Public Member Functions | Private Member Functions | Private Attributes | List of all members
ossimGmlSupportData Class Reference
GML support data class. More...
#include <ossimGmlSupportData.h>
 ossimGmlSupportData ()
 default constructor More...
 ~ossimGmlSupportData ()
 destructor More...
bool initialize (const ossimImageGeometry *geom, const ossimIrect &rect)
 Initializes gml block from geometry file. More...
bool initialize (std::istream &in)
 Initializes from stream assumed to be a gml block. More...
bool write (std::ostream &os)
 Write xml doc to stream. More...
ossimRefPtr< ossimXmlDocumentgetXmlDoc () const
bool getImageGeometry (ossimKeywordlist &geomKwl) const
 Extracts geometry info to keyword list. More...
ossimRefPtr< ossimXmlNodegetGmljp2V1RootNode () const
ossimRefPtr< ossimXmlNodegetGmljp2V2RootNode () const
void getGeoOrigin (const ossimImageGeometry *geom, const ossimIpt &ul, ossimString &originString, ossimString &offsetVector1String, ossimString &offsetVector2String) const
void getMapOrigin (const ossimImageGeometry *geom, const ossimIpt &ul, ossimString &originString, ossimString &offsetVector1String, ossimString &offsetVector2String) const
void getLimits (const ossimIrect &rect, ossimString &gridHighString, ossimString &gridLowString) const
void getGeoBounds (const ossimImageGeometry *geom, const ossimIrect &rect, ossimString &upperCornerString, ossimString &lowerCornerString) const
bool configureGmljp2V2 (ossimRefPtr< ossimXmlNode > node, const ossimImageGeometry *geom, const ossimIrect &rect)
bool configureBounds (ossimRefPtr< ossimXmlNode > node, const ossimImageGeometry *geom, const ossimIrect &rect)
bool getImageGeometryFromSeonsorModel (ossimKeywordlist &geomKwl) const
 For sensor model data: More...
bool getImageGeometryFromRectifiedGrid (ossimKeywordlist &geomKwl) const
 For map projected data: More...
bool addLineSamps (const ossimString &xpath0, bool useGmlPrefix, ossimKeywordlist &geomKwl) const
 Adds line and sample to keyword list. More...
bool addTie (const ossimString &xpath0, bool useGmlPrefix, ossim_uint32 pcsCode, ossimKeywordlist &geomKwl) const
 Adds tie point to keyword list. More...
bool addScale (const ossimString &xpath0, bool useGmlPrefix, ossim_uint32 pcsCode, ossimKeywordlist &geomKwl) const
 Adds tie and scale to keyword list. More...
Private Attributes
ossimRefPtr< ossimXmlDocumentm_xmlDocument
ossim_uint32 m_pcsCodeMap
ossim_uint32 m_pcsCodeGeo
ossimString m_srsNameStringMap
ossimString m_srsNameStringGeo
ossimString m_srsDimensionString
ossimString m_axisLabelsStringMap
ossimString m_axisLabelsStringGeo
ossimString m_uomLabelsStringMap
ossimString m_uomLabelsStringGeo
Detailed Description
Definition at line 29 of file ossimGmlSupportData.h.
◆ ossimGmlSupportData()
ossimGmlSupportData::ossimGmlSupportData ( )
default constructor
Definition at line 40 of file ossimGmlSupportData.cpp.
41  :
42  m_xmlDocument(0),
43  // m_use_gmljp2_version2(true),
46  m_srsNameStringMap("http://www.opengis.net/def/crs/EPSG/0/32767"),
47  m_srsNameStringGeo("http://www.opengis.net/def/crs/EPSG/0/32767"),
49  m_axisLabelsStringMap("X Y"),
50  m_axisLabelsStringGeo("Lat Long"),
51  m_uomLabelsStringMap("m m"),
52  m_uomLabelsStringGeo("deg deg")
53 {
54 }
#define UNKNOWN_PCSCODE
ossimRefPtr< ossimXmlDocument > m_xmlDocument
◆ ~ossimGmlSupportData()
ossimGmlSupportData::~ossimGmlSupportData ( )
destructor
Definition at line 56 of file ossimGmlSupportData.cpp.
57 {
58 }
Member Function Documentation
◆ addLineSamps()
bool ossimGmlSupportData::addLineSamps ( const ossimString xpath0,
bool  useGmlPrefix,
ossimKeywordlist geomKwl
) const
private
Parameters
xpath0
useGmlPrefixIf true tack on "gml:" to paths.
geomKwlInitialized by this.
Definition at line 1177 of file ossimGmlSupportData.cpp.
References ossimKeywordlist::add(), ossimString::afterPos(), ossimString::beforePos(), ossimString::clear(), ossimString::find(), ossimXmlDocument::findNodes(), m_xmlDocument, ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, status, ossimString::toInt32(), and ossimRefPtr< T >::valid().
Referenced by getImageGeometryFromRectifiedGrid().
1180 {
1181  bool status = false;
1182
1183  if ( m_xmlDocument.valid() )
1184  {
1185  vector< ossimRefPtr<ossimXmlNode> > xml_nodes;
1186
1187  // Number of lines & samples, for either sensor or rectified imagery:
1188  ossimString xpath_limits_low;
1189  if (useGmlPrefix)
1190  {
1191  xpath_limits_low = "/gml:limits/gml:GridEnvelope/gml:low";
1192  }
1193  else
1194  {
1195  xpath_limits_low = "/limits/GridEnvelope/low";
1196  }
1197  ossimString xpath = xpath0 + xpath_limits_low;
1198  m_xmlDocument->findNodes( xpath, xml_nodes );
1199  if ( xml_nodes.size() == 1 )
1200  {
1201  const ossimString& lowerCorner = xml_nodes[0]->getText();
1202  size_t spacePos = lowerCorner.find( ' ' );
1203  ossimString lowerXString = lowerCorner.beforePos( spacePos );
1204  ossimString lowerYString = lowerCorner.afterPos ( spacePos );
1205  ossim_uint32 lowX = lowerXString.toInt32();
1206  ossim_uint32 lowY = lowerYString.toInt32();
1207
1208  ossimString xpath_limits_high;
1209  if ( useGmlPrefix )
1210  {
1211  xpath_limits_high = "/gml:limits/gml:GridEnvelope/gml:high";
1212  }
1213  else
1214  {
1215  xpath_limits_high = "/limits/GridEnvelope/high";
1216  }
1217
1218  xpath = xpath0 + xpath_limits_high;
1219  xml_nodes.clear();
1220  m_xmlDocument->findNodes( xpath, xml_nodes );
1221  if ( xml_nodes.size() == 1 )
1222  {
1223  const ossimString& higherCorner = xml_nodes[0]->getText();
1224  size_t spacePos = higherCorner.find( ' ' );
1225  ossimString higherXString = higherCorner.beforePos( spacePos );
1226  ossimString higherYString = higherCorner.afterPos ( spacePos );
1227  ossim_uint32 highX = higherXString.toInt32();
1228  ossim_uint32 highY = higherYString.toInt32();
1229
1230  geomKwl.add( ossimKeywordNames::NUMBER_LINES_KW, highY - lowY + 1 );
1231  geomKwl.add( ossimKeywordNames::NUMBER_SAMPLES_KW, highX - lowX + 1 );
1232
1233  status = true;
1234  }
1235  }
1236  }
1237
1238  return status;
1239
1240 } // ossimGmlSupportData::addLineSamps
void clear()
Erases the entire container.
Definition: ossimString.h:432
bool valid() const
Definition: ossimRefPtr.h:75
ossimString afterPos(std::string::size_type pos) const
static const char * NUMBER_LINES_KW
ossim_int32 toInt32() const
unsigned int ossim_uint32
return status
ossimString beforePos(std::string::size_type pos) const
void findNodes(const ossimString &xpath, std::vector< ossimRefPtr< ossimXmlNode > > &nodelist) const
Appends any matching nodes to the list supplied (should be empty):
static const char * NUMBER_SAMPLES_KW
std::string::size_type find(const std::string &s, std::string::size_type pos=0) const
Searches for s as a substring of *this, beginning at character pos of *this.
Definition: ossimString.h:753
◆ addScale()
bool ossimGmlSupportData::addScale ( const ossimString xpath0,
bool  useGmlPrefix,
) const
private
Parameters
xpath0
Definition at line 1338 of file ossimGmlSupportData.cpp.
References ossim::acosd(), ossimKeywordlist::add(), ossimString::afterPos(), ossimString::beforePos(), ossimString::c_str(), ossimString::clear(), ossimString::find(), ossimXmlDocument::findNodes(), m_xmlDocument, ossimKeywordNames::ORIGIN_LATITUDE_KW, ossimKeywordNames::PIXEL_SCALE_UNITS_KW, ossimKeywordNames::PIXEL_SCALE_XY_KW, status, ossimString::toFloat64(), ossimDpt::toString(), ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
1342 {
1343  bool status = false;
1344
1345  if ( m_xmlDocument.valid() && (pcsCode != 32767 ) )
1346  {
1347  vector< ossimRefPtr<ossimXmlNode> > xml_nodes;
1348
1349  //---
1350  // origin:
1351  // Note: In GML the origin is the tie point, NOT the projection origin.
1352  //---
1353
1354  // axis labels for rectified imagery:
1355  ossimString xpath_axisLabels;
1356  if ( useGmlPrefix )
1357  {
1358  xpath_axisLabels = "/gml:axisLabels";
1359  }
1360  else
1361  {
1362  xpath_axisLabels = "/axisLabels";
1363  }
1364
1365  ossimString xpath = xpath0 + xpath_axisLabels;
1366  m_xmlDocument->findNodes( xpath, xml_nodes );
1367  if ( xml_nodes.size() == 1 )
1368  {
1369  ossimString axisLabelsString = xml_nodes[0]->getText();
1370
1371  ossimString xpath_offsetVector;
1372  if ( useGmlPrefix )
1373  {
1374  xpath_offsetVector = "/gml:offsetVector";
1375  }
1376  else
1377  {
1378  xpath_offsetVector = "/offsetVector";
1379  }
1380
1381  xpath = xpath0 + xpath_offsetVector;
1382  xml_nodes.clear();
1383  m_xmlDocument->findNodes( xpath, xml_nodes );
1384  if ( xml_nodes.size() == 2 )
1385  {
1386  const ossimString& offsetVectorString0 = xml_nodes[0]->getText();
1387  const ossimString& offsetVectorString1 = xml_nodes[1]->getText();
1388
1389  size_t spacePos0 = offsetVectorString0.find( ' ' );
1390  size_t spacePos1 = offsetVectorString1.find( ' ' );
1391
1392  ossimString firstOffsetVectorString0 = offsetVectorString0.beforePos( spacePos0 );
1393  ossimString secondOffsetVectorString0 = offsetVectorString0.afterPos ( spacePos0 );
1394  ossimString firstOffsetVectorString1 = offsetVectorString1.beforePos( spacePos1 );
1395  ossimString secondOffsetVectorString1 = offsetVectorString1.afterPos ( spacePos1 );
1396
1397  // TODO: Add for rotational matrix:
1398
1399  std::string scale_xy;
1400  std::string scale_units;
1401  if ( pcsCode == 4326 )
1402  {
1403  scale_units = "degrees";
1404  }
1405  else
1406  {
1407  scale_units = "meters";
1408  }
1409
1410  ossimDpt scale;
1411  if ( ( scale_units == "degrees" ) &&
1412  ( axisLabelsString == "Lat Long" ) )
1413  {
1414  scale.x = secondOffsetVectorString1.toFloat64();
1415  scale.y = firstOffsetVectorString0.toFloat64();
1416  }
1417  else
1418  {
1419  scale.x = firstOffsetVectorString0.toFloat64();
1420  scale.y = secondOffsetVectorString1.toFloat64();
1421  }
1422  if ( scale.y < 0.0 )
1423  {
1424  scale.y *= -1.0; // make positive
1425  }
1426
1427  if ( ( scale_units == "degrees" ) && ( scale.x != scale.y ) )
1428  {
1429  // Compute/add the origin latitude of true scale.
1430  ossim_float64 origin_lat = ossim::acosd(scale.y/scale.x);
1431
1432  geomKwl.add( ossimKeywordNames::ORIGIN_LATITUDE_KW, origin_lat );
1433  }
1434
1436  geomKwl.add( ossimKeywordNames::PIXEL_SCALE_UNITS_KW, scale_units.c_str() );
1437  status = true;
1438  }
1439  }
1440
1441  } // Matches: if ( m_xmlDocument.valid() && (pscCode != 32767 ) )
1442
1443  return status;
1444
1445 } // End: ossimGmlSupportData::addScale( ... )
void clear()
bool valid() const
double y
Definition: ossimDpt.h:165
double acosd(double x)
Definition: ossimCommon.h:264
static const char * PIXEL_SCALE_XY_KW
double ossim_float64
ossim_float64 toFloat64() const
static const char * ORIGIN_LATITUDE_KW
return status
ossimString toString(ossim_uint32 precision=15) const
Definition: ossimDpt.cpp:160
double x
Definition: ossimDpt.h:164
const char * c_str() const
Definition: ossimString.h:396
static const char * PIXEL_SCALE_UNITS_KW
◆ addTie()
bool ossimGmlSupportData::addTie ( const ossimString xpath0,
bool  useGmlPrefix,
) const
private
Parameters
xpath0
Definition at line 1242 of file ossimGmlSupportData.cpp.
References ossimKeywordlist::add(), ossimString::afterPos(), ossimString::beforePos(), ossimString::clear(), ossimString::find(), ossimXmlDocument::findNodes(), m_xmlDocument, status, ossimString::string(), ossimKeywordNames::TIE_POINT_UNITS_KW, ossimKeywordNames::TIE_POINT_XY_KW, and ossimRefPtr< T >::valid().
1246 {
1247  bool status = false;
1248
1249  if ( m_xmlDocument.valid() && (pcsCode != 32767 ) )
1250  {
1251  vector< ossimRefPtr<ossimXmlNode> > xml_nodes;
1252
1253  //---
1254  // origin:
1255  // Note: In GML the origin is the tie point, NOT the projection origin.
1256  //---
1257
1258  // axis labels for rectified imagery:
1259  ossimString xpath_axisLabels;
1260  if ( useGmlPrefix )
1261  {
1262  xpath_axisLabels = "/gml:axisLabels";
1263  }
1264  else
1265  {
1266  xpath_axisLabels = "/axisLabels";
1267  }
1268
1269  ossimString xpath = xpath0 + xpath_axisLabels;
1270  m_xmlDocument->findNodes( xpath, xml_nodes );
1271  if ( xml_nodes.size() == 1 )
1272  {
1273  ossimString axisLabelsString = xml_nodes[0]->getText();
1274
1275  ossimString xpath_originPoint;
1276
1277  if ( useGmlPrefix )
1278  {
1279  xpath_originPoint = "/gml:origin/gml:Point";
1280  }
1281  else
1282  {
1283  xpath_originPoint = "/origin/Point";
1284  }
1285
1286  xpath = xpath0 + xpath_originPoint;
1287  xml_nodes.clear();
1288  m_xmlDocument->findNodes( xpath, xml_nodes );
1289  if ( xml_nodes.size() == 1 )
1290  {
1291  const ossimString& originString = xml_nodes[0]->getChildTextValue( ossimString( "pos" ) );
1292  size_t spacePos = originString.find( ' ' );
1293  ossimString firstOriginString = originString.beforePos( spacePos );
1294  ossimString secondOriginString = originString.afterPos ( spacePos );
1295
1296  std::string tie_point_xy;
1297  std::string tie_point_units;
1298
1299  if ( pcsCode == 4326 ) // map projection
1300  {
1301  // Longitude first, e.g. (lon,lat)
1302  tie_point_units = "degrees";
1303  }
1304  else
1305  {
1306  tie_point_units = "meters";
1307  }
1308
1309  if ( ( tie_point_units == "degrees" ) &&
1310  ( axisLabelsString == "Lat Long" ) )
1311  {
1312  tie_point_xy = "(";
1313  tie_point_xy += secondOriginString.string();
1314  tie_point_xy += ",";
1315  tie_point_xy += firstOriginString.string();
1316  tie_point_xy += ")";
1317  }
1318  else
1319  {
1320  tie_point_xy = "(";
1321  tie_point_xy += firstOriginString.string();
1322  tie_point_xy += ",";
1323  tie_point_xy += secondOriginString.string();
1324  tie_point_xy += ")";
1325  }
1326  geomKwl.add( ossimKeywordNames::TIE_POINT_XY_KW, tie_point_xy.c_str() );
1327  geomKwl.add( ossimKeywordNames::TIE_POINT_UNITS_KW, tie_point_units.c_str() );
1328  status = true;
1329  }
1330  }
1331
1332  } // Matches: if ( m_xmlDocument.valid() && (pscCode != 32767 ) )
1333
1334  return status;
1335
1336 } // End: ossimGmlSupportData::addTie( ... )
void clear()
bool valid() const
static const char * TIE_POINT_XY_KW
return status
static const char * TIE_POINT_UNITS_KW
const std::string & string() const
Definition: ossimString.h:414
◆ configureBounds()
bool ossimGmlSupportData::configureBounds ( ossimRefPtr< ossimXmlNode node,
const ossimImageGeometry geom,
const ossimIrect rect
private
Definition at line 377 of file ossimGmlSupportData.cpp.
References ossimXmlNode::addAttribute(), ossimXmlNode::addChildNode(), getGeoBounds(), m_axisLabelsStringGeo, m_srsDimensionString, m_srsNameStringGeo, m_uomLabelsStringGeo, and ossimXmlAttribute::setNameValue().
Referenced by configureGmljp2V2().
381 {
382  bool success = true;
383  const ossimString BLANK = "";
384
385  ossimString upperCornerString;
386  ossimString lowerCornerString;
387  getGeoBounds( geom, rect, upperCornerString, lowerCornerString );
388
389  ossimString path = "boundedBy";
390  ossimRefPtr<ossimXmlNode> node1 = node0->addChildNode( path, BLANK );
391
392  path = "Envelope";
393  ossimRefPtr<ossimXmlNode> node1a = node1->addChildNode( path, BLANK );
394
396  ossimString name;
397
398  attr = new ossimXmlAttribute();
399  name = "srsName";
400  attr->setNameValue( name, m_srsNameStringGeo );
401  node1a->addAttribute( attr );
402
403  attr = new ossimXmlAttribute();
404  name = "axisLabels";
405  attr->setNameValue( name, m_axisLabelsStringGeo );
406  node1a->addAttribute( attr );
407
408  attr = new ossimXmlAttribute();
409  name = "uomLabels";
410  attr->setNameValue( name, m_uomLabelsStringGeo );
411  node1a->addAttribute( attr );
412
413  attr = new ossimXmlAttribute();
414  name = "srsDimension";
415  attr->setNameValue( name, m_srsDimensionString );
416  node1a->addAttribute( attr );
417
418  path = "lowerCorner";
419  ossimRefPtr<ossimXmlNode> node1a1 =
420  node1a->addChildNode( path, lowerCornerString );
421
422  path = "upperCorner";
423  ossimRefPtr<ossimXmlNode> node1a2 =
424  node1a->addChildNode( path, upperCornerString );
425
426  return success;
427 }
void getGeoBounds(const ossimImageGeometry *geom, const ossimIrect &rect, ossimString &upperCornerString, ossimString &lowerCornerString) const
void addAttribute(ossimRefPtr< ossimXmlAttribute > attribute)
void addChildNode(ossimRefPtr< ossimXmlNode > node)
◆ configureGmljp2V2()
bool ossimGmlSupportData::configureGmljp2V2 ( ossimRefPtr< ossimXmlNode node,
private
Definition at line 183 of file ossimGmlSupportData.cpp.
References ossimXmlNode::addAttribute(), ossimXmlNode::addChildNode(), configureBounds(), ossimImageGeometry::getAsMapProjection(), getGeoOrigin(), getLimits(), getMapOrigin(), ossimMapProjection::isGeographic(), m_axisLabelsStringGeo, m_axisLabelsStringMap, m_srsNameStringGeo, m_srsNameStringMap, ossimXmlAttribute::setNameValue(), ossimIrect::ul(), and ossimRefPtr< T >::valid().
Referenced by initialize().
186 {
187  bool success = false;
188
190  if ( mapProj.valid() )
191  {
192  bool isGeographic = mapProj->isGeographic();
193
194  const ossimString BLANK = "";
195
197  ossimString name;
198  ossimString value;
199
200  ossimString gridHighString;
201  ossimString gridLowString;
202  getLimits( rect, gridHighString, gridLowString );
203
204  configureBounds( node0, geom, rect );
205
206  ossimString path = "domainSet";
208  node0->addChildNode( path, BLANK );
209
210  path = "rangeSet";
212  node0->addChildNode( path, BLANK );
213
214  path = "File";
216  node3->addChildNode( path, BLANK );
217
218  path = "rangeParameters";
219  ossimRefPtr<ossimXmlNode> node3a1 =
220  node3a->addChildNode( path, BLANK );
221
222  path = "fileName";
223  ossimRefPtr<ossimXmlNode> node3a2 =
224  node3a->addChildNode( path, "gmljp2://codestream" );
225
226  path = "fileStructure";
227  ossimRefPtr<ossimXmlNode> node3a3 =
228  node3a->addChildNode( path, "inapplicable" );
229
230  path = "gmlcov:rangeType";
232  node0->addChildNode( path, BLANK );
233
234  path = "gmljp2:featureMember";
236  node0->addChildNode( path, BLANK );
237
238  path = "gmljp2:GMLJP2RectifiedGridCoverage";
240  node5->addChildNode( path, BLANK );
241
242  attr = new ossimXmlAttribute();
243  name = "gml:id";
244  value = "CodeStream_0";
245  attr->setNameValue( name, value );
246  node5a->addAttribute( attr );
247
248  path = "domainSet";
249  ossimRefPtr<ossimXmlNode> node5a1 =
250  node5a->addChildNode( path, BLANK );
251
252  path = "RectifiedGrid";
253  ossimRefPtr<ossimXmlNode> node5a1a =
254  node5a1->addChildNode( path, BLANK );
255
256  attr = new ossimXmlAttribute();
257  name = "gml:id";
258  value = "RG0001";
259  attr->setNameValue( name, value );
260  node5a1a->addAttribute( attr );
261
262  attr = new ossimXmlAttribute();
263  name = "dimension";
264  value = "2";
265  attr->setNameValue( name, value );
266  node5a1a->addAttribute( attr );
267
268  attr = new ossimXmlAttribute();
269  name = "srsName";
270  attr->setNameValue( name, m_srsNameStringMap );
271  node5a1a->addAttribute( attr );
272
273  path = "limits";
274  ossimRefPtr<ossimXmlNode> node5a1a1 =
275  node5a1a->addChildNode( path, BLANK );
276
277  path = "GridEnvelope";
278  ossimRefPtr<ossimXmlNode> node5a1a1a =
279  node5a1a1->addChildNode( path, BLANK );
280
281  path = "low";
282  ossimRefPtr<ossimXmlNode> node5a1a1a1 =
283  node5a1a1a->addChildNode( path, gridLowString );
284
285  path = "high";
286  ossimRefPtr<ossimXmlNode> node5a1a1a2 =
287  node5a1a1a->addChildNode( path, gridHighString );
288
289  path = "axisLabels";
290  ossimRefPtr<ossimXmlNode> node5a1a2 =
291  node5a1a->addChildNode( path,
292  mapProj->isGeographic() ?
294
295  path = "origin";
296  ossimRefPtr<ossimXmlNode> node5a1a3 =
297  node5a1a->addChildNode( path, BLANK );
298
299  path = "Point";
300  ossimRefPtr<ossimXmlNode> node5a1a3a =
301  node5a1a3->addChildNode( path, BLANK );
302
303  attr = new ossimXmlAttribute();
304  name = "gml:id";
305  value = "P0001";
306  attr->setNameValue( name, value );
307  node5a1a3a->addAttribute( attr );
308
309  attr = new ossimXmlAttribute();
310  name = "srsName";
311  attr->setNameValue( name, m_srsNameStringMap );
312  node5a1a3a->addAttribute( attr );
313
314  ossimString originString;
315  ossimString offsetVector1String;
316  ossimString offsetVector2String;
317  if ( isGeographic )
318  {
319  getGeoOrigin( geom, rect.ul(), originString,
320  offsetVector1String, offsetVector2String );
321  }
322  else
323  {
324  getMapOrigin( geom, rect.ul(), originString,
325  offsetVector1String, offsetVector2String );
326  }
327
328  path = "pos";
329  ossimRefPtr<ossimXmlNode> node5a1a3a1 =
330  node5a1a3a->addChildNode( path, originString );
331
332  path = "offsetVector";
333  ossimRefPtr<ossimXmlNode> node5a1a4 =
334  node5a1a->addChildNode( path, offsetVector1String );
335
336  attr = new ossimXmlAttribute();
337  name = "srsName";
338  attr->setNameValue( name,
339  (isGeographic ? m_srsNameStringGeo : m_srsNameStringMap ) );
340  node5a1a4->addAttribute( attr );
341
342  path = "offsetVector";
343  ossimRefPtr<ossimXmlNode> node5a1a5 =
344  node5a1a->addChildNode( path, offsetVector2String );
345
346  attr = new ossimXmlAttribute();
347  name = "srsName";
348  attr->setNameValue( name, (isGeographic ? m_srsNameStringGeo : m_srsNameStringMap) );
349  node5a1a5->addAttribute( attr );
350
351  path = "rangeSet";
352  ossimRefPtr<ossimXmlNode> node5a2 =
353  node5a->addChildNode( path, BLANK );
354
355  path = "File";
356  ossimRefPtr<ossimXmlNode> node5a2a =
357  node5a2->addChildNode( path, BLANK );
358
359  path = "rangeParameters";
360  ossimRefPtr<ossimXmlNode> node5a2a1 =
361  node5a2a->addChildNode( path, BLANK );
362
363  path = "fileName";
364  ossimRefPtr<ossimXmlNode> node5a2a2 =
365  node5a2a->addChildNode( path, "gmljp2://codestream" );
366
367  path = "fileStructure";
368  ossimRefPtr<ossimXmlNode> node5a2a3 =
369  node5a2a->addChildNode( path, "inapplicable" );
370
371  success = true;
372  }
373
374  return success;
375 }
void getLimits(const ossimIrect &rect, ossimString &gridHighString, ossimString &gridLowString) const
bool valid() const
const ossimMapProjection * getAsMapProjection() const
virtual bool isGeographic() const
const ossimIpt & ul() const
Definition: ossimIrect.h:274
void getGeoOrigin(const ossimImageGeometry *geom, const ossimIpt &ul, ossimString &originString, ossimString &offsetVector1String, ossimString &offsetVector2String) const
void getMapOrigin(const ossimImageGeometry *geom, const ossimIpt &ul, ossimString &originString, ossimString &offsetVector1String, ossimString &offsetVector2String) const
bool configureBounds(ossimRefPtr< ossimXmlNode > node, const ossimImageGeometry *geom, const ossimIrect &rect)
◆ getGeoBounds()
void ossimGmlSupportData::getGeoBounds ( const ossimImageGeometry geom,
const ossimIrect rect,
ossimString upperCornerString,
) const
private
Definition at line 1048 of file ossimGmlSupportData.cpp.
References ossimImageGeometry::getAsMapProjection(), ossimGpt::lat, ossimImageGeometry::localToWorld(), ossimGpt::lon, ossimIrect::lr(), os2, ossimIrect::ul(), and ossimRefPtr< T >::valid().
Referenced by configureBounds().
1052 {
1053  if ( geom )
1054  {
1056  if ( mapProj.valid() )
1057  {
1058  // Get the bounding rect. This assumes North up.
1059  ossimGpt ulGpt;
1060  ossimGpt lrGpt;
1061  geom->localToWorld( rect.ul(), ulGpt );
1062  geom->localToWorld( rect.lr(), lrGpt );
1063
1064  std::ostringstream os;
1065  os.precision(15);
1066  os << ulGpt.lat << " " << ulGpt.lon;
1067  upperCornerString = os.str();
1068
1070  os2.precision(15);
1071  os2 << lrGpt.lat << " " << lrGpt.lon;
1072  lowerCornerString = os2.str();
1073  }
1074  }
1075
1076 } // End: ossimGmlSupportData::getGeoBounds
std::ostringstream os2
std::basic_ostringstream< char > ostringstream
Class for char output memory streams.
Definition: ossimIosFwd.h:35
bool valid() const
ossim_float64 lon
Definition: ossimGpt.h:266
bool localToWorld(const ossimDpt &local_pt, ossimGpt &world_pt) const
Exposes the 3D projection from image to world coordinates.
const ossimIpt & lr() const
Definition: ossimIrect.h:276
ossim_float64 lat
Definition: ossimGpt.h:265
◆ getGeoOrigin()
void ossimGmlSupportData::getGeoOrigin ( const ossimImageGeometry geom,
const ossimIpt ul,
ossimString originString,
ossimString offsetVector1String,
) const
private
Definition at line 971 of file ossimGmlSupportData.cpp.
References ossimImageGeometry::getDegreesPerPixel(), ossimGpt::lat, ossimImageGeometry::localToWorld(), ossimGpt::lon, os2, ossimDpt::x, and ossimDpt::y.
977 {
978  if ( geom )
979  {
980  // Get the gsd:
981  ossimDpt gsd;
982  geom->getDegreesPerPixel( gsd );
983
984  // Get tie point:
985  ossimGpt tie;
986  geom->localToWorld( ul, tie );
987
989  os.precision(15);
990  os << tie.lat << " " << tie.lon;
991  originString = os.str();
992
994  os2.precision(15);
995  os2 << -gsd.y << " " << "0.0";
996  offsetVector1String = os2.str();
997
998  std::ostringstream os3;
999  os3.precision(15);
1000  os3 << "0.0" << " " << gsd.x;
1001  offsetVector2String = os3.str();
1002  }
1003
1004 } // End: ossimGmlSupportData::getGeoOrigin
double y
ossimDpt getDegreesPerPixel() const
Returns the resolution of this image in degrees/pixel.
ossim_float64 lon
double x
ossim_float64 lat
◆ getGmljp2V1RootNode()
ossimRefPtr< ossimXmlNode > ossimGmlSupportData::getGmljp2V1RootNode ( ) const
private
Definition at line 486 of file ossimGmlSupportData.cpp.
References ossimXmlNode::addAttribute(), ossimXmlAttribute::setNameValue(), and ossimXmlNode::setTag().
487 {
489
490  ossimString os = "gml:FeatureCollection";
491  node->setTag( os );
492
494  ossimString name;
495  ossimString value;
496
497  attr = new ossimXmlAttribute();
498  name = "xmlns";
499  value = "http://www.opengis.net/gml";
500  attr->setNameValue( name, value );
501  node->addAttribute( attr );
502
503  attr = new ossimXmlAttribute();
504  name = "xmlns:gml";
505  value = "http://www.opengis.net/gml";
506  attr->setNameValue( name, value );
507  node->addAttribute( attr );
508
509  attr = new ossimXmlAttribute();
510  name = "xmlns:xsi";
511  value = "http://www.w3.org/2001/XMLSchema-instance";
512  attr->setNameValue( name, value );
513  node->addAttribute( attr );
514
515  attr = new ossimXmlAttribute();
516  name = "xsi:schemaLocation";
517  value = "http://www.opengis.net/gml gmlJP2Profile.xsd";
518  attr->setNameValue( name, value );
519  node->addAttribute( attr );
520
521  return node;
522
523 } // ossimGmlSupportData::getGmljp2V1Node()
void setTag(const ossimString &tag)
◆ getGmljp2V2RootNode()
ossimRefPtr< ossimXmlNode > ossimGmlSupportData::getGmljp2V2RootNode ( ) const
private
Definition at line 429 of file ossimGmlSupportData.cpp.
430 {
432
433  ossimString os = "gmljp2:GMLJP2CoverageCollection";
434  node->setTag( os );
435
437  ossimString name;
438  ossimString value;
439
440  attr = new ossimXmlAttribute();
441  name = "gml:id";
442  value = "JPEG2000_0";
443  attr->setNameValue( name, value );
444  node->addAttribute( attr );
445
446  attr = new ossimXmlAttribute();
447  name = "xmlns";
448  value = "http://www.opengis.net/gml/3.2";
449  attr->setNameValue( name, value );
450  node->addAttribute( attr );
451
452  attr = new ossimXmlAttribute();
453  name = "xmlns:gml";
454  value = "http://www.opengis.net/gml/3.2";
455  attr->setNameValue( name, value );
456  node->addAttribute( attr );
457
458  attr = new ossimXmlAttribute();
459  name = "xmlns:gmlcov";
460  value = "http://www.opengis.net/gmlcov/1.0";
461  attr->setNameValue( name, value );
462  node->addAttribute( attr );
463
464  attr = new ossimXmlAttribute();
465  name = "xmlns:gmljp2";
466  value = "http://www.opengis.net/gmljp2/2.0";
467  attr->setNameValue( name, value );
468  node->addAttribute( attr );
469
470  attr = new ossimXmlAttribute();
471  name = "xmlns:xsi";
472  value = "http://www.w3.org/2001/XMLSchema-instance";
473  attr->setNameValue( name, value );
474  node->addAttribute( attr );
475
476  attr = new ossimXmlAttribute();
477  name = "xsi:schemaLocation";
478  value = "http://www.opengis.net/gmljp2/2.0 http://schemas.opengis.net/gmljp2/2.0/gmljp2.xsd";
479  attr->setNameValue( name, value );
480  node->addAttribute( attr );
481
482  return node;
483
484 } // ossimGmlSupportData::getGmljp2V2Node()
◆ getImageGeometry()
bool ossimGmlSupportData::getImageGeometry ( ossimKeywordlist geomKwl) const
Populates the keyword list with image geometry information. This method is used to relay projection/model information to users.
Parameters
geomKwlKeyword list that will be initialized with geometry info.
Returns
true if geometry info is present, false if not.
Definition at line 544 of file ossimGmlSupportData.cpp.
References getImageGeometryFromRectifiedGrid(), and getImageGeometryFromSeonsorModel().
545 {
546  // Try for map projected geometry first...
547  bool success = getImageGeometryFromRectifiedGrid( geomKwl );
548  if ( !success )
549  {
550  // Look for sensor model block.
552  }
553
554  return success;
555 }
bool getImageGeometryFromRectifiedGrid(ossimKeywordlist &geomKwl) const
bool getImageGeometryFromSeonsorModel(ossimKeywordlist &geomKwl) const
◆ getImageGeometryFromRectifiedGrid()
bool ossimGmlSupportData::getImageGeometryFromRectifiedGrid ( ossimKeywordlist geomKwl) const
private
Parameters
Definition at line 1117 of file ossimGmlSupportData.cpp.
References ossimKeywordlist::add(), addLineSamps(), addScale(), addTie(), ossimString::after(), ossimString::c_str(), ossimXmlDocument::findNodes(), ossimXmlAttribute::getValue(), m_xmlDocument, ossimKeywordNames::PCS_CODE_KW, ossimKeywordNames::SRS_NAME_KW, status, ossimString::string(), ossimString::toUInt32(), ossimKeywordNames::TYPE_KW, and ossimRefPtr< T >::valid().
Referenced by getImageGeometry().
1118 {
1119  bool status = false;
1120
1121  if ( m_xmlDocument.valid() )
1122  {
1123  bool useGmlPrefix = false;
1124
1125  vector< ossimRefPtr<ossimXmlNode> > xml_nodes;
1126
1127  ossimString xpath0 = "/gmljp2:GMLJP2CoverageCollection/gmljp2:featureMember/gmljp2:GMLJP2RectifiedGridCoverage/domainSet/RectifiedGrid";
1128  m_xmlDocument->findNodes( xpath0, xml_nodes );
1129  if ( !xml_nodes.size() )
1130  {
1131  xpath0 = "/gmljp2:GMLJP2CoverageCollection/gmljp2:featureMember/gmljp2:GMLJP2RectifiedGridCoverage/gml:domainSet/gml:RectifiedGrid";
1132  m_xmlDocument->findNodes( xpath0, xml_nodes );
1133  if ( xml_nodes.size() )
1134  {
1135  useGmlPrefix = true;
1136  }
1137  }
1138
1139  if ( xml_nodes.size() )
1140  {
1141  const ossimString SRS_NAME( "srsName" );
1142  const ossimString PCS_CODE_DEFINITION_STR( "http://www.opengis.net/def/crs/EPSG/0/" );
1143
1144  const ossimRefPtr<ossimXmlAttribute> hrefAttribute =
1145  xml_nodes[0]->findAttribute( SRS_NAME );
1146  const ossimString& originSrsName = hrefAttribute->getValue();
1147
1148  ossimString pcsCodeStr = originSrsName.after( PCS_CODE_DEFINITION_STR.string() );
1149  ossim_uint32 pcsCode = pcsCodeStr.toUInt32();
1150
1151  if ( pcsCode != 32767 )
1152  {
1153  // Add the pcs code.
1154  geomKwl.add( ossimKeywordNames::PCS_CODE_KW, pcsCodeStr.c_str() );
1155  if ( pcsCode == 4326 )
1156  {
1157  ossimString srsName = "EPSG:";
1158  srsName += pcsCodeStr;
1159  geomKwl.add( ossimKeywordNames::SRS_NAME_KW, srsName.c_str() );
1160  geomKwl.add( ossimKeywordNames::TYPE_KW, "ossimEquDistCylProjection");
1161  }
1162
1163  if ( addLineSamps( xpath0, useGmlPrefix, geomKwl ) )
1164  {
1165  if ( addTie( xpath0, useGmlPrefix, pcsCode, geomKwl ) )
1166  {
1167  status = addScale( xpath0, useGmlPrefix, pcsCode, geomKwl );
1168  }
1169  }
1170  }
1171  }
1172  }
1173
1174  return status;
1175 }
bool valid() const
bool addLineSamps(const ossimString &xpath0, bool useGmlPrefix, ossimKeywordlist &geomKwl) const
ossim_uint32 toUInt32() const
const ossimString & getValue() const
static const char * TYPE_KW
bool addTie(const ossimString &xpath0, bool useGmlPrefix, ossim_uint32 pcsCode, ossimKeywordlist &geomKwl) const
bool addScale(const ossimString &xpath0, bool useGmlPrefix, ossim_uint32 pcsCode, ossimKeywordlist &geomKwl) const
return status
static const char * PCS_CODE_KW
ossimString after(const ossimString &str, std::string::size_type pos=0) const
METHOD: after(str, pos) Returns string immediately after the token str.
static const char * SRS_NAME_KW
◆ getImageGeometryFromSeonsorModel()
bool ossimGmlSupportData::getImageGeometryFromSeonsorModel ( ossimKeywordlist geomKwl) const
private
Parameters
Definition at line 1096 of file ossimGmlSupportData.cpp.
References ossimXmlDocument::findNodes(), m_xmlDocument, status, and ossimRefPtr< T >::valid().
1097 {
1098  bool status = false;
1099
1100  if ( m_xmlDocument.valid() )
1101  {
1102  vector< ossimRefPtr<ossimXmlNode> > xml_nodes;
1103  ossimString xpath0 = "/gmljp2:GMLJP2CoverageCollection/gmljp2:featureMember/gmljp2:GMLJP2ReferenceableGridCoverage/gml:domainSet/gmlcov:ReferenceableGridBySensorModel";
1104
1105  m_xmlDocument->findNodes( xpath0, xml_nodes );
1106  if ( xml_nodes.size() >= 1 )
1107  {
1108  // Put sensor model code here...
1109
1110  status = true;
1111  }
1112  }
1113
1114  return status;
1115 }
bool valid() const
return status
◆ getLimits()
void ossimGmlSupportData::getLimits ( const ossimIrect rect,
ossimString gridHighString,
) const
private
Definition at line 1078 of file ossimGmlSupportData.cpp.
References ossimIrect::hasNans(), ossimIrect::height(), and ossimIrect::width().
1081 {
1082  if ( rect.hasNans() == false )
1083  {
1084  // Zero based image rect.
1085  gridLowString = "0 0";
1086
1087  ossim_uint32 w = rect.width();
1088  ossim_uint32 h = rect.height();
1089
1090  std::ostringstream os;
1091  os << (w-1) << " " << (h-1);
1092  gridHighString = os.str();
1093  }
1094 }
ossim_uint32 height() const
Definition: ossimIrect.h:487
ossim_uint32 width() const
Definition: ossimIrect.h:500
bool hasNans() const
Definition: ossimIrect.h:337
◆ getMapOrigin()
void ossimGmlSupportData::getMapOrigin ( const ossimImageGeometry geom,
const ossimIpt ul,
) const
private
Definition at line 1007 of file ossimGmlSupportData.cpp.
References ossimMapProjection::forward(), ossimImageGeometry::getAsMapProjection(), ossimImageGeometry::getMetersPerPixel(), ossimImageGeometry::localToWorld(), os2, ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
1013 {
1014  if ( geom )
1015  {
1017  if ( mapProj.valid() != 0 )
1018  {
1019  // Get the tie point:
1020  ossimGpt gpt;
1021  geom->localToWorld( ul, gpt );
1022
1023  ossimDpt tie = mapProj->forward( gpt );
1024
1025  std::ostringstream os;
1026  os.precision(15);
1027  os << tie.x << " " << tie.y;
1028  originString = os.str();
1029  }
1030
1031  // Get the projected CS gsd:
1032  ossimDpt gsdMap;
1033  geom->getMetersPerPixel( gsdMap );
1034
1036  os2.precision(15);
1037  os2 << gsdMap.x << " " << "0.0";
1038  offsetVector1String = os2.str();
1039
1040  std::ostringstream os3;
1041  os3.precision(15);
1042  os3 << "0.0" << " " << -gsdMap.y;
1043  offsetVector2String = os3.str();
1044  }
1045
1046 } // End: ossimGmlSupportData::getMapBounds
bool valid() const
double y
ossimDpt getMetersPerPixel() const
Returns the GSD associated with this image in the active projection.
virtual ossimDpt forward(const ossimGpt &worldPoint) const =0
double x
◆ getXmlDoc()
ossimRefPtr< ossimXmlDocument > ossimGmlSupportData::getXmlDoc ( ) const
Returns
Reference to xml doc.
Definition at line 539 of file ossimGmlSupportData.cpp.
References m_xmlDocument.
540 {
541  return m_xmlDocument;
542 }
◆ initialize() [1/2]
bool ossimGmlSupportData::initialize ( const ossimImageGeometry geom,
Parameters
geom
rectOutput rectangle (view rect).
Definition at line 78 of file ossimGmlSupportData.cpp.
References configureGmljp2V2(), ossimImageGeometry::getAsMapProjection(), getGmljp2V1RootNode(), getGmljp2V2RootNode(), ossimMapProjection::getPcsCode(), ossimXmlDocument::initRoot(), m_pcsCodeGeo, m_pcsCodeMap, m_srsNameStringGeo, m_srsNameStringMap, m_xmlDocument, ossimFilename::NIL, os2, ossimNotify(), ossimNotifyLevel_DEBUG, status, and ossimRefPtr< T >::valid().
Referenced by ossimOpjCompressor::writeGmlBox(), and ossimKakaduCompressor::writeGmlBox().
80 {
81  static const char MODULE[] = "ossimGmlSupportData::initialize(geom)";
82
83  bool status = false;
84
85  if ( geom )
86  {
87  // ossim_uint32 code = UNKNOWN_PCSCODE; // unknown code
88
91  {
92  // Get the PCS code:
93  m_pcsCodeMap = mapProj->getPcsCode();
94  m_pcsCodeGeo = mapProj->getPcsCode();
95
96  // Create an SRS Name for the map projection
98  os << "http://www.opengis.net/def/crs/EPSG/0/" << m_pcsCodeMap;
99  m_srsNameStringMap = os.str();
100
101  // Create an SRS Name for the projection datum
103  os2 << "http://www.opengis.net/def/crs/EPSG/0/" << m_pcsCodeGeo;
104  m_srsNameStringGeo = os2.str();
105
107
108  // if ( m_use_gmljp2_version2 == true )
109  // {
110
112  m_xmlDocument->initRoot( rootNode );
113  status = configureGmljp2V2( rootNode, geom, rect );
114  // }
115
116 #if 0
117  else
118  {
120  m_xmlDocument->initRoot( rootNode );
121  status = configureGmljp2V1( rootNode, geom, rect );
122  }
123 #endif
124
125  // cout << "gmljp2Node: " << *(gmljp2Node.get()) << endl;
126
127  // cout << "xmlDoc: " << *(m_xmlDocument.get()) << endl;
128  }
129  }
130
131  if ( status == false )
132  {
134  << MODULE << " DEBUG Entered...\n";
135
136  }
137
138  return status;
139
140 } // End: ossimGmlSupportData::initialize( geom, mapProj )
static const ossimFilename NIL
This was taken from Wx widgets for performing touch and access date stamps.
Definition: ossimFilename.h:40
bool valid() const
virtual ossim_uint32 getPcsCode() const
Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection.
ossimRefPtr< ossimXmlNode > getGmljp2V1RootNode() const
ossimRefPtr< ossimXmlNode > getGmljp2V2RootNode() const
return status
bool configureGmljp2V2(ossimRefPtr< ossimXmlNode > node, const ossimImageGeometry *geom, const ossimIrect &rect)
void initRoot(ossimRefPtr< ossimXmlNode > node)
◆ initialize() [2/2]
bool ossimGmlSupportData::initialize ( std::istream &  in)
Parameters
in
Definition at line 60 of file ossimGmlSupportData.cpp.
References m_xmlDocument, ossimXmlDocument::read(), and status.
61 {
62  bool status = false;
63
64  if ( in.good() )
65  {
67  m_xmlDocument->read( in );
68  status = true;
69  }
70  else
71  {
72  m_xmlDocument = 0;
73  }
74
75  return status;
76 }
return status
bool read(std::istream &in)
◆ write()
bool ossimGmlSupportData::write ( std::ostream &  os)
Definition at line 525 of file ossimGmlSupportData.cpp.
References ossimRefPtr< T >::get(), m_xmlDocument, status, and ossimRefPtr< T >::valid().
526 {
527  bool status = false;
528
529  if ( m_xmlDocument.valid() )
530  {
531  os << *(m_xmlDocument.get());
532
533  status = true;
534  }
535
536  return status;
537 }
bool valid() const
return status
Member Data Documentation
◆ m_axisLabelsStringGeo
ossimString ossimGmlSupportData::m_axisLabelsStringGeo
private
Definition at line 164 of file ossimGmlSupportData.h.
Referenced by configureBounds(), and configureGmljp2V2().
◆ m_axisLabelsStringMap
ossimString ossimGmlSupportData::m_axisLabelsStringMap
private
Definition at line 163 of file ossimGmlSupportData.h.
◆ m_pcsCodeGeo
ossim_uint32 ossimGmlSupportData::m_pcsCodeGeo
private
Definition at line 159 of file ossimGmlSupportData.h.
◆ m_pcsCodeMap
ossim_uint32 ossimGmlSupportData::m_pcsCodeMap
private
Definition at line 158 of file ossimGmlSupportData.h.
◆ m_srsDimensionString
ossimString ossimGmlSupportData::m_srsDimensionString
private
Definition at line 162 of file ossimGmlSupportData.h.
◆ m_srsNameStringGeo
ossimString ossimGmlSupportData::m_srsNameStringGeo
private
Definition at line 161 of file ossimGmlSupportData.h.
Referenced by configureBounds(), configureGmljp2V2(), and initialize().
◆ m_srsNameStringMap
ossimString ossimGmlSupportData::m_srsNameStringMap
private
Definition at line 160 of file ossimGmlSupportData.h.
Referenced by configureGmljp2V2(), and initialize().
◆ m_uomLabelsStringGeo
ossimString ossimGmlSupportData::m_uomLabelsStringGeo
private
Definition at line 166 of file ossimGmlSupportData.h.
◆ m_uomLabelsStringMap
ossimString ossimGmlSupportData::m_uomLabelsStringMap
private
Definition at line 165 of file ossimGmlSupportData.h.
◆ m_xmlDocument
ossimRefPtr<ossimXmlDocument> ossimGmlSupportData::m_xmlDocument
private
