ossimHsvToRgbSource Class Reference
#include <ossimHsvToRgbSource.h>
Inheritance diagram for ossimHsvToRgbSource:
ossimImageSourceFilter ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimHsvToRgbSource ()
 ossimHsvToRgbSource (ossimImageSource *inputSource)
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual double getNullPixelValue () const
virtual void initialize ()
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
Protected Member Functions
virtual ~ossimHsvToRgbSource ()
virtual void allocate ()
virtual ~ossimReferenced ()
Protected Attributes
ossimRefPtr< ossimImageDatatheBlankTile
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Additional Inherited Members
Detailed Description
Definition at line 16 of file ossimHsvToRgbSource.h.
◆ ossimHsvToRgbSource() [1/2]
ossimHsvToRgbSource::ossimHsvToRgbSource ( )
Definition at line 22 of file ossimHsvToRgbSource.cpp.
24  theBlankTile(NULL),
25  theTile(NULL)
26 {
27 }
ossimImageSourceFilter(ossimObject *owner=NULL)
ossimRefPtr< ossimImageData > theBlankTile
◆ ossimHsvToRgbSource() [2/2]
ossimHsvToRgbSource::ossimHsvToRgbSource ( ossimImageSource inputSource)
Definition at line 29 of file ossimHsvToRgbSource.cpp.
30  : ossimImageSourceFilter(inputSource),
31  theBlankTile(NULL),
32  theTile(NULL)
33 {
34 }
◆ ~ossimHsvToRgbSource()
ossimHsvToRgbSource::~ossimHsvToRgbSource ( )
protectedvirtual
Definition at line 36 of file ossimHsvToRgbSource.cpp.
37 {
38 }
Member Function Documentation
◆ allocate()
void ossimHsvToRgbSource::allocate ( )
protectedvirtual
Definition at line 134 of file ossimHsvToRgbSource.cpp.
References ossimImageDataFactory::create(), ossimImageData::dup(), ossimImageData::initialize(), ossimImageDataFactory::instance(), theBlankTile, and theTile.
Referenced by getTile().
135 {
138  theTile->initialize();
139 }
virtual void initialize()
Initialize the data buffer.
virtual ossimObject * dup() const
◆ getMaxPixelValue()
double ossimHsvToRgbSource::getMaxPixelValue ( ossim_uint32  band = 0) const
virtual
Definition at line 156 of file ossimHsvToRgbSource.cpp.
References OSSIM_DEFAULT_MAX_PIX_UCHAR.
157 {
159 }
#define OSSIM_DEFAULT_MAX_PIX_UCHAR
◆ getMinPixelValue()
double ossimHsvToRgbSource::getMinPixelValue ( ossim_uint32  band = 0) const
virtual
Definition at line 151 of file ossimHsvToRgbSource.cpp.
References OSSIM_DEFAULT_MIN_PIX_UCHAR.
152 {
154 }
#define OSSIM_DEFAULT_MIN_PIX_UCHAR
◆ getNullPixelValue()
double ossimHsvToRgbSource::getNullPixelValue ( ) const
virtual
Definition at line 146 of file ossimHsvToRgbSource.cpp.
147 {
148  return 0;
149 }
◆ getOutputScalarType()
ossimScalarType ossimHsvToRgbSource::getOutputScalarType ( ) const
virtual
Definition at line 141 of file ossimHsvToRgbSource.cpp.
References OSSIM_UINT8.
142 {
143  return OSSIM_UINT8;
144 }
8 bit unsigned integer
◆ getTile()
ossimRefPtr< ossimImageData > ossimHsvToRgbSource::getTile ( const ossimIrect rect,
ossim_uint32  resLevel = 0
virtual
Returns
Definition at line 40 of file ossimHsvToRgbSource.cpp.
References allocate(), ossimRgbVector::getB(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimRgbVector::getG(), ossimImageData::getHeight(), ossimImageData::getNumberOfBands(), ossimRgbVector::getR(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossimImageData::getWidth(), ossimIrect::height(), ossimImageData::initialize(), ossimSource::isSourceEnabled(), ossimImageData::makeBlank(), OSSIM_NORMALIZED_FLOAT, OSSIM_NULL, ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setOrigin(), ossimImageData::setWidthHeight(), theBlankTile, ossimImageSourceFilter::theInputConnection, theTile, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), and ossimIrect::width().
43 {
45  {
46  ossimRefPtr<ossimImageData> imageData =
47  theInputConnection->getTile(tileRect, resLevel);
48
49  if(!imageData.valid()) return theBlankTile;
50
51  if(!isSourceEnabled())
52  {
53  return imageData;
54  }
55
56  if(!theTile.valid()) allocate();
57  if(!theTile.valid())
58  {
60  << "Unable to initialize ossimHsvToRgbSource in getTile"
61  << std::endl;
63  }
64
65  long w = tileRect.width();
66  long h = tileRect.height();
67  long tw = theTile->getWidth();
68  long th = theTile->getHeight();
69
70  theBlankTile->setOrigin(tileRect.ul());
72  theTile->setWidthHeight(w, h);
73  theTile->setOrigin(tileRect.ul());
74  if( (tw*th) != (w*h))
75  {
77  }
78  else
79  {
80  theTile->makeBlank();
81  }
82
83  if((imageData->getNumberOfBands()==3)&&
84  (imageData->getScalarType()==OSSIM_NORMALIZED_FLOAT)&&
85  (imageData->getDataObjectStatus()!=OSSIM_NULL))
86  {
87  ossim_uint8* outputBands[3];
88  float* inputBands[3];
89  outputBands[0] = static_cast<ossim_uint8*>(theTile->getBuf(0));
90  outputBands[1] = static_cast<ossim_uint8*>(theTile->getBuf(1));
91  outputBands[2] = static_cast<ossim_uint8*>(theTile->getBuf(2));
92  inputBands[0] = static_cast<float*>(imageData->getBuf(0));
93  inputBands[1] = static_cast<float*>(imageData->getBuf(1));
94  inputBands[2] = static_cast<float*>(imageData->getBuf(2));
95
96  long height = imageData->getHeight();
97  long width = imageData->getWidth();
98  long offset = 0;
99  for(long row = 0; row < height; ++row)
100  {
101  for(long col = 0; col < width; ++col)
102  {
103  ossimHsvVector hsv(inputBands[0][offset],
104  inputBands[1][offset],
105  inputBands[2][offset]);
106
107  ossimRgbVector rgb(hsv);
108
109  outputBands[0][offset] = rgb.getR();
110  outputBands[1][offset] = rgb.getG();
111  outputBands[2][offset] = rgb.getB();
112
113  ++offset;
114  }
115  }
116  }
117  else
118  {
119  return imageData;
120  }
121  theTile->validate();
122  return theTile;
123  }
124
125  return theBlankTile;
126 }
virtual void setWidthHeight(ossim_uint32 w, ossim_uint32 h)
bool valid() const
Definition: ossimRefPtr.h:75
virtual void setOrigin(const ossimIpt &origin)
virtual void makeBlank()
unsigned char ossim_uint8
◆ initialize()
void ossimHsvToRgbSource::initialize ( )
virtual
Definition at line 128 of file ossimHsvToRgbSource.cpp.
References theBlankTile, and theTile.
129 {
130  theBlankTile = NULL;
131  theTile = NULL;
132 }
Member Data Documentation
◆ theBlankTile
ossimRefPtr<ossimImageData> ossimHsvToRgbSource::theBlankTile
protected
Definition at line 36 of file ossimHsvToRgbSource.h.
Referenced by allocate(), getTile(), and initialize().
◆ theTile
ossimRefPtr<ossimImageData> ossimHsvToRgbSource::theTile
protected
Definition at line 37 of file ossimHsvToRgbSource.h.
