Public Member Functions | Protected Member Functions | Private Member Functions | Private Attributes | List of all members
ossimShiftFilter Class Reference
Class to shift/stretch input values to given min/max. More...
#include <ossimShiftFilter.h>
Inheritance diagram for ossimShiftFilter:
ossimImageSourceFilter ossimImageSource ossimConnectableObjectListener ossimSource ossimListener ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
 ossimShiftFilter ()
 default constructor More...
virtual void initialize ()
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0)
virtual double getNullPixelValue (ossim_uint32 band) const
virtual double getMinPixelValue (ossim_uint32 band) const
virtual double getMaxPixelValue (ossim_uint32 band) const
void setNullPixelValue (double null)
 Set the null output pixel. More...
void setMinPixelValue (double min)
 Set the min output pixel. More...
void setMaxPixelValue (double max)
 Set the max output pixel. More...
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ProcessEvent. More...
 ossimListener ()
virtual ~ossimListener ()
void enableListener ()
void disableListener ()
virtual ~ossimShiftFilter ()
 virtual protected destructor More...
virtual ~ossimReferenced ()
 ossimShiftFilter (const ossimShiftFilter &)
 Private to disallow use... More...
ossimShiftFilteroperator= (const ossimShiftFilter &)
void allocate ()
 Allocates the tile. More...
template<class T >
void fillTile (T dummy, const ossimImageData *inputTile, ossimImageData *outputTile) const
 Template to fill the tile. More...
Private Attributes
double m_min
double m_max
double m_null
Additional Inherited Members
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
bool theListenerEnableFlag
Detailed Description
Callers must set the min, max, null output values. Input data shifted stretch base on:
pix = outMin + (inPix - inMin) * (outMax-outMin)/(inMax-inMin)
See ossim-shift-filter-test.cpp for concrete example of usage.
Definition at line 32 of file ossimShiftFilter.h.
◆ ossimShiftFilter() [1/2]
ossimShiftFilter::ossimShiftFilter ( )
default constructor
Definition at line 26 of file ossimShiftFilter.cpp.
27  :
28  ossimImageSourceFilter(), // base class
29  m_tile(0),
30  m_min(ossim::nan()),
31  m_max(ossim::nan()),
33 {
34  if (traceDebug())
35  {
37  << "ossimShiftFilter::ossimShiftFilter entered...\n";
38  }
39 }
ossimImageSourceFilter(ossimObject *owner=NULL)
double nan()
Definition: ossimCommon.h:135
ossimRefPtr< ossimImageData > m_tile
◆ ~ossimShiftFilter()
ossimShiftFilter::~ossimShiftFilter ( )
protectedvirtual
Definition at line 41 of file ossimShiftFilter.cpp.
42 {
43 }
◆ ossimShiftFilter() [2/2]
ossimShiftFilter::ossimShiftFilter ( const ossimShiftFilter )
private
Definition at line 304 of file ossimShiftFilter.cpp.
305 : m_min(0),m_max(0),m_null(0)
306 {
307 }
Member Function Documentation
◆ allocate()
void ossimShiftFilter::allocate ( )
private
Allocates the tile.
Called on first getTile.
Definition at line 297 of file ossimShiftFilter.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), and m_tile.
Referenced by getTile().
298 {
300  m_tile->initialize();
301 }
virtual void initialize()
Initialize the data buffer.
◆ fillTile()
template<class T >
void ossimShiftFilter::fillTile ( dummy,
const ossimImageData inputTile,
ossimImageData outputTile
) const
private
Parameters
dummytemplate type.
inputTile
outputTile
Definition at line 176 of file ossimShiftFilter.cpp.
References ossimImageData::getBuf(), ossimImageData::getMaxPix(), ossimImageData::getMinPix(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getSizePerBand(), m_max, m_min, m_null, and ossimImageData::validate().
179 {
180  const double BANDS = inputTile->getNumberOfBands();
181  const ossim_uint32 SPB = inputTile->getSizePerBand();
182  std::vector<double> inNull(BANDS);
183  std::vector<double> inMin(BANDS);
184  std::vector<double> inMax(BANDS);
185  std::vector<double> coef(BANDS);
186  ossim_uint32 band = 0;
187
188  for( ; band < BANDS; ++band )
189  {
190  inNull[band] = inputTile->getNullPix(band);
191  inMin[band] = inputTile->getMinPix(band);
192  inMax[band] = inputTile->getMaxPix(band);
193  coef[band] = (m_max-m_min)/(inMax[band]-inMin[band]);
194  }
195
196  double pix = 0;
197  for( band = 0; band < BANDS; ++band )
198  {
199  const T* inBuf = static_cast<const T*>(inputTile->getBuf(band));
200  T* outBuf = static_cast<T*>(outputTile->getBuf(band));
201
202  for ( ossim_uint32 i = 0; i < SPB; ++i )
203  {
204  pix = inBuf[i];
205  if ( pix == inNull[band] )
206  {
207  pix = m_null;
208  }
209  else
210  {
211  // Shift and multiply:
212  pix = m_min + (pix - inMin[band]) * coef[band];
213
214  // Range check:
215  pix = pix <= m_max ? (pix >= m_min ? pix : m_min) : m_max;
216  }
217
218  outBuf[i] = static_cast<T>(pix);
219  }
220  }
221
222  outputTile->validate();
223 }
virtual const ossim_float64 * getMaxPix() const
virtual ossim_uint32 getSizePerBand() const
Returns the number of pixels in a single band in a tile.
unsigned int ossim_uint32
virtual const ossim_float64 * getNullPix() const
virtual const ossim_float64 * getMinPix() const
◆ getClassName()
ossimString ossimShiftFilter::getClassName ( ) const
virtual
Returns
"ossimShiftFilter"
Definition at line 225 of file ossimShiftFilter.cpp.
226 {
227  return ossimString("ossimShiftFilter");
228 }
◆ getLongName()
ossimString ossimShiftFilter::getLongName ( ) const
virtual
Returns
"OSSIM shift filter"
Definition at line 230 of file ossimShiftFilter.cpp.
231 {
232  return ossimString("OSSIM shift filter");
233 }
◆ getMaxPixelValue()
double ossimShiftFilter::getMaxPixelValue ( ossim_uint32  band) const
virtual
Returns
The max pixel of the band.
Definition at line 268 of file ossimShiftFilter.cpp.
References ossimImageSource::getMaxPixelValue(), ossim::isnan(), m_max, and ossimSource::theEnableFlag.
269 {
270  double result = 0;;
271  if ( theEnableFlag && !ossim::isnan(m_max) )
272  {
273  result = m_max;
274  }
275  else
276  {
278  }
279  return result;
280 }
bool theEnableFlag
Definition: ossimSource.h:62
bool isnan(const float &v)
Definition: ossimCommon.h:91
◆ getMinPixelValue()
double ossimShiftFilter::getMinPixelValue ( ossim_uint32  band) const
virtual
Returns
The min pixel of the band.
Definition at line 254 of file ossimShiftFilter.cpp.
References ossimImageSource::getMinPixelValue(), ossim::isnan(), m_min, and ossimSource::theEnableFlag.
255 {
256  double result = 0;;
257  if ( theEnableFlag && !ossim::isnan(m_min) )
258  {
259  result = m_min;
260  }
261  else
262  {
264  }
265  return result;
266 }
bool theEnableFlag
◆ getNullPixelValue()
double ossimShiftFilter::getNullPixelValue ( ossim_uint32  band) const
virtual
Returns
The null pixel of the band.
Definition at line 240 of file ossimShiftFilter.cpp.
References ossimImageSource::getNullPixelValue(), ossim::isnan(), m_null, and ossimSource::theEnableFlag.
241 {
242  double result = 0;;
243  if ( theEnableFlag && !ossim::isnan(m_null) )
244  {
245  result = m_null;
246  }
247  else
248  {
250  }
251  return result;
252 }
bool theEnableFlag
◆ getShortName()
ossimString ossimShiftFilter::getShortName ( ) const
virtual
Returns
"shift filter"
Definition at line 235 of file ossimShiftFilter.cpp.
236 {
237  return ossimString("shift filter");
238 }
◆ getTile()
ossimRefPtr< ossimImageData > ossimShiftFilter::getTile ( const ossimIrect rect,
ossim_uint32  resLevel = 0
virtual
Returns
Definition at line 66 of file ossimShiftFilter.cpp.
References allocate(), fillTile(), ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossim::isnan(), ossimSource::isSourceEnabled(), m_max, m_min, m_null, m_tile, ossimImageData::makeBlank(), OSSIM_EMPTY, OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_NULL, OSSIM_SCALAR_UNKNOWN, OSSIM_SINT16, OSSIM_SINT32, OSSIM_SINT8, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setImageRectangle(), ossimImageSourceFilter::theInputConnection, and ossimImageData::validate().
69 {
70  ossimRefPtr<ossimImageData> result = 0;
71
72  if ( theInputConnection )
73  {
74  ossimRefPtr<ossimImageData> inputTile = theInputConnection->getTile( tileRect, resLevel );
75
76  if ( inputTile.get() && isSourceEnabled() &&
78  {
79  // Get its status of the input tile.
80  ossimDataObjectStatus tile_status = inputTile->getDataObjectStatus();
81
82  if ( tile_status != OSSIM_NULL )
83  {
84  if ( !m_tile )
85  {
86  allocate(); // First time through.
87  }
88
89  if ( tile_status != OSSIM_EMPTY )
90  {
91  // Set the origin,bands of the output tile.
92  m_tile->setImageRectangle(tileRect);
93
94  switch(inputTile->getScalarType())
95  {
96  case OSSIM_UINT8:
97  {
98  fillTile( ossim_uint8(0), inputTile.get(), m_tile.get() );
99  break;
100  }
101  case OSSIM_SINT8:
102  {
103  fillTile( ossim_sint8(0), inputTile.get(), m_tile.get() );
104  break;
105  }
106  case OSSIM_UINT16:
107  case OSSIM_USHORT11:
108  case OSSIM_USHORT12:
109  case OSSIM_USHORT13:
110  case OSSIM_USHORT14:
111  case OSSIM_USHORT15:
112  {
113  fillTile( ossim_uint16(0), inputTile.get(), m_tile.get() );
114  break;
115  }
116  case OSSIM_SINT16:
117  {
118  fillTile( ossim_sint16(0), inputTile.get(), m_tile.get() );
119  break;
120  }
121  case OSSIM_SINT32:
122  {
123  fillTile( ossim_sint32(0), inputTile.get(), m_tile.get() );
124  break;
125  }
126  case OSSIM_UINT32:
127  {
128  fillTile( ossim_uint32(0), inputTile.get(), m_tile.get() );
129  break;
130  }
131  case OSSIM_FLOAT32:
133  {
134  fillTile( ossim_float32(0), inputTile.get(), m_tile.get() );
135  break;
136  }
137  case OSSIM_FLOAT64:
139  {
140  fillTile( ossim_float64(0), inputTile.get(), m_tile.get() );
141  break;
142  }
144  default:
145  {
147  << "ossimShiftFilter::getTile ERROR Unhandled scalar!" << endl;
148  break;
149  }
150
151  } // Matches: switch(inputTile->getScalarType())
152
153  m_tile->validate();
154  }
155  else
156  {
157  m_tile->makeBlank();
158  }
159
160  result = m_tile;
161
162  } // Matches: if ( tile_status != OSSIM_NULL )
163
164  } // Matches: if ( inputTile.get() ... )
165
166  if ( !result && inputTile.get() )
167  {
168  result = inputTile;
169  }
170
171  } // Matches: if ( theInputConnection )
172
173  return result;
174 }
8 bit signed integer
64 bit floating point
16 bit unsigned integer
float ossim_float32
16 bit signed integer
signed char ossim_sint8
32 bit floating point
unsigned short ossim_uint16
32 bit unsigned integer
double ossim_float64
signed short ossim_sint16
32 bit signed integer
signed int ossim_sint32
void allocate()
Allocates the tile.
virtual void makeBlank()
8 bit unsigned integer
Definitions for data object status.
void fillTile(T dummy, const ossimImageData *inputTile, ossimImageData *outputTile) const
unsigned char ossim_uint8
◆ initialize()
void ossimShiftFilter::initialize ( )
virtual
Definition at line 45 of file ossimShiftFilter.cpp.
46 {
47  if (traceDebug())
48  {
50  << "ossimShiftFilter::initialize entered..." << endl;
51  }
52
53  //---
54  // Call the base class initialize.
55  // Note: This will reset "theInputConnection" if it changed...
56  //---
58
59  if (traceDebug())
60  {
62  << "ossimShiftFilter::initialize exited..." << endl;
63  }
64 }
◆ operator=()
ossimShiftFilter & ossimShiftFilter::operator= ( const ossimShiftFilter )
private
Definition at line 310 of file ossimShiftFilter.cpp.
311 {
312  return *this;
313 }
◆ setMaxPixelValue()
void ossimShiftFilter::setMaxPixelValue ( double  max)
Definition at line 292 of file ossimShiftFilter.cpp.
References m_max, and max.
Referenced by ossimHdf5Tool::initProcessingChain().
293 {
294  m_max = max;
295 }
#define max(a, b)
Definition: auxiliary.h:76
◆ setMinPixelValue()
void ossimShiftFilter::setMinPixelValue ( double  min)
Definition at line 287 of file ossimShiftFilter.cpp.
References m_min, and min.
288 {
289  m_min = min;
290 }
#define min(a, b)
Definition: auxiliary.h:75
◆ setNullPixelValue()
void ossimShiftFilter::setNullPixelValue ( double  null)
Definition at line 282 of file ossimShiftFilter.cpp.
References m_null.
283 {
284  m_null = null;
285 }
Member Data Documentation
◆ m_max
double ossimShiftFilter::m_max
private
Definition at line 99 of file ossimShiftFilter.h.
Referenced by fillTile(), getMaxPixelValue(), getTile(), and setMaxPixelValue().
◆ m_min
double ossimShiftFilter::m_min
private
Definition at line 98 of file ossimShiftFilter.h.
Referenced by fillTile(), getMinPixelValue(), getTile(), and setMinPixelValue().
◆ m_null
double ossimShiftFilter::m_null
private
Definition at line 100 of file ossimShiftFilter.h.
Referenced by fillTile(), getNullPixelValue(), getTile(), and setNullPixelValue().
◆ m_tile
ossimRefPtr<ossimImageData> ossimShiftFilter::m_tile
private
Definition at line 97 of file ossimShiftFilter.h.
Referenced by allocate(), and getTile().
