ossimHillshadeTool.cpp
Go to the documentation of this file.
1 //**************************************************************************************************
2 //
3 // OSSIM Open Source Geospatial Data Processing Library
4 // See top level LICENSE.txt file for license information
5 //
6 //**************************************************************************************************
7
13 #include <ossim/base/ossimIrect.h>
16 #include <ossim/base/ossimNotify.h>
18 #include <ossim/base/ossimRefPtr.h>
23 #include <ossim/base/ossimTrace.h>
25
46 #include <ossim/init/ossimInit.h>
47
54
57 #include <cmath>
58 #include <sstream>
59 #include <string>
60
61 static ossimTrace traceDebug("ossimHillshadeUtil:debug");
62
63 static const std::string COLOR_BLUE_KW = "color_blue";
64 static const std::string COLOR_GREEN_KW = "color_green";
65 static const std::string COLOR_RED_KW = "color_red";
66 static const std::string COLOR_SOURCE_KW = "color_source";
67
69  "Computes shaded representation of input elevation surface with specified lighting parameters.";
70
72 {
74 }
75
76 // Private/hidden from use.
78 {
79 }
80
81 // Private/hidden from use.
83 {
84  return *this;
85 }
86
88 {
89  clear();
90 }
91
93 {
94  // Permit base class to pull out common options first.
96  return false;
97  if (m_helpRequested)
98  return true;
99
100  std::string tempString1;
101  ossimArgumentParser::ossimParameter stringParam1(tempString1);
102  std::string tempString2;
103  ossimArgumentParser::ossimParameter stringParam2(tempString2);
104  std::string tempString3;
105  ossimArgumentParser::ossimParameter stringParam3(tempString3);
106  std::string tempString4;
107  ossimArgumentParser::ossimParameter stringParam4(tempString4);
108  std::string tempString5;
109  ossimArgumentParser::ossimParameter stringParam5(tempString5);
110  std::string tempString6;
111  ossimArgumentParser::ossimParameter stringParam6(tempString6);
112  double tempDouble1;
113  ossimArgumentParser::ossimParameter doubleParam1(tempDouble1);
114  double tempDouble2;
115  ossimArgumentParser::ossimParameter doubleParam2(tempDouble2);
116
117  // Extract optional arguments and stuff them in a keyword list.
118  if( ap.read("--azimuth", stringParam1) )
119  {
120  m_kwl.addPair( std::string(ossimKeywordNames::AZIMUTH_ANGLE_KW), tempString1 );
121  }
122
123  if( ap.read("--color", stringParam1, stringParam2, stringParam3) )
124  {
125  m_kwl.addPair( COLOR_RED_KW, tempString1 );
126  m_kwl.addPair( COLOR_GREEN_KW, tempString2 );
127  m_kwl.addPair( COLOR_BLUE_KW, tempString3 );
128  }
129
130  int color_source_idx = 0;
131  while( ap.read("--color-source", stringParam1) )
132  {
133  ossimString key = COLOR_SOURCE_KW;
134  key += ossimString::toString(color_source_idx++);
135  key += ".";
137  m_kwl.addPair(key.string(), tempString1 );
138  }
139
140  if ( ap.read("--elevation", stringParam1) )
141  {
142  m_kwl.addPair( std::string(ossimKeywordNames::ELEVATION_ANGLE_KW), tempString1 );
143  }
144
146  return true;
147 }
148
149
151 {
152  // Need a mosaic of DEM over the AOI as an image mosaic:
154  m_procChain->add(demMosaic.get());
155
156  // Set up the normal source.
158  normSource->setTrackScaleFlag(true);
159  m_procChain->add( normSource.get() );
160
161  // Set the smoothness factor.
162  ossim_float64 gain = 1.0;
163  normSource->setSmoothnessFactor(gain);
164
165  // Create the bump shade.
167  m_procChain->add(bumpShade.get());
168
169  // Set the azimuth angle.
170  ossim_float64 azimuthAngle = 180;
172  if ( lookup.size() )
173  {
174  ossim_float64 f = lookup.toFloat64();
175  if ( (f >= 0) && (f <= 360) )
176  {
177  azimuthAngle = f;
178  }
179  }
180  bumpShade->setAzimuthAngle(azimuthAngle);
181
182  // Set the elevation angle.
183  ossim_float64 elevationAngle = 45.0;
185  if ( lookup.size() )
186  {
187  ossim_float64 f = lookup.toFloat64();
188  if ( (f >= 0.0) && (f <= 90) )
189  {
190  elevationAngle = f;
191  }
192  }
193  bumpShade->setElevationAngle(elevationAngle);
194
195
196  // Color can be added via color image source:
197  if (!m_imgLayers.empty())
198  {
199  // A color source image (or list) is provided. Add them as input to bump shade:
201  bumpShade->connectMyInputTo(1, colorSource.get());
202  }
203  else
204  {
205  // Default colors are grey:
206  ossim_uint8 r = 0xff;
207  ossim_uint8 g = 0xff;
208  ossim_uint8 b = 0xff;
209  lookup = m_kwl.findKey( COLOR_RED_KW );
210  if ( lookup.size() )
211  r = lookup.toUInt8();
212  lookup = m_kwl.findKey( COLOR_GREEN_KW );
213  if ( lookup.size() )
214  g = lookup.toUInt8();
215  lookup = m_kwl.findKey( COLOR_BLUE_KW );
216  if ( lookup.size() )
217  b = lookup.toUInt8();
218  bumpShade->setRgbColorSource(r, g, b);
219  }
220 }
221
223 {
224  // Add global usage options.
226
227  // Set app name.
228  ossimString appName = ap.getApplicationName();
230  ossimString usageString = appName;
231  usageString += " hillshade [option]... [input-option]... <input-file(s)> <output-file>\nNote at least one input is required either from one of the input options, e.g. --input-dem <my-dem.hgt> or adding to command line in front of the output file in which case the code will try to ascertain what type of input it is.\n\nAvailable traces:\n-T \"ossimChipperUtil:debug\" - General debug trace to standard out.\n-T \"ossimChipperUtil:log\" - Writes a log file to output-file.log.\n-T \"ossimChipperUtil:options\" - Writes the options to output-file-options.kwl.";
232  au->setCommandLineUsage(usageString);
233
234  // Add arguments.
235  au->addCommandLineOption("--azimuth", "<azimuth>\nLight source azimuth angle for bump shade.\nRange: 0 to 360, Default = 180.0");
236  au->addCommandLineOption("--color","<r> <g> <b>\nSet the red, green and blue color values to be used with hillshade.\nRange 0 to 255, Defualt r=255, g=255, b=255");
237  au->addCommandLineOption("--color-source","<file>\nSpecifies the image file to use as a color source instead of a fixed RGB value.");
238  au->addCommandLineOption("--elevation", "<elevation>\nhillshade option - Light source elevation angle for bumb shade.\nRange: 0 to 90, Default = 45.0");
239
240  // Base class has its own:
242
243  ostringstream description;
244  description << DESCRIPTION << "\n\nNOTES:\n"
245  << "1) Never use same base name in the same directory! Example is you have a Chicago.tif\n"
246  << " and you want a Chicago.jp2, output Chicago.jp2 to its own directory.\n"
247  << "\nExample command to Hill shade: Hill shade two DEMs, output to a geotiff.\n"
248  << appName << " --color 255 255 255 --azimuth 270 --elevation 45 --exaggeration 2.0 N37W123.hgt N38W123.hgt outputs/hillshade.tif\n"
249  << "\n// Above command where all options are in a keyword list:\n"
250  << appName << " --options r39-options.kwl\n"
251  << std::endl;
252
253  au->setDescription(description.str());
254
255 }
256
virtual bool initialize(ossimArgumentParser &ap)
Initial method to be ran prior to execute.
std::string getApplicationName() const
return the application name, as specified by argv[0]
void addCommandLineOption(const ossimString &option, const ossimString &explanation)
This uses a derivative of Blinn&#39;s bump function to compute a 3-D looking image.
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
static const char * FILE_KW
virtual void setUsage(ossimArgumentParser &ap)
Initializes the aurgument parser with expected parameters and options.
const std::string & findKey(const std::string &key) const
Find methods that take std::string(s).
bool m_helpRequested
Definition: ossimTool.h:150
ossim_uint8 toUInt8() const
static const char * DESCRIPTION
Used by ossimUtilityFactory.
void addOptions(ossimArgumentParser &parser)
Definition: ossimInit.cpp:100
bool read(const std::string &str)
search for an occurance of a string in the argument list, on sucess remove that occurance from the li...
Numeric to string methods.
virtual void initProcessingChain()
Derived classes initialize their custom chains here.
ossimKeywordlist m_kwl
Definition: ossimTool.h:148
ossimRefPtr< ossimImageSource > combineLayers(std::vector< ossimRefPtr< ossimSingleImageChain > > &layers) const
When multiple input sources are present, this method instantiates a combiner and adds inputs...
void addPair(const std::string &key, const std::string &value, bool overwrite=true)
ossimHillshadeTool()
default constructor
void setCommandLineUsage(const ossimString &explanation)
ossimApplicationUsage * getApplicationUsage()
virtual ~ossimHillshadeTool()
virtual destructor
ossimRefPtr< ossimImageChain > m_procChain
virtual void setElevationAngle(double angle)
double ossim_float64
virtual void clear()
Disconnects and clears the dem and image layers.
std::string::size_type size() const
Definition: ossimString.h:405
void processRemainingArgs(ossimArgumentParser &ap)
Intended to be called after derived class has picked off its own options from the parser...
ossimRefPtr< ossimImageSource > mosaicDemSources()
Some utilities need to work on DEMs as images.
void setRgbColorSource(ossim_uint8 r, ossim_uint8 g, ossim_uint8 b)
Set the red, green and blue color source values.
ossim_float64 toFloat64() const
std::vector< ossimRefPtr< ossimSingleImageChain > > m_imgLayers
virtual void setAzimuthAngle(double angle)
virtual bool add(ossimConnectableObject *source)
Will return true or false if an image source was added to the chain.
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
static const char * AZIMUTH_ANGLE_KW
void setDescription(const ossimString &desc)
const ossimHillshadeTool & operator=(const ossimHillshadeTool &rhs)
Hidden from use assignment operator.
static ossimInit * instance()
Definition: ossimInit.cpp:89
static const char * ELEVATION_ANGLE_KW
void setExpandEnvVarsFlag(bool flag)
unsigned char ossim_uint8
const std::string & string() const
Definition: ossimString.h:414
