Public Member Functions | Private Member Functions | List of all members
ossimEnviCgModel Class Reference
#include <ossimEnviCgModel.h>
Inheritance diagram for ossimEnviCgModel:
ossimCoarseGridModel ossimSensorModel ossimProjection ossimOptimizableProjection ossimAdjustableParameterInterface ossimObject ossimErrorStatusInterface ossimReferenced
 ossimEnviCgModel ()
 ossimEnviCgModel (const ossimFilename &geoc_file)
bool loadEnviGeocFile (const ossimFilename &geoc_file)
bool saveState (ossimKeywordlist &kwl, const char *prefix=0) const
 Fulfills ossimObject base-class pure virtuals. More...
- Public Member Functions inherited from ossimCoarseGridModel
 ossimCoarseGridModel ()
 ossimCoarseGridModel (const ossimCoarseGridModel &copy_this)
 ossimCoarseGridModel (const ossimFilename &geom_file)
 Accepts name of geometry file. More...
 ossimCoarseGridModel (const ossimKeywordlist &geom_kwl)
 Accepts OSSIM keywordlist geometry file. More...
 ~ossimCoarseGridModel ()
virtual void buildGrid (const ossimDrect &imageBounds, ossimProjection *proj, double heightDelta=500.0, bool enableHeightFlag=false, bool makeAdjustableFlag=true)
 This method will build a grid from any projector. More...
virtual void buildGrid (const ossimDrect &imageBounds, ossimImageGeometry *geom, double heightDelta=500.0, bool enableHeightFlag=false, bool makeAdjustableFlag=true)
 Assigns the grid data given a geometry. More...
 Extends base-class implementation. More...
 Returns pointer to a new instance, copy of this. More...
bool saveCoarseGrid (const ossimFilename &cgFileName) const
 Saves the coarse grid to the specified file. More...
bool loadCoarseGrid (const ossimFilename &cgFileName)
 Loads the coarse grid from the specified file. More...
virtual void imagingRay (const ossimDpt &image_point, ossimEcefRay &image_ray) const
virtual void lineSampleToWorld (const ossimDpt &image_point, ossimGpt &gpt) const
virtual void lineSampleHeightToWorld (const ossimDpt &image_point, const double &heightEllipsoid, ossimGpt &world_pt) const
 This is the virtual that performs the actual work of projecting the image point to the earth at some specified elevation. More...
virtual void initAdjustableParameters ()
virtual bool useForward () const
 image to ground faster More...
- Public Member Functions inherited from ossimSensorModel
 ossimSensorModel ()
 ossimSensorModel (const ossimSensorModel &copy_this)
 ossimSensorModel (const ossimKeywordlist &geom_kwl)
const ossimSensorModeloperator= (const ossimSensorModel &rhs)
 assignment operator More...
virtual ossimObjectgetBaseObject ()
virtual const ossimObjectgetBaseObject () const
virtual const double & getNominalPosError () const
 Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More...
virtual const double & getRelativePosError () const
 Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More...
virtual void setNominalPosError (const double &ce90)
 Assigns the absolute image position error uncertainty (abs CE90) More...
virtual void setRelativePosError (const double &ce90)
 Assigns the relative image position error uncertainty (rel CE90) More...
virtual void worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const
void setRefImgPt (const ossimDpt &pt)
 Sets the center line sampe of the image. More...
void setRefGndPt (const ossimGpt &pt)
 Sets the center latitude, longitude, height of the image. More...
void setImageRect (const ossimDrect &imageRect)
void setGroundRect (const ossimGpt &ul, const ossimGpt &ur, const ossimGpt &lr, const ossimGpt &ll)
ossimDpt imageSize () const
void setImageSize (const ossimDpt &size)
virtual void adjustableParametersChanged ()
virtual void updateModel ()
virtual bool insideImage (const ossimDpt &p) const
virtual bool operator== (const ossimProjection &proj) const
 Access methods: More...
const ossimDrectgetImageClipRect () const
virtual ossim_uint32 degreesOfFreedom () const
virtual bool needsInitialState () const
 needsInitialState() More...
virtual double optimizeFit (const ossimTieGptSet &tieSet, double *targetVariance=0)
virtual ossimDpt getForwardDeriv (int parmIdx, const ossimGpt &gpos, double hdelta=1e-11)
virtual ossimGpt getInverseDeriv (int parmIdx, const ossimDpt &ipos, double hdelta=1e-11)
virtual ossimSensorModel::CovMatStatus getObsCovMat (const ossimDpt &ipos, NEWMAT::SymmetricMatrix &Cov, const ossim_float64 defPointingSigma=0.5) const
 Gives 2X2 covariance matrix of observations. More...
void computeGsd ()
 This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More...
virtual bool getImageGeometry (const ossimString &, const ossimString &, ossimKeywordlist &) const
 Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More...
 ossimProjection ()
virtual ~ossimProjection ()
virtual ossimDpt forward (const ossimGpt &wp) const
virtual ossimGpt inverse (const ossimDpt &pp) const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimErrorStatusInterface ()
bool hasError () const
- Public Member Functions inherited from ossimOptimizableProjection
 ossimOptimizableProjection ()
 ossimOptimizableProjection (const ossimOptimizableProjection &source)
virtual ~ossimOptimizableProjection ()
virtual ossimOptimizableProjectionoperator= (const ossimOptimizableProjection &source)
virtual bool setupOptimizer (const ossimString &setup)
 setupFromString() Derived classes should implement as needed. Initialize parameters needed for optimizeFit and degreesOfFreedom More...
- Public Member Functions inherited from ossimAdjustableParameterInterface
 ossimAdjustableParameterInterface ()
 ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs)
virtual ~ossimAdjustableParameterInterface ()
void newAdjustment (ossim_uint32 numberOfParameters=0)
void setAdjustmentDescription (const ossimString &description)
ossimString getAdjustmentDescription () const
ossimString getAdjustmentDescription (ossim_uint32 adjustmentIdx) const
 Returns adjustmentDescription of specific adjustmentInfo. More...
void setCurrentAdjustment (ossim_uint32 adjustmentIndex, bool notify=false)
bool setCurrentAdjustment (const ossimString &description, bool notify=false)
 Sets the current adjustment to the adjustment with a matching description. More...
void eraseAdjustment (bool notify)
void eraseAdjustment (ossim_uint32 idx, bool notify)
void resetAdjustableParameters (bool notify=false)
void copyAdjustment (ossim_uint32 idx, bool notify)
void copyAdjustment (bool notify=false)
void keepAdjustment (ossim_uint32 idx, bool createCopy)
virtual void keepAdjustment (bool createCopy=true)
const ossimAdjustableParameterInterfaceoperator= (const ossimAdjustableParameterInterface &rhs)
void removeAllAdjustments ()
ossim_uint32 getNumberOfAdjustableParameters () const
double getAdjustableParameter (ossim_uint32 idx) const
virtual void setAdjustableParameter (ossim_uint32 idx, double value, bool notify=false)
virtual void setAdjustableParameter (ossim_uint32 idx, double value, double sigma, bool notify=false)
double getParameterSigma (ossim_uint32 idx) const
void setParameterSigma (ossim_uint32 idx, double value, bool notify=false)
ossimUnitType getParameterUnit (ossim_uint32 idx) const
void setParameterUnit (ossim_uint32 idx, ossimUnitType unit)
void setParameterUnit (ossim_uint32 idx, const ossimString &unit)
void setParameterCenter (ossim_uint32 idx, double center, bool notify=false)
double getParameterCenter (ossim_uint32 idx) const
double computeParameterOffset (ossim_uint32 idx) const
void setParameterOffset (ossim_uint32 idx, ossim_float64 value, bool notify=false)
ossimString getParameterDescription (ossim_uint32 idx) const
void setParameterDescription (ossim_uint32 idx, const ossimString &descrption)
ossim_int32 findParameterIdxGivenDescription (ossim_uint32 adjustmentIdx, const ossimString &name) const
ossim_int32 findParameterIdxContainingDescription (ossim_uint32 adjustmentIdx, const ossimString &name) const
bool isParameterLocked (ossim_uint32 idx) const
void setParameterLockFlag (ossim_uint32 idxParam, bool flag)
bool getParameterLockFlag (ossim_uint32 idx) const
void lockAllParametersCurrentAdjustment ()
void unlockAllParametersCurrentAdjustment ()
void lockAllParameters (ossim_uint32 idxAdjustment)
void unlockAllParameters (ossim_uint32 idxAdjustment)
void resizeAdjustableParameterArray (ossim_uint32 numberOfParameters)
void setAdjustment (const ossimAdjustmentInfo &adj, bool notify=false)
void setAdjustment (ossim_uint32 idx, const ossimAdjustmentInfo &adj, bool notify=false)
void addAdjustment (const ossimAdjustmentInfo &adj, bool notify)
void getAdjustment (ossimAdjustmentInfo &adj) const
void getAdjustment (ossim_uint32 idx, ossimAdjustmentInfo &adj) const
ossim_uint32 getNumberOfAdjustments () const
ossim_uint32 getCurrentAdjustmentIdx () const
void setDirtyFlag (bool flag=true)
void setAllDirtyFlag (bool flag=true)
bool hasDirtyAdjustments () const
virtual void saveCurrentAdjustmentOnly (ossimKeywordlist &kwl, const ossimString &prefix=ossimString(""))
 Saves the current active adjustment to the KWL file. More...
bool saveAdjustments (ossimKeywordlist &kwl, const ossimString &prefix=ossimString("")) const
 Save all adjustments to the KWL file. More...
bool loadAdjustments (const ossimKeywordlist &kwl, const ossimString &prefix=ossimString(""))
std::ostream & print (std::ostream &out) const
 Dumps the currently active adjustment to ostream. More...
double readValue (ifstream &s, bool bigEndian) const
Additional Inherited Members
- Public Types inherited from ossimSensorModel
enum  CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 }
enum  DeriveMode {
  OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2,
  P_WRT_Z = -3
- Static Public Member Functions inherited from ossimCoarseGridModel
static void setInterpolationError (double error=.1)
 This is used when building a grid from a projector. More...
static void setMinGridSpacing (ossim_int32 minSpacing=100)
static void writeGeomTemplate (ostream &os)
 Writes a template of geometry keywords processed by loadState and saveState to output stream. More...
- Static Public Member Functions inherited from ossimSensorModel
- Protected Member Functions inherited from ossimCoarseGridModel
void reallocateGrid (const ossimIpt &size)
 Deletes existing allocated memory and reallocates new space. More...
void initializeModelParams (ossimIrect irect)
 Initializes base class data members after grids have been assigned. More...
virtual ossimGpt extrapolate (const ossimDpt &imgPt, const double &height=ossim::nan()) const
 Implements its own extrapolation since this can be handled by ossimDblGrid. More...
- Protected Member Functions inherited from ossimSensorModel
virtual ~ossimSensorModel ()
virtual ossimDpt extrapolate (const ossimGpt &gp) const
void buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale)
NEWMAT::ColumnVector getResidue (const ossimTieGptSet &tieSet)
NEWMAT::ColumnVector solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const
NEWMAT::Matrix invert (const NEWMAT::Matrix &m) const
 stable invert stolen from ossimRpcSolver More...
virtual ~ossimReferenced ()
- Protected Member Functions inherited from ossimAdjustableParameterInterface
bool paramChanged (ossim_uint32 param_idx) const
 Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More...
void setAllChangeFlags (bool areChanged)
 Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More...
void initChangeFlags ()
 Initializes the change flags to TRUE. More...
- Protected Attributes inherited from ossimCoarseGridModel
ossimFilename theGridFilename
ossimDblGrid theLatGrid
ossimDblGrid theLonGrid
ossimDblGrid theDlatDhGrid
ossimDblGrid theDlonDhGrid
ossimDblGridtheDlatDparamGrid
ossimDblGridtheDlonDparamGrid
ossimAdjustmentInfo theInitialAdjustment
bool theHeightEnabledFlag
- Protected Attributes inherited from ossimSensorModel
ossimIpt theImageSize
ossimDpt theSubImageOffset
ossimString theImageID
ossimString theSensorID
ossimDpt theGSD
ossim_float64 theMeanGSD
ossimGpt theRefGndPt
ossimDpt theRefImgPt
ossimPolygon theBoundGndPolygon
ossimDrect theImageClipRect
ossim_float64 theRelPosError
ossim_float64 theNominalPosError
ossimDpt theParWRTx
 Partials for current point. More...
ossimDpt theParWRTy
ossimDpt theParWRTz
ossimDpt theObs
 Observations & residuals for current point. More...
ossimDpt theResid
ossimRefPtr< ossimProjectiontheSeedFunction
 Used as an initial guess for iterative solutions and a guess for points outside the support bounds. More...
bool theExtrapolateImageFlag
bool theExtrapolateGroundFlag
ossimErrorCode theErrorStatus
- Static Protected Attributes inherited from ossimCoarseGridModel
static double theInterpolationError = .1
static ossim_int32 theMinGridSpacing = 100
Detailed Description
Definition at line 13 of file ossimEnviCgModel.h.
◆ ossimEnviCgModel() [1/2]
ossimEnviCgModel::ossimEnviCgModel ( )
Definition at line 32 of file ossimEnviCgModel.cpp.
◆ ossimEnviCgModel() [2/2]
ossimEnviCgModel::ossimEnviCgModel ( const ossimFilename geoc_file)
Definition at line 37 of file ossimEnviCgModel.cpp.
References loadEnviGeocFile().
39 {
40  loadEnviGeocFile(geoc_file);
41 }
bool loadEnviGeocFile(const ossimFilename &geoc_file)
Member Function Documentation
◆ loadEnviGeocFile()
bool ossimEnviCgModel::loadEnviGeocFile ( const ossimFilename geoc_file)
Definition at line 45 of file ossimEnviCgModel.cpp.
References ossimString::after(), ossimString::c_str(), ossimString::contains(), ossimDblGrid::fill(), ossimSensorModel::imageSize(), ossimDblGrid::initialize(), ossimCoarseGridModel::initializeModelParams(), readValue(), ossimDblGrid::SAWTOOTH_90, ossimDblGrid::setDomainType(), ossimErrorStatusInterface::setErrorStatus(), ossimDblGrid::setNode(), ossimCoarseGridModel::theDlatDhGrid, ossimCoarseGridModel::theDlonDhGrid, ossimCoarseGridModel::theHeightEnabledFlag, ossimCoarseGridModel::theLatGrid, ossimCoarseGridModel::theLonGrid, ossimString::toInt(), ossimString::trim(), ossimDblGrid::WRAP_180, ossimDpt::x, x, ossimDpt::y, and y.
Referenced by ossimEnviCgModel().
46 {
47  theHeightEnabledFlag = false;
49
50  ossimFilename geoc_hdr (geoc_file + ".hdr");
51
52  ifstream geocHdrStream (geoc_hdr.c_str());
53  if (geocHdrStream.fail())
54  {
55  cout << "ossimEnviCgModel:loadEnviGeocFile() Error encountered opening GEOC header file <"<<geoc_hdr<<">"<<endl;
56  return false;
57  }
58
59  char line[1024];
61  geocHdrStream.getline(line, 1024);
62  ossimString oline(line);
63  int bigEndian=0;
64  if (!oline.contains("ENVI"))
65  {
66  cout << "ossimEnviCgModel:loadEnviGeocFile() Error: GEOC header file <"<<geoc_hdr
67  <<"> missing \"ENVI\" magic number."<<endl;
68  return false;
69  }
70  while (!geocHdrStream.eof())
71  {
72  geocHdrStream.getline(line, 1024);
73  oline = line;
74  vector<ossimString> strSplit;
75  if (oline.contains("samples"))
76  imageSize.x = oline.after("=").trim().toInt();
77  else if (oline.contains("lines"))
78  imageSize.y = oline.after("=").trim().toInt();
79  else if (oline.contains("byte order"))
80  bigEndian = oline.after("=").trim().toInt();
81  }
82
83  ossimDpt gridOrigin(0,0);
84
85  ifstream geocStream (geoc_file.c_str(), ios_base::binary|ios_base::in);
86  if (geocStream.fail())
87  {
88  cout << "ossimEnviCgModel:Ctor Error encountered opening GEOC file <"<<geoc_file<<">"<<endl;
89  return false;
90  }
91
92  ossimDpt spacing (1,1);
93  theLatGrid.initialize(imageSize, gridOrigin, spacing);
94  theLonGrid.initialize(imageSize, gridOrigin, spacing);
95  theDlatDhGrid.initialize(imageSize, gridOrigin, spacing);
96  theDlonDhGrid.initialize(imageSize, gridOrigin, spacing);
97
98  double value;
99  for (int y=0; (y<imageSize.y) && !geocStream.eof() ; ++y)
100  {
101  for (int x=0; (x<imageSize.x) && !geocStream.eof() ; ++x)
102  {
103  value = readValue(geocStream, (bool) bigEndian);
104  theLonGrid.setNode(x, y, value);
105  }
106  }
107  for (int y=0; (y<imageSize.y) && !geocStream.eof() ; ++y)
108  {
109  for (int x=0; (x<imageSize.x) && !geocStream.eof() ; ++x)
110  {
111  value = readValue(geocStream, (bool) bigEndian);
112  theLatGrid.setNode(x, y, value);
113  }
114  }
115
116  theDlatDhGrid.fill(0.0);
117  theDlonDhGrid.fill(0.0);
120
121  ossimIrect imageBounds(0, 0, imageSize.x-1, imageSize.y-1);
122  initializeModelParams(imageBounds);
123
124  return true;
125 }
ossim_uint32 x
ossim_uint32 y
std::basic_ifstream< char > ifstream
Class for char input file streams.
Definition: ossimIosFwd.h:44
double readValue(ifstream &s, bool bigEndian) const
double y
Definition: ossimDpt.h:165
void setDomainType(DomainType dt)
Definition: ossimDblGrid.h:156
void initialize(const ossimIpt &size, const ossimDpt &origin, const ossimDpt &spacing, double null_value=OSSIM_DEFAULT_NULL_PIX_DOUBLE)
ossimDpt imageSize() const
double x
Definition: ossimDpt.h:164
const char * c_str() const
Definition: ossimString.h:396
void initializeModelParams(ossimIrect irect)
void fill(double fill_value)
void setNode(const ossimIpt &p, const double &value)
Definition: ossimDblGrid.h:107
◆ readValue()
double ossimEnviCgModel::readValue ( ifstream &  s,
bool  bigEndian
) const
private
Definition at line 135 of file ossimEnviCgModel.cpp.
Referenced by loadEnviGeocFile().
136 {
137  double value;
138  s.read( reinterpret_cast<char*>(&value) , sizeof(double) );
139  if (bigEndian)
140  {
141  char * pc = reinterpret_cast<char *>(&value);
142  std::swap(pc[0], pc[7]);
143  std::swap(pc[1], pc[6]);
144  std::swap(pc[2], pc[5]);
145  std::swap(pc[3], pc[4]);
146  cout<<endl;
147  }
148  return value;
149 }
◆ saveState()
bool ossimEnviCgModel::saveState ( ossimKeywordlist kwl,
const char *  prefix = 0
) const
virtual
Saves geometry KWL files.
Returns
Returns true if successful.
Reimplemented from ossimCoarseGridModel.
Definition at line 127 of file ossimEnviCgModel.cpp.
References ossimKeywordlist::add(), ossimCoarseGridModel::saveState(), and status.
128 {
129  bool status = ossimCoarseGridModel::saveState(kwl, prefix);
130  if (status)
131  kwl.add(prefix, "type", "ossimCoarseGridModel");
132  return status;
133 }
return status
