Public Types | Public Member Functions | Static Public Member Functions | Protected Attributes | List of all members
ossimApplicationUsage Class Reference
#include <ossimApplicationUsage.h>
Public Types
enum  Type { OSSIM_COMMAND_LINE_OPTION = 0x1, OSSIM_ENVIRONMENTAL_VARIABLE = 0x2 }
typedef std::map< ossimString, ossimString, ossimStringLtstrUsageMap
 ossimApplicationUsage ()
 ossimApplicationUsage (const ossimString &commandLineUsage)
void setApplicationName (const ossimString &name)
const ossimStringgetApplicationName () const
void setDescription (const ossimString &desc)
const ossimStringgetDescription () const
void addUsageExplanation (Type type, const ossimString &option, const ossimString &explanation)
void setCommandLineUsage (const ossimString &explanation)
const ossimStringgetCommandLineUsage () const
void addCommandLineOption (const ossimString &option, const ossimString &explanation)
const UsageMapgetCommandLineOptions () const
void addEnvironmentalVariable (const ossimString &option, const ossimString &explanation)
const UsageMapgetEnvironmentalVariables () const
void getFormatedString (ossimString &str, const UsageMap &um, unsigned int widthOfOutput=80)
void write (std::ostream &output, const UsageMap &um, unsigned int widthOfOutput=80)
void write (std::ostream &output, unsigned int type=OSSIM_COMMAND_LINE_OPTION|OSSIM_ENVIRONMENTAL_VARIABLE, unsigned int widthOfOutput=80)
static ossimApplicationUsageinstance ()
ossimString theApplicationName
ossimString theDescription
ossimString theCommandLineUsage
UsageMap theCommandLineOptions
UsageMap theEnvironmentalVariables
Detailed Description
Definition at line 15 of file ossimApplicationUsage.h.
Member Typedef Documentation
◆ UsageMap
Definition at line 25 of file ossimApplicationUsage.h.
◆ Type
Enumerator
Definition at line 33 of file ossimApplicationUsage.h.
◆ ossimApplicationUsage() [1/2]
ossimApplicationUsage::ossimApplicationUsage ( )
inline
Definition at line 21 of file ossimApplicationUsage.h.
21 {}
◆ ossimApplicationUsage() [2/2]
ossimApplicationUsage::ossimApplicationUsage ( const ossimString commandLineUsage)
Definition at line 13 of file ossimApplicationUsage.cpp.
13  :
14  theCommandLineUsage(commandLineUsage)
15 {
16 }
Member Function Documentation
◆ addCommandLineOption()
void ossimApplicationUsage::addCommandLineOption ( const ossimString option,
const ossimString explanation
◆ addEnvironmentalVariable()
void ossimApplicationUsage::addEnvironmentalVariable ( const ossimString option,
Definition at line 74 of file ossimApplicationUsage.cpp.
References theEnvironmentalVariables.
Referenced by addUsageExplanation().
75 {
76  theEnvironmentalVariables[option]=explanation;
77 }
◆ addUsageExplanation()
void ossimApplicationUsage::addUsageExplanation ( Type  type,
Definition at line 42 of file ossimApplicationUsage.cpp.
References addCommandLineOption(), addEnvironmentalVariable(), OSSIM_COMMAND_LINE_OPTION, and OSSIM_ENVIRONMENTAL_VARIABLE.
Referenced by ApplicationUsageProxy::ApplicationUsageProxy().
43 {
44  switch(type)
45  {
47  addCommandLineOption(option,explanation);
48  break;
50  addEnvironmentalVariable(option,explanation);
51  break;
52  }
53 }
void addCommandLineOption(const ossimString &option, const ossimString &explanation)
void addEnvironmentalVariable(const ossimString &option, const ossimString &explanation)
◆ getApplicationName()
const ossimString & ossimApplicationUsage::getApplicationName ( ) const
Definition at line 28 of file ossimApplicationUsage.cpp.
References theApplicationName.
29 {
30  return theApplicationName;
31 }
◆ getCommandLineOptions()
const ossimApplicationUsage::UsageMap & ossimApplicationUsage::getCommandLineOptions ( ) const
◆ getCommandLineUsage()
const ossimString & ossimApplicationUsage::getCommandLineUsage ( ) const
Definition at line 59 of file ossimApplicationUsage.cpp.
References theCommandLineUsage.
Referenced by write().
60 {
61  return theCommandLineUsage;
62 }
◆ getDescription()
const ossimString & ossimApplicationUsage::getDescription ( ) const
Definition at line 37 of file ossimApplicationUsage.cpp.
References theDescription.
38 {
39  return theDescription;
40 }
◆ getEnvironmentalVariables()
const ossimApplicationUsage::UsageMap & ossimApplicationUsage::getEnvironmentalVariables ( ) const
Definition at line 78 of file ossimApplicationUsage.cpp.
79 {
81 }
◆ getFormatedString()
void ossimApplicationUsage::getFormatedString ( ossimString str,
const UsageMap um,
unsigned int  widthOfOutput = 80
Definition at line 83 of file ossimApplicationUsage.cpp.
References ossimString::assign(), ossimString::begin(), ossimString::find(), ossimString::length(), ossim::max(), ossim::min(), and ossimString::replace().
84 {
85
86  unsigned int maxNumCharsInOptions = 0;
87  ossimApplicationUsage::UsageMap::const_iterator citr;
88  for(citr=um.begin();
89  citr!=um.end();
90  ++citr)
91  {
92  maxNumCharsInOptions = ossim::max(maxNumCharsInOptions,(unsigned int)citr->first.length());
93  }
94
95  unsigned int fullWidth = widthOfOutput;
96  unsigned int optionPos = 2;
97  unsigned int explanationPos = 2+maxNumCharsInOptions+2;
98  unsigned int explanationWidth = fullWidth-explanationPos;
99
100  ossimString line;
101
102  for(citr=um.begin();
103  citr!=um.end();
104  ++citr)
105  {
106  line.assign(fullWidth,' ');
107  line.replace(optionPos,citr->first.length(),citr->first);
108
109  const ossimString& explanation = citr->second;
110  std::string::size_type pos = 0;
111  std::string::size_type offset = 0;
112  bool firstInLine = true;
113  while (pos<explanation.length())
114  {
115  if (firstInLine) offset = 0;
116
117  // skip any leading white space.
118  while (pos<explanation.length() && *(explanation.begin()+pos)==' ')
119  {
120  if (firstInLine) ++offset;
121  ++pos;
122  }
123
124  firstInLine = false;
125
126  std::string::size_type width = ossim::min((ossim_int64)(explanation.length()-pos),
127  (ossim_int64)(explanationWidth-offset));
128  std::string::size_type slashn_pos = explanation.find('\n',pos);
129
130  unsigned int extraSkip = 0;
131  bool concatinated = false;
132  if (slashn_pos!=std::string::npos)
133  {
134  if (slashn_pos<pos+width)
135  {
136  width = slashn_pos-pos;
137  ++extraSkip;
138  firstInLine = true;
139  }
140  else if (slashn_pos==pos+width)
141  {
142  ++extraSkip;
143  firstInLine = true;
144  }
145  }
146
147  if (pos+width<explanation.length())
148  {
149  // now reduce width until we get a space or a return
150  // so that we ensure that whole words are printed.
151  while (width>0 &&
152  *(explanation.begin()+(pos+width))!=' ' &&
153  *(explanation.begin()+(pos+width))!='\n') --width;
154
155  if (width==0)
156  {
157  // word must be longer than a whole line so will need
158  // to concatinate it.
159  width = explanationWidth-1;
160  concatinated = true;
161  }
162  }
163
164  line.replace(explanationPos+offset,explanationWidth, explanation, pos, width);
165
166  if (concatinated) { str += line; str += "-\n"; }
167  else { str += line; str += "\n"; }
168
169  // move to the next line of output.
170  line.assign(fullWidth,' ');
171
172  pos += width+extraSkip;
173
174
175  }
176
177  }
178 }
T max(T a, T b)
Definition: ossimCommon.h:236
std::string::size_type length() const
Definition: ossimString.h:408
std::string::iterator begin()
Definition: ossimString.h:420
T min(T a, T b)
Definition: ossimCommon.h:203
std::string & replace(std::string::size_type pos, std::string::size_type n, const std::string &s)
Replaces a substring of *this with the string s.
Definition: ossimString.h:870
long long ossim_int64
std::string & assign(std::string::size_type n, char c)
Erases the existing characters and replaces them by n copies of c.
Definition: ossimString.h:865
std::string::size_type find(const std::string &s, std::string::size_type pos=0) const
Searches for s as a substring of *this, beginning at character pos of *this.
Definition: ossimString.h:753
◆ instance()
ossimApplicationUsage * ossimApplicationUsage::instance ( )
static
Definition at line 18 of file ossimApplicationUsage.cpp.
19 {
20  static ossimApplicationUsage theApplicationUsage;
21  return &theApplicationUsage;
22 }
◆ setApplicationName()
void ossimApplicationUsage::setApplicationName ( const ossimString name)
◆ setCommandLineUsage()
void ossimApplicationUsage::setCommandLineUsage ( const ossimString explanation)
◆ setDescription()
void ossimApplicationUsage::setDescription ( const ossimString desc)
◆ write() [1/2]
void ossimApplicationUsage::write ( std::ostream &  output,
const UsageMap um,
Definition at line 180 of file ossimApplicationUsage.cpp.
References getFormatedString().
Referenced by ossimEquationUtil::execute(), ossimTool::initialize(), ossimPointCloudTool::usage(), ossimBatchTest::usage(), ossimAutRegUtil::usage(), ossimImageUtil::usage(), ossimChipperUtil::usage(), and write().
181 {
182  ossimString str;
183  getFormatedString(str, um, widthOfOutput);
184  output << str << std::endl;
185 }
void getFormatedString(ossimString &str, const UsageMap &um, unsigned int widthOfOutput=80)
◆ write() [2/2]
unsigned int  type = OSSIM_COMMAND_LINE_OPTION|OSSIM_ENVIRONMENTAL_VARIABLE,
Definition at line 187 of file ossimApplicationUsage.cpp.
References ossimString::c_str(), getCommandLineOptions(), getCommandLineUsage(), getEnvironmentalVariables(), OSSIM_COMMAND_LINE_OPTION, OSSIM_ENVIRONMENTAL_VARIABLE, ossimString::size(), theDescription, and write().
188 {
189
190  output << "Usage: "<<getCommandLineUsage()<<std::endl;
191  if(theDescription.size()>0)
192  {
193  // TODO: take into account "widthOfOutput"
194  output << "\nDescription:\n" << theDescription.c_str() << "\n"
195  << std::endl;
196  }
197
198  bool needspace = false;
199  if ((type&OSSIM_COMMAND_LINE_OPTION) && !getCommandLineOptions().empty())
200  {
201  // if (needspace) output << std::endl;
202  output << "Options:"<<std::endl;
203  write(output,getCommandLineOptions(),widthOfOutput);
204  needspace = true;
205  }
206
208  {
209  if (needspace) output << std::endl;
210  output << "Environmental Variables:"<<std::endl;
211  write(output,getEnvironmentalVariables(),widthOfOutput);
212  needspace = true;
213  }
214
215 }
void write(std::ostream &output, const UsageMap &um, unsigned int widthOfOutput=80)
const UsageMap & getEnvironmentalVariables() const
const UsageMap & getCommandLineOptions() const
std::string::size_type size() const
Definition: ossimString.h:405
const ossimString & getCommandLineUsage() const
const char * c_str() const
Definition: ossimString.h:396
Member Data Documentation
◆ theApplicationName
ossimString ossimApplicationUsage::theApplicationName
protected
Definition at line 63 of file ossimApplicationUsage.h.
Referenced by getApplicationName(), and setApplicationName().
◆ theCommandLineOptions
UsageMap ossimApplicationUsage::theCommandLineOptions
protected
Definition at line 66 of file ossimApplicationUsage.h.
Referenced by addCommandLineOption(), and getCommandLineOptions().
◆ theCommandLineUsage
ossimString ossimApplicationUsage::theCommandLineUsage
protected
Definition at line 65 of file ossimApplicationUsage.h.
Referenced by getCommandLineUsage(), and setCommandLineUsage().
◆ theDescription
ossimString ossimApplicationUsage::theDescription
protected
Definition at line 64 of file ossimApplicationUsage.h.
Referenced by getDescription(), setDescription(), and write().
◆ theEnvironmentalVariables
UsageMap ossimApplicationUsage::theEnvironmentalVariables
protected
Definition at line 67 of file ossimApplicationUsage.h.
Referenced by addEnvironmentalVariable(), and getEnvironmentalVariables().
