51 static ossimTrace traceDebug (
"ossimAutRegUtil:debug");
52 static ossimTrace traceLog(
"ossimAutRegUtil:log");
53 static ossimTrace traceOptions(
"ossimAutRegUtil:options");
55 static const std::string APPLICATION_NAME_KW =
"application_name";
56 static const std::string ADJ_DESC_LABEL_KW =
"adj_desc_label";
57 static const std::string FALSE_KW =
"false";
58 static const std::string IMG_1_KW =
"img_1";
59 static const std::string IMG_2_KW =
"img_2";
60 static const std::string IMG_M_KW =
"img_m";
61 static const std::string IMG_S_KW =
"img_s";
62 static const std::string OP_KW =
"operation";
63 static const std::string SRC_FILE_KW =
"src_file";
64 static const std::string TRUE_KW =
"true";
65 static const std::string ROI_CENTER_LAT_KW =
"roi_center_lat";
66 static const std::string ROI_CENTER_LON_KW =
"roi_center_lon";
67 static const std::string ROI_RADIUS_KW =
"roi_radius";
68 static const std::string ROI_HEIGHT_KW =
"roi_height";
69 static const std::string ROI_MAX_LAT_KW =
"roi_max_lat";
70 static const std::string ROI_MAX_LON_KW =
"roi_max_lon";
71 static const std::string ROI_MIN_LAT_KW =
"roi_min_lat";
72 static const std::string ROI_MIN_LON_KW =
"roi_min_lon";
73 static const std::string ROI_WIDTH_KW =
"roi_width";
74 static const std::string REPORT_FILE_KW =
"report_file";
76 static const std::string FILE_KW =
"file";
77 static const std::string IMG_KW =
"image";
78 static const std::string READER_PROPERTY_KW =
"reader_property";
80 static const std::string OCV_CONFIG_FILE_KW =
"ocv_config_file";
81 static const std::string OCV_DETECTOR_NAME_KW =
"ocv_detector_name";
82 static const std::string OCV_DRAW_MATCHES_FLAG_KW =
"ocv_draw_matches_flag";
83 static const std::string OCV_EXTRACTOR_NAME_KW =
"ocv_extractor_name";
84 static const std::string OCV_MATCHER_NAME_KW =
"ocv_matcher_name";
85 static const std::string OCV_MAX_MATCHES_KW =
"ocv_max_matches";
86 static const std::string OCV_USE_CROSS_CHECK_KW =
"ocv_use_cross_check";
87 static const std::string OCV_USE_GRID_ADAPTED_DETECT_KW =
"ocv_use_grid_adapted_detect";
88 static const std::string OCV_RESULTS_WINDOW_SHOW_KW =
"ocv_results_window_show";
90 static const std::string OAX_CONFIG_FILE_KW =
"oax_config_file";
91 static const std::string OAX_CONVERGENCE_CRITERIA_KW =
"oax_convergence_criteria";
92 static const std::string OAX_GROUND_SIGMA_KW =
"oax_ground_sigma";
93 static const std::string OAX_LAT_SIGMA_KW =
"oax_lat_sigma";
94 static const std::string OAX_LON_SIGMA_KW =
"oax_lon_sigma";
95 static const std::string OAX_HGT_SIGMA_KW =
"oax_hgt_sigma";
96 static const std::string OAX_CONTROL_SIGMA_KW =
"oax_control_sigma";
97 static const std::string OAX_MAX_ITERATIONS_KW =
"oax_max_iterations";
110 m_showMatchWindow(false),
114 m_LatLonHgtControlSigmas(),
121 m_operation(OSSIM_AUTREG_OP_UNKNOWN)
127 <<
"\nossimAutRegUtil::ossimAutRegUtil 1 DEBUG:" << std::endl;
172 <<
"DEBUG: ~ossimAutRegUtil(): entered..." << std::endl;
176 *
m_rep <<
"\n~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~\n";
180 <<
"DEBUG: ~ossimAutRegUtil(): returning..." << std::endl;
187 usageString +=
" [option]... [input-option]... -img_1 <input-file 1> -img_2 <input-file 2>\n\nAvailable traces:\n-T \"ossimAutRegUtil:debug\" - General debug trace to standard out.\n-T \"ossimAutRegUtil:log\" - Writes a log file to output-file.log.\n-T \"ossimAutRegUtil:options\" - Writes the options to output-file-options.kwl.";
197 au->
addCommandLineOption(
"--quality",
"<quality>\nNOT WORKING... Desired quality of tiepoint collection.\nRange: 1 to 5, Default = 3");
199 au->
"--roi-center-llwh",
"<latitude> <longitude> <width> <height>\nSpecify the center ROI in latitude longitude space with width and height in pixels.");
201 au->
"--roi-center-llr",
"<latitude> <longitude> <radius_in_meters>\nSpecify the center ROI in latitude longitude space with radius in meters.");
203 au->
"--ocv_config_file",
"<file_path>\nSpecify a keyword list OpenCV configuration file.");
205 au->
"--oax_config_file",
"<file_path>\nSpecify a keyword list oax configuration file.");
214 std::vector< ossimRefPtr<ossimSingleImageChain> >::iterator i =
m_imgLayer.begin();
235 static const char MODULE[] =
"ossimAutRegUtil::initialize(ossimArgumentParser&)";
243 if( ap.
read(
"-h") || ap.
read(
"--help") || (ap.
argc() == 1) )
253 std::string tempString1;
255 std::string tempString2;
257 std::string tempString3;
259 std::string tempString4;
270 if( ap.
read(
"--report_file", stringParam1) )
272 m_kwl->
addPair( std::string(REPORT_FILE_KW), tempString1 );
276 if( ap.
read(
"--quality", stringParam1) )
282 if( ap.
read(
"--op", stringParam1) )
288 if( ap.
read(
"--img_1", stringParam1))
294 if( ap.
read(
"--img_2", stringParam1))
300 if( ap.
read(
"--img_m", stringParam1))
306 if( ap.
read(
"--img_s", stringParam1))
312 if( ap.
read(
"--ocv_config_file", stringParam1))
314 m_kwl->
addPair( std::string(OCV_CONFIG_FILE_KW), tempString1 );
318 if( ap.
read(
"--oax_config_file", stringParam1))
320 m_kwl->
addPair( std::string(OAX_CONFIG_FILE_KW), tempString1 );
324 if( ap.
read(
"--roi-center-llwh", stringParam1, stringParam2, stringParam3, stringParam4) )
333 if( ap.
read(
"--roi-center-llr", stringParam1, stringParam2, stringParam3) )
341 if( ap.
read(
"--input-src", stringParam1) )
347 if( ap.
read(
355 if( ap.
read(
"--options", stringParam1) )
358 if ( optionsKwl.
exists() )
362 std::string errMsg =
"ERROR could not open options keyword list file: ";
363 errMsg += optionsKwl.
string();
369 std::string errMsg =
"ERROR options keyword list file does not exists: ";
370 errMsg += optionsKwl.
string();
383 std::string errMsg =
"Unknown option...";
388 if ( ap.
argc() >= 2 )
398 std::string errMsg =
"Must supply an output file.";
406 while ( pos < (ap.
argc()-1) )
412 <<
"argv[" << pos <<
"]: " << file <<
"\n";
417 if (
m_kwl->
find( SRC_FILE_KW.c_str() ) )
419 std::string errMsg = MODULE;
420 errMsg +=
"ERROR Multiple src files passed in. Please combine into one.";
469 static const char MODULE[] =
"ossimAutRegUtil::initialize()";
476 if ( traceOptions() )
481 optionsFile +=
"-options.kwl";
482 ossimString comment =
" Can be use for --options argument.";
497 else if ( s ==
"masreg" )
503 std::string errMsg =
"unknown operation: ";
510 std::string errMsg =
"keyword not found: ";
512 errMsg +=
"\nUse --op option to specify operation.\n";
529 *
m_rep <<
"\n ossimAutRegUtil Summary..."<<std::endl;
532 *
m_rep <<
"\n" << ts;
533 *
m_rep <<
598 <<
"options keyword list:\n" 604 <<
"support record keyword list:\n" 620 throw ossimException(
"ossimTieMeasurementGenerator createObject failed...");
640 static const char MODULE[] =
"ossimAutRegUtil::loadImages";
647 bool isGoodLoad =
false;
669 *
m_rep <<
" open for image 1 failed..."<<std::endl;
677 *
m_rep <<
"-----------------" << endl
679 <<
"width = " << bounds.
width() << endl
680 <<
"height = " << bounds.
height() << endl
681 <<
"overview count = " << (overviews-1) << endl
702 *
m_rep <<
" open for image 2 failed"<<std::endl;
710 *
m_rep <<
712 <<
width() << endl
713 <<
height() << endl
714 <<
717 *
m_rep <<
"-----------------" << endl;
740 static const char MODULE[] =
"ossimAutRegUtil::delineateROIs";
747 bool isGoodOp =
false;
749 for (
int img=0; img<2; ++img)
759 if (
m_geom[img].valid() )
761 if (
m_kwl->
find( ROI_CENTER_LAT_KW.c_str() ) )
766 if ( latStr.
size() && lonStr.
size() )
788 if (
m_ivt[img].valid() )
798 if ( widthStr.
size() && heightStr.
size() )
802 if ( width && height )
804 ossimIpt ul( ossim::round<int>(centerDpt.
x - (width/2)),
805 ossim::round<int>(centerDpt.
y - (height/2)) );
806 ossimIpt lr( (ul.
x + width - 1), ul.
y + height - 1);
813 if ( radiusStr.
size() )
826 ossimIpt ul( ossim::round<int>( centerDpt.
x - rx ),
827 ossim::round<int>( centerDpt.
y - ry ) );
828 ossimIpt lr( ossim::round<int>( centerDpt.
x + rx ),
829 ossim::round<int>( centerDpt.
y + ry ) );
848 std::string errMsg = MODULE;
851 errMsg +=
" image source null!";
881 static const char MODULE[] =
"ossimAutRegUtil::populateObsSet";
888 bool isGoodLoad =
true;
902 for (
956 static const char MODULE[] =
"ossimAutRegUtil::configureTieMeasGenerator";
992 if (maxMatches.
size())
1022 static const char MODULE[] =
"ossimAutRegUtil::configureAdjustmentExecutive";
1042 if (
m_oaxKwl->
find(OAX_CONVERGENCE_CRITERIA_KW.c_str()))
1122 static const char MODULE[] =
"ossimAutRegUtil::execute";
1133 *
m_rep<<
"\n\n >> Tie point collection follows...\n"<<endl;
1145 std::vector<ossimImageSource*> src;
1167 bool waitKey =
true;
1177 if (iface1 && iface2)
1204 bool solutionOK =
false;
1206 *
m_rep<<
"\n\n >> Adjustment summary follows...\n"<<endl;
1230 throw ossimException(
"m_adjExec->initializeSolution() failed...");
1242 throw ossimException(
"ossimAdjustableParameterInterface missing...");
1265 for (
1315 bool result =
false;
1344 <<
"1) Note 1 content\n" 1345 <<
" Note 1 place holder continued...\n" 1346 <<
"2) Note 2 content\n" 1347 <<
" Note 2 place holder continued...\n" 1349 <<
"\nExample commands:\n" 1351 <<
"\n// Co-register image1 and image2 with 512x512 ROIs centered on point:\n" 1352 << appName <<
" --op coreg --img_1 image1.ntf --img_2 image2.ntf --roi-center-llwh 28.097255037664400 -80.630762190246145 512 512\n" 1354 <<
"\n// Register image2 to control image1 (master): (TBD... not working)\n" 1355 << appName <<
" --op masreg -img_m image1.ntf -img_s image2.ntf -cfg configFile.kwl\n" 1357 <<
"\n// Above command where all options are in a keyword list:\n" 1358 << appName <<
" --options autreg-options.kwl\n" 1365 static const char MODULE[] =
"ossimAutRegUtil::initializeSrcKwl";
1369 << MODULE <<
" entered...\n";
1372 std::string value =
m_kwl->
findKey(std::string(SRC_FILE_KW));
1392 <<
"src keyword list:\n" << *(
m_srcKwl.
get()) <<
"\n";
1395 << MODULE <<
" exited...\n";
1402 static const char MODULE[] =
"ossimAutRegUtil::initializeOcvKwl";
1406 << MODULE <<
" entered...\n";
1409 std::string value =
m_kwl->
findKey(std::string(OCV_CONFIG_FILE_KW));
1429 <<
"ocv keyword list:\n" << *(
m_ocvKwl.
get()) <<
"\n";
1432 << MODULE <<
" exited...\n";
1439 static const char MODULE[] =
"ossimAutRegUtil::initializeOaxKwl";
1443 << MODULE <<
" entered...\n";
1446 std::string value =
m_kwl->
findKey(std::string(OAX_CONFIG_FILE_KW));
1466 <<
"oax keyword list:\n" << *(
m_oaxKwl.
get()) <<
"\n";
1469 << MODULE <<
" exited...\n";
1476 static const char MODULE[] =
"ossimAutRegUtil::addImgSource";
1483 << MODULE <<
" entered...\nFile: " << file <<
"\n";
1514 std::vector<ossimString> splitArray;
1515 value.
split(splitArray,
1516 if(splitArray.size() == 2)
1532 bool result =
false;
1533 if ( chain.
valid() )
1547 static const char MODULE[] =
"ossimAutRegUtil::createChain(const ossimFilename&";
1552 << MODULE <<
" entered..." 1553 <<
"\nfile: " << file
1554 <<
"\nentry: " << entryIndex
1565 if ( ic->
open( file ) )
1577 errMsg << MODULE <<
" ERROR:\nEntry " << entryIndex <<
" out of range!" 1643 if ( ic.
valid() == false )
1645 std::string errMsg =
"Could not open: ";
1656 <<
"chain:\n" << kwl <<
"\n" 1657 << MODULE <<
" exiting...\n";
1666 static const char MODULE[] =
"ossimAutRegUtil::createIdentityProjection";
1696 if (
m_geom[idx].valid() )
1712 <<
"\nAffine transform parameters:" 1713 <<
"\nrotation: " << rotation
1714 <<
"\nmid point: " << midPt << std::endl;
1737 bool result =
false;
1740 std::string value = kwl->
findKey( key );
virtual bool setDescriptorExtractor(const ossimString &name)=0
ossimRefPtr< ossimKeywordlist > m_kwl
Hold all options passed into intialize.
void write(std::ostream &output, const UsageMap &um, unsigned int widthOfOutput=80)
ossimColumnVector3d m_LatLonHgtControlSigmas
std::string getApplicationName() const
return the application name, as specified by argv[0]
void addCommandLineOption(const ossimString &option, const ossimString &explanation)
void setAddResamplerCacheFlag(bool flag)
If flag is true a resampler cache will be added to the chain at create time.
ossimFilename noExtension() const
ossim_uint32 numberOf(const char *str) const
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
void clear()
Disconnects and clears the dem and image layers?????????????.
void getOutputFilename(ossimFilename &f) const
Gets the output file name.
static const char * OUTPUT_FILE_KW
bool addImgSource(const ossimFilename &file, ossim_uint32 entryIndex)
Method to create a chain and add to img layers from file.
void addArguments(ossimArgumentParser &ap)
Adds application arguments to the argument parser.
bool loadImages()
Internal load image pair method.
void setReaderProps(ossimImageHandler *ih) const
Passes reader properties to single image handler if any.
void configureAdjustmentExecutive()
Configures adjustment executive.
bool addFile(const char *file)
const std::string & findKey(const std::string &key) const
Find methods that take std::string(s).
void configureTieMeasGenerator()
Configures tie measurement generator.
ossimRefPtr< const ossimImageHandler > getImageHandler() const
void setMaxIter(const int maxIter)
virtual bool saveState(ossimKeywordlist &kwl, const char *prefix=NULL) const
Will save the state of the chain.
void addOptions(ossimArgumentParser &parser)
ossimReferenced allows for shared object ref counting if the reference count ever gets to 0 or less i...
virtual ossimString getEntryString(ossim_int32 entry_number) const
ossimRefPtr< ossimImageViewAffineTransform > m_ivt[2]
Image view transform(IVT).
bool read(const std::string &str)
search for an occurance of a string in the argument list, on sucess remove that occurance from the li...
void getBoundingRect(ossimIrect &bounding_rect) const
Get the bounding rect of (0, 0) to (imageSize.x-1, imageSize.y-1).
ossim_uint32 height() const
virtual int numMeasurements() const =0
ossimImageGeometry * getImageGeom(const int index)
void addList(const ossimKeywordlist &src, bool overwrite=true)
void createRenderedChain()
Create a rendered image chain.
Numeric to string methods.
std::vector< ossimRefPtr< ossimSingleImageChain > > m_imgLayer
Array of image source chains.
ossim_uint32 numImages() const
ossimRefPtr< ossimObject > m_tGenObj
virtual bool init(std::ostream &report=std::cout)=0
static ossimObjectFactoryRegistry * instance()
void addPair(const std::string &key, const std::string &value, bool overwrite=true)
virtual ossimString getClassName() const
void setAdjustmentDescription(const ossimString &description)
static ossimElevManager * instance()
METHOD: instance() Implements singelton pattern.
void setCommandLineUsage(const ossimString &explanation)
ossimRefPtr< ossimSingleImageChain > createChain(const ossimFilename &file, ossim_uint32 entryIndex) const
Creates a ossimSingleImageChain from file.
bool populateObsSet()
Internal observation set poplulate method.
ossimApplicationUsage * getApplicationUsage()
virtual bool write(const char *file, const char *comment=0) const
Methods to dump the ossimKeywordlist to a file on disk.
void initializeOcvKwl()
Initializes m_ocvKwl if option was set.
void setImageViewTransform(ossimImageViewTransform *transform)
virtual void setShowCvWindow(const bool showCvWindow)=0
virtual bool setFeatureDetector(const ossimString &name)=0
Single image chain class.
virtual ossim_uint32 getNumberOfDecimationLevels() const
This returns the total number of decimation levels.
virtual bool setDescriptorMatcher(const ossimString &name)=0
void setAdjustment(const ossimAdjustmentInfo &adj, bool notify=false)
ossim_int32 toInt32() const
void reportRemainingOptionsAsUnrecognized(ossimErrorSeverity severity=OSSIM_BENIGN)
for each remaining option report it as an unrecongnized.
virtual ossimAdjustableParameterInterface * getAdjustableParameterInterface()
~ossimAutRegUtil()
virtual destructor
static ossimScalarTypeLut * instance()
Returns the static instance of an ossimScalarTypeLut object.
bool initializeSolution(ossimObservationSet &obsSet)
initialize adjustment solution
std::ostream * m_rep
Report stream pointer.
bool errors(ossimErrorSeverity severity=OSSIM_BENIGN) const
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
virtual const ossimFilename & getFilename() const
Returns the filename.
bool localToWorld(const ossimDpt &local_pt, ossimGpt &world_pt) const
Exposes the 3D projection from image to world coordinates.
OSSIM_DLL void getFormattedTime(const std::string &format, bool gmtFlag, std::string &result)
Gets the current time.
std::string::size_type size() const
virtual double getHeightAboveEllipsoid(const ossimGpt &gpt)
ossimRefPtr< ossimKeywordlist > m_oaxKwl
Hold contents of oax config file if –oax_config_file is used.
bool toBool() const
String to numeric methods.
virtual void closeCvWindow(const bool waitKeyPress=false)=0
unsigned int ossim_uint32
ossimDpt getMetersPerPixel() const
Returns the GSD associated with this image in the active projection.
ossim_float64 toFloat64() const
void execute()
Execute method.
void setApplicationName(const ossimString &name)
void createIdentityProjection(int idx)
Sets the single image chain for identity operations view to an ossimImageViewAffineTransform.
void usage(ossimArgumentParser &ap)
Initializes arg parser and outputs usage.
ossimObject * createObject(const ossimString &objectType)
ossimRefPtr< ossimKeywordlist > m_srcKwl
Hold contents of src file if –src is used.
ossimRefPtr< ossimKeywordlist > m_ocvKwl
Hold contents of OpenCV config file if –ocv_config_file is used.
bool keyIsTrue(ossimRefPtr< ossimKeywordlist > kwl, const std::string &key) const
ossim_uint32 width() const
ossimTieMeasurementGeneratorInterface * m_tGen
Tie point generator interface.
void setConvCriteria(const int convCriteria)
void setGroundSigmas(const double &latSig, const double &lonSig, const double &hgtSig)
std::vector< ossimIrect > m_roiRects
Correlation ROIs.
ossimAutRegOperation m_operation
Enumerated operation to perform.
bool runSolution()
run adjustment solution
ossimRefPtr< ossimAdjustmentExecutive > m_adjExec
Adjustment executive interface.
bool delineateROIs()
Internal correlation region determination.
void initializeOaxKwl()
Initializes m_oaxKwl if option was set.
void summarizeSolution() const
summarize solution
virtual void setUseGrid(const bool useGrid)=0
void addMeasurement(const ossimDpt &meas, const ossimFilename &imgFile, const ossimDpt &measSigma=ossimDpt(1.0, 1.0))
void saveAdjustment()
saveAdjustment method
Used to convert from scalar type enumeration to strings and vice versa.
This class defines an abstract Handler which all image handlers(loaders) should derive from...
bool m_showMatchWindow
OpenCV match window display flag.
bool setChainEntry(ossimRefPtr< ossimSingleImageChain > &chain, ossim_uint32 entryIndex) const
Sets entry for a chain.
ossimDpt midPoint() const
void setDescription(const ossimString &desc)
void initialize()
Internal initialize method.
virtual ossimDpt pointIndexedAt(const ossim_uint32 imgIdx, const ossim_uint32 measIdx)=0
virtual bool setImageList(std::vector< ossimImageSource *> src)=0
void initializeSrcKwl()
Initializes m_srcKwl if option was set.
bool open(const ossimFilename &file, bool openOverview=true)
open method that takes an image file.
const char * c_str() const
Returns a pointer to a null-terminated array of characters representing the string's contents...
ossimFilename imageFile(const int index) const
virtual ossimObject * getBaseObject()=0
static ossimInit * instance()
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
unsigned int numMeas() const
Returns zero-based bounding rectangle of the image.
bool addObservation(ossimRefPtr< ossimPointObservation > obs)
operations
void getAdjustment(ossimAdjustmentInfo &adj) const
std::basic_ofstream< char > ofstream
Class for char output file streams.
ossimRefPtr< const ossimImageRenderer > getImageRenderer() const
ossimAutRegUtil()
default constructor
virtual bool setMaxMatches(const int &maxMatches)=0
ossimFilename & setExtension(const ossimString &e)
Sets the extension of a file name.
virtual bool setCurrentEntry(ossim_uint32 entryIdx)
ossimRefPtr< ossimImageGeometry > m_geom[2]
The image geometry.
static const char * QUALITY_KW
const ossimAutRegUtil & operator=(const ossimAutRegUtil &rhs)
Hidden from use assignment operator.
virtual bool setROIs(std::vector< ossimIrect > roi)=0
bool isSrcFile(const ossimFilename &file) const
int & argc()
return the argument count.
void setExpandEnvVarsFlag(bool flag)
ossimColumnVector3d m_LatLonHgtSigmas
A priori tie point sigmas.
ossimRefPtr< ossimObservationSet > m_obsSet
Observation set.
void writeErrorMessages(std::ostream &output, ossimErrorSeverity sevrity=OSSIM_BENIGN)
write out error messages at an above specified .
const std::string & string() const
bool m_controlImage[2]
Control image flags.
void setAddChainCacheFlag(bool flag)
If flag is true a chain cache will be added to the chain at create time.
