ossimGeoAnnotationEllipseObject.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: See top level LICENSE.txt file.
4 //
5 // Author: Garrett Potts
6 //
7 //*************************************************************************
8 // $Id: ossimGeoAnnotationEllipseObject.cpp 15766 2009-10-20 12:37:09Z gpotts $
9
10 #include <sstream>
11
18
20  "ossimGeoAnnotationEllipseObject",
22
24  const ossimGpt& center,
25  const ossimDpt& widthHeight,
26  bool enableFill,
27  ossim_uint8 r,
28  ossim_uint8 g,
29  ossim_uint8 b,
30  ossim_uint8 thickness)
31  :ossimGeoAnnotationObject(r, g, b, thickness),
32  theProjectedEllipse(0),
33  theCenter(center),
34  theWidthHeight(widthHeight),
35  theEllipseWidthHeightUnitType(OSSIM_PIXEL) // default to image space
36 {
38  ossimDpt(0,0),
39  enableFill,
40  r,
41  g,
42  b,
43  thickness);
44 }
45
49  theProjectedEllipse(rhs.theProjectedEllipse.valid()?(ossimAnnotationEllipseObject*)rhs.theProjectedEllipse->dup():(ossimAnnotationEllipseObject*)0),
50  theCenter(rhs.theCenter),
51  theWidthHeight(rhs.theWidthHeight),
52  theEllipseWidthHeightUnitType(rhs.theEllipseWidthHeightUnitType)
53 {
54 }
55
57 {
59  {
61  }
62 }
63
65 {
66  return new ossimGeoAnnotationEllipseObject(*this);
67 }
68
70  double y)
71 {
75  theWidthHeight .x *= x;
76  theWidthHeight .y *= y;
77 }
78
80 {
81  out << "center ground: " << theCenter << endl
82  << "width height image space flag = " << theEllipseWidthHeightUnitType
83  << endl
85  return out;
86 }
87
89 {
91  {
92  theProjectedEllipse->draw(anImage);
93  }
94 }
95
97 {
99  {
101  }
102
103  return false;
104 }
105
107 {
108  if(intersects(rect))
109  {
111  {
113  }
114  }
115
116  return (ossimAnnotationObject*)0;
117 }
118
120 {
122  {
124  }
125  else
126  {
127  rect.makeNan();
128  }
129 }
130
132 {
134  {
136  }
137 }
138
140 {
141  if(!projection)
142  {
143  return;
144  }
145
146  // Ellipse center, height and width in image space.
147  ossimDpt projectedCenter;
148  ossimDpt projectedWidthHeight;
149
150  // first get the center projected
151  projection->worldToLocal(theCenter, projectedCenter);
152
153  getWidthHeightInPixels(projectedWidthHeight, projection);
154
155  theProjectedEllipse->setCenterWidthHeight(projectedCenter,
156  projectedWidthHeight);
157 }
158
160  const char* prefix) const
161 {
162  kwl.add(prefix, "center", theCenter.toString().c_str());
163  kwl.add(prefix, "ellipse_width", theWidthHeight.x);
164  kwl.add(prefix, "ellipse_height", theWidthHeight.y);
165  kwl.add(prefix, "azimuth", getAzimuth());
166  kwl.add(prefix, "fill", ossimString::toString(getFillFlag()));
167  kwl.add(prefix, "draw_axes", ossimString::toString(getDrawAxesFlag()));
168  kwl.add(prefix, "units",
169  ossimUnitTypeLut::instance()->getEntryString(theEllipseWidthHeightUnitType).c_str());
170
171  return ossimGeoAnnotationObject::saveState(kwl, prefix);
172 }
173
175  const char* prefix)
176 {
177  if (!theProjectedEllipse)
178  {
179  return false;
180  }
181
182  //---
183  // Base class state must be called first to pick up colors...
184  //---
185  bool status = ossimGeoAnnotationObject::loadState(kwl, prefix);
186  if (status == true)
187  {
190  }
191
192  const char* center = kwl.find(prefix, "center");
193  const char* ellipse_width = kwl.find(prefix, "ellipse_width");
194  const char* ellipse_height = kwl.find(prefix, "ellipse_height");
195  const char* azimuth = kwl.find(prefix, "azimuth");
196  const char* fill = kwl.find(prefix, "fill");
197  const char* draw_axes = kwl.find(prefix, "draw_axes");
198  const char* units = kwl.find(prefix, "units");
199
200  if(units)
201  {
205  {
207  }
208  }
209
210  if (center)
211  {
212  std::istringstream is(center);
213  is >> theCenter;
214  }
215  if(ellipse_width)
216  {
217  theWidthHeight.x = ossimString(ellipse_width).toDouble();
218  }
219  if(ellipse_height)
220  {
221  theWidthHeight.y = ossimString(ellipse_height).toDouble();
222  }
223
224  if (azimuth)
225  {
226  setAzimuth(ossimString(azimuth).toFloat64());
227  }
228
229  if (fill)
230  {
231  setFillFlag(ossimString(fill).toBool());
232  }
233
234  if (draw_axes)
235  {
236  setDrawAxesFlag(ossimString(draw_axes).toBool());
237  }
238
239  return status;
240 }
241
243  ossimUnitType type)
244 {
246 }
247
249 {
250  theWidthHeight = pt;
251 }
252
254 {
256  {
258  }
259 }
260
262 {
264  {
266  }
267  return 0.0;
268 }
269
271  ossimDpt& widthHeight, const ossimImageGeometry* projection) const
272 {
274  {
275  case OSSIM_PIXEL:
276  {
277  widthHeight = theWidthHeight;
278
279  break;
280  }
281
282  case OSSIM_DEGREES:
283  case OSSIM_MINUTES:
284  case OSSIM_SECONDS:
285  {
286  ossimGpt origin = projection->hasProjection()?projection->getProjection()->origin():ossimGpt();
287  ossimDpt gsd = projection->getMetersPerPixel();
288
289  ossimUnitConversionTool uct(origin,
292
293  double x = uct.getValue(OSSIM_METERS);
294
296
297  double y = uct.getValue(OSSIM_METERS);
298
299  widthHeight.x = ceil(x/gsd.x);
300  widthHeight.y = ceil(y/gsd.y);
301
302  break;
303  }
304
305  case OSSIM_METERS:
306  {
307  ossimDpt gsd = projection->getMetersPerPixel();
308  widthHeight.x = static_cast<ossim_int32>(theWidthHeight.x/gsd.x+0.5);
309  widthHeight.y = static_cast<ossim_int32>(theWidthHeight.y/gsd.y+0.5);
310
311  break;
312  }
313
314  default:
315  {
316  ossimDpt gsd = projection->getMetersPerPixel();
317
320
321  double x = uct.getValue(OSSIM_METERS);
322
324
325  double y = uct.getValue(OSSIM_METERS);
326
327  widthHeight.x = ceil(x/gsd.x);
328  widthHeight.y = ceil(y/gsd.y);
329
330  break;
331  }
332  }
333 }
335  ossim_uint8 g,
336  ossim_uint8 b)
337 {
339  {
340  theProjectedEllipse->setColor(r, g, b);
341  }
343 }
344
346 {
348  {
349  theProjectedEllipse->setThickness(thickness);
350  }
351 }
352
354 {
356  {
358  }
359 }
360
362 {
364  {
366  }
367  return false;
368 }
369
371 {
373  {
375  }
376 }
377
379 {
381  {
383  }
384  return false;
385 }
386
388 {
389  theCenter = gpt;
390 }
391
393 {
394  gpt = theCenter;
395 }
396
virtual void setDrawAxesFlag(bool flag)
Turns on and off drawing of axes on the ellipse.
void makeNan()
Definition: ossimDrect.h:388
ossim_uint32 x
virtual ossim_float64 getAzimuth() const
Gets the azimuth.
virtual void setThickness(ossim_uint8 thickness)
Sets the pen thickness of theProjectedEllipse.
double getValue(ossimUnitType unitType=OSSIM_METERS) const
virtual void getBoundingRect(ossimDrect &rect) const
virtual void setWidthHeight(const ossimDpt &pt)
Sets the width and height of point.
double lond() const
Will convert the radian measure to degrees.
Definition: ossimGpt.h:97
virtual void setEllipseWidthHeightUnitType(ossimUnitType type)
ossimUnitType
ossim_uint32 y
virtual void transform(ossimImageGeometry *projection)
bool valid() const
Definition: ossimRefPtr.h:75
virtual void setAzimuth(ossim_float64 azimuth)
Sets the azimuth.
void setValue(double value, ossimUnitType unitType=OSSIM_METERS)
double y
Definition: ossimDpt.h:165
virtual ossimAnnotationObject * getNewClippedObject(const ossimDrect &rect) const
Numeric to string methods.
Saves the current state of this object.
virtual ossim_int32 getEntryNumber(const char *entry_string, bool case_insensitive=true) const
Generic print method.
double latd() const
Definition: ossimGpt.h:87
virtual void applyScale(double x, double y)
virtual bool intersects(const ossimDrect &rect) const
virtual void getCenter(ossimGpt &gpt) const
double ossim_float64
virtual void setColor(ossim_uint8 r, ossim_uint8 g, ossim_uint8 b)
Sets the color of theProjectedEllipse.
void getWidthHeightInPixels(ossimDpt &widthHeight, const ossimImageGeometry *projection) const
virtual ossimDrect getBoundingRect() const
virtual void setCenter(const ossimGpt &gpt)
Sets the center ground point.
ossimDpt getMetersPerPixel() const
Returns the GSD associated with this image in the active projection.
double toDouble() const
virtual void draw(ossimRgbImage &anImage) const
virtual void setCenterWidthHeight(const ossimDpt &center, const ossimDpt &widthHeight)
return status
virtual ossimGpt origin() const =0
Sets the azimuth.
double x
Definition: ossimDpt.h:164
const char * c_str() const
Definition: ossimString.h:396
bool hasProjection() const
Returns TRUE if valid projection defined.
bool worldToLocal(const ossimGpt &world_pt, ossimDpt &local_pt) const
Exposes the 3D world-to-local image coordinate reverse projection.
ossimString toString(ossim_uint32 precision=15) const
Definition: ossimGpt.cpp:78
ossimRefPtr< ossimAnnotationEllipseObject > theProjectedEllipse
std::basic_istringstream< char > istringstream
Class for char input memory streams.
Definition: ossimIosFwd.h:32
ossimGeoAnnotationEllipseObject(const ossimGpt &center=ossimGpt(0, 0), const ossimDpt &widthHeight=ossimDpt(0, 0), bool enableFill=false, ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1)
virtual void setFillFlag(bool flag)
Sets the fill flag.
static ossimUnitTypeLut * instance()
Returns the static instance of an ossimUnitTypeLut object.
RTTI_DEF1(ossimGeoAnnotationEllipseObject, "ossimGeoAnnotationEllipseObject", ossimGeoAnnotationObject)
unsigned char ossim_uint8
std::basic_ostream< char > ostream
Base class for char output streams.
Definition: ossimIosFwd.h:23
int ossim_int32
Gets the azimuth.
