ossimQuadProjection Class Reference
#include <ossimQuadProjection.h>
Inheritance diagram for ossimQuadProjection:
ossimProjection ossimObject ossimErrorStatusInterface ossimReferenced
Public Member Functions
 ossimQuadProjection ()
 ossimQuadProjection (const ossimQuadProjection &rhs)
 ossimQuadProjection (const ossimIrect &rect, const ossimGpt &ulg, const ossimGpt &urg, const ossimGpt &lrg, const ossimGpt &llg)
virtual void worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSampPt) const
virtual void lineSampleToWorld (const ossimDpt &lineSampPt, ossimGpt &worldPt) const
virtual void lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const
virtual bool operator== (const ossimProjection &projection) const
 ossimProjection ()
virtual ~ossimProjection ()
virtual ossimDpt forward (const ossimGpt &wp) const
virtual ossimGpt inverse (const ossimDpt &pp) const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimErrorStatusInterface ()
bool hasError () const
Protected Member Functions
virtual ~ossimQuadProjection ()
void initializeGrids ()
ossimGpt extrapolate (const ossimDpt &imagePoint, const double &height) const
virtual ~ossimReferenced ()
Protected Attributes
ossimIrect theInputRect
ossimGpt theUlg
ossimGpt theUrg
ossimGpt theLrg
ossimGpt theLlg
ossimDblGrid theLatGrid
ossimDblGrid theLonGrid
ossimErrorCode theErrorStatus
Detailed Description
Definition at line 16 of file ossimQuadProjection.h.
◆ ossimQuadProjection() [1/3]
ossimQuadProjection::ossimQuadProjection ( )
◆ ossimQuadProjection() [2/3]
ossimQuadProjection::ossimQuadProjection ( const ossimQuadProjection rhs)
Definition at line 33 of file ossimQuadProjection.cpp.
◆ ossimQuadProjection() [3/3]
ossimQuadProjection::ossimQuadProjection ( const ossimIrect rect,
const ossimGpt ulg,
const ossimGpt urg,
const ossimGpt lrg,
const ossimGpt llg
Definition at line 45 of file ossimQuadProjection.cpp.
References initializeGrids().
50  :theInputRect(rect),
51  theUlg(ulg),
52  theUrg(urg),
53  theLrg(lrg),
54  theLlg(llg)
55 {
57 }
◆ ~ossimQuadProjection()
ossimQuadProjection::~ossimQuadProjection ( )
protectedvirtual
Definition at line 59 of file ossimQuadProjection.cpp.
60 {
61 }
Member Function Documentation
◆ dup()
ossimObject * ossimQuadProjection::dup ( ) const
virtual
Implements ossimProjection.
Definition at line 63 of file ossimQuadProjection.cpp.
References ossimQuadProjection().
64 {
65  return new ossimQuadProjection(*this);
66 }
◆ extrapolate()
ossimGpt ossimQuadProjection::extrapolate ( const ossimDpt imagePoint,
const double &  height
) const
protected
Definition at line 455 of file ossimQuadProjection.cpp.
References ossimDpt::hasNans(), ossimGpt::hgt, ossim::isnan(), ossimGpt::lat, ossimDpt::length(), lineSampleHeightToWorld(), lineSampleToWorld(), ossimGpt::lon, ossimIrect::midPoint(), ossim::nan(), and theInputRect.
Referenced by lineSampleHeightToWorld().
457 {
458  //---
459  // If image point supplied has NaN components, return now with a NaN point.
460  // This prevents an infinite recursion between model worldToLineSample
461  // and this method:
462  //---
463  if (imagePoint.hasNans())
464  {
465  return ossimGpt(ossim::nan(), ossim::nan(), ossim::nan());
466  }
467
468  //***
469  // Determine which edge is intersected by the radial, and establish
470  // intersection:
471  //***
472  ossimGpt gpt;
473  ossimDpt edgePt (imagePoint);
474  ossimDpt image_center (theInputRect.midPoint());
475  ossimDrect clipRect = theInputRect;
476  clipRect.clip(image_center, edgePt);
477
478  //***
479  // Need edgePt relative to image center. Compute an epsilon perturbation in
480  // the direction of edgePt for later computing directional derivative,
481  // and back out the offset to origin:
482  //***
483  ossimDpt deltaPt (edgePt - image_center);
484  ossimDpt epsilon (deltaPt/deltaPt.length());
485  edgePt -= epsilon; // insure that we are inside the image
486  ossimDpt edgePt_prime (edgePt - epsilon); // epsilon=1pixel
487
488  //***
489  // Establish ground point corresponding to edge point and edgePt+epsilon:
490  //***
491  ossimGpt edgeGP;
492  ossimGpt edgeGP_prime;
493
494  if (ossim::isnan(height))
495  {
496  lineSampleToWorld(edgePt, edgeGP);
497  lineSampleToWorld(edgePt_prime, edgeGP_prime);
498  }
499  else
500  {
501  lineSampleHeightToWorld(edgePt, height, edgeGP);
502  lineSampleHeightToWorld(edgePt_prime, height, edgeGP_prime);
503  }
504
505  //***
506  // Compute approximate directional derivatives of lat and lon along radial
507  // at the edge:
508  //***
509  double dpixel = (edgePt-edgePt_prime).length();
510  double dlat_drad = (edgeGP.lat - edgeGP_prime.lat)/dpixel;
511  double dlon_drad = (edgeGP.lon - edgeGP_prime.lon)/dpixel;
512
513  //***
514  // Now extrapolate to image point of interest:
515  //***
516  double delta_pixel = (imagePoint - edgePt).length();
517
518  gpt.lat = edgeGP.lat + dlat_drad*delta_pixel;
519  gpt.lon = edgeGP.lon + dlon_drad*delta_pixel;
520 // if (height == OSSIM_DBL_NAN)
521 // {
522 // gpt.hgt = theElevation->getHeightAboveMSL(gpt);
523 // }
524 // else
525  gpt.hgt = height;
526
527  return gpt;
528
529 }
double nan()
Definition: ossimCommon.h:135
ossim_float64 hgt
Height in meters above the ellipsiod.
Definition: ossimGpt.h:274
ossim_float64 lon
Definition: ossimGpt.h:266
ossimIpt midPoint() const
Definition: ossimIrect.h:750
bool hasNans() const
Definition: ossimDpt.h:67
virtual void lineSampleHeightToWorld(const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const
virtual void lineSampleToWorld(const ossimDpt &lineSampPt, ossimGpt &worldPt) const
ossim_float64 lat
Definition: ossimGpt.h:265
bool isnan(const float &v)
Definition: ossimCommon.h:91
◆ getMetersPerPixel()
ossimDpt ossimQuadProjection::getMetersPerPixel ( ) const
virtual
ACCESS METHODS:
Definition at line 405 of file ossimQuadProjection.cpp.
References lineSampleToWorld(), ossimEcefVector::magnitude(), ossimIrect::midPoint(), theInputRect, and ossimDpt::x.
406 {
407  ossimGpt centerG;
408  ossimGpt rightG;
409  ossimGpt topG;
410
414
415  ossimEcefPoint centerP = centerG;
416  ossimEcefPoint rightP = rightG;
417  ossimEcefPoint topP = topG;
418
419  ossimEcefVector horizontal = rightP-centerP;
420  ossimEcefVector vertical = topP-centerP;
421
422  ossimDpt result(horizontal.magnitude(),
423  vertical.magnitude());
424
425  result.x = (result.x + result.y)/2.0;
426  result.y = result.x;
427
428
429  return result;
430 }
double magnitude() const
double x
Definition: ossimDpt.h:164
◆ initializeGrids()
void ossimQuadProjection::initializeGrids ( )
protected
Definition at line 432 of file ossimQuadProjection.cpp.
References ossimIrect::height(), ossimDblGrid::initialize(), ossimGpt::latd(), ossimGpt::lond(), ossim::nan(), ossimDblGrid::setNode(), ossimDblGrid::setNullValue(), theInputRect, theLatGrid, theLlg, theLonGrid, theLrg, theUlg, theUrg, ossimIrect::ul(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
Referenced by loadState(), and ossimQuadProjection().
433 {
434  ossimIpt gridSize(2,2);
435
436  ossimDpt spacing = ossimDpt((double)(theInputRect.width()-1)/(gridSize.x-1),
437  (double)(theInputRect.height()-1)/(gridSize.y-1));
438
441  theLatGrid.initialize(gridSize, theInputRect.ul(), spacing);
442  theLonGrid.initialize(gridSize, theInputRect.ul(), spacing);
443
444  theLatGrid.setNode(0,0, theUlg.latd());
445  theLatGrid.setNode(1,0, theUrg.latd());
446  theLatGrid.setNode(1,1, theLrg.latd());
447  theLatGrid.setNode(0,1, theLlg.latd());
448
449  theLonGrid.setNode(0,0, theUlg.lond());
450  theLonGrid.setNode(1,0, theUrg.lond());
451  theLonGrid.setNode(1,1, theLrg.lond());
452  theLonGrid.setNode(0,1, theLlg.lond());
453 }
double lond() const
Will convert the radian measure to degrees.
Definition: ossimGpt.h:97
double nan()
ossim_uint32 height() const
Definition: ossimIrect.h:487
void setNullValue(double value)
Definition: ossimDblGrid.h:183
const ossimIpt & ul() const
Definition: ossimIrect.h:274
void initialize(const ossimIpt &size, const ossimDpt &origin, const ossimDpt &spacing, double null_value=OSSIM_DEFAULT_NULL_PIX_DOUBLE)
double latd() const
Definition: ossimGpt.h:87
ossim_uint32 width() const
Definition: ossimIrect.h:500
void setNode(const ossimIpt &p, const double &value)
Definition: ossimDblGrid.h:107
◆ isAffectedByElevation()
virtual bool ossimQuadProjection::isAffectedByElevation ( ) const
inlinevirtual
Implementation of pure virtual ossimProjection::isAffectedByElevation method.
Returns
false.
Definition at line 62 of file ossimQuadProjection.h.
62 { return false; }
◆ lineSampleHeightToWorld()
void ossimQuadProjection::lineSampleHeightToWorld ( const ossimDpt lineSampPt,
const double &  heightAboveEllipsoid,
ossimGpt worldPt
) const
virtual
METHOD: lineSampleHeightToWorld This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. Useful for projections that are sensitive to elevation (such as sensor models).
Definition at line 107 of file ossimQuadProjection.cpp.
References ossimGpt::datum(), extrapolate(), ossimElevManager::getHeightAboveEllipsoid(), ossimIrect::hasNans(), ossimGpt::hgt, ossimElevManager::instance(), ossimGpt::isLatNan(), ossimGpt::isLonNan(), ossimGpt::lat, ossimGpt::lon, ossimGpt::makeNan(), ossimIrect::pointWithin(), theInputRect, theLatGrid, theLlg, theLonGrid, theLrg, theUlg, and theUrg.
Referenced by extrapolate(), and lineSampleToWorld().
110 {
111  worldPt.makeNan();
112  worldPt.datum(theUlg.datum());
113
114  if(theUlg.isLatNan()||
115  theUlg.isLonNan()||
116  theUrg.isLatNan()||
117  theUrg.isLonNan()||
118  theLrg.isLatNan()||
119  theLrg.isLonNan()||
120  theLlg.isLatNan()||
121  theLlg.isLonNan()||
123  {
124  return;
125  }
126
127  if(!theInputRect.pointWithin(lineSampPt))
128  {
129  worldPt = extrapolate(lineSampPt,
130  heightAboveEllipsoid);
132  return;
133  }
134
135  worldPt.lat = theLatGrid(lineSampPt);
136  worldPt.lon = theLonGrid(lineSampPt);
137  worldPt.hgt = heightAboveEllipsoid;
139 }
bool isLonNan() const
Definition: ossimGpt.h:140
void makeNan()
Definition: ossimGpt.h:130
ossim_float64 hgt
static ossimElevManager * instance()
METHOD: instance() Implements singelton pattern.
bool isLatNan() const
Definition: ossimGpt.h:139
const ossimDatum * datum() const
datum().
Definition: ossimGpt.h:196
ossim_float64 lon
virtual double getHeightAboveEllipsoid(const ossimGpt &gpt)
Definition: ossimIrect.h:337
ossim_float64 lat
ossimGpt extrapolate(const ossimDpt &imagePoint, const double &height) const
bool pointWithin(const ossimIpt &pt) const
Definition: ossimIrect.h:729
◆ lineSampleToWorld()
void ossimQuadProjection::lineSampleToWorld ( const ossimDpt lineSampPt,
ossimGpt worldPt
) const
virtual
METHOD: lineSampleToWorld() Performs the inverse projection from line, sample to ground (world):
Definition at line 98 of file ossimQuadProjection.cpp.
References lineSampleHeightToWorld(), and ossim::nan().
Referenced by extrapolate(), and getMetersPerPixel().
100 {
101  lineSampleHeightToWorld(lineSampPt,
102  ossim::nan(),
103  worldPt);
104
105 }
double nan()
◆ loadState()
bool ossimQuadProjection::loadState ( const ossimKeywordlist kwl,
const char *  prefix = 0
virtual
Reimplemented from ossimProjection.
Definition at line 269 of file ossimQuadProjection.cpp.
References ossimDatumFactory::create(), ossimGpt::datum(), ossimKeywordNames::DATUM_KW, ossimKeywordlist::find(), initializeGrids(), ossimDatumFactory::instance(), ossimGpt::latd(), ossimKeywordNames::LL_LAT_KW, ossimKeywordNames::LL_LON_KW, ossimProjection::loadState(), ossimGpt::lond(), ossimKeywordNames::LR_LAT_KW, ossimKeywordNames::LR_LON_KW, ossimIpt::makeNan(), ossimGpt::makeNan(), ossimIrect::makeNan(), ossim::nan(), theInputRect, theLlg, theLrg, theUlg, theUrg, ossimString::toDouble(), ossimString::toInt32(), ossimString::toUInt32(), ossimKeywordNames::UL_LAT_KW, ossimKeywordNames::UL_LON_KW, ossimKeywordNames::UL_X_KW, ossimKeywordNames::UL_Y_KW, ossimKeywordNames::UR_LAT_KW, ossimKeywordNames::UR_LON_KW, ossimIpt::x, and ossimIpt::y.
271 {
272  ossimProjection::loadState(kwl, prefix);
273  theUlg.makeNan();
274  theUrg.makeNan();
275  theLrg.makeNan();
276  theLlg.makeNan();
278
279  ossimString ulLat = kwl.find(prefix, ossimKeywordNames::UL_LAT_KW);
280  ossimString ulLon = kwl.find(prefix, ossimKeywordNames::UL_LON_KW);
281  ossimString urLat = kwl.find(prefix, ossimKeywordNames::UR_LAT_KW);
282  ossimString urLon = kwl.find(prefix, ossimKeywordNames::UR_LON_KW);
283  ossimString lrLat = kwl.find(prefix, ossimKeywordNames::LR_LAT_KW);
284  ossimString lrLon = kwl.find(prefix, ossimKeywordNames::LR_LON_KW);
285  ossimString llLat = kwl.find(prefix, ossimKeywordNames::LL_LAT_KW);
286  ossimString llLon = kwl.find(prefix, ossimKeywordNames::LL_LON_KW);
287  ossimString datum = kwl.find(prefix, ossimKeywordNames::DATUM_KW);
288  ossimString ulX = kwl.find(prefix, ossimKeywordNames::UL_X_KW);
289  ossimString ulY = kwl.find(prefix, ossimKeywordNames::UL_Y_KW);
290  ossimString width = kwl.find(prefix, "width");
291  ossimString height = kwl.find(prefix, "height");
292
293  if(ulLat == "nan")
294  {
296  }
297  else
298  {
299  theUlg.latd(ulLat.toDouble());
300  }
301  if(ulLon == "nan")
302  {
304  }
305  else
306  {
307  theUlg.lond(ulLon.toDouble());
308  }
309
310  if(urLat == "nan")
311  {
313  }
314  else
315  {
316  theUrg.latd(urLat.toDouble());
317  }
318  if(urLon == "nan")
319  {
321  }
322  else
323  {
324  theUrg.lond(urLon.toDouble());
325  }
326
327  if(lrLat == "nan")
328  {
330  }
331  else
332  {
333  theLrg.latd(lrLat.toDouble());
334  }
335  if(lrLon == "nan")
336  {
338  }
339  else
340  {
341  theLrg.lond(lrLon.toDouble());
342  }
343
344  if(llLat == "nan")
345  {
347  }
348  else
349  {
350  theLlg.latd(llLat.toDouble());
351  }
352  if(llLon == "nan")
353  {
355  }
356  else
357  {
358  theLlg.lond(llLon.toDouble());
359  }
360
361  ossimIpt ul;
362
363  ul.makeNan();
364
365  if((ulX != "nan") &&
366  (ulY != "nan"))
367  {
368  ul.x = ulX.toInt32();
369  ul.y = ulY.toInt32();
370  }
371  ossim_uint32 w = width.toUInt32();
372  ossim_uint32 h = height.toUInt32();
373  if(datum == "")
374  {
375  datum = "WGE";
376  }
377  const ossimDatum* datumPtr = ossimDatumFactory::instance()->create(datum);
378  theUlg.datum(datumPtr);
379  theUrg.datum(datumPtr);
380  theLrg.datum(datumPtr);
381  theLlg.datum(datumPtr);
382
383  if(w&&h)
384  {
386  ul.y,
387  ul.x + w - 1,
388  ul.y + h - 1);
389  }
390  else
391  {
393  }
394
395  initializeGrids();
396
397  return true;
398 }
virtual const ossimDatum * create(const ossimString &code) const
create method
void makeNan()
Definition: ossimIpt.h:56
static const char * DATUM_KW
double lond() const
static const char * UL_LAT_KW
double nan()
void makeNan()
static const char * LR_LON_KW
ossim_uint32 toUInt32() const
double latd() const
datum().
ossim_int32 toInt32() const
static const char * LR_LAT_KW
static const char * UL_X_KW
static const char * LL_LON_KW
unsigned int ossim_uint32
double toDouble() const
static ossimDatumFactory * instance()
static const char * LL_LAT_KW
static const char * UL_Y_KW
ossim_int32 y
Definition: ossimIpt.h:142
void makeNan()
Definition: ossimIrect.h:329
static const char * UL_LON_KW
static const char * UR_LAT_KW
static const char * UR_LON_KW
ossim_int32 x
Definition: ossimIpt.h:141
◆ operator==()
bool ossimQuadProjection::operator== ( const ossimProjection projection) const
virtual
OPERATOR: == Compares this instance with arg projection.
Definition at line 400 of file ossimQuadProjection.cpp.
401 {
402  return false;
403 }
◆ origin()
ossimGpt ossimQuadProjection::origin ( ) const
virtual
METHOD: origin() Returns projection's ground point origin. That is the GP corresponding to line=0, sample=0.
Definition at line 68 of file ossimQuadProjection.cpp.
References ossimGpt::datum(), ossimGpt::isLatNan(), ossimGpt::isLonNan(), ossimGpt::latd(), ossimGpt::lond(), ossimGpt::makeNan(), theLlg, theLrg, theUlg, and theUrg.
69 {
70  ossimGpt result;
71  result.makeNan();
72  if(theUlg.isLatNan()||
73  theUlg.isLonNan()||
74  theUrg.isLatNan()||
75  theUrg.isLonNan()||
76  theLrg.isLatNan()||
77  theLrg.isLonNan()||
78  theLlg.isLatNan()||
79  theLlg.isLonNan())
80  {
81  return result;
82  }
83
84  result.latd( (theUlg.latd() + theUrg.latd() + theLrg.latd() + theLlg.latd())*.25);
85  result.lond( (theUlg.lond() + theUrg.lond() + theLrg.lond() + theLlg.lond())*.25);
86
87  result.datum(theUlg.datum());
88
89  return result;
90 }
double lond() const
void makeNan()
double latd() const
datum().
◆ saveState()
bool ossimQuadProjection::saveState ( ossimKeywordlist kwl,
) const
virtual
METHODS: saveState, loadState Fulfills ossimObject base-class pure virtuals.
Definition at line 141 of file ossimQuadProjection.cpp.
References ossimKeywordlist::add(), ossimDatum::code(), ossimGpt::datum(), ossimKeywordNames::DATUM_KW, ossimIrect::hasNans(), ossimIrect::height(), ossimGpt::isLatNan(), ossimGpt::isLonNan(), ossimGpt::latd(), ossimKeywordNames::LL_LAT_KW, ossimKeywordNames::LL_LON_KW, ossimGpt::lond(), ossimKeywordNames::LR_LAT_KW, ossimKeywordNames::LR_LON_KW, ossimProjection::saveState(), theInputRect, theLlg, theLrg, theUlg, theUrg, ossimIrect::ul(), ossimKeywordNames::UL_LAT_KW, ossimKeywordNames::UL_LON_KW, ossimKeywordNames::UL_X_KW, ossimKeywordNames::UL_Y_KW, ossimKeywordNames::UR_LAT_KW, ossimKeywordNames::UR_LON_KW, ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
143 {
144  ossimProjection::saveState(kwl, prefix);
145  kwl.add(prefix,
147  theUlg.datum()->code(),
148  true);
149
150  if(theInputRect.hasNans())
151  {
152  kwl.add(prefix,
154  "nan",
155  true);
156  kwl.add(prefix,
158  "nan",
159  true);
160  kwl.add(prefix,
161  "width",
162  0,
163  true);
164  kwl.add(prefix,
165  "height",
166  0,
167  true);
168  }
169  else
170  {
171  kwl.add(prefix,
173  theInputRect.ul().x,
174  true);
175  kwl.add(prefix,
177  theInputRect.ul().y,
178  true);
179  kwl.add(prefix,
180  "width",
182  true);
183  kwl.add(prefix,
184  "height",
186  true);
187  }
188
189  if(theUlg.isLatNan()||
190  theUlg.isLonNan()||
191  theUrg.isLatNan()||
192  theUrg.isLonNan()||
193  theLrg.isLatNan()||
194  theLrg.isLonNan()||
195  theLlg.isLatNan()||
196  theLlg.isLonNan())
197  {
198  kwl.add(prefix,
200  "nan",
201  true);
202  kwl.add(prefix,
204  "nan",
205  true);
206  kwl.add(prefix,
208  "nan",
209  true);
210  kwl.add(prefix,
212  "nan",
213  true);
214  kwl.add(prefix,
216  "nan",
217  true);
218  kwl.add(prefix,
220  "nan",
221  true);
222  kwl.add(prefix,
224  "nan",
225  true);
226  kwl.add(prefix,
228  "nan",
229  true);
230  }
231  else
232  {
233  kwl.add(prefix,
235  theUlg.latd(),
236  true);
237  kwl.add(prefix,
239  theUlg.lond(),
240  true);
241  kwl.add(prefix,
243  theUrg.latd(),
244  true);
245  kwl.add(prefix,
247  theUrg.lond(),
248  true);
249  kwl.add(prefix,
251  theLrg.latd(),
252  true);
253  kwl.add(prefix,
255  theLrg.lond(),
256  true);
257  kwl.add(prefix,
259  theLlg.latd(),
260  true);
261  kwl.add(prefix,
263  theLlg.lond(),
264  true);
265  }
266  return true;
267 }
double lond() const
virtual const ossimString & code() const
Definition: ossimDatum.h:57
double latd() const
datum().
ossim_int32 y
ossim_int32 x
◆ worldToLineSample()
void ossimQuadProjection::worldToLineSample ( const ossimGpt worldPoint,
ossimDpt lineSampPt
) const
virtual
METHOD: worldToLineSample() Performs the forward projection from ground point to line, sample.
Definition at line 92 of file ossimQuadProjection.cpp.
References ossimProjection::worldToLineSample().
94 {
95  ossimProjection::worldToLineSample(worldPoint, lineSampPt);
96 }
virtual void worldToLineSample(const ossimGpt &worldPoint, ossimDpt &lineSampPt) const =0
Member Data Documentation
◆ theInputRect
ossimIrect ossimQuadProjection::theInputRect
protected
◆ theLatGrid
ossimDblGrid ossimQuadProjection::theLatGrid
protected
Definition at line 73 of file ossimQuadProjection.h.
Referenced by initializeGrids(), and lineSampleHeightToWorld().
◆ theLlg
ossimGpt ossimQuadProjection::theLlg
protected
◆ theLonGrid
ossimDblGrid ossimQuadProjection::theLonGrid
protected
Definition at line 74 of file ossimQuadProjection.h.
◆ theLrg
ossimGpt ossimQuadProjection::theLrg
protected
◆ theUlg
ossimGpt ossimQuadProjection::theUlg
protected
◆ theUrg
ossimGpt ossimQuadProjection::theUrg
protected
