28 : m_operation (LOWEST_DEM),
45 usageString +=
" [options] <point-cloud-file> <output-image>";
51 "Specifies output GSD in meters. Defaults to the same " 52 "resolution as input DEM.");
55 "Specifies the input DEM filename. If none provided, the elevation database is " 56 "referenced as specified in prefs file");
59 "Specifies the optional lookup table filename for " 60 "mapping the single-band output image to an RGB. The LUT provided must be " 61 "in the ossimIndexToRgbLutFilter format and must handle the three output " 62 "viewshed values (see --values option).");
65 "Specify the desired operation. Possible values are:\n" 66 " \"highest-dem\", \"lowest-dem\" (default), or \"highest-lowest\". \n" 67 "Alternatively can be specified in shorthand as \"h-d\", \"l-d\", or \"h-l\", " 71 "Causes applications API to be output as JSON to stdout." 72 " Accepts optional filename to store JSON output.");
75 "Number of threads. Defaults to use all available cores. " 76 "For engineering/debug purposes ");
91 <<
"\nPerforms specified processing on point-cloud.\n\n" 97 if ( (ap.
argc() == 1) || ap.
read(
"-h") || ap.
read(
"--help") )
106 if ( ap.
read(
"--dem", sp1) )
109 if ( ap.
read(
"--gsd", sp1) )
112 if ( ap.
read(
"--lut", sp1) )
115 if ( ap.
read(
"--method", sp1) )
123 if ( ap.
read(
"--pc", sp1) )
164 <<
"ossimPointCloudTool::initialize ERR: Cannot open PC file at <"<<
m_pcFile 183 <<
m_pcFile 184 <<
">\n" << std::endl;
210 <<
"ossimViewshedUtil::initialize ERR: Cannot open DEM file at <"<<
m_demFile<<
">\n" 229 m_gsd = meters_per_pixel;
247 "file <"<<
m_lutFile<<
"> could not be read. Ignoring remap request.\n"<< std::endl;
254 last_source = lutSource.
get();
261 bool success =
false;
virtual void initialize()
void write(std::ostream &output, const UsageMap &um, unsigned int widthOfOutput=80)
std::string getApplicationName() const
return the application name, as specified by argv[0]
void addCommandLineOption(const ossimString &option, const ossimString &explanation)
bool addFile(const char *file)
void addOptions(ossimArgumentParser &parser)
void setUseGeoidIfNullFlag(bool flag)
const ossimMapProjection * getAsMapProjection() const
bool read(const std::string &str)
search for an occurance of a string in the argument list, on sucess remove that occurance from the li...
double nan()
bool contains(char aChar) const
Class used for rendering point cloud data into a raster tile.
static ossimImageWriterFactoryRegistry * instance()
bool setPointCloudHandler(ossimPointCloudHandler *pch)
Permits backdoor for setting the input point cloud handler object.
static ossimElevManager * instance()
METHOD: instance() Implements singelton pattern.
void setCommandLineUsage(const ossimString &explanation)
ossimApplicationUsage * getApplicationUsage()
virtual void setMetersPerPixel(const ossimDpt &gsd)
virtual ossimPointCloudHandler * open(const ossimFilename &fileName) const
ossimRefPtr< ossimImageGeometry > getImageGeometry() override
Returns the image geometry object associated with this tile source or NULL if non defined...
virtual bool loadState(const ossimKeywordlist &kwl, const char *prefix=NULL)
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
static ossimPointCloudHandlerRegistry * instance()
void setDefaultHeightAboveEllipsoid(double meters)
static ossimInit * instance()
ossimImageFileWriter * createWriter(const ossimFilename &filename) const
virtual bool open(const ossimString &connectionString)
Open a connection to a database.
void addDatabase(ossimElevationDatabase *database, bool set_as_first=false)
Adds a new elevation database to the collection.
int & argc()
return the argument count.
virtual bool execute()
Calls: writeFile() writeMetaDataFiles()
