Public Types | Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ossimVideoSource Class Reference
Pure virtual base class for all video sources – analogous to ossimImageSource. More...
#include <ossimVideoSource.h>
Inheritance diagram for ossimVideoSource:
ossimSource ossimConnectableObject ossimErrorStatusInterface ossimObject ossimListenerManager ossimPropertyInterface ossimReferenced ossimVideoHandler
Public Types
enum  SeekType { SEEK_NONE = 0, SEEK_RELATIVE = 1, SEEK_ABSOLUTE = 2 }
virtual void rewind ()
 For rewinding all active streams to beginning. More...
virtual bool seek (ossim_float64 reference_time_sec, SeekType seekType)
 Seeks to the frame at time specified, according to the seekType (relative to active frame or absolute time from start of video). More...
virtual bool nextFrame ()
 Seeks to start of next frame. Returns TRUE if successful. More...
virtual ossim_float64 duration () const
 Total length of video in seconds. More...
virtual ossim_uint32 getNumberOfFrames () const
 Total number of frames in video. More...
virtual ossim_float64 currentFrameTime () const
 Time in seconds from start of video of the current active frame, or NAN if no active frame. More...
virtual ossim_float64 videoFrameRate () const
 Nominal frames per second. More...
int computeFrameNumber (double seconds_from_start) const
 Utility method for computing frame number from frame time. More...
double computeFrameTime (ossim_uint32 frame_count) const
 Utility method for computing frame time from frame number. More...
virtual const ossimRefPtr< ossimVideoGeometrygetVideoGeometry () const
 Access to video geometry object. More...
virtual const ossimRefPtr< ossimVideoImageHandlergetCurrentFrame () const
 Access to current active frame. More...
const ossimIptframeSize () const
 Nominal size of a frame in pixels. More...
virtual bool canConnectMyInputTo (ossim_int32 index, const ossimConnectableObject *object) const
 Connections only to other video sources are allowed. More...
virtual bool canConnectMyOutputTo (ossim_int32 index, const ossimConnectableObject *object) const
 Presently can only connect into an image chain via an ossimVideoImageSource bridge, or to another video source for video chains. More...
virtual ~ossimSource ()
virtual void enableSource ()
virtual void disableSource ()
virtual void initialize ()
const ossimIdgetId () const
 ossimObject ()
virtual ~ossimObject ()
 ossimReferenced ()
void ref () const
void unref () const
void unref_nodelete () const
int referenceCount () const
 ossimListenerManager ()
 ossimPropertyInterface ()
 ossimErrorStatusInterface ()
bool hasError () const
 ossimVideoSource ()
 Default constructor. More...
virtual ~ossimReferenced ()
ossimIpt m_frameSize
 in pixels More...
bool theEnableFlag
bool theInitializedFlag
ossimId theId
ossimString theDescription
ossimObjecttheOwner
bool theInputListIsFixedFlag
bool theOutputListIsFixedFlag
bool theEnabledFlag
bool theFireEventFlag
ossimErrorCode theErrorStatus
Detailed Description
Definition at line 27 of file ossimVideoSource.h.
◆ SeekType
Enumerator
SEEK_NONE
SEEK_RELATIVE
SEEK_ABSOLUTE
Definition at line 31 of file ossimVideoSource.h.
◆ ossimVideoSource()
ossimVideoSource::ossimVideoSource ( )
protected
Definition at line 23 of file ossimVideoSource.cpp.
24 { }
Member Function Documentation
◆ canConnectMyInputTo()
bool ossimVideoSource::canConnectMyInputTo ( ossim_int32  index,
const ossimConnectableObject object
) const
virtual
Implements ossimConnectableObject.
Reimplemented in ossimVideoHandler.
Definition at line 155 of file ossimVideoSource.cpp.
References PTR_CAST.
157 {
158  if (object && (index == 0) && PTR_CAST(ossimVideoSource, object))
159  return true;
160  // else
161  return false;
162 }
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
◆ canConnectMyOutputTo()
bool ossimVideoSource::canConnectMyOutputTo ( ossim_int32  index,
) const
virtual
Returns TRUE if connection possible.
Reimplemented from ossimConnectableObject.
Definition at line 168 of file ossimVideoSource.cpp.
170 {
171  if (!object || (index != 0))
172  return false;
173
174  if (PTR_CAST(ossimVideoSource, object))
175  return true;
176
177  if (PTR_CAST(ossimVideoImageSource, object))
178  return true;
179
180  if (PTR_CAST(ossimVideoImageHandler, object))
181  return true;
182
183  return false;
184 }
Contains class declaration for ossimVideoImageSource.
OSSIM Image handler for video frames.
◆ computeFrameNumber()
int ossimVideoSource::computeFrameNumber ( double  seconds_from_start) const
Returns
Returns frame number corresponding to the time (sec) from start of video or -1 if time is outside valid window.
Definition at line 131 of file ossimVideoSource.cpp.
References videoFrameRate().
Referenced by ossimVideoImageHandler::getNumberOfEntries(), and getNumberOfFrames().
132 {
133  double frame_rate = videoFrameRate();
134  if (frame_rate > 0.0)
135  return (int) seconds_from_start*frame_rate;
136  // else
137  return -1;
138 }
virtual ossim_float64 videoFrameRate() const
◆ computeFrameTime()
double ossimVideoSource::computeFrameTime ( ossim_uint32  frame_count) const
Returns
Returns frame time (sec) from start of video corresponding to the frame count, or NaN if frame count is invalid.
Definition at line 143 of file ossimVideoSource.cpp.
References ossim::nan(), and videoFrameRate().
Referenced by ossimVideoImageHandler::getImageGeometry(), and ossimVideoImageHandler::setCurrentEntry().
144 {
145  double frame_rate = videoFrameRate();
146  if (frame_rate > 0.0)
147  return frame_count/frame_rate;
148  // else
149  return ossim::nan();
150 }
double nan()
Definition: ossimCommon.h:135
◆ currentFrameTime()
ossim_float64 ossimVideoSource::currentFrameTime ( ) const
virtual
Definition at line 76 of file ossimVideoSource.cpp.
References currentFrameTime(), ossimConnectableObject::getInput(), and PTR_CAST.
Referenced by currentFrameTime().
77 {
79  if (inter)
80  return inter->currentFrameTime();
81
82  return 0.0;
83 }
virtual ossim_float64 currentFrameTime() const
Time in seconds from start of video of the current active frame, or NAN if no active frame...
◆ duration()
ossim_float64 ossimVideoSource::duration ( ) const
virtual
Definition at line 64 of file ossimVideoSource.cpp.
References duration(), ossimConnectableObject::getInput(), and PTR_CAST.
Referenced by duration(), getNumberOfFrames(), and ossimVideoImageSource::setFrameTime().
65 {
67  if (inter)
68  return inter->duration();
69
70  return 0.0;
71 }
virtual ossim_float64 duration() const
◆ frameSize()
const ossimIpt& ossimVideoSource::frameSize ( ) const
inline
Definition at line 81 of file ossimVideoSource.h.
Referenced by ossimVideoImageHandler::getNumberOfLines(), ossimVideoImageHandler::getNumberOfSamples(), and ossimVideoImageSource::initialize().
81 { return m_frameSize; }
in pixels
◆ getCurrentFrame()
const ossimRefPtr< ossimVideoImageHandler > ossimVideoSource::getCurrentFrame ( ) const
virtual
Definition at line 112 of file ossimVideoSource.cpp.
113 {
114  //STUB
115  return NULL;
116 }
◆ getNumberOfFrames()
ossim_uint32 ossimVideoSource::getNumberOfFrames ( ) const
virtual
Definition at line 121 of file ossimVideoSource.cpp.
References computeFrameNumber(), and duration().
122 {
123  // Base class implementation just computes number of frames from duration:
125  return num_frames;
126 }
int computeFrameNumber(double seconds_from_start) const
unsigned int ossim_uint32
◆ getVideoGeometry()
const ossimRefPtr< ossimVideoGeometry > ossimVideoSource::getVideoGeometry ( ) const
virtual
Definition at line 100 of file ossimVideoSource.cpp.
References ossimConnectableObject::getInput(), getVideoGeometry(), and PTR_CAST.
Referenced by ossimVideoImageSource::getImageGeometry(), and getVideoGeometry().
101 {
103  if (inter)
104  return inter->getVideoGeometry();
105
106  return NULL;
107 }
virtual const ossimRefPtr< ossimVideoGeometry > getVideoGeometry() const
◆ nextFrame()
bool ossimVideoSource::nextFrame ( )
virtual
Definition at line 52 of file ossimVideoSource.cpp.
References ossimConnectableObject::getInput(), nextFrame(), and PTR_CAST.
Referenced by nextFrame().
53 {
55  if (inter)
56  return inter->nextFrame();
57
58  return false;
59 }
virtual bool nextFrame()
◆ rewind()
void ossimVideoSource::rewind ( )
virtual
Definition at line 29 of file ossimVideoSource.cpp.
References ossimConnectableObject::getInput(), PTR_CAST, and rewind().
Referenced by rewind().
30 {
32  if (inter)
33  inter->rewind();
34 }
virtual void rewind()
◆ seek()
bool ossimVideoSource::seek ( ossim_float64  reference_time_sec,
SeekType  seekType
virtual
Definition at line 40 of file ossimVideoSource.cpp.
References ossimConnectableObject::getInput(), PTR_CAST, and seek().
Referenced by seek(), and ossimVideoImageSource::setFrameTime().
41 {
43  if (inter)
44  return inter->seek(reference_time_sec, seekType);
45
46  return false;
47 }
virtual bool seek(ossim_float64 reference_time_sec, SeekType seekType)
Seeks to the frame at time specified, according to the seekType (relative to active frame or absolute...
◆ videoFrameRate()
ossim_float64 ossimVideoSource::videoFrameRate ( ) const
virtual
Definition at line 88 of file ossimVideoSource.cpp.
References ossimConnectableObject::getInput(), PTR_CAST, and videoFrameRate().
Referenced by computeFrameNumber(), computeFrameTime(), and videoFrameRate().
89 {
91  if (inter)
92  return inter->videoFrameRate();
93
94  return 0.0;
95 }
Member Data Documentation
◆ m_frameSize
ossimIpt ossimVideoSource::m_frameSize
protected
in pixels
Definition at line 97 of file ossimVideoSource.h.
