27 m_inputTileSize.makeNan();
111 ossimIpt inputOrigin = clip_rect.
ul() - input_rect.
ul();
118 inputOrigin += input_rect.
ul();
177 if ( ( tileSize.
hasNans() == false ) && (tileSize.
x > 0) && (tileSize.
y > 0) )
191 std::string myPrefix = (prefix ? prefix :
192 std::string key =
"tile_size";
193 std::string value = kwl.
findKey( myPrefix, key );
203 std::string myPrefix = (prefix ? prefix :
204 std::string key =
"tile_size";
ossimString toString() const
virtual ~ossimTiledImagePatch()
virtual protected destructor
This will return the bounding rect of the source.
default constructor
const std::string & findKey(const std::string &key) const
Find methods that take std::string(s).
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
virtual ossimString getClassName() const
Class to fill a patch from input tiles requested on even tile boundaries with a tile size typically m...
const ossimIpt & getInputTileSize() const
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tileRect, ossim_uint32 resLevel=0)
Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab fr...
const ossimIpt & ul() const
void addPair(const std::string &key, const std::string &value, bool overwrite=true)
virtual void initialize()
Initializes bounding rects and tile size(if not set) from input.
virtual ossim_uint32 getNumberOfDecimationLevels() const
Will return the number of resolution levels.
virtual ossimString getLongName() const
bool intersects(const ossimIrect &rect) const
Initialize the data buffer.
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
bool isValidRLevel(ossim_uint32 resLevel) const
Test the bounds of resLevel.
void allocateTile()
Allocates the tile.
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
ossimTiledImagePatch & operator=(const ossimTiledImagePatch &)
Private to disallow use...
unsigned int ossim_uint32
virtual ossimIrect getImageRectangle() const
const ossimIpt & lr() const
Method to the load the class state from a keyword list.
void toPoint(const std::string &s)
Initializes this point from string.
virtual void makeBlank()
ossimRefPtr< ossimImageData > m_tile
#define RTTI_DEF1(cls, name, b1)
bool setInputTileSize(const ossimIpt &tileSize)
Sets the input tile size.
virtual ossimString getShortName() const
const std::string & string() const
