the DTED handler is an elevation source that allows for handling of a single cell of data. More...
#include <ossimDtedHandler.h>
Classes | |
class | DtedHeight |
DtedHeight is a class for storing DTED information. More... | |
class | DtedPost |
DtedPost, this class contains the height, weighting factor and status. More... | |
Public Types | |
enum | { DATA_RECORD_OFFSET_TO_POST = 8, DATA_RECORD_CHECKSUM_SIZE = 4, POST_SIZE = 2, NULL_POST = -32767 } |
enum | ossimConnectableObjectDirectionType { CONNECTABLE_DIRECTION_NONE = 0, CONNECTABLE_DIRECTION_INPUT = 1, CONNECTABLE_DIRECTION_OUTPUT = 2 } |
typedef std::vector< ossimRefPtr< ossimConnectableObject > > | ConnectableObjectList |
ossimDtedHandler () | |
Constructor. More... | |
ossimDtedHandler (const ossimFilename &dted_file, bool memoryMapFlag=false) | |
virtual bool | open (const ossimFilename &file, bool memoryMapFlag=false) |
opens a cell More... | |
virtual bool | open (std::shared_ptr< ossim::istream > &fileStr, const std::string &connectionString, bool memoryMapFlag=false) |
opens a cell given a stream More... | |
virtual void | close () |
virtual double | getHeightAboveMSL (const ossimGpt &gpt) |
virtual ossimIpt | getSizeOfElevCell () const |
virtual double | getPostValue (const ossimIpt &gridPt) const |
ossimString | edition () const |
ossimString | productLevel () const |
ossimString | compilationDate () const |
virtual bool | isOpen () const |
virtual bool | getAccuracyInfo (ossimElevationAccuracyInfo &info, const ossimGpt &gpt) const |
const ossimDtedVol & | vol () const |
const ossimDtedHdr & | hdr () const |
const ossimDtedUhl & | uhl () const |
const ossimDtedDsi & | dsi () const |
const ossimDtedAcc & | acc () const |
virtual ossimObject * | dup () const |
virtual | ~ossimDtedHandler () |
ossimElevCellHandler (const char *elev_filename) | |
Constructors: More... | |
ossimElevCellHandler (const ossimElevCellHandler &src) | |
virtual const ossimFilename & | getFilename () const |
virtual double | getMeanSpacingMeters () const |
METHOD: meanSpacingMeters() Implements pure virtual for. More... | |
virtual bool | pointHasCoverage (const ossimGpt &) const |
METHOD: pointIsInsideRect() Method to check if the ground point elevation is defined: More... | |
bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence): More... | |
virtual std::ostream & | print (std::ostream &out) const |
Outputs theErrorStatus as an ossimErrorCode and an ossimString. More... | |
virtual double | getHeightAboveEllipsoid (const ossimGpt &) |
bool | intersectRay (const ossimEcefRay &ray, ossimGpt &gpt, double defaultElevValue=0.0) |
METHOD: intersectRay() More... | |
virtual double | getMinHeightAboveMSL () const |
Access methods for the bounding elevations: More... | |
virtual double | getMaxHeightAboveMSL () const |
double | getNullHeightValue () const |
Special numeric quantities as defined by this source: More... | |
double | getSeaLevelValue () const |
virtual const ossimGrect & | getBoundingGndRect () const |
METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence) in the region of gpt: More... | |
virtual void | initialize () |
Implement ossimSource base-class pure virtuals: More... | |
virtual bool | getComputeStatisticsFlag () const |
Opens a stream to an elevation cell. More... | |
virtual void | setComputeStatisticsFlag (bool flag) |
Sets the flag which controls whether or not statistics will be computed upon opening a cell and not finding a corresponding statistics file. More... | |
ossimSource (ossimObject *owner=0) | |
ossimSource (ossimObject *owner, ossim_uint32 inputListSize, ossim_uint32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimSource () |
virtual bool | isSourceEnabled () const |
virtual void | enableSource () |
virtual void | disableSource () |
virtual bool | getEnableFlag () const |
virtual void | setEnableFlag (bool flag) |
virtual bool | isInitialized () const |
virtual void | setInitializedFlag (bool flag) |
virtual void | setProperty (ossimRefPtr< ossimProperty > property) |
virtual ossimRefPtr< ossimProperty > | getProperty (const ossimString &name) const |
virtual void | getPropertyNames (std::vector< ossimString > &propertyNames) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=0) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=0) |
ossimConnectableObject (ossimObject *owner=0) | |
Base constructor of this object. More... | |
ossimConnectableObject (ossimObject *owner, ossim_int32 inputListSize, ossim_int32 outputListSize, bool inputListIsFixedFlag=true, bool outputListIsFixedFlag=true) | |
virtual | ~ossimConnectableObject () |
void | setId (const ossimId &id) |
All connectable objects will have id's. More... | |
const ossimId & | getId () const |
Will allow us to get this object's id. More... | |
const ossimObject * | getOwner () const |
Fetches the current owner, most likely a container but not limited to one. More... | |
virtual void | changeOwner (ossimObject *owner) |
Permits changing the object's owner. More... | |
virtual void | setDescription (const ossimString &description) |
virtual ossimString | getDescription () const |
virtual bool | isConnected (ossimConnectableObjectDirectionType direction=CONNECTABLE_DIRECTION_INPUT) const |
will check the direction specified to see if all slots are full. More... | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findConnectableObject(const ossimId &id)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(RTTItypeid typeId, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObjectOfType(const ossimString &obj, ossimConnectableObjectDirectionType directionType, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findInputObjectOfType(const ossimString &className)) | |
virtual ossim_int32 | findInputIndex (const ossimConnectableObject *object) |
Return a valid index of the input list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findInputIndex (const ossimId &id) |
Return a valid index of the input list if the passed id is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimConnectableObject *object) |
Return a valid index of the output list if the passed in object is found else return -1. More... | |
virtual ossim_int32 | findOutputIndex (const ossimId &id) |
virtual ossim_int32 | getMyInputIndexToConnectTo (ossimConnectableObject *object) const |
Should return the first available index to connect to. More... | |
virtual ossim_int32 | getMyOutputIndexToConnectTo (ossimConnectableObject *object) const |
virtual bool | canConnectMyOutputTo (ossim_int32 myOutputIndex, const ossimConnectableObject *object) const |
default implementation is to allow anyone to connect to us. More... | |
virtual void | disconnect (ossimConnectableObject *object=0) |
Will disconnect the object passed in. More... | |
virtual void | disconnect (const ossimId &id) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyInput (ossim_int32 inputIndex, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given input index and generate a connection event. More... | |
virtual void | disconnectMyInput (ossimConnectableObject *input, bool disconnectOutputFlag=true, bool createEventFlag=true) |
Finds the index of the passed in input and calls disconnectMyInput(inputIndex, disconnectOutputFlag, createEventFlag);. More... | |
virtual void | disconnectMyInputs (ConnectableObjectList &inputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual ossimRefPtr< ossimConnectableObject > | disconnectMyOutput (ossim_int32 outputIndex, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the object at the given output index and generate a connection event. More... | |
virtual void | disconnectMyOutput (ossimConnectableObject *output, bool disconnectInputFlag=true, bool createEventFlag=true) |
Will disconnect the output object. More... | |
virtual void | disconnectMyOutputs (ConnectableObjectList &outputList, bool disconnectOutputFlag=true, bool createEventFlag=true) |
virtual void | disconnectAllInputs () |
Will disconnect all of the input objects. More... | |
virtual void | disconnectAllOutputs () |
Will disconnect all of the output objects. More... | |
virtual ossim_int32 | connectMyInputTo (ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will try to connect this objects input to the passed in object. More... | |
virtual ossim_int32 | connectMyInputTo (ossim_int32 inputIndex, ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true) |
Will connect the specified input to the passed in object. More... | |
virtual bool | connectMyInputTo (ConnectableObjectList &inputList, bool makeOutputConnection=true, bool createEventFlag=true) |
virtual ossim_int32 | connectMyOutputTo (ossimConnectableObject *outputObject, bool makeInputConnection=true, bool createEventFlag=true) |
Will try to connect this objects output to the passed in object. More... | |
virtual bool | connectMyOutputTo (ConnectableObjectList &outputList, bool makeInputConnection=true, bool createEventFlag=true) |
virtual bool | connectInputList (ConnectableObjectList &inputList) |
Will disconnect itself from all inputs and reset to the passed in input list. More... | |
virtual bool | connectOutputList (ConnectableObjectList &outputList) |
Will disconnect itself from all outputs and reset to the passed in output list. More... | |
virtual ossim_uint32 | getNumberOfInputs () const |
Returns the number of input objects. More... | |
virtual ossim_uint32 | getNumberOfOutputs () const |
Return the number of output objects. More... | |
ossimConnectableObject * | getInput (ossim_uint32 index=0) |
returns the object at the specified index. More... | |
const ossimConnectableObject * | getInput (ossim_uint32 index=0) const |
ossimConnectableObject * | getOutput (ossim_uint32 index=0) |
const ossimConnectableObject * | getOutput (ossim_uint32 index=0) const |
virtual void | setNumberOfInputs (ossim_int32 numberOfInputs) |
Will set the number of inputs. More... | |
virtual bool | getInputListIsFixedFlag () const |
virtual bool | getOutputListIsFixedFlag () const |
virtual void | setNumberOfOutputs (ossim_int32 numberOfInputs) |
Will set the number of outputs. More... | |
const ConnectableObjectList & | getInputList () const |
const ConnectableObjectList & | getOutputList () const |
ConnectableObjectList & | getInputList () |
ConnectableObjectList & | getOutputList () |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const RTTItypeid &typeInfo, bool recurse=true)) | |
OSSIM_DEPRECATE_METHOD (virtual void findAllObjectsOfType(ConnectableObjectList &result, const ossimString &className, bool recurse=true)) | |
virtual void | propagateEventToOutputs (ossimEvent &event) |
virtual void | propagateEventToInputs (ossimEvent &event) |
virtual void | setProperty (const ossimString &name, const ossimString &value) |
virtual ossim_uint32 | saveStateOfAllInputs (ossimKeywordlist &kwl, bool saveThisStateFlag=true, ossim_uint32 objectIndex=1, const char *prefix=0) const |
Save the state of all inputs to a keyword list. More... | |
virtual bool | fillContainer (ossimConnectableContainer &container) |
Inserts this object and all of its children and inputs into the container provided. More... | |
bool | moveInputUp (const ossimId &id) |
Moves the input connection matching id up one in the connection list. More... | |
bool | moveInputDown (const ossimId &id) |
Moves the input connection matching id down one in the connection list. More... | |
bool | moveInputToTop (const ossimId &id) |
Moves the input connection matching id to the top of the connection list. More... | |
bool | moveInputToBottom (const ossimId &id) |
Moves the input connection matching id to the bottom of the connection list. More... | |
virtual void | accept (ossimVisitor &visitor) |
We will add a visitor interface for all connectable objects. More... | |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimListenerManager () | |
virtual | ~ossimListenerManager () |
virtual void | fireEvent (ossimEvent &event) |
virtual bool | addListener (ossimListener *listener) |
virtual bool | removeListener (ossimListener *listener) |
virtual bool | findListener (ossimListener *listener) |
ossimPropertyInterface () | |
virtual | ~ossimPropertyInterface () |
virtual ossimString | getPropertyValueAsString (const ossimString &name) const |
void | getPropertyList (std::vector< ossimRefPtr< ossimProperty > > &propertyList) const |
void | setProperties (std::vector< ossimRefPtr< ossimProperty > > &propertyList) |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
Static Public Attributes | |
static const int | TOTAL_POSTS = 4 |
static const int | NUM_POSTS_PER_BLOCK = 2 |
const ossimDtedHandler & | operator= (const ossimDtedHandler &rhs) |
ossimDtedHandler (const ossimDtedHandler &) | |
void | gatherStatistics () |
ossim_sint16 | convertSignedMagnitude (ossim_uint16 &s) const |
virtual double | getHeightAboveMSL (const ossimGpt &, bool readFromFile) |
void | readPostsFromFile (DtedHeight &postData, int offset) |
read the height posts from the File More... | |
ossimElevCellHandler () | |
virtual | ~ossimElevCellHandler () |
virtual | ~ossimElevSource () |
ossimElevSource () | |
Constructors/Destructors: More... | |
ossimElevSource (const ossimElevSource &src) | |
ossimSource (const ossimSource &rhs) | |
const ossimSource & | operator= (const ossimSource &rhs) |
ossimConnectableObject * | findObjectOfType (ConnectableObjectList *connectableList, ossimVisitor &visitor) |
virtual | ~ossimReferenced () |
ossimListenerManager (const ossimListenerManager &rhs) | |
DTED is typically a 1x1 degree cell.
This can open from an ossim::istream or from a filename. It allows one to query the cell by overriding the getHeightAboveMSL.
For reference
When a height is calculated it will use a weighted average of 4 neighboring posts.
Definition at line 57 of file ossimDtedHandler.h.
anonymous enum |
Enumerator | |
DATA_RECORD_OFFSET_TO_POST | |
DATA_RECORD_CHECKSUM_SIZE | |
POST_SIZE | |
NULL_POST |
Definition at line 84 of file ossimDtedHandler.h.
inline |
ossimDtedHandler::ossimDtedHandler | ( | const ossimFilename & | dted_file, |
bool | memoryMapFlag = false |
Constructor.
dted_file | is a file path to the dted cell we wish to open |
memoryMapFlag | If this is set we will pull the entire cell into memory and treat that memory location as an inputstream. |
Definition at line 36 of file ossimDtedHandler.cpp.
Definition at line 97 of file ossimDtedHandler.cpp.
References close().
protected |
Definition at line 548 of file ossimDtedHandler.cpp.
inline |
Definition at line 162 of file ossimDtedHandler.h.
inlinevirtual |
Reimplemented from ossimElevCellHandler.
Definition at line 293 of file ossimDtedHandler.h.
References m_fileStr, and m_memoryMap.
Referenced by open(), and ~ossimDtedHandler().
ossimString ossimDtedHandler::compilationDate | ( | ) | const |
inlineprotected |
Definition at line 267 of file ossimDtedHandler.h.
References m_swapBytesFlag.
Referenced by getHeightAboveMSL(), and readPostsFromFile().
inline |
Definition at line 158 of file ossimDtedHandler.h.
inlinevirtual |
Implements ossimElevSource.
Definition at line 167 of file ossimDtedHandler.h.
References ossimElevCellHandler::getFilename().
ossimString ossimDtedHandler::edition | ( | ) | const |
protected |
If statistics file exist, stats will be initialized from that; else, this scans the dted cell and gets stats, then, writes new stats file. The statistics file will be named accordingly: If dted cell = n27.dt1 then the stats file = n27.statistics. Currently method only grabs the min and max posts value.
Definition at line 424 of file ossimDtedHandler.cpp.
References ossimFilename::setExtension(), and ossimElevCellHandler::theFilename.
Definition at line 102 of file ossimDtedHandler.cpp.
References ossimElevationAccuracyInfo::hasValidAbsoluteError(), ossimElevationAccuracyInfo::m_absoluteCE, ossimElevationAccuracyInfo::m_absoluteLE, m_acc, ossimElevationAccuracyInfo::m_confidenceLevel, m_dsi, ossimElevationAccuracyInfo::m_relativeCE, ossimElevationAccuracyInfo::m_relativeLE, and ossimElevationAccuracyInfo::m_surfaceName.
gpt | is a ground point <lat, lon> that is used to lookup the elevation pos value. |
Definition at line 116 of file ossimDtedHandler.cpp.
References m_fileStr, m_memoryMap, and ossim::nan().
protectedvirtual |
read the posts from the DTED file.
Definition at line 266 of file ossimDtedHandler.cpp.
References ossimDtedHandler::DtedHeight::calcHeight(), convertSignedMagnitude(), DATA_RECORD_OFFSET_TO_POST, ossimDtedHandler::DtedHeight::debug(), ossimDpt::lat, ossimGpt::lat, ossimDpt::lon, ossimGpt::lon, m_dtedRecordSizeInBytes, ossimDtedHandler::DtedPost::m_height, m_latSpacing, m_lonSpacing, m_memoryMap, m_numLatPoints, m_numLonLines, m_offsetToFirstDataRecord, ossimDtedHandler::DtedHeight::m_posts, ossimDtedHandler::DtedPost::m_status, m_swCornerPost, ossimDtedHandler::DtedPost::m_weight, ossim::nan(), POST_SIZE, and readPostsFromFile().
METHOD: getPostValue Returns the value at a given grid point as a double. Satisfies pure virtual.
Implements ossimElevCellHandler.
Definition at line 387 of file ossimDtedHandler.cpp.
References m_numLatPoints, m_numLonLines, ossimIpt::x, and ossimIpt::y.
METHOD: getSizeOfElevCell Returns the number of post in the cell. Satisfies pure virtual. Note: x = longitude, y = latitude
Definition at line 522 of file ossimDtedHandler.cpp.
References m_numLatPoints, and m_numLonLines.
inline |
Definition at line 150 of file ossimDtedHandler.h.
inlinevirtual |
Definition at line 284 of file ossimDtedHandler.h.
References m_fileStr, m_fileStrMutex, and m_memoryMap.
opens a cell
Definition at line 130 of file ossimDtedHandler.cpp.
References ossimString::c_str(), and ossim::StreamFactoryRegistry::instance().
Referenced by ossimDtedElevationDatabase::inititializeExtension().
fileStr | is a stream that was opened and has access to a cell. |
connectionString | is the connection string used to open the input stream. |
Definition at line 139 of file ossimDtedHandler.cpp.
References close(), m_acc, m_connectionString, m_dsi, m_dtedRecordSizeInBytes, m_fileStr, m_hdr, m_numLatPoints, m_numLonLines, m_uhl, m_vol, and ossimErrorCodes::OSSIM_ERROR.
protected |
Definition at line 542 of file ossimDtedHandler.cpp.
ossimString ossimDtedHandler::productLevel | ( | ) | const |
protected |
postData | - post heights, status & weight |
offset | - file contents offset to start reading from |
Definition at line 351 of file ossimDtedHandler.cpp.
References convertSignedMagnitude(), m_dtedRecordSizeInBytes, m_fileStr, m_fileStrMutex, ossimDtedHandler::DtedPost::m_height, ossimDtedHandler::DtedHeight::m_posts, ossimDtedHandler::DtedPost::m_status, NUM_POSTS_PER_BLOCK, and POST_SIZE.
Referenced by getHeightAboveMSL().
inline |
Definition at line 154 of file ossimDtedHandler.h.
inline |
Definition at line 146 of file ossimDtedHandler.h.
protected |
Definition at line 262 of file ossimDtedHandler.h.
Referenced by getAccuracyInfo(), and open().
protected |
Definition at line 246 of file ossimDtedHandler.h.
Referenced by compilationDate().
mutableprotected |
Definition at line 239 of file ossimDtedHandler.h.
Referenced by open().
protected |
Definition at line 261 of file ossimDtedHandler.h.
protected |
Definition at line 243 of file ossimDtedHandler.h.
Referenced by getHeightAboveMSL(), open(), and readPostsFromFile().
protected |
Definition at line 244 of file ossimDtedHandler.h.
Referenced by edition().
mutableprotected |
Definition at line 238 of file ossimDtedHandler.h.
Referenced by close(), getHeightAboveMSL(), isOpen(), open(), and readPostsFromFile().
mutableprotected |
Definition at line 236 of file ossimDtedHandler.h.
Referenced by isOpen(), and readPostsFromFile().
protected |
Definition at line 259 of file ossimDtedHandler.h.
protected |
Definition at line 248 of file ossimDtedHandler.h.
protected |
Definition at line 249 of file ossimDtedHandler.h.
mutableprotected |
Definition at line 256 of file ossimDtedHandler.h.
Referenced by close(), getHeightAboveMSL(), and isOpen().
mutableprotected |
Definition at line 255 of file ossimDtedHandler.h.
protected |
Definition at line 242 of file ossimDtedHandler.h.
Referenced by getHeightAboveMSL(), getPostValue(), getSizeOfElevCell(), and open().
protected |
Definition at line 241 of file ossimDtedHandler.h.
protected |
Definition at line 247 of file ossimDtedHandler.h.
protected |
Definition at line 245 of file ossimDtedHandler.h.
Referenced by productLevel().
protected |
Definition at line 253 of file ossimDtedHandler.h.
Referenced by convertSignedMagnitude().
protected |
Definition at line 250 of file ossimDtedHandler.h.
protected |
Definition at line 260 of file ossimDtedHandler.h.
protected |
Definition at line 258 of file ossimDtedHandler.h.
static |
Definition at line 64 of file ossimDtedHandler.h.
Referenced by readPostsFromFile().
static |
Definition at line 62 of file ossimDtedHandler.h.
Referenced by ossimDtedHandler::DtedHeight::calcHeight().
