Public Member Functions | Protected Member Functions | Private Member Functions | Private Attributes | List of all members
ossimTiledImagePatch Class Reference
Class to fill a patch from input tiles requested on even tile boundaries with a tile size typically matching the input, with some output tile size different from the input. More...
#include <ossimTiledImagePatch.h>
Inheritance diagram for ossimTiledImagePatch:
ossimImageSourceFilter ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
 ossimTiledImagePatch ()
 default constructor More...
virtual void initialize ()
 Initializes bounding rects and tile size(if not set) from input. More...
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0)
 Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More...
 Method to get a tile. More...
const ossimIptgetInputTileSize () const
bool setInputTileSize (const ossimIpt &tileSize)
 Sets the input tile size. More...
 Method to the load the class state from a keyword list. More...
virtual ~ossimImageSource ()
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
virtual ~ossimTiledImagePatch ()
 virtual protected destructor More...
virtual ~ossimReferenced ()
void allocateTile ()
 Allocates the tile. More...
bool isValidRLevel (ossim_uint32 resLevel) const
 Test the bounds of resLevel. More...
 ossimTiledImagePatch (const ossimTiledImagePatch &)
 Private to disallow use... More...
ossimTiledImagePatchoperator= (const ossimTiledImagePatch &)
Private Attributes
ossimIpt m_inputTileSize
Additional Inherited Members
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Detailed Description
Definition at line 29 of file ossimTiledImagePatch.h.
◆ ossimTiledImagePatch() [1/2]
ossimTiledImagePatch::ossimTiledImagePatch ( )
default constructor
Definition at line 21 of file ossimTiledImagePatch.cpp.
22  :
23  ossimImageSourceFilter(), // base class
24  m_tile(0),
26 {
28 }
void makeNan()
Definition: ossimIpt.h:56
ossimImageSourceFilter(ossimObject *owner=NULL)
ossimRefPtr< ossimImageData > m_tile
◆ ~ossimTiledImagePatch()
ossimTiledImagePatch::~ossimTiledImagePatch ( )
protectedvirtual
Definition at line 30 of file ossimTiledImagePatch.cpp.
31 {
32 }
◆ ossimTiledImagePatch() [2/2]
ossimTiledImagePatch::ossimTiledImagePatch ( const ossimTiledImagePatch )
private
Definition at line 222 of file ossimTiledImagePatch.cpp.
223  : m_tile(0),
225 {
226 }
Member Function Documentation
◆ allocateTile()
void ossimTiledImagePatch::allocateTile ( )
private
Allocates the tile.
Called on first getTile.
Definition at line 209 of file ossimTiledImagePatch.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), and m_tile.
Referenced by getTile().
210 {
212  m_tile->initialize();
213 }
virtual void initialize()
Initialize the data buffer.
◆ getClassName()
ossimString ossimTiledImagePatch::getClassName ( ) const
virtual
Returns
"ossimTiledImagePatch"
Definition at line 154 of file ossimTiledImagePatch.cpp.
155 {
156  return ossimString("ossimTiledImagePatch");
157 }
◆ getInputTileSize()
const ossimIpt & ossimTiledImagePatch::getInputTileSize ( ) const
Returns
The reference to the input tile size.
Definition at line 169 of file ossimTiledImagePatch.cpp.
References m_inputTileSize.
170 {
171  return m_inputTileSize;
172 }
◆ getLongName()
ossimString ossimTiledImagePatch::getLongName ( ) const
virtual
Returns
"OSSIM tiled image patch"
Definition at line 159 of file ossimTiledImagePatch.cpp.
160 {
161  return ossimString("OSSIM tiled image patch");
162 }
◆ getShortName()
ossimString ossimTiledImagePatch::getShortName ( ) const
virtual
Returns
"tiled_image_patch"
Definition at line 164 of file ossimTiledImagePatch.cpp.
165 {
166  return ossimString("tiled_image_patch");
167 }
◆ getTile() [1/2]
ossimRefPtr< ossimImageData > ossimTiledImagePatch::getTile ( const ossimIrect tileRect,
ossim_uint32  resLevel = 0
virtual
Satisfies pure virtual from TileSource class.
Definition at line 56 of file ossimTiledImagePatch.cpp.
References allocateTile(), ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), m_tile, ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), and ossimRefPtr< T >::valid().
58 {
59  if ( m_tile.valid() == false )
60  {
61  allocateTile(); // First time through...
62  }
63
64  if ( m_tile.valid() )
65  {
66  // Image rectangle must be set prior to calling getTile.
67  m_tile->setImageRectangle(tileRect);
68
69  if ( getTile( m_tile.get(), resLevel ) == false )
70  {
72  {
73  m_tile->makeBlank();
74  }
75  }
76  }
77
78  return m_tile;
79 }
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tileRect, ossim_uint32 resLevel=0)
Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab fr...
void allocateTile()
Allocates the tile.
virtual void makeBlank()
◆ getTile() [2/2]
bool ossimTiledImagePatch::getTile ( ossimImageData result,
virtual
Parameters
resultThe tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing.
Returns
true on success false on error. If return is false, result is undefined so caller should handle appropriately with makeBlank or whatever.
Definition at line 81 of file ossimTiledImagePatch.cpp.
References ossimIrect::clipToRect(), ossimRefPtr< T >::get(), ossimImageSource::getBoundingRect(), ossimDataObject::getDataObjectStatus(), ossimImageData::getImageRectangle(), ossimImageSource::getTile(), ossimIpt::hasNans(), ossimImageData::initialize(), ossimIrect::intersects(), ossimSource::isSourceEnabled(), isValidRLevel(), ossimImageData::loadTile(), ossimIrect::lr(), m_inputTileSize, ossimImageData::makeBlank(), OSSIM_EMPTY, OSSIM_NULL, status, ossimImageSourceFilter::theInputConnection, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIpt::x, x, ossimIpt::y, and y.
82 {
83  bool status = false;
84
85  if ( isSourceEnabled() && theInputConnection && isValidRLevel(resLevel) &&
86  result && (m_inputTileSize.hasNans() == false) )
87  {
88  status = true;
89
90  // See if any point of the requested tile is in the image.
91  ossimIrect tile_rect = result->getImageRectangle();
92
93  ossimIrect input_rect;
94  theInputConnection->getBoundingRect( input_rect, resLevel );
95
96  if ( tile_rect.intersects( input_rect ) )
97  {
98  // Initialize the tile if needed as we're going to stuff it.
99  if (result->getDataObjectStatus() == OSSIM_NULL)
100  {
101  result->initialize();
102  }
103
104  // If empty imput tiles are pulled the entire output tile might not be filled.
105  result->makeBlank();
106
107  // Clip rect:
108  ossimIrect clip_rect = tile_rect.clipToRect( input_rect );
109
110  // Zero based start point.
111  ossimIpt inputOrigin = clip_rect.ul() - input_rect.ul();
112
113  // Zero based point on input tile boundary.
114  inputOrigin.x = (inputOrigin.x / m_inputTileSize.x) * m_inputTileSize.x;
115  inputOrigin.y = (inputOrigin.y / m_inputTileSize.y) * m_inputTileSize.y;
116
117  // Shift back to original space:
118  inputOrigin += input_rect.ul();
119
120  // Line loop:
121  for ( ossim_int32 y = inputOrigin.y; y < clip_rect.lr().y; y += m_inputTileSize.y )
122  {
123  // Sample loop:
124  for ( ossim_int32 x = inputOrigin.x; x < clip_rect.lr().x; x += m_inputTileSize.x )
125  {
126  ossimIrect rect( x, y, x + m_inputTileSize.x - 1, y + m_inputTileSize.y - 1 );
127
128  ossimRefPtr<ossimImageData> tile = theInputConnection->getTile( rect, resLevel );
129  if ( tile.valid() )
130  {
131  if ( (tile->getDataObjectStatus() != OSSIM_NULL) &&
132  (tile->getDataObjectStatus() != OSSIM_EMPTY) )
133  {
134  result->loadTile( tile.get() );
135  }
136  }
137  }
138  }
139
140  result->validate();
141
142  }
143  else
144  {
145  // No part of requested tile within the image rectangle.
146  result->makeBlank();
147  }
148
149  } // matches: if( isOpen() && isSourceEnabled() && isValidRLevel(level) )
150
151  return status;
152 }
ossim_uint32 x
This will return the bounding rect of the source.
ossim_uint32 y
bool valid() const
const ossimIpt & ul() const
Definition: ossimIrect.h:274
bool intersects(const ossimIrect &rect) const
Definition: ossimIrect.cpp:183
bool isValidRLevel(ossim_uint32 resLevel) const
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
virtual ossimIrect getImageRectangle() const
const ossimIpt & lr() const
Definition: ossimIrect.h:276
return status
ossim_int32 y
Definition: ossimIpt.h:142
ossim_int32 x
Definition: ossimIpt.h:141
bool hasNans() const
Definition: ossimIpt.h:58
int ossim_int32
◆ initialize()
void ossimTiledImagePatch::initialize ( )
virtual
Definition at line 34 of file ossimTiledImagePatch.cpp.
References ossimImageSource::getTileHeight(), ossimImageSource::getTileWidth(), ossimIpt::hasNans(), ossimImageSourceFilter::initialize(), m_inputTileSize, m_tile, ossimImageSourceFilter::theInputConnection, ossimIpt::x, and ossimIpt::y.
35 {
36  //---
37  // Call the base class initialize.
38  // Note: This will reset "theInputConnection" if it changed...
39  //---
41
42  // Clear everything. The tile will be allocated on first getTile call.
43  m_tile = 0;
44
45  // Get the input tile sizes:
46  if ( theInputConnection )
47  {
48  if ( m_inputTileSize.hasNans() )
49  {
52  }
53  }
54 }
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
ossim_int32 y
ossim_int32 x
◆ isValidRLevel()
bool ossimTiledImagePatch::isValidRLevel ( ossim_uint32  resLevel) const
private
Definition at line 215 of file ossimTiledImagePatch.cpp.
References ossimImageSource::getNumberOfDecimationLevels().
216 {
217  // return (resLevel < m_inputBoundingRect.size());
218  return (resLevel < theInputConnection->getNumberOfDecimationLevels());
219 }
virtual ossim_uint32 getNumberOfDecimationLevels() const
Will return the number of resolution levels.
◆ loadState()
bool ossimTiledImagePatch::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Parameters
kwl
prefix
Returns
Definition at line 189 of file ossimTiledImagePatch.cpp.
References ossimKeywordlist::findKey(), ossimImageSourceFilter::loadState(), m_inputTileSize, and ossimIpt::toPoint().
190 {
191  std::string myPrefix = (prefix ? prefix : "" );
192  std::string key = "tile_size";
193  std::string value = kwl.findKey( myPrefix, key );
194  if ( value.size() )
195  {
196  m_inputTileSize.toPoint( value );
197  }
198  return ossimImageSourceFilter::loadState(kwl, prefix);
199 }
const std::string & findKey(const std::string &key) const
Find methods that take std::string(s).
void toPoint(const std::string &s)
Initializes this point from string.
Definition: ossimIpt.cpp:170
◆ operator=()
ossimTiledImagePatch & ossimTiledImagePatch::operator= ( const ossimTiledImagePatch )
private
Definition at line 229 of file ossimTiledImagePatch.cpp.
230 {
231  return *this;
232 }
◆ saveState()
bool ossimTiledImagePatch::saveState ( ossimKeywordlist kwl,
) const
virtual
Parameters
kwl
prefix
Returns
Definition at line 201 of file ossimTiledImagePatch.cpp.
References ossimKeywordlist::addPair(), m_inputTileSize, ossimImageSourceFilter::saveState(), ossimString::string(), and ossimIpt::toString().
202 {
203  std::string myPrefix = (prefix ? prefix : "" );
204  std::string key = "tile_size";
205  kwl.addPair( myPrefix, key, m_inputTileSize.toString().string() );
206  return ossimImageSourceFilter::saveState(kwl, prefix);
207 }
ossimString toString() const
Definition: ossimIpt.cpp:139
void addPair(const std::string &key, const std::string &value, bool overwrite=true)
const std::string & string() const
Definition: ossimString.h:414
◆ setInputTileSize()
bool ossimTiledImagePatch::setInputTileSize ( const ossimIpt tileSize)
Parameters
tileSize
Returns
true on success, false on error. On error m_inpuTileSize is set to nans.
Definition at line 174 of file ossimTiledImagePatch.cpp.
References ossimIpt::hasNans(), m_inputTileSize, ossimIpt::makeNan(), status, ossimIpt::x, and ossimIpt::y.
Referenced by ossimSingleImageChain::createRenderedChain().
175 {
176  bool status = true;
177  if ( ( tileSize.hasNans() == false ) && (tileSize.x > 0) && (tileSize.y > 0) )
178  {
179  m_inputTileSize = tileSize;
180  }
181  else
182  {
184  status = false;
185  }
186  return status;
187 }
void makeNan()
return status
ossim_int32 y
ossim_int32 x
Member Data Documentation
◆ m_inputTileSize
ossimIpt ossimTiledImagePatch::m_inputTileSize
private
◆ m_tile
ossimRefPtr<ossimImageData> ossimTiledImagePatch::m_tile
private
Definition at line 118 of file ossimTiledImagePatch.h.
Referenced by allocateTile(), getTile(), and initialize().
