ossimVideoImageSource Class Referenceabstract
Contains class declaration for ossimVideoImageSource. More...
#include <ossimVideoImageSource.h>
Inheritance diagram for ossimVideoImageSource:
ossimImageSource ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced
Public Member Functions
virtual bool setFrameTime (const double &t)
 Sets the time stamp (in seconds from start of video) for the frame of interest. More...
virtual ossim_uint32 getNumberOfLines (ossim_uint32 resLevel=0) const
 Changes the frame to the new index (frame count from start of video). More...
virtual ossim_uint32 getNumberOfSamples (ossim_uint32 resLevel=0) const
 Currently assuming all videos are 8-bit RGB. More...
virtual ossimRefPtr< ossimImageDatagetTile (const ossimIrect &rect, ossim_uint32 resLevel=0)=0
virtual bool canConnectMyInputTo (ossim_int32 index, const ossimConnectableObject *object) const
 From ossimConnectableObject base class. Returns true if object is an ossimVideoSource. More...
 Video frames have no overviews, only full-res. More...
virtual ~ossimImageSource ()
 Method to get a tile. More...
 For RTTI support. More...
 Initializes bandList. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
Protected Member Functions
 ossimVideoImageSource (ossimVideoSource *video, const double &frame_time_seconds=0)
 Constructor used when accessing a common video object (versus instantiating a new video for each frame. More...
 ossimVideoImageSource ()
 Default Constructor. More...
virtual void initialize ()
 Common initialization code for all construction methods. More...
virtual ~ossimReferenced ()
Protected Attributes
double m_frameTime
 seconds from start of video More...
ossimIrect m_frameRect
 Always (0,0) based. More...
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Additional Inherited Members
Detailed Description
This is the ossimImageSource-derived class representing a single frame in a video stream.
Definition at line 27 of file ossimVideoImageSource.h.
◆ ossimVideoImageSource() [1/2]
ossimVideoImageSource::ossimVideoImageSource ( ossimVideoSource video,
const double &  frame_time_seconds = 0
protected
Definition at line 33 of file ossimVideoImageSource.cpp.
References initialize(), and setFrameTime().
35 : m_frameTime (-1.0)
36 {
37  initialize();
38  setFrameTime(frame_time_seconds);
39 }
double m_frameTime
virtual void initialize()
virtual bool setFrameTime(const double &t)
◆ ossimVideoImageSource() [2/2]
ossimVideoImageSource::ossimVideoImageSource ( )
protected
Definition at line 24 of file ossimVideoImageSource.cpp.
25 : m_frameTime (-1.0)
26 {
27 }
double m_frameTime
Member Function Documentation
◆ canConnectMyInputTo()
bool ossimVideoImageSource::canConnectMyInputTo ( ossim_int32  index,
const ossimConnectableObject object
) const
virtual
Implements ossimConnectableObject.
Definition at line 189 of file ossimVideoImageSource.cpp.
References PTR_CAST.
191 {
192  return ( (!object || PTR_CAST(ossimVideoSource, object)) && (inputIndex == 0) );
193 }
Pure virtual base class for all video sources – analogous to ossimImageSource.
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
◆ getDecimationFactor()
void ossimVideoImageSource::getDecimationFactor ( ossim_uint32  resLevel,
ossimDpt result
) const
virtual
Definition at line 198 of file ossimVideoImageSource.cpp.
199 {
200  result = ossimDpt(0.0, 0.0);
201  if (resLevel == 0)
202  result = ossimDpt(1.0, 1.0);
203 }
◆ getDecimationFactors()
void ossimVideoImageSource::getDecimationFactors ( std::vector< ossimDpt > &  decimations) const
virtual
Definition at line 208 of file ossimVideoImageSource.cpp.
209 {
210  decimations.clear();
211  decimations.push_back(ossimDpt(1.0, 1.0));
212 }
◆ getImageGeometry()
ossimRefPtr< ossimImageGeometry > ossimVideoImageSource::getImageGeometry ( )
virtual
Returns the image geometry object associated with this tile source or NULL if not defined.
The geometry contains full-to-local image transform as well as projection (image-to-world). Default implementation returns the image geometry object associated with the next
(left) input source (if any) connected to this source in the chain, or NULL.
Definition at line 173 of file ossimVideoImageSource.cpp.
References ossimVideoGeometry::getImageGeometry(), ossimConnectableObject::getInput(), ossimVideoSource::getVideoGeometry(), m_frameTime, and ossimRefPtr< T >::valid().
174 {
175  ossimVideoSource* video = dynamic_cast<ossimVideoSource*>(getInput());
176  if (!video)
177  return NULL;
178
179  ossimRefPtr<ossimVideoGeometry> video_geometry = video->getVideoGeometry();
180  if (!video_geometry.valid())
181  return NULL;
182
183  return video_geometry->getImageGeometry(m_frameTime);
184 }
bool valid() const
Definition: ossimRefPtr.h:75
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry(const double &t)=0
Provides an image geometry object for frame at specified time in seconds since start of sequence...
virtual const ossimRefPtr< ossimVideoGeometry > getVideoGeometry() const
Access to video geometry object.
double m_frameTime
◆ getImageTileHeight()
virtual ossim_uint32 ossimVideoImageSource::getImageTileHeight ( ) const
inlinevirtual
Definition at line 43 of file ossimVideoImageSource.h.
43 { return getNumberOfLines(); }
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const
◆ getImageTileWidth()
virtual ossim_uint32 ossimVideoImageSource::getImageTileWidth ( ) const
inlinevirtual
Definition at line 42 of file ossimVideoImageSource.h.
42 { return getNumberOfSamples(); }
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const
◆ getNumberOfDecimationLevels()
virtual ossim_uint32 ossimVideoImageSource::getNumberOfDecimationLevels ( ) const
inlinevirtual
Definition at line 58 of file ossimVideoImageSource.h.
58 { return 1; }
◆ getNumberOfInputBands()
virtual ossim_uint32 ossimVideoImageSource::getNumberOfInputBands ( ) const
inlinevirtual
Implements ossimImageSource.
Definition at line 46 of file ossimVideoImageSource.h.
46 { return 3; }
◆ getNumberOfLines()
ossim_uint32 ossimVideoImageSource::getNumberOfLines ( ossim_uint32  resLevel = 0) const
virtual
This will necessarily change the image geometry. Returns false if frame count is outside of allowable range.
Definition at line 149 of file ossimVideoImageSource.cpp.
References ossimIrect::height(), and m_frameRect.
150 {
151  // Only full-image res level = 0 presently supported:
152  if (resLevel != 0)
153  return 0;
154
155  return m_frameRect.height();
156 }
ossim_uint32 height() const
Definition: ossimIrect.h:487
Always (0,0) based.
◆ getNumberOfOutputBands()
virtual ossim_uint32 ossimVideoImageSource::getNumberOfOutputBands ( ) const
inlinevirtual
Definition at line 47 of file ossimVideoImageSource.h.
47 { return 3; }
◆ getNumberOfSamples()
ossim_uint32 ossimVideoImageSource::getNumberOfSamples ( ossim_uint32  resLevel = 0) const
virtual
Definition at line 161 of file ossimVideoImageSource.cpp.
References m_frameRect, and ossimIrect::width().
162 {
163  // Only full-image res level = 0 presently supported:
164  if (resLevel != 0)
165  return 0;
166
167  return m_frameRect.width();
168 }
Always (0,0) based.
ossim_uint32 width() const
Definition: ossimIrect.h:500
◆ getOutputScalarType()
virtual ossimScalarType ossimVideoImageSource::getOutputScalarType ( ) const
inlinevirtual
Definition at line 48 of file ossimVideoImageSource.h.
References OSSIM_UINT8.
48 { return OSSIM_UINT8; }
8 bit unsigned integer
◆ getTile()
virtual ossimRefPtr<ossimImageData> ossimVideoImageSource::getTile ( const ossimIrect rect,
pure virtual
Returns
◆ initialize()
void ossimVideoImageSource::initialize ( )
protectedvirtual
Definition at line 44 of file ossimVideoImageSource.cpp.
References ossimImageDataFactory::create(), ossimVideoSource::frameSize(), ossimConnectableObject::getInput(), ossimImageData::initialize(), ossimImageDataFactory::instance(), m_frameRect, m_tile, ossimImageData::setHeight(), and ossimImageData::setWidth().
Referenced by ossimVideoImageSource().
45 {
46  ossimVideoSource* video = dynamic_cast<ossimVideoSource*>(getInput());
47  if (!video)
48  return;
49
50  // Establish the frame rect:
51  ossimIpt frame_size (video->frameSize());
52  m_frameRect = ossimIrect(0, 0, frame_size.x-1, frame_size.y-1);
53
54  // Initialize the tile data buffer:
56  m_tile->setWidth(frame_size.x);
57
58  m_tile->setHeight(frame_size.y);
59  m_tile->initialize();
60 }
const ossimIpt & frameSize() const
Nominal size of a frame in pixels.
Initialize the data buffer.
virtual void setHeight(ossim_uint32 height)
ossimRefPtr< ossimImageData > m_tile
Always (0,0) based.
virtual void setWidth(ossim_uint32 width)
◆ setFrameTime()
bool ossimVideoImageSource::setFrameTime ( const double &  t)
virtual
Returns false if frame time is outside of allowable range.
This will necessarily change the image geometry. Returns false if frame time is outside of allowable range.
Definition at line 122 of file ossimVideoImageSource.cpp.
References ossimVideoSource::duration(), ossimConnectableObject::getInput(), m_frameTime, ossimVideoSource::seek(), and ossimVideoSource::SEEK_ABSOLUTE.
123 {
124  ossimVideoSource* video = dynamic_cast<ossimVideoSource*>(getInput());
125  if (!video)
126  return false;
127
128  // If the requested frame number corresponds with the current active frame, we're done:
129  if (frameTime == m_frameTime)
130  return true;
131
132  // Check that it is not past the last frame. Use video geometry's duration as it is more accurate
133  m_frameTime = frameTime;
134  if (m_frameTime > video->duration())
135  {
136  m_frameTime = 0;
137  return false;
138  }
139
140  // Seek to that frame:
142
143  return true;
144 }
virtual ossim_float64 duration() const
Total length of video in seconds.
virtual bool seek(ossim_float64 reference_time_sec, SeekType seekType)
Seeks to the frame at time specified, according to the seekType (relative to active frame or absolute...
double m_frameTime
Member Data Documentation
◆ m_frameRect
ossimIrect ossimVideoImageSource::m_frameRect
protected
Always (0,0) based.
Definition at line 72 of file ossimVideoImageSource.h.
Referenced by getNumberOfLines(), getNumberOfSamples(), and initialize().
◆ m_frameTime
double ossimVideoImageSource::m_frameTime
protected
Definition at line 71 of file ossimVideoImageSource.h.
Referenced by getImageGeometry(), and setFrameTime().
◆ m_tile
ossimRefPtr<ossimImageData> ossimVideoImageSource::m_tile
protected
Definition at line 73 of file ossimVideoImageSource.h.
Referenced by initialize().
