ossimRgbToHsiSource Class Reference
#include <ossimRgbToHsiSource.h>
Inheritance diagram for ossimRgbToHsiSource:
ossimImageSourceFilter ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
 ossimRgbToHsiSource ()
 ossimRgbToHsiSource (ossimImageSource *inputSource)
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual double getNullPixelValue () const
virtual void initialize ()
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
Protected Member Functions
virtual ~ossimRgbToHsiSource ()
void allocate ()
 Called on first getTile, will initialize all data needed. More...
virtual ~ossimReferenced ()
Protected Attributes
ossimRefPtr< ossimImageDatatheBlankTile
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Additional Inherited Members
Detailed Description
Definition at line 16 of file ossimRgbToHsiSource.h.
◆ ossimRgbToHsiSource() [1/2]
ossimRgbToHsiSource::ossimRgbToHsiSource ( )
Definition at line 23 of file ossimRgbToHsiSource.cpp.
25  theBlankTile(NULL),
26  theTile(NULL)
27 {
28 }
ossimImageSourceFilter(ossimObject *owner=NULL)
ossimRefPtr< ossimImageData > theBlankTile
◆ ossimRgbToHsiSource() [2/2]
ossimRgbToHsiSource::ossimRgbToHsiSource ( ossimImageSource inputSource)
Definition at line 30 of file ossimRgbToHsiSource.cpp.
31  : ossimImageSourceFilter(inputSource),
32  theBlankTile(NULL),
33  theTile(NULL)
34 {
35 }
◆ ~ossimRgbToHsiSource()
ossimRgbToHsiSource::~ossimRgbToHsiSource ( )
protectedvirtual
Definition at line 37 of file ossimRgbToHsiSource.cpp.
38 {
39 }
Member Function Documentation
◆ allocate()
void ossimRgbToHsiSource::allocate ( )
protected
Definition at line 132 of file ossimRgbToHsiSource.cpp.
References ossimImageDataFactory::create(), ossimImageData::dup(), ossimImageData::initialize(), ossimImageDataFactory::instance(), theBlankTile, ossimImageSourceFilter::theInputConnection, and theTile.
Referenced by getTile().
133 {
134  theBlankTile = NULL;
135  theTile = NULL;
136
137  if(!theInputConnection) return;
138
141  theTile->initialize();
142 }
virtual void initialize()
Initialize the data buffer.
virtual ossimObject * dup() const
◆ getMaxPixelValue()
double ossimRgbToHsiSource::getMaxPixelValue ( ossim_uint32  band = 0) const
virtual
Definition at line 159 of file ossimRgbToHsiSource.cpp.
160 {
161  return 1.0;
162 }
◆ getMinPixelValue()
double ossimRgbToHsiSource::getMinPixelValue ( ossim_uint32  band = 0) const
virtual
Definition at line 154 of file ossimRgbToHsiSource.cpp.
155 {
156  return 0.0;
157 }
◆ getNullPixelValue()
double ossimRgbToHsiSource::getNullPixelValue ( ) const
virtual
Definition at line 149 of file ossimRgbToHsiSource.cpp.
References ossim::nan().
150 {
151  return ossim::nan();
152 }
double nan()
Definition: ossimCommon.h:135
◆ getNumberOfOutputBands()
ossim_uint32 ossimRgbToHsiSource::getNumberOfOutputBands ( ) const
virtual
Definition at line 144 of file ossimRgbToHsiSource.cpp.
145 {
146  return 3;
147 }
◆ getOutputScalarType()
ossimScalarType ossimRgbToHsiSource::getOutputScalarType ( ) const
virtual
Definition at line 121 of file ossimRgbToHsiSource.cpp.
References OSSIM_NORMALIZED_FLOAT.
122 {
123  return OSSIM_NORMALIZED_FLOAT;
124 }
◆ getTile()
ossimRefPtr< ossimImageData > ossimRgbToHsiSource::getTile ( const ossimIrect rect,
ossim_uint32  resLevel = 0
virtual
Returns
Definition at line 41 of file ossimRgbToHsiSource.cpp.
References allocate(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimHsiVector::getH(), ossimImageData::getHeight(), ossimHsiVector::getI(), ossimImageData::getNumberOfBands(), ossimHsiVector::getS(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossimImageData::getWidth(), ossimSource::isSourceEnabled(), OSSIM_EMPTY, OSSIM_NULL, OSSIM_UCHAR, ossimImageData::setImageRectangle(), theBlankTile, ossimImageSourceFilter::theInputConnection, theTile, ossimRefPtr< T >::valid(), and ossimImageData::validate().
44 {
46  {
47  return ossimRefPtr<ossimImageData>(); // This filter requires an input.
48  }
49
51  resLevel);
52  if(!isSourceEnabled() || !inputTile.valid())
53  {
54  return inputTile;
55  }
56
57  if(!theTile)
58  {
59  allocate(); // First time through...
60  }
61
62  if (!theTile.valid())
63  {
64  return inputTile;
65  }
66
67  if( inputTile->getDataObjectStatus() == OSSIM_NULL ||
68  inputTile->getDataObjectStatus() == OSSIM_EMPTY )
69  {
71  return theBlankTile;
72  }
73
74  if((inputTile->getNumberOfBands()==3)&&
75  (inputTile->getScalarType()==OSSIM_UCHAR)&&
76  (inputTile->getDataObjectStatus()!=OSSIM_NULL))
77  {
78  // Set the origin, resize if needed of the output tile.
79  theTile->setImageRectangle(tileRect);
80
81  float* outputBands[3];
82  ossim_uint8* inputBands[3];
83  outputBands[0] = static_cast<float*>(theTile->getBuf(0));
84  outputBands[1] = static_cast<float*>(theTile->getBuf(1));
85  outputBands[2] = static_cast<float*>(theTile->getBuf(2));
86  inputBands[0] = static_cast<ossim_uint8*>(inputTile->getBuf(0));
87  inputBands[1] = static_cast<ossim_uint8*>(inputTile->getBuf(1));
88  inputBands[2] = static_cast<ossim_uint8*>(inputTile->getBuf(2));
89
90  long height = inputTile->getHeight();
91  long width = inputTile->getWidth();
92  long offset = 0;
93  for(long row = 0; row < height; ++row)
94  {
95  for(long col = 0; col < width; ++col)
96  {
97  ossimRgbVector rgb(inputBands[0][offset],
98  inputBands[1][offset],
99  inputBands[2][offset]);
100
101  ossimHsiVector hsi(rgb);
102
103
104  outputBands[0][offset] = hsi.getH();
105  outputBands[1][offset] = hsi.getS();
106  outputBands[2][offset] = hsi.getI();
107
108  ++offset;
109  }
110  }
111  }
112  else // Input tile not of correct type to process...
113  {
114  return inputTile;
115  }
116
117  theTile->validate();
118  return theTile;
119 }
bool valid() const
Definition: ossimRefPtr.h:75
void allocate()
unsigned char ossim_uint8
8 bit unsigned iteger
◆ initialize()
void ossimRgbToHsiSource::initialize ( )
virtual
Definition at line 126 of file ossimRgbToHsiSource.cpp.
References ossimImageSourceFilter::initialize().
127 {
128  // Base class will recapture "theInputConnection".
130 }
Member Data Documentation
◆ theBlankTile
ossimRefPtr<ossimImageData> ossimRgbToHsiSource::theBlankTile
protected
Definition at line 41 of file ossimRgbToHsiSource.h.
Referenced by allocate(), and getTile().
◆ theTile
ossimRefPtr<ossimImageData> ossimRgbToHsiSource::theTile
protected
Definition at line 42 of file ossimRgbToHsiSource.h.
