src/hdf5/ossimViirsHandler.cpp
Go to the documentation of this file.
1 /*****************************************************************************
2 * *
3 * O S S I M *
4 * Open Source, Geospatial Image Processing Project *
5 * License: MIT, see LICENSE at the top-level directory *
6 * *
7 *****************************************************************************/
8
11
12 static const ossimString VIIRS_DATASET ("/All_Data/VIIRS-DNB-SDR_All/Radiance");
13 static const ossimString VIIRS_GEOMETRY ("/All_Data/VIIRS-DNB-GEO_All");
14
16 {
17  m_renderableNames.push_back(VIIRS_DATASET);
18 }
19
21 {
22  if (theGeometry.valid())
23  return theGeometry;
24
26  if (!theGeometry.valid() && isOpen())
27  {
29
30  // Attempt to create an OSSIM coarse grid model from HDF5 lat lon grids:
32  if ( hdf5GridModel->initialize(m_hdf5.get(), VIIRS_GEOMETRY) )
33  {
34  theGeometry->setProjection(hdf5GridModel.get());
36  }
37  else
38  theGeometry = 0;
39  }
40
41  return theGeometry;
42 }
43
44
46 {
47  // NPP VIIRS data has null of "-999.3".
48  return -999.3;
49 }
ossimRefPtr< ossimImageGeometry > theGeometry
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
bool valid() const
Definition: ossimRefPtr.h:75
ossimRefPtr< ossimHdf5 > m_hdf5
bool initialize(ossimHdf5 *hdf5, const ossimString &projDataPath="")
Initializes from an open HDF5 file.
unsigned int ossim_uint32
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
virtual bool isOpen() const
virtual ossimRefPtr< ossimImageGeometry > getExternalImageGeometry() const
Returns the image geometry object associated with this tile source or NULL if non defined...
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
std::vector< ossimString > m_renderableNames
