRemapper::m_minValues
protected
◆ m_tile
ossimRefPtr<ossimImageData> ossimLinearStretchRemapper::m_tile
protected
Definition at line 67 of file ossimLinearStretchRemapper.h.
Referenced by allocate(), getTile(), and initialize().
