ossimElevCellHandler Class Referenceabstract
#include <ossimElevCellHandler.h>
Inheritance diagram for ossimElevCellHandler:
ossimElevSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced ossimDtedHandler ossimGeneralRasterElevHandler ossimImageElevationHandler ossimSrtmHandler
Public Member Functions
 ossimElevCellHandler (const char *elev_filename)
 Constructors: More...
 ossimElevCellHandler (const ossimElevCellHandler &src)
virtual ossimIpt getSizeOfElevCell () const =0
 METHOD: getSizeOfElevCell Returns the number of post in the cell. More...
virtual double getPostValue (const ossimIpt &gridPt) const =0
 METHOD: getPostValue Returns the value at a given grid point as a double. More...
virtual double getMeanSpacingMeters () const
 METHOD: meanSpacingMeters() Implements pure virtual for. More...
virtual bool pointHasCoverage (const ossimGpt &) const
 METHOD: pointIsInsideRect() Method to check if the ground point elevation is defined: More...
virtual bool getAccuracyInfo (ossimElevationAccuracyInfo &info, const ossimGpt &gpt) const
 METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence): More...
virtual void close ()
virtual bool open (const ossimFilename &, bool=false)
- Public Member Functions inherited from ossimElevSource
virtual double getHeightAboveMSL (const ossimGpt &)=0
 Height access methods: More...
virtual double getHeightAboveEllipsoid (const ossimGpt &)
virtual ossimObjectdup () const =0
bool intersectRay (const ossimEcefRay &ray, ossimGpt &gpt, double defaultElevValue=0.0)
 METHOD: intersectRay() More...
virtual double getMinHeightAboveMSL () const
 Access methods for the bounding elevations: More...
virtual double getMaxHeightAboveMSL () const
double getNullHeightValue () const
 Special numeric quantities as defined by this source: More...
double getSeaLevelValue () const
virtual const ossimGrectgetBoundingGndRect () const
 METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence) in the region of gpt: More...
virtual void initialize ()
 Implement ossimSource base-class pure virtuals: More...
virtual bool getComputeStatisticsFlag () const
 Opens a stream to an elevation cell. More...
virtual void setComputeStatisticsFlag (bool flag)
 Sets the flag which controls whether or not statistics will be computed upon opening a cell and not finding a corresponding statistics file. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
Protected Member Functions
 ossimElevCellHandler ()
virtual ~ossimElevCellHandler ()
- Protected Member Functions inherited from ossimElevSource
virtual ~ossimElevSource ()
 ossimElevSource ()
 Constructors/Destructors: More...
 ossimElevSource (const ossimElevSource &src)
virtual ~ossimReferenced ()
Protected Attributes
ossimFilename theFilename
 Virtual method for reading. More...
double theMeanSpacing
double theAbsLE90
double theAbsCE90
- Protected Attributes inherited from ossimElevSource
double theMinHeightAboveMSL
 Data members: More...
double theMaxHeightAboveMSL
double theNullHeightValue
double theSeaLevelValue
ossimGrect theGroundRect
bool theComputeStatsFlag
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Additional Inherited Members
Detailed Description
Definition at line 34 of file ossimElevCellHandler.h.
◆ ossimElevCellHandler() [1/3]
ossimElevCellHandler::ossimElevCellHandler ( const char *  elev_filename)
Constructors:
Definition at line 55 of file ossimElevCellHandler.cpp.
56  : ossimElevSource(),
57  theFilename(filename),
58  theMeanSpacing(0.0),
59  theAbsLE90(0.0),
60  theAbsCE90(0.0)
61 {}
ossimElevSource()
◆ ossimElevCellHandler() [2/3]
ossimElevCellHandler::ossimElevCellHandler ( const ossimElevCellHandler src)
Definition at line 46 of file ossimElevCellHandler.cpp.
47  : ossimElevSource(src),
50  theAbsLE90 (src.theAbsLE90),
52 {
53 }
ossimElevSource()
◆ ossimElevCellHandler() [3/3]
ossimElevCellHandler::ossimElevCellHandler ( )
protected
Definition at line 37 of file ossimElevCellHandler.cpp.
38  : ossimElevSource(),
39  theFilename(),
40  theMeanSpacing(0.0),
41  theAbsLE90(0.0),
42  theAbsCE90(0.0)
43 {
44 }
ossimElevSource()
◆ ~ossimElevCellHandler()
ossimElevCellHandler::~ossimElevCellHandler ( )
protectedvirtual
Definition at line 63 of file ossimElevCellHandler.cpp.
64 {}
Member Function Documentation
◆ canConnectMyInputTo()
bool ossimElevCellHandler::canConnectMyInputTo ( ossim_int32  inputIndex,
const ossimConnectableObject object
) const
virtual
Reimplemented from ossimElevSource.
Definition at line 86 of file ossimElevCellHandler.cpp.
89 {
90  return false;
91 }
◆ close()
virtual void ossimElevCellHandler::close ( )
inlinevirtual
◆ getAccuracyInfo()
bool ossimElevCellHandler::getAccuracyInfo ( ossimElevationAccuracyInfo info,
const ossimGpt gpt
) const
virtual
◆ getFilename()
const ossimFilename & ossimElevCellHandler::getFilename ( ) const
virtual
◆ getMeanSpacingMeters()
double ossimElevCellHandler::getMeanSpacingMeters ( ) const
virtual
This method is used for deterrming preferred DEM among multiple overlapping elev sources:
Implements ossimElevSource.
Definition at line 71 of file ossimElevCellHandler.cpp.
References theMeanSpacing.
Referenced by ossimImageElevationDatabase::getHeightAboveMSL(), and ossimGeneralRasterElevationDatabase::openGeneralRasterDirectory().
72 {
73  return theMeanSpacing;
74 }
◆ getPostValue()
virtual double ossimElevCellHandler::getPostValue ( const ossimIpt gridPt) const
pure virtual
Implemented in ossimDtedHandler, ossimGeneralRasterElevHandler, ossimSrtmHandler, and ossimImageElevationHandler.
◆ getSizeOfElevCell()
virtual ossimIpt ossimElevCellHandler::getSizeOfElevCell ( ) const
pure virtual
Note: x = longitude, y = latitude
◆ open()
virtual bool ossimElevCellHandler::open ( const ossimFilename ,
bool  = false
inlinevirtual
Reimplemented in ossimGeneralRasterElevHandler, ossimDtedHandler, and ossimSrtmHandler.
Definition at line 84 of file ossimElevCellHandler.h.
84 {return false;}
◆ pointHasCoverage()
bool ossimElevCellHandler::pointHasCoverage ( const ossimGpt gpt) const
inlinevirtual
Reimplemented in ossimGeneralRasterElevHandler, and ossimImageElevationHandler.
Definition at line 105 of file ossimElevCellHandler.h.
References ossimGrect::pointWithin(), and ossimElevSource::theGroundRect.
Referenced by ossimDtedElevationDatabase::getHeightAboveMSL().
106 {
107  return theGroundRect.pointWithin(gpt);
108 }
bool pointWithin(const ossimGpt &gpt, bool considerHgt=false) const
METHOD: pointWithin(ossimGpt)
Definition: ossimGrect.h:232
◆ print()
std::ostream & ossimElevCellHandler::print ( std::ostream &  out) const
virtual
Returns
std::ostream&
Note
Derived classes should only have to implement a virtual print, not an operator<< funtion as it's implemented here.
Definition at line 93 of file ossimElevCellHandler.cpp.
References theAbsCE90, theAbsLE90, theFilename, and theMeanSpacing.
94 {
95  out << "\nossimElevCellHandler @ "<< (ossim_uint64) this
96  << "\n theFilename = "<< theFilename
97  << "\n theMeanSpacing = "<< theMeanSpacing
98  << "\n theAbsLE90 = "<< theAbsLE90
99  << "\n theAbsCE90 = "<< theAbsCE90;
100  //<< ossimElevSource::print(out);
101  return out;
102 }
unsigned long long ossim_uint64
Member Data Documentation
◆ theAbsCE90
double ossimElevCellHandler::theAbsCE90
protected
Definition at line 98 of file ossimElevCellHandler.h.
Referenced by getAccuracyInfo(), and print().
◆ theAbsLE90
double ossimElevCellHandler::theAbsLE90
protected
Definition at line 97 of file ossimElevCellHandler.h.
◆ theFilename
ossimFilename ossimElevCellHandler::theFilename
protected
◆ theMeanSpacing
double ossimElevCellHandler::theMeanSpacing
protected
