Classes | Public Member Functions | Protected Member Functions | List of all members
ossimClosestToCenterCombiner Class Reference
This implements a closest to center combiner. More...
#include <ossimClosestToCenterCombiner.h>
Inheritance diagram for ossimClosestToCenterCombiner:
ossimImageMosaic ossimImageCombiner ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Classes
class  ossimClosestToCenterCombinerInfo
 ossimClosestToCenterCombiner ()
 Executes the ossimClosestToCenterCombiner algorithm. More...
- Public Member Functions inherited from ossimImageMosaic
 ossimImageMosaic ()
 ossimImageMosaic (ossimConnectableObject::ConnectableObjectList &inputSources)
virtual void initialize ()
- Public Member Functions inherited from ossimImageCombiner
 ossimImageCombiner ()
 ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag)
 ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources)
virtual void updateRects ()
 This will go through and precompute the bounding rects of each input image. More...
 Returns the number of bands available from the input. More...
virtual ossim_uint32 getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const
 Used to retrieve the number of overlapping images withint the given rect. More...
virtual void getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const
 Used to populate the result with the index of the overlapping images. More...
virtual ossimRefPtr< ossimImageDatagetNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual ossimRefPtr< ossimImageDatagetNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual bool getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0)
virtual ossimRefPtr< ossimImageDatagetNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual ossimRefPtr< ossimImageDatagetNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual bool canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const
virtual bool hasDifferentInputs () const
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
ossim_int32 findIdx (const std::vector< ossimClosestToCenterCombinerInfo > &normTileList, const ossimIpt &pt, ossim_uint32 offset) const
- Protected Member Functions inherited from ossimImageMosaic
virtual ~ossimImageMosaic ()
void allocate ()
 Called on first getTile, will initialize all data needed. More...
template<class T >
ossimRefPtr< ossimImageDatacombine (T, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
template<class T >
ossimRefPtr< ossimImageDatacombineNorm (T, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
- Protected Member Functions inherited from ossimImageCombiner
virtual ~ossimImageCombiner ()
void precomputeBounds () const
virtual ~ossimReferenced ()
Additional Inherited Members
- Protected Attributes inherited from ossimImageMosaic
- Protected Attributes inherited from ossimImageCombiner
ossim_uint32 theLargestNumberOfInputBands
ossim_uint32 theInputToPassThrough
bool theHasDifferentInputs
ossimRefPtr< ossimImageDatatheNormTile
std::vector< ossimIrecttheFullResBounds
bool theComputeFullResBoundsFlag
ossim_uint32 theCurrentIndex
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Detailed Description
It will first grab all images overlapping a given rectangle query. The first non-null closest pixel to the center of the image is used. This basically uses only pixels along the "sweet" spot of the image. This combiner is typically used when there is overlapping sensor data.
Definition at line 25 of file ossimClosestToCenterCombiner.h.
◆ ossimClosestToCenterCombiner()
ossimClosestToCenterCombiner::ossimClosestToCenterCombiner ( )
Definition at line 17 of file ossimClosestToCenterCombiner.cpp.
19 {
20 }
Member Function Documentation
◆ findIdx()
ossim_int32 ossimClosestToCenterCombiner::findIdx ( const std::vector< ossimClosestToCenterCombinerInfo > &  normTileList,
const ossimIpt pt,
ossim_uint32  offset
) const
protected
Definition at line 114 of file ossimClosestToCenterCombiner.cpp.
References distance(), ossimDataObject::getDataObjectStatus(), ossimImageData::isNull(), ossimIrect::midPoint(), OSSIM_FULL, ossimImageCombiner::theFullResBounds, and ossimImageMosaic::theTile.
Referenced by getTile().
116 {
117  ossim_float32 distance = 1000000;
118  ossim_int32 returnIdx = -1;
119  ossim_float32 tempDistance;
120  ossim_int32 idx = 0;
121  ossim_int32 maxIdx = (ossim_int32)normTileList.size();
122  ossimIpt midPt;
123  ossimIrect rect;
124  for(idx = 0; idx < maxIdx; ++ idx)
125  {
126  rect = theFullResBounds[ normTileList[idx].theIndex ];
127  midPt = rect.midPoint();
128
129  tempDistance = (pt-midPt).length();
130  if(tempDistance < distance)
131  {
132  if(normTileList[idx].theTile->getDataObjectStatus() == OSSIM_FULL)
133  {
134  distance = tempDistance;
135  returnIdx = idx;
136  }
137  else if(!normTileList[idx].theTile->isNull(offset))
138  {
139  distance = tempDistance;
140  returnIdx = idx;
141  }
142  }
143  }
144
145  return returnIdx;
146 }
float ossim_float32
bool isNull(ossim_uint32 offset) const
ossimIpt midPoint() const
Definition: ossimIrect.h:750
std::vector< ossimIrect > theFullResBounds
float distance(double lat1, double lon1, double lat2, double lon2, int units)
int ossim_int32
◆ getTile()
ossimRefPtr< ossimImageData > ossimClosestToCenterCombiner::getTile ( const ossimIrect rect,
ossim_uint32  resLevel = 0
virtual
sets the pixels to the closest Valid value. This simulates a sweet spot cutter.
Parameters
rectThe region of interest.
resLevel.For this combiner this is assumed to always be 0
Reimplemented from ossimImageMosaic.
Definition at line 22 of file ossimClosestToCenterCombiner.cpp.
References ossimImageMosaic::allocate(), ossimImageData::copyNormalizedBufferToTile(), ossimImageDataFactory::create(), ossimImageData::dup(), findIdx(), ossimImageData::getBuf(), ossimImageCombiner::getNextNormTile(), ossimImageData::getNumberOfBands(), ossimImageSource::getNumberOfOutputBands(), ossimImageMosaic::getTile(), ossimIrect::height(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimSource::isSourceEnabled(), ossimImageData::makeBlank(), ossim::min(), OSSIM_NORMALIZED_FLOAT, ossimImageData::setImageRectangle(), ossimImageData::setImageRectangleAndBands(), ossimImageMosaic::theTile, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
24 {
25  ossim_uint32 layerIdx = 0;
26  if(!isSourceEnabled())
27  {
28  return ossimImageMosaic::getTile(rect, resLevel);
29  }
30  if(!theTile.valid())
31  {
32  allocate();
33  if(!theTile.valid())
34  {
35  return 0;
36  }
37  }
39  theTile->makeBlank();
40  std::vector<ossimClosestToCenterCombinerInfo > normTileList;
41  ossimRefPtr<ossimImageData> currentTile = getNextNormTile(layerIdx, 0, rect);
42  while(currentTile.valid())
43  {
44  normTileList.push_back(ossimClosestToCenterCombinerInfo((ossimImageData*)currentTile->dup(),
45  layerIdx));
46  currentTile = getNextNormTile(layerIdx, rect, resLevel);
47  }
48
49
50  if(normTileList.size() == 1)
51  {
53  }
54  else if(normTileList.size() > 1)
55  {
58  copyTile->setImageRectangleAndBands(rect,
60  copyTile->initialize();
61
62  ossim_int32 idx = 0;
63  ossim_uint32 w = rect.width();
64  ossim_uint32 h = rect.height();
65  ossim_uint32 idxW = 0;
66  ossim_uint32 idxH = 0;
67  ossimIpt origin = rect.ul();
68  ossimIpt ulPt = rect.ul();
69  ossim_uint32 band = 0;
70  ossim_uint32 bands = copyTile->getNumberOfBands();
71  ossim_uint32 srcBandIdx = 0;
72  std::vector<ossim_float32*> bandList(bands);
73
74  for(band = 0; band < bands; ++band)
75  {
76  bandList[band] = (ossim_float32*)copyTile->getBuf(band);
77  }
78  ossim_uint32 offset = 0;
79  origin.y = ulPt.y;
80  for(idxH = 0; idxH < h; ++idxH)
81  {
82  origin.x = ulPt.x;
83  for(idxW = 0; idxW < w;++idxW)
84  {
85  idx = findIdx(normTileList, origin, offset);
86
87  if(idx >=0)
88  {
89  ossim_uint32 tileBands = normTileList[idx].theTile->getNumberOfBands();
90  if (tileBands > 0)
91  {
92  tileBands -= 1;
93  for(band = 0; band < bands; ++band)
94  {
95  srcBandIdx = ossim::min( tileBands, band );
96  bandList[band][offset] = *(((ossim_float32*)normTileList[idx].theTile->getBuf(srcBandIdx))+offset);
97  }
98  }
99  }
100  ++offset;
101  ++origin.x;
102  }
103  ++origin.y;
104  }
106  }
107
108  theTile->validate();
109
110  return theTile;
111
112 }
ossim_int32 findIdx(const std::vector< ossimClosestToCenterCombinerInfo > &normTileList, const ossimIpt &pt, ossim_uint32 offset) const
bool valid() const
Definition: ossimRefPtr.h:75
float ossim_float32
virtual ossimRefPtr< ossimImageData > getNextNormTile(ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0)
ossim_uint32 height() const
Definition: ossimIrect.h:487
const ossimIpt & ul() const
Definition: ossimIrect.h:274
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &origin, ossim_uint32 resLevel=0)
virtual void initialize()
Initialize the data buffer.
virtual ossimObject * dup() const
void allocate()
virtual void setImageRectangleAndBands(const ossimIrect &rect, ossim_uint32 numberOfBands)
unsigned int ossim_uint32
virtual void copyNormalizedBufferToTile(ossim_float64 *buf)
Copies buf passed in to tile.
T min(T a, T b)
Definition: ossimCommon.h:203
ossim_uint32 width() const
Definition: ossimIrect.h:500
virtual void makeBlank()
ossim_int32 y
Definition: ossimIpt.h:142
ossim_int32 x
Definition: ossimIpt.h:141
int ossim_int32
