ossimGeoAnnotationEllipseObject Class Reference
#include <ossimGeoAnnotationEllipseObject.h>
Inheritance diagram for ossimGeoAnnotationEllipseObject:
ossimGeoAnnotationObject ossimAnnotationObject ossimObject ossimReferenced
Public Member Functions
 ossimGeoAnnotationEllipseObject (const ossimGpt &center=ossimGpt(0, 0), const ossimDpt &widthHeight=ossimDpt(0, 0), bool enableFill=false, ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1)
 ossimGeoAnnotationEllipseObject (const ossimGeoAnnotationEllipseObject &rhs)
virtual void applyScale (double x, double y)
 Generic print method. More...
virtual void draw (ossimRgbImage &anImage) const
virtual bool intersects (const ossimDrect &rect) const
virtual ossimAnnotationObjectgetNewClippedObject (const ossimDrect &rect) const
virtual void getBoundingRect (ossimDrect &rect) const
virtual void computeBoundingRect ()
virtual void transform (ossimImageGeometry *projection)
 Saves the current state of this object. More...
virtual void setEllipseWidthHeightUnitType (ossimUnitType type)
virtual void setWidthHeight (const ossimDpt &pt)
 Sets the width and height of point. More...
virtual void setAzimuth (ossim_float64 azimuth)
 Sets the azimuth. More...
virtual ossim_float64 getAzimuth () const
 Gets the azimuth. More...
virtual void setColor (ossim_uint8 r, ossim_uint8 g, ossim_uint8 b)
 Sets the color of theProjectedEllipse. More...
virtual void setThickness (ossim_uint8 thickness)
 Sets the pen thickness of theProjectedEllipse. More...
virtual void setFillFlag (bool flag)
 Sets the fill flag. More...
virtual bool getFillFlag () const
virtual void setDrawAxesFlag (bool flag)
 Turns on and off drawing of axes on the ellipse. More...
virtual bool getDrawAxesFlag () const
virtual void setCenter (const ossimGpt &gpt)
 Sets the center ground point. More...
virtual void getCenter (ossimGpt &gpt) const
- Public Member Functions inherited from ossimGeoAnnotationObject
 ossimGeoAnnotationObject (unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1)
 ossimGeoAnnotationObject (const ossimGeoAnnotationObject &rhs)
- Public Member Functions inherited from ossimAnnotationObject
virtual ~ossimAnnotationObject ()
 ossimAnnotationObject (ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1)
virtual void applyScale (const ossimDpt &scale)
virtual ossimDrect getBoundingRect () const
void getColor (ossim_uint8 &r, ossim_uint8 &g, ossim_uint8 &b) const
ossim_uint8 getThickness () const
virtual bool isPointWithin (const ossimDpt &imagePoint) const
virtual ossimString getName () const
virtual void setName (const ossimString &name)
ossim_uint32 getId () const
virtual ossim_uint32 setId ()
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
Protected Member Functions
virtual ~ossimGeoAnnotationEllipseObject ()
void getWidthHeightInPixels (ossimDpt &widthHeight, const ossimImageGeometry *projection) const
- Protected Member Functions inherited from ossimGeoAnnotationObject
virtual ~ossimGeoAnnotationObject ()
virtual ~ossimReferenced ()
Protected Attributes
ossimRefPtr< ossimAnnotationEllipseObjecttheProjectedEllipse
ossimGpt theCenter
ossimDpt theWidthHeight
ossimUnitType theEllipseWidthHeightUnitType
- Protected Attributes inherited from ossimAnnotationObject
ossim_uint8 theRed
ossim_uint8 theGreen
ossim_uint8 theBlue
ossim_uint8 theThickness
ossimString theName
ossim_uint32 theId
Additional Inherited Members
- Static Public Member Functions inherited from ossimAnnotationObject
static ossim_uint32 getNextId ()
static void restIdCounter ()
- Static Protected Attributes inherited from ossimAnnotationObject
static ossim_uint32 theIdCounter = 0
Detailed Description
Definition at line 14 of file ossimGeoAnnotationEllipseObject.h.
◆ ossimGeoAnnotationEllipseObject() [1/2]
ossimGeoAnnotationEllipseObject::ossimGeoAnnotationEllipseObject ( const ossimGpt center = ossimGpt(0,0),
const ossimDpt widthHeight = ossimDpt(0,0),
bool  enableFill = false,
ossim_uint8  r = 255,
ossim_uint8  g = 255,
ossim_uint8  b = 255,
ossim_uint8  thickness = 1
It is important to note that the width and height should be specified in width = deltaLon and height = deltaLat. Use the ossimDpt .lat and .lon attributes to set it.
Definition at line 23 of file ossimGeoAnnotationEllipseObject.cpp.
References theProjectedEllipse.
Referenced by dup().
31  :ossimGeoAnnotationObject(r, g, b, thickness),
33  theCenter(center),
34  theWidthHeight(widthHeight),
35  theEllipseWidthHeightUnitType(OSSIM_PIXEL) // default to image space
36 {
38  ossimDpt(0,0),
39  enableFill,
40  r,
41  g,
42  b,
43  thickness);
44 }
ossimGeoAnnotationObject(unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1)
ossimRefPtr< ossimAnnotationEllipseObject > theProjectedEllipse
◆ ossimGeoAnnotationEllipseObject() [2/2]
ossimGeoAnnotationEllipseObject::ossimGeoAnnotationEllipseObject ( const ossimGeoAnnotationEllipseObject rhs)
◆ ~ossimGeoAnnotationEllipseObject()
ossimGeoAnnotationEllipseObject::~ossimGeoAnnotationEllipseObject ( )
protectedvirtual
Definition at line 56 of file ossimGeoAnnotationEllipseObject.cpp.
References theProjectedEllipse, and ossimRefPtr< T >::valid().
57 {
59  {
61  }
62 }
bool valid() const
Definition: ossimRefPtr.h:75
Member Function Documentation
◆ applyScale()
void ossimGeoAnnotationEllipseObject::applyScale ( double  x,
double  y
virtual
Implements ossimAnnotationObject.
Definition at line 69 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::applyScale(), ossimGpt::latd(), ossimGpt::lond(), theCenter, theProjectedEllipse, theWidthHeight, ossimRefPtr< T >::valid(), ossimDpt::x, x, ossimDpt::y, and y.
71 {
75  theWidthHeight .x *= x;
76  theWidthHeight .y *= y;
77 }
ossim_uint32 x
double lond() const
Will convert the radian measure to degrees.
Definition: ossimGpt.h:97
ossim_uint32 y
bool valid() const
double y
Definition: ossimDpt.h:165
double latd() const
Definition: ossimGpt.h:87
virtual void applyScale(double x, double y)
double x
Definition: ossimDpt.h:164
◆ computeBoundingRect()
void ossimGeoAnnotationEllipseObject::computeBoundingRect ( )
virtual
◆ draw()
void ossimGeoAnnotationEllipseObject::draw ( ossimRgbImage anImage) const
virtual
Definition at line 88 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::draw(), theProjectedEllipse, and ossimRefPtr< T >::valid().
89 {
91  {
92  theProjectedEllipse->draw(anImage);
93  }
94 }
bool valid() const
virtual void draw(ossimRgbImage &anImage) const
◆ dup()
ossimObject * ossimGeoAnnotationEllipseObject::dup ( ) const
virtual
Definition at line 64 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimGeoAnnotationEllipseObject().
65 {
66  return new ossimGeoAnnotationEllipseObject(*this);
67 }
ossimGeoAnnotationEllipseObject(const ossimGpt &center=ossimGpt(0, 0), const ossimDpt &widthHeight=ossimDpt(0, 0), bool enableFill=false, ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1)
◆ getAzimuth()
ossim_float64 ossimGeoAnnotationEllipseObject::getAzimuth ( ) const
virtual
Gets the azimuth.
Returns
The azimuth in decimal degrees.
Definition at line 261 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::getAzimuth(), theProjectedEllipse, and ossimRefPtr< T >::valid().
Referenced by saveState().
262 {
264  {
266  }
267  return 0.0;
268 }
bool valid() const
virtual ossim_float64 getAzimuth() const
Gets the azimuth.
◆ getBoundingRect()
void ossimGeoAnnotationEllipseObject::getBoundingRect ( ossimDrect rect) const
virtual
Definition at line 119 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::getBoundingRect(), ossimDrect::makeNan(), theProjectedEllipse, and ossimRefPtr< T >::valid().
120 {
122  {
124  }
125  else
126  {
127  rect.makeNan();
128  }
129 }
void makeNan()
Definition: ossimDrect.h:388
virtual void getBoundingRect(ossimDrect &rect) const
bool valid() const
◆ getCenter()
void ossimGeoAnnotationEllipseObject::getCenter ( ossimGpt gpt) const
virtual
Parameters
gptThe point to initialize with the center.
Definition at line 392 of file ossimGeoAnnotationEllipseObject.cpp.
References theCenter.
393 {
394  gpt = theCenter;
395 }
◆ getDrawAxesFlag()
bool ossimGeoAnnotationEllipseObject::getDrawAxesFlag ( ) const
virtual
Returns
The draw axes flag.
Definition at line 378 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::getDrawAxesFlag(), theProjectedEllipse, and ossimRefPtr< T >::valid().
379 {
381  {
383  }
384  return false;
385 }
bool valid() const
◆ getFillFlag()
bool ossimGeoAnnotationEllipseObject::getFillFlag ( ) const
virtual
Returns
The fill flag.
Definition at line 361 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::getFillFlag(), theProjectedEllipse, and ossimRefPtr< T >::valid().
362 {
364  {
366  }
367  return false;
368 }
bool valid() const
◆ getNewClippedObject()
ossimAnnotationObject * ossimGeoAnnotationEllipseObject::getNewClippedObject ( const ossimDrect rect) const
virtual
Will allocate a new object that is clipped to the passed. in rect. Look at derived classes to see if the object is actually clipped or not. A new object is returned if it clips to the rect else NULL should be returned it doesn't clip.
Definition at line 106 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::getNewClippedObject(), intersects(), theProjectedEllipse, and ossimRefPtr< T >::valid().
107 {
108  if(intersects(rect))
109  {
111  {
113  }
114  }
115
116  return (ossimAnnotationObject*)0;
117 }
bool valid() const
virtual bool intersects(const ossimDrect &rect) const
virtual ossimAnnotationObject * getNewClippedObject(const ossimDrect &rect) const
◆ getWidthHeightInPixels()
void ossimGeoAnnotationEllipseObject::getWidthHeightInPixels ( ossimDpt widthHeight,
const ossimImageGeometry projection
) const
protected
Definition at line 270 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimImageGeometry::getMetersPerPixel(), ossimImageGeometry::getProjection(), ossimUnitConversionTool::getValue(), ossimImageGeometry::hasProjection(), ossimProjection::origin(), OSSIM_DEGREES, OSSIM_METERS, OSSIM_MINUTES, OSSIM_PIXEL, OSSIM_SECONDS, ossimUnitConversionTool::setValue(), theEllipseWidthHeightUnitType, theWidthHeight, ossimDpt::x, x, ossimDpt::y, and y.
Referenced by transform().
272 {
274  {
275  case OSSIM_PIXEL:
276  {
277  widthHeight = theWidthHeight;
278
279  break;
280  }
281
282  case OSSIM_DEGREES:
283  case OSSIM_MINUTES:
284  case OSSIM_SECONDS:
285  {
286  ossimGpt origin = projection->hasProjection()?projection->getProjection()->origin():ossimGpt();
287  ossimDpt gsd = projection->getMetersPerPixel();
288
289  ossimUnitConversionTool uct(origin,
292
293  double x = uct.getValue(OSSIM_METERS);
294
296
297  double y = uct.getValue(OSSIM_METERS);
298
299  widthHeight.x = ceil(x/gsd.x);
300  widthHeight.y = ceil(y/gsd.y);
301
302  break;
303  }
304
305  case OSSIM_METERS:
306  {
307  ossimDpt gsd = projection->getMetersPerPixel();
308  widthHeight.x = static_cast<ossim_int32>(theWidthHeight.x/gsd.x+0.5);
309  widthHeight.y = static_cast<ossim_int32>(theWidthHeight.y/gsd.y+0.5);
310
311  break;
312  }
313
314  default:
315  {
316  ossimDpt gsd = projection->getMetersPerPixel();
317
320
321  double x = uct.getValue(OSSIM_METERS);
322
324
325  double y = uct.getValue(OSSIM_METERS);
326
327  widthHeight.x = ceil(x/gsd.x);
328  widthHeight.y = ceil(y/gsd.y);
329
330  break;
331  }
332  }
333 }
ossim_uint32 x
ossim_uint32 y
double y
ossimDpt getMetersPerPixel() const
Returns the GSD associated with this image in the active projection.
virtual ossimGpt origin() const =0
double x
bool hasProjection() const
Returns TRUE if valid projection defined.
int ossim_int32
◆ intersects()
bool ossimGeoAnnotationEllipseObject::intersects ( const ossimDrect rect) const
virtual
Definition at line 96 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::intersects(), theProjectedEllipse, and ossimRefPtr< T >::valid().
Referenced by getNewClippedObject().
97 {
99  {
101  }
102
103  return false;
104 }
bool valid() const
◆ loadState()
bool ossimGeoAnnotationEllipseObject::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Reimplemented from ossimGeoAnnotationObject.
Definition at line 174 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimKeywordlist::find(), ossimUnitTypeLut::getEntryNumber(), ossimUnitTypeLut::instance(), ossimGeoAnnotationObject::loadState(), OSSIM_PIXEL, OSSIM_UNIT_UNKNOWN, setAzimuth(), ossimAnnotationObject::setColor(), setDrawAxesFlag(), setFillFlag(), ossimAnnotationObject::setThickness(), status, ossimAnnotationObject::theBlue, theCenter, theEllipseWidthHeightUnitType, ossimAnnotationObject::theGreen, theProjectedEllipse, ossimAnnotationObject::theRed, ossimAnnotationObject::theThickness, theWidthHeight, ossimString::toDouble(), ossimDpt::x, and ossimDpt::y.
176 {
177  if (!theProjectedEllipse)
178  {
179  return false;
180  }
181
182  //---
183  // Base class state must be called first to pick up colors...
184  //---
185  bool status = ossimGeoAnnotationObject::loadState(kwl, prefix);
186  if (status == true)
187  {
190  }
191
192  const char* center = kwl.find(prefix, "center");
193  const char* ellipse_width = kwl.find(prefix, "ellipse_width");
194  const char* ellipse_height = kwl.find(prefix, "ellipse_height");
195  const char* azimuth = kwl.find(prefix, "azimuth");
196  const char* fill = kwl.find(prefix, "fill");
197  const char* draw_axes = kwl.find(prefix, "draw_axes");
198  const char* units = kwl.find(prefix, "units");
199
200  if(units)
201  {
205  {
207  }
208  }
209
210  if (center)
211  {
212  std::istringstream is(center);
213  is >> theCenter;
214  }
215  if(ellipse_width)
216  {
217  theWidthHeight.x = ossimString(ellipse_width).toDouble();
218  }
219  if(ellipse_height)
220  {
221  theWidthHeight.y = ossimString(ellipse_height).toDouble();
222  }
223
224  if (azimuth)
225  {
226  setAzimuth(ossimString(azimuth).toFloat64());
227  }
228
229  if (fill)
230  {
231  setFillFlag(ossimString(fill).toBool());
232  }
233
234  if (draw_axes)
235  {
236  setDrawAxesFlag(ossimString(draw_axes).toBool());
237  }
238
239  return status;
240 }
virtual void setDrawAxesFlag(bool flag)
virtual void setThickness(ossim_uint8 thickness)
ossimUnitType
virtual void setAzimuth(ossim_float64 azimuth)
Sets the azimuth.
double y
virtual ossim_int32 getEntryNumber(const char *entry_string, bool case_insensitive=true) const
double toDouble() const
virtual void setColor(ossim_uint8 r, ossim_uint8 g, ossim_uint8 b)
return status
double x
std::basic_istringstream< char > istringstream
Class for char input memory streams.
Definition: ossimIosFwd.h:32
virtual void setFillFlag(bool flag)
Sets the fill flag.
static ossimUnitTypeLut * instance()
Returns the static instance of an ossimUnitTypeLut object.
◆ print()
std::ostream & ossimGeoAnnotationEllipseObject::print ( std::ostream &  out) const
virtual
Derived classes should re-implement as they see fit.
Returns
std::ostream&
Reimplemented from ossimAnnotationObject.
Definition at line 79 of file ossimGeoAnnotationEllipseObject.cpp.
References theCenter, theEllipseWidthHeightUnitType, and theProjectedEllipse.
80 {
81  out << "center ground: " << theCenter << endl
82  << "width height image space flag = " << theEllipseWidthHeightUnitType
83  << endl
85  return out;
86 }
◆ saveState()
bool ossimGeoAnnotationEllipseObject::saveState ( ossimKeywordlist kwl,
) const
virtual
Keywords:
center: ( 42.403388263727003, -90.708557648541046, 0.0, WGE )
ellipse_width: 500
ellipse_height: 500
units: meters
Definition at line 159 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), getAzimuth(), getDrawAxesFlag(), getFillFlag(), ossimUnitTypeLut::instance(), ossimGeoAnnotationObject::saveState(), theCenter, theEllipseWidthHeightUnitType, theWidthHeight, ossimGpt::toString(), ossimString::toString(), ossimDpt::x, and ossimDpt::y.
161 {
162  kwl.add(prefix, "center", theCenter.toString().c_str());
163  kwl.add(prefix, "ellipse_width", theWidthHeight.x);
164  kwl.add(prefix, "ellipse_height", theWidthHeight.y);
165  kwl.add(prefix, "azimuth", getAzimuth());
166  kwl.add(prefix, "fill", ossimString::toString(getFillFlag()));
167  kwl.add(prefix, "draw_axes", ossimString::toString(getDrawAxesFlag()));
168  kwl.add(prefix, "units",
169  ossimUnitTypeLut::instance()->getEntryString(theEllipseWidthHeightUnitType).c_str());
170
171  return ossimGeoAnnotationObject::saveState(kwl, prefix);
172 }
Gets the azimuth.
double y
Numeric to string methods.
double x
const char * c_str() const
Definition: ossimString.h:396
ossimString toString(ossim_uint32 precision=15) const
Definition: ossimGpt.cpp:78
◆ setAzimuth()
void ossimGeoAnnotationEllipseObject::setAzimuth ( ossim_float64  azimuth)
virtual
Sets the azimuth.
Parameters
azimuthin degrees.
Definition at line 253 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::setAzimuth(), theProjectedEllipse, and ossimRefPtr< T >::valid().
Referenced by loadState().
254 {
256  {
258  }
259 }
bool valid() const
Sets the azimuth.
◆ setCenter()
void ossimGeoAnnotationEllipseObject::setCenter ( const ossimGpt gpt)
virtual
Parameters
gptThe center ground point.
Definition at line 387 of file ossimGeoAnnotationEllipseObject.cpp.
388 {
389  theCenter = gpt;
390 }
◆ setColor()
void ossimGeoAnnotationEllipseObject::setColor ( ossim_uint8  r,
ossim_uint8  g,
ossim_uint8  b
virtual
RGB range 0 to 255
Parameters
rDN value for red.
gDN value for green.
bDN value for blue.
Definition at line 334 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationObject::setColor(), theProjectedEllipse, and ossimRefPtr< T >::valid().
337 {
339  {
340  theProjectedEllipse->setColor(r, g, b);
341  }
343 }
bool valid() const
◆ setDrawAxesFlag()
void ossimGeoAnnotationEllipseObject::setDrawAxesFlag ( bool  flag)
virtual
This flag is only used if fill is turned off.
Parameters
flagtrue to enable, false to disable.
Definition at line 370 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::setDrawAxesFlag(), theProjectedEllipse, and ossimRefPtr< T >::valid().
371 {
373  {
375  }
376 }
bool valid() const
◆ setEllipseWidthHeightUnitType()
void ossimGeoAnnotationEllipseObject::setEllipseWidthHeightUnitType ( ossimUnitType  type)
virtual
◆ setFillFlag()
void ossimGeoAnnotationEllipseObject::setFillFlag ( bool  flag)
virtual
Sets the fill flag.
flag True to fill, false to not fill.
Definition at line 353 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationEllipseObject::setFillFlag(), theProjectedEllipse, and ossimRefPtr< T >::valid().
Referenced by loadState(), and ossimGdalOgrVectorAnnotation::updateAnnotationSettings().
354 {
356  {
358  }
359 }
bool valid() const
◆ setThickness()
void ossimGeoAnnotationEllipseObject::setThickness ( ossim_uint8  thickness)
virtual
range 0 to 255
Parameters
thicknessPen thickness.
Definition at line 345 of file ossimGeoAnnotationEllipseObject.cpp.
References ossimAnnotationObject::setThickness(), theProjectedEllipse, and ossimRefPtr< T >::valid().
346 {
348  {
349  theProjectedEllipse->setThickness(thickness);
350  }
351 }
bool valid() const
◆ setWidthHeight()
void ossimGeoAnnotationEllipseObject::setWidthHeight ( const ossimDpt pt)
virtual
Parameters
ptPoint with pt.x being width and pt.y being height.
Definition at line 248 of file ossimGeoAnnotationEllipseObject.cpp.
References theWidthHeight.
Referenced by ossimGdalOgrVectorAnnotation::updateAnnotationSettings().
◆ transform()
void ossimGeoAnnotationEllipseObject::transform ( ossimImageGeometry projection)
virtual
Add the projection interface to all geographically defined objects.
Implements ossimGeoAnnotationObject.
Definition at line 139 of file ossimGeoAnnotationEllipseObject.cpp.
References getWidthHeightInPixels(), ossimAnnotationEllipseObject::setCenterWidthHeight(), theCenter, theProjectedEllipse, and ossimImageGeometry::worldToLocal().
Referenced by ossimGdalOgrVectorAnnotation::loadPoint(), and ossimGdalOgrVectorAnnotation::updateAnnotationSettings().
140 {
141  if(!projection)
142  {
143  return;
144  }
145
146  // Ellipse center, height and width in image space.
147  ossimDpt projectedCenter;
148  ossimDpt projectedWidthHeight;
149
150  // first get the center projected
151  projection->worldToLocal(theCenter, projectedCenter);
152
153  getWidthHeightInPixels(projectedWidthHeight, projection);
154
155  theProjectedEllipse->setCenterWidthHeight(projectedCenter,
156  projectedWidthHeight);
157 }
void getWidthHeightInPixels(ossimDpt &widthHeight, const ossimImageGeometry *projection) const
virtual void setCenterWidthHeight(const ossimDpt &center, const ossimDpt &widthHeight)
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
Member Data Documentation
◆ theCenter
ossimGpt ossimGeoAnnotationEllipseObject::theCenter
protected
◆ theEllipseWidthHeightUnitType
ossimUnitType ossimGeoAnnotationEllipseObject::theEllipseWidthHeightUnitType
protected
◆ theProjectedEllipse
ossimRefPtr<ossimAnnotationEllipseObject> ossimGeoAnnotationEllipseObject::theProjectedEllipse
protected
◆ theWidthHeight
ossimDpt ossimGeoAnnotationEllipseObject::theWidthHeight
protected
