36 "Utility for computing the slope at each elevation post and generating " 37 "a corresponding slope image.";
40 : m_recursiveCall (false)
53 usageString +=
" slope [options] <output-image>";
92 std::vector<ossimFilename> cells;
std::string getApplicationName() const
return the application name, as specified by argv[0]
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Filter class for computing the slope image of the input image connection.
void addPair(const std::string &key, const std::string &value, bool overwrite=true)
static ossimElevManager * instance()
METHOD: instance() Implements singelton pattern.
void setCommandLineUsage(const ossimString &explanation)
ossimApplicationUsage * getApplicationUsage()
void getCellsForBounds(const std::string &connectionString, const ossim_float64 &minLat, const ossim_float64 &minLon, const ossim_float64 &maxLat, const ossim_float64 &maxLon, std::vector< ossimFilename > &cells, ossim_uint32 maxNumberOfCells=0)
Gets a list of elevation cells needed to cover bounding box.
void removeKeysThatMatch(const ossimString ®ularExpression)
std::vector< ossimRefPtr< ossimConnectableObject > > ConnectableObjectList
unsigned int ossim_uint32
virtual bool add(ossimConnectableObject *source)
Will return true or false if an image source was added to the chain.
void setSlopeType(SlopeType t)
void setDescription(const ossimString &desc)
static const char * IMAGE_FILE_KW
static const char * ELEVATION_SOURCE_KW
