ossimMapProjectionInfo.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 // Copyright (C) 2001 ImageLinks Inc.
3 //
4 // License: See top level LICENSE.txt file.
5 //
6 // Author: David Burken
7 //
8 // Description:
9 // Class for encapsulate projection info given a projection, datum, and
10 // output rectangle.
11 //
12 // NOTE:
13 // - Output rectangle should be relative to the center of pixels.
14 // Shifts will be made for "pixel is area" internally.
15 //
16 //*******************************************************************
17 // $Id: ossimMapProjectionInfo.cpp 13025 2008-06-13 17:06:30Z sbortman $
18
19 #include <cstdlib>
20 #include <fstream>
21 #include <time.h>
22
23 using namespace std;
24
27 #include <ossim/base/ossimTrace.h>
28 #include <ossim/base/ossimCommon.h>
30 #include <ossim/base/ossimDatum.h>
33 #include <ossim/base/ossimDrect.h>
37
38 //***
39 // Static trace for debugging.
40 //***
41 static ossimTrace traceDebug("ossimMapProjectionInfo::debug");
42
43 //***
44 // Keywords for getStateFrom/saveStateTo.
45 //***
47 "viewinfo.output_readme_in_us_ft_flag";
48
49 const char* ossimMapProjectionInfo::PIXEL_TYPE_KW = "viewinfo.pixel_type";
50
52 "viewinfo.readme_image_string";
53
55  const ossimDrect& output_rect)
56  :
57  theProjection (proj),
58  theErrorStatus (false),
59  theLinesPerImage (0),
60  thePixelsPerLine (0),
61  theCornerGroundPt (),
62  theCornerEastingNorthingPt (),
63  theCenterGroundPt (),
64  theCenterEastingNorthingPt (0.0, 0.0),
65  thePixelType (OSSIM_PIXEL_IS_POINT),
66  theOutputInfoInFeetFlag (false),
67  theImageInfoString ()
68 {
69  if (!theProjection)
70  {
71  theErrorStatus = true;
73  << "FATAL ossimMapProjectionInfo::ossimMapProjectionInfo: "
74  << "Null projection pointer passed to constructor!"
75  << "\nError status has been set. Returning..."
76  << std::endl;
77  return;
78  }
79
80  initializeMembers(output_rect);
81
82  if (traceDebug())
83  {
85  << "DEBUG ossimMapProjectionInfo::ossimMapProjectionInfo:\n"
86  << "output_rect: " << output_rect << "\n"
87  << *this << std::endl;
88  }
89 }
90
92 {
93 }
94
96 {
97  return theErrorStatus;
98 }
99
101 {
102  theBoundingRect = rect;
103  theLinesPerImage = ossim::round<int>(rect.height());
104  thePixelsPerLine = ossim::round<int>(rect.width());
105
107  theCornerGroundPt[0]);
108
110  theCornerGroundPt[1]);
111
113  theCornerGroundPt[2]);
114
115
117  theCornerGroundPt[3]);
118
121
124
127
130
134  theCornerEastingNorthingPt[3].x) / 4.0;
135
139  theCornerEastingNorthingPt[3].y) / 4.0;
140
142 }
143
144
146  const char* prefix)const
147 {
148  theProjection->saveState(kwl, prefix);
149
151  {
152  ossimGpt gpt = ulGroundPt();
153  kwl.add(prefix,
155  ossimDpt(gpt).toString().c_str(),
156  true);
157  kwl.add(prefix,
159  ossimUnitTypeLut::instance()->getEntryString(OSSIM_DEGREES),
160  true);
161  }
162  else
163  {
165  kwl.add(prefix,
167  dpt.toString().c_str(),
168  true);
169  kwl.add(prefix,
171  ossimUnitTypeLut::instance()->getEntryString(OSSIM_METERS),
172  true);
173  }
174 }
175
177 {
178  if (!os)
179  {
180  return os;
181  }
182
183  os << setiosflags(ios::left)
184  << setiosflags(ios::fixed)
185  << "ossimMapProjectionInfo Data Members:\n"
186  << "Projection name: " << theProjection->getProjectionName()
187  << setw(30) << "\nOutput pixel type:"
188  << ((getPixelType() == OSSIM_PIXEL_IS_POINT) ? "pixel is point" :
189  "pixel is area")
190  << setw(30) << "\nMeters per pixel:"
191  << getMetersPerPixel()
192  << setw(30) << "\nUS survey feet per pixel:"
194  << setw(30) << "\nDecimal degrees per pixel:"
196  << setw(30) << "\nNumber of lines:"
198  << setw(30) << "\nNumber of pixels:"
200  << setw(30) << "\nUpper left ground point:"
201  << theCornerGroundPt[0]
202  << setw(30) << "\nUpper right ground point:"
203  << theCornerGroundPt[1]
204  << setw(30) << "\nLower right ground point:"
205  << theCornerGroundPt[2]
206  << setw(30) << "\nLower left ground point:"
207  << theCornerGroundPt[3]
208  << setw(30) << "\nUpper left easting_northing:"
210  << setw(30) << "\nUpper right easting_northing:"
212  << setw(30) << "\nLower right easting_northing:"
214  << setw(30) << "\nLower left easting_northing:"
216  << setw(30) << "\nCenter ground point:"
218  << setw(30) << "\nCenter easting_northing:"
220  << "\nMap Projection dump:";
221  theProjection->print(os);
222
223  return os;
224 }
225
227 {
228  thePixelType = type;
229 }
230
232 {
233  return thePixelType;
234 }
235
237 {
239 }
240
242 {
244 }
245
247 {
248  return theImageInfoString;
249 }
250
252 {
253  theImageInfoString = string;
254 }
255
257 {
258  return theProjection;
259 }
260
262 {
264  {
265  ossimDpt mpp = getMetersPerPixel();
266  ossimDpt pt;
267  pt.x = theCornerEastingNorthingPt[0].x - (mpp.x / 2.0);
268  pt.y = theCornerEastingNorthingPt[0].y + (mpp.y / 2.0);
269  return pt;
270  }
271  else
272  {
273  return theCornerEastingNorthingPt[0];
274  }
275 }
276
278 {
280  {
281  ossimDpt mpp = getMetersPerPixel();
282  ossimDpt pt;
283  pt.x = theCornerEastingNorthingPt[1].x + (mpp.x / 2.0);
284  pt.y = theCornerEastingNorthingPt[1].y + (mpp.y / 2.0);
285  return pt;
286  }
287  else
288  {
289  return theCornerEastingNorthingPt[1];
290  }
291 }
292
294 {
296  {
297  ossimDpt mpp = getMetersPerPixel();
298  ossimDpt pt;
299  pt.x = theCornerEastingNorthingPt[2].x + (mpp.x / 2.0);
300  pt.y = theCornerEastingNorthingPt[2].y - (mpp.y / 2.0);
301  return pt;
302  }
303  else
304  {
305  return theCornerEastingNorthingPt[2];
306  }
307 }
308
310 {
312  {
313  ossimDpt mpp = getMetersPerPixel();
314  ossimDpt pt;
315  pt.x = theCornerEastingNorthingPt[3].x - (mpp.x / 2.0);
316  pt.y = theCornerEastingNorthingPt[3].y - (mpp.y / 2.0);
317  return pt;
318  }
319  else
320  {
321  return theCornerEastingNorthingPt[3];
322  }
323 }
324
326 {
328  {
330  ossimGpt gpt;
331  gpt.latd(theCornerGroundPt[0].latd() + (ddpp.y / 2.0));
332  gpt.lond(theCornerGroundPt[0].lond() - (ddpp.x / 2.0));
333  return gpt;
334  }
335  else
336  {
337  return theCornerGroundPt[0];
338  }
339 }
340
342 {
344  {
346  ossimGpt gpt;
347  gpt.latd(theCornerGroundPt[1].latd() + (ddpp.y / 2.0));
348  gpt.lond(theCornerGroundPt[1].lond() + (ddpp.x / 2.0));
349  return gpt;
350  }
351  else
352  {
353  return theCornerGroundPt[1];
354  }
355 }
356
358 {
360  {
362  ossimGpt gpt;
363  gpt.latd(theCornerGroundPt[2].latd() - (ddpp.y / 2.0));
364  gpt.lond(theCornerGroundPt[2].lond() + (ddpp.x / 2.0));
365  return gpt;
366  }
367  else
368  {
369  return theCornerGroundPt[2];
370  }
371 }
372
374 {
376  {
378  ossimGpt gpt;
379  gpt.latd(theCornerGroundPt[3].latd() - (ddpp.y / 2.0));
380  gpt.lond(theCornerGroundPt[3].lond() - (ddpp.x / 2.0));
381  return gpt;
382  }
383  else
384  {
385  return theCornerGroundPt[3];
386  }
387 }
388
390 {
391  // Center is simply center, no shift for pixel is area...
392  return theCenterGroundPt;
393 }
394
396 {
398 }
399
401 {
402  return theLinesPerImage;
403 }
404
406 {
407  return thePixelsPerLine;
408 }
409
411  const char* )
412 {
413  const char* lookupReturn = kwl.find(README_IMAGE_STRING_KW);
414
415  //***
416  // "theImageInfoString" goes in the README file "Image:" field and can
417  // be used to identify the image.
418  //***
419  if (lookupReturn) theImageInfoString = lookupReturn;
420
421  lookupReturn = kwl.find(ossimKeywordNames::PIXEL_TYPE_KW);
422
423  if (lookupReturn)
424  {
425  ossimString tmp = lookupReturn;
426
427  tmp.downcase();
428
429  if (tmp.contains("area"))
430  {
432  }
433  else
434  {
436  }
437  }
438
439  lookupReturn = kwl.find(OUTPUT_US_FT_INFO_KW);
440
441  if (lookupReturn)
442  {
443  int tmp = atoi(lookupReturn);
444
445  if (tmp)
446  {
448  }
449  else
450  {
451  theOutputInfoInFeetFlag = false;
452  }
453  }
454
455  if (traceDebug())
456  {
458  << "DEBUG ossimMapProjectionInfo::loadState:"
459  << "\ntheImageInfoString: " << theImageInfoString
460  << "\nthePixelType: " << int(thePixelType)
461  << "\ntheOutputInfoInFeetFlag: " << theOutputInfoInFeetFlag
462  << endl;
463  }
464
465  return true;
466 }
467
469  const char* ) const
470 {
473
474  ossimString tmp;
475
477  {
478  tmp = "point";
479  }
480  else
481  {
482  tmp = "area";
483  }
484
485  kwl.add(PIXEL_TYPE_KW,
486  tmp.chars());
487
490
491  return true;
492 }
493
495 {
497
498  pt.x = ossim::mtrs2usft(pt.x);
499
500  pt.y = ossim::mtrs2usft(pt.y);
501
502  return pt;
503 }
504
506 {
508  pt.x = ossim::mtrs2usft(pt.x);
509  pt.y = ossim::mtrs2usft(pt.y);
510  return pt;
511 }
512
514 {
516  pt.x = ossim::mtrs2usft(pt.x);
517  pt.y = ossim::mtrs2usft(pt.y);
518  return pt;
519 }
520
522 {
524  pt.x = ossim::mtrs2usft(pt.x);
525  pt.y = ossim::mtrs2usft(pt.y);
526  return pt;
527 }
528
530 {
532 }
533
535 {
537
538  pt.x = ossim::mtrs2usft(pt.x);
539  pt.y = ossim::mtrs2usft(pt.y);
540
541  return pt;
542 }
543
545 {
547 }
virtual const ossimDpt & getDecimalDegreesPerPixel() const
Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing...
ossimGpt urGroundPt() const
Returns the upper right ground point.
ossim_float64 width() const
Definition: ossimDrect.h:522
ossim_int32 linesPerImage() const
double lond() const
Will convert the radian measure to degrees.
Definition: ossimGpt.h:97
ossimDpt lrEastingNorthingPtInFt() const
Returns the lower right easting and northing as a ossimDpt.
const ossimDpt & ul() const
Definition: ossimDrect.h:339
ossimDpt getUsSurveyFeetPerPixel() const
Returns the pixel size in U.S.
double y
Definition: ossimDpt.h:165
ossimDpt getDecimalDegreesPerPixel() const
Returns the decimal degrees per pixel.
bool contains(char aChar) const
Definition: ossimString.h:58
ossimDpt ulEastingNorthingPtInFt() const
Returns the upper left easting and northing as a ossimDpt.
virtual bool isGeographic() const
void setPixelType(ossimPixelType type)
Sets the data member "thePixelType".
const ossimMapProjection * theProjection
ossimDpt lrEastingNorthingPt() const
double latd() const
Definition: ossimGpt.h:87
virtual ossimGpt inverse(const ossimDpt &projectedPoint) const =0
ossimPixelType getPixelType() const
Returns data member "thePixelType".
bool errorStatus() const
Returns true on error false if ok.
bool unitsInFeet() const
Returns the data member "theOutputInfoInFeetFlag".
void setOutputFeetFlag(bool flag)
Sets the data member "theOutputInfoInFeetFlag".
virtual ossimGpt lineSampleToWorld(const ossimDpt &projectedPoint) const
static const char * README_IMAGE_STRING_KW
static const char * TIE_POINT_XY_KW
virtual void lineSampleToEastingNorthing(const ossimDpt &liineSample, ossimDpt &eastingNorthing) const
ossimGpt lrGroundPt() const
Returns the lower right ground point.
ossimDpt centerEastingNorthingPt() const
ossimString getImageInfoString() const
Returns theImageInfoString.
virtual ossimString getProjectionName() const
Returns the projection name.
const char * chars() const
For backward compatibility.
Definition: ossimString.h:77
ossimGpt ulGroundPt() const
Returns the upper left ground point.
ossimDpt urEastingNorthingPt() const
Returns the upper right easting and northing as a ossimDpt.
ossim_int32 pixelsPerLine() const
ossim_float64 height() const
Definition: ossimDrect.h:517
void setImageInfoString(const ossimString &string)
Used to set data member "theImageInfoString".
ossimDpt llEastingNorthingPt() const
Returns the lower left easting and northing as a ossimDpt.
const ossimMapProjection * getProjection() const
Returns reference to "theProjection".
ossimDpt getMetersPerPixel() const
Returns the pixel size in meters.
void getGeom(ossimKeywordlist &kwl, const char *prefix=0) const
Adds tie point to keyword list.
ossimString theImageInfoString
"theImageInfoString" goes in the README file "Image:" field to identify the image.
ossimDpt ulEastingNorthingPt() const
ossimPixelType
ossimString toString(ossim_uint32 precision=15) const
Definition: ossimDpt.cpp:160
void initializeMembers(const ossimDrect &output_rect)
ossimDpt llEastingNorthingPtInFt() const
ossimGpt centerGroundPt() const
Returns the center ground point.
static const char * PIXEL_TYPE_KW
const ossimDpt & ur() const
Definition: ossimDrect.h:340
double x
Definition: ossimDpt.h:164
const char * c_str() const
Definition: ossimString.h:396
bool theOutputInfoInFeetFlag
If "theOutputInfoInFeetFlag" is true the readme file tie point info will be output in both meters and...
const ossimDpt & ll() const
Definition: ossimDrect.h:342
double mtrs2usft(double meters)
Definition: ossimCommon.h:375
virtual ossimDpt getMetersPerPixel() const
std::ostream & print(std::ostream &os) const
Formatted print of data members.
ossimDpt urEastingNorthingPtInFt() const
static ossimUnitTypeLut * instance()
Returns the static instance of an ossimUnitTypeLut object.
const ossimDpt & lr() const
Definition: ossimDrect.h:341
ossimPixelType thePixelType
"thePixelType" defines whether the tie point coordinates are relative to the center of the pixel(whic...
Prints data members to stream.
std::basic_ostream< char > ostream
Base class for char output streams.
Definition: ossimIosFwd.h:23
static const char * TIE_POINT_UNITS_KW
ossimGpt llGroundPt() const
Returns the lower left ground point.
int ossim_int32
static const char * OUTPUT_US_FT_INFO_KW
