#include <ossimPleiadesModel.h>
ossimPleiadesModel () | |
default constructor More... | |
ossimPleiadesModel (const ossimPleiadesModel &rhs) | |
copy constructor More... | |
virtual | ~ossimPleiadesModel () |
Destructor. More... | |
bool | open (const ossimFilename &file) |
virtual ossimObject * | dup () const |
virtual std::ostream & | print (std::ostream &out) const |
virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
loadState Fulfills ossimObject base-class pure virtuals. More... | |
void | setSupportData (ossimPleiadesDimapSupportData *supportData) |
ossimPleiadesDimapSupportData * | getSupportData () |
const ossimPleiadesDimapSupportData * | getSupportData () const |
ossimRpcModel () | |
ossimRpcModel (const ossimRpcModel ©_this) | |
copy construtor More... | |
void | setAttributes (ossim_float64 theSampleOffset, ossim_float64 theLineOffset, ossim_float64 theSampleScale, ossim_float64 theLineScale, ossim_float64 theLatOffset, ossim_float64 theLonOffset, ossim_float64 theHeightOffset, ossim_float64 theLatScale, ossim_float64 theLonScale, ossim_float64 theHeightScale, const std::vector< double > &xNumeratorCoeffs, const std::vector< double > &xDenominatorCoeffs, const std::vector< double > &yNumeratorCoeffs, const std::vector< double > &yDenominatorCoeffs, PolynomialType polyType=B, bool computeGsdFlag=true) |
void | setMetersPerPixel (const ossimDpt &metersPerPixel) |
void | setPositionError (const ossim_float64 &biasError, const ossim_float64 &randomError, bool initNominalPostionErrorFlag) |
Sets data member theBiasError, theRandError. More... | |
virtual void | worldToLineSample (const ossimGpt &world_point, ossimDpt &image_point) const |
worldToLineSample() Overrides base class implementation. More... | |
virtual void | lineSampleToWorld (const ossimDpt &image_point, ossimGpt &world_point) const |
virtual void | lineSampleHeightToWorld (const ossimDpt &image_point, const double &heightEllipsoid, ossimGpt &worldPoint) const |
virtual void | imagingRay (const ossimDpt &image_point, ossimEcefRay &image_ray) const |
imagingRay() Overrides base class pure virtual. More... | |
virtual void | updateModel () |
virtual void | initAdjustableParameters () |
virtual bool | useForward () const |
virtual bool | setupOptimizer (const ossimString &init_file) |
uses file path to init model More... | |
virtual ossimDpt | getForwardDeriv (int parmIdx, const ossimGpt &gpos, double h) |
Compute partials of samp/line WRT ground point. More... | |
double | getBiasError () const |
Returns Error - Bias. More... | |
double | getRandError () const |
Returns Error - Random. More... | |
void | getRpcParameters (ossimRpcModel::rpcModelStruct &model) const |
Returns RPC parameter set in structure. More... | |
void | setImageOffset (const ossimDpt &offset_to_chip_ul) |
Allows setting an offset to a subimage while using the coefficients of a full-image model. More... | |
bool | toJSON (std::ostream &json) const |
Serializes RPC to JSON format. More... | |
bool | toRPB (std::ostream &out) const |
Serialize to WorldView-style .RPB file to the stream provided. More... | |
ossimSensorModel () | |
ossimSensorModel (const ossimSensorModel ©_this) | |
ossimSensorModel (const ossimKeywordlist &geom_kwl) | |
const ossimSensorModel & | operator= (const ossimSensorModel &rhs) |
assignment operator More... | |
virtual ossimObject * | getBaseObject () |
virtual const ossimObject * | getBaseObject () const |
virtual ossimGpt | origin () const |
virtual ossimDpt | getMetersPerPixel () const |
virtual const double & | getNominalPosError () const |
Returns the estimated Absolute horizontal position error (CE90) of the sensor model. More... | |
virtual const double & | getRelativePosError () const |
Returns the estimated RELATIVE horizontal position error (CE90) of the sensor model. More... | |
virtual void | setNominalPosError (const double &ce90) |
Assigns the absolute image position error uncertainty (abs CE90) More... | |
virtual void | setRelativePosError (const double &ce90) |
Assigns the relative image position error uncertainty (rel CE90) More... | |
void | setRefImgPt (const ossimDpt &pt) |
Sets the center line sampe of the image. More... | |
void | setRefGndPt (const ossimGpt &pt) |
Sets the center latitude, longitude, height of the image. More... | |
void | setImageRect (const ossimDrect &imageRect) |
void | setGroundRect (const ossimGpt &ul, const ossimGpt &ur, const ossimGpt &lr, const ossimGpt &ll) |
ossimDpt | imageSize () const |
void | setImageSize (const ossimDpt &size) |
virtual void | adjustableParametersChanged () |
virtual bool | insideImage (const ossimDpt &p) const |
virtual bool | operator== (const ossimProjection &proj) const |
const ossimString & | getImageID () const |
Access methods: More... | |
const ossimDrect & | getImageClipRect () const |
virtual ossim_uint32 | degreesOfFreedom () const |
virtual bool | needsInitialState () const |
needsInitialState() More... | |
virtual double | optimizeFit (const ossimTieGptSet &tieSet, double *targetVariance=0) |
virtual ossimGpt | getInverseDeriv (int parmIdx, const ossimDpt &ipos, double hdelta=1e-11) |
virtual ossimSensorModel::CovMatStatus | getObsCovMat (const ossimDpt &ipos, NEWMAT::SymmetricMatrix &Cov, const ossim_float64 defPointingSigma=0.5) const |
Gives 2X2 covariance matrix of observations. More... | |
virtual bool | isAffectedByElevation () const |
Implementation of pure virtual ossimProjection::isAffectedByElevation method. More... | |
void | computeGsd () |
This method computes the ground sample distance(gsd) and sets class attributes theGSD and theMeanGSD by doing a lineSampleHeightToWorld on four points and calculating the distance from them. More... | |
virtual bool | getImageGeometry (const ossimString &, const ossimString &, ossimKeywordlist &) const |
Extracts geometry info from a non-ossim key,value pair to an ossim keyword list. More... | |
ossimProjection () | |
virtual | ~ossimProjection () |
virtual ossimDpt | forward (const ossimGpt &wp) const |
virtual ossimGpt | inverse (const ossimDpt &pp) const |
virtual void | getRoundTripError (const ossimDpt &imagePoint, ossimDpt &errorResult) const |
virtual void | getRoundTripError (const ossimGpt &groundPoint, ossimDpt &errorResult) const |
virtual void | getGroundClipPoints (ossimGeoPolygon &gpts) const |
virtual bool | isEqualTo (const ossimObject &obj, ossimCompareType compareType=OSSIM_COMPARE_FULL) const |
virtual bool | operator!= (const ossimProjection &projection) const |
ossimObject () | |
virtual | ~ossimObject () |
virtual ossimString | getShortName () const |
virtual ossimString | getLongName () const |
virtual ossimString | getDescription () const |
virtual ossimString | getClassName () const |
virtual RTTItypeid | getType () const |
virtual bool | canCastTo (ossimObject *obj) const |
virtual bool | canCastTo (const RTTItypeid &id) const |
virtual bool | canCastTo (const ossimString &parentClassName) const |
virtual void | accept (ossimVisitor &visitor) |
ossimReferenced () | |
ossimReferenced (const ossimReferenced &) | |
ossimReferenced & | operator= (const ossimReferenced &) |
void | ref () const |
increment the reference count by one, indicating that this object has another pointer which is referencing it. More... | |
void | unref () const |
decrement the reference count by one, indicating that a pointer to this object is referencing it. More... | |
void | unref_nodelete () const |
int | referenceCount () const |
ossimErrorStatusInterface () | |
virtual | ~ossimErrorStatusInterface () |
virtual ossimErrorCode | getErrorStatus () const |
virtual ossimString | getErrorStatusString () const |
virtual void | setErrorStatus (ossimErrorCode error_status) const |
virtual void | setErrorStatus () const |
virtual void | clearErrorStatus () const |
bool | hasError () const |
ossimOptimizableProjection () | |
ossimOptimizableProjection (const ossimOptimizableProjection &source) | |
virtual | ~ossimOptimizableProjection () |
virtual ossimOptimizableProjection & | operator= (const ossimOptimizableProjection &source) |
ossimAdjustableParameterInterface () | |
ossimAdjustableParameterInterface (const ossimAdjustableParameterInterface &rhs) | |
virtual | ~ossimAdjustableParameterInterface () |
void | newAdjustment (ossim_uint32 numberOfParameters=0) |
void | setAdjustmentDescription (const ossimString &description) |
ossimString | getAdjustmentDescription () const |
ossimString | getAdjustmentDescription (ossim_uint32 adjustmentIdx) const |
Returns adjustmentDescription of specific adjustmentInfo. More... | |
void | setCurrentAdjustment (ossim_uint32 adjustmentIndex, bool notify=false) |
bool | setCurrentAdjustment (const ossimString &description, bool notify=false) |
Sets the current adjustment to the adjustment with a matching description. More... | |
void | eraseAdjustment (bool notify) |
void | eraseAdjustment (ossim_uint32 idx, bool notify) |
void | resetAdjustableParameters (bool notify=false) |
void | copyAdjustment (ossim_uint32 idx, bool notify) |
void | copyAdjustment (bool notify=false) |
void | keepAdjustment (ossim_uint32 idx, bool createCopy) |
virtual void | keepAdjustment (bool createCopy=true) |
const ossimAdjustableParameterInterface & | operator= (const ossimAdjustableParameterInterface &rhs) |
void | removeAllAdjustments () |
ossim_uint32 | getNumberOfAdjustableParameters () const |
double | getAdjustableParameter (ossim_uint32 idx) const |
virtual void | setAdjustableParameter (ossim_uint32 idx, double value, bool notify=false) |
virtual void | setAdjustableParameter (ossim_uint32 idx, double value, double sigma, bool notify=false) |
double | getParameterSigma (ossim_uint32 idx) const |
void | setParameterSigma (ossim_uint32 idx, double value, bool notify=false) |
ossimUnitType | getParameterUnit (ossim_uint32 idx) const |
void | setParameterUnit (ossim_uint32 idx, ossimUnitType unit) |
void | setParameterUnit (ossim_uint32 idx, const ossimString &unit) |
void | setParameterCenter (ossim_uint32 idx, double center, bool notify=false) |
double | getParameterCenter (ossim_uint32 idx) const |
double | computeParameterOffset (ossim_uint32 idx) const |
void | setParameterOffset (ossim_uint32 idx, ossim_float64 value, bool notify=false) |
ossimString | getParameterDescription (ossim_uint32 idx) const |
void | setParameterDescription (ossim_uint32 idx, const ossimString &descrption) |
ossim_int32 | findParameterIdxGivenDescription (ossim_uint32 adjustmentIdx, const ossimString &name) const |
ossim_int32 | findParameterIdxContainingDescription (ossim_uint32 adjustmentIdx, const ossimString &name) const |
bool | isParameterLocked (ossim_uint32 idx) const |
void | setParameterLockFlag (ossim_uint32 idxParam, bool flag) |
bool | getParameterLockFlag (ossim_uint32 idx) const |
void | lockAllParametersCurrentAdjustment () |
void | unlockAllParametersCurrentAdjustment () |
void | lockAllParameters (ossim_uint32 idxAdjustment) |
void | unlockAllParameters (ossim_uint32 idxAdjustment) |
void | resizeAdjustableParameterArray (ossim_uint32 numberOfParameters) |
void | setAdjustment (const ossimAdjustmentInfo &adj, bool notify=false) |
void | setAdjustment (ossim_uint32 idx, const ossimAdjustmentInfo &adj, bool notify=false) |
void | addAdjustment (const ossimAdjustmentInfo &adj, bool notify) |
void | getAdjustment (ossimAdjustmentInfo &adj) const |
void | getAdjustment (ossim_uint32 idx, ossimAdjustmentInfo &adj) const |
ossim_uint32 | getNumberOfAdjustments () const |
ossim_uint32 | getCurrentAdjustmentIdx () const |
void | setDirtyFlag (bool flag=true) |
void | setAllDirtyFlag (bool flag=true) |
bool | hasDirtyAdjustments () const |
virtual void | saveCurrentAdjustmentOnly (ossimKeywordlist &kwl, const ossimString &prefix=ossimString("")) |
Saves the current active adjustment to the KWL file. More... | |
bool | saveAdjustments (ossimKeywordlist &kwl, const ossimString &prefix=ossimString("")) const |
Save all adjustments to the KWL file. More... | |
bool | loadAdjustments (const ossimKeywordlist &kwl, const ossimString &prefix=ossimString("")) |
Dumps the currently active adjustment to ostream. More... | |
bool | parseMetaData (const ossimFilename &file) |
bool | parseRpcData (const ossimFilename &file) |
void | finishConstruction () |
Collects common code among all parsers. More... | |
virtual | ~ossimRpcModel () |
virtual destructor More... | |
double | polynomial (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
double | dPoly_dLat (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
double | dPoly_dLon (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
double | dPoly_dHgt (const double &nlat, const double &nlon, const double &nhgt, const double *coeffs) const |
virtual | ~ossimSensorModel () |
virtual ossimDpt | extrapolate (const ossimGpt &gp) const |
virtual ossimGpt | extrapolate (const ossimDpt &ip, const double &height=ossim::nan()) const |
void | buildNormalEquation (const ossimTieGptSet &tieSet, NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &residue, NEWMAT::ColumnVector &projResidue, double pstep_scale) |
NEWMAT::ColumnVector | getResidue (const ossimTieGptSet &tieSet) |
NEWMAT::ColumnVector | solveLeastSquares (NEWMAT::SymmetricMatrix &A, NEWMAT::ColumnVector &r) const |
NEWMAT::Matrix | invert (const NEWMAT::Matrix &m) const |
stable invert stolen from ossimRpcSolver More... | |
virtual | ~ossimReferenced () |
bool | paramChanged (ossim_uint32 param_idx) const |
Returns true if specified parameter has been modified since last setAllChangeFlag(false) call. More... | |
void | setAllChangeFlags (bool areChanged) |
Sets all the change flags to the boolean indicated to indicate parameters are changed (TRUE) or not (FALSE). More... | |
void | initChangeFlags () |
Initializes the change flags to TRUE. More... | |
enum | PolynomialType { A ='A', B ='B' } |
enum | CovMatStatus { COV_INVALID = 0, COV_PARTIAL = 1, COV_FULL = 2 } |
enum | DeriveMode { OBS_INIT =-99, EVALUATE =-98, P_WRT_X = -1, P_WRT_Y = -2, P_WRT_Z = -3 } |
static void | writeGeomTemplate (ostream &os) |
STATIC METHOD: writeGeomTemplate(ostream) Writes a template of geom keywords processed by loadState and saveState to output stream. More... | |
enum | AdjustParamIndex { INTRACK_OFFSET = 0, CRTRACK_OFFSET, INTRACK_SCALE, CRTRACK_SCALE, MAP_ROTATION, NUM_ADJUSTABLE_PARAMS } |
Definition at line 43 of file ossimPleiadesModel.h.
ossimplugins::ossimPleiadesModel::ossimPleiadesModel | ( | ) |
default constructor
CONSTRUCTORS:
Definition at line 61 of file ossimPleiadesModel.cpp.
References ossimRpcModel::theLineDenCoef, ossimRpcModel::theLineNumCoef, ossimRpcModel::theSampDenCoef, and ossimRpcModel::theSampNumCoef.
Referenced by dup().
ossimplugins::ossimPleiadesModel::ossimPleiadesModel | ( | const ossimPleiadesModel & | rhs | ) |
copy constructor
Definition at line 77 of file ossimPleiadesModel.cpp.
Destructor.
Definition at line 86 of file ossimPleiadesModel.cpp.
References ossimNotify(), ossimNotifyLevel_DEBUG, and theSupportData.
Returns pointer to a new instance, copy of this. Not implemented yet! Returns NULL...
Reimplemented from ossimRpcModel.
Definition at line 97 of file ossimPleiadesModel.cpp.
References ossimPleiadesModel().
protected |
Definition at line 355 of file ossimPleiadesModel.cpp.
References ossimSensorModel::computeGsd(), ossimDpt::hasNans(), ossimDrect::height(), ossimGpt::hgt, ossimGpt::lat, ossimIpt::line, ossimDpt::line, ossimRpcModel::lineSampleHeightToWorld(), ossimDrect::ll(), ossimGpt::lon, ossimDrect::lr(), ossimDrect::midPoint(), ossimNotify(), ossimNotifyLevel_WARN, ossimIpt::samp, ossimDpt::samp, ossimSensorModel::theBoundGndPolygon, ossimSensorModel::theGSD, ossimRpcModel::theHgtOffset, ossimSensorModel::theImageClipRect, ossimSensorModel::theImageSize, ossimRpcModel::theLatOffset, ossimRpcModel::theLonOffset, ossimSensorModel::theRefGndPt, ossimSensorModel::theRefImgPt, ossimDrect::ul(), ossimRpcModel::updateModel(), ossimDrect::ur(), ossimException::what(), ossimDrect::width(), ossimDpt::x, and ossimDpt::y.
Referenced by open().
inline |
Definition at line 85 of file ossimPleiadesModel.h.
inline |
Definition at line 89 of file ossimPleiadesModel.h.
Loads and saves geometry KWL files. Returns true if successful.
Definition at line 159 of file ossimPleiadesModel.cpp.
References ossimRpcModel::loadState(), and theSupportData.
bool ossimplugins::ossimPleiadesModel::open | ( | const ossimFilename & | file | ) |
Definition at line 186 of file ossimPleiadesModel.cpp.
References _productXmlFile, ossimSupportFilesList::add(), ossimRpcModel::B, ossimErrorStatusInterface::clearErrorStatus(), ossimFilename::dirCat(), ossimString::downcase(), ossimFilename::exists(), ossimFilename::ext(), ossimFilename::file(), finishConstruction(), ossimSupportFilesList::instance(), ossimDpt::makeNan(), ossimNotify(), ossimNotifyLevel_DEBUG, ossimNotifyLevel_WARN, ossimFilename::path(), ossimString::replaceStrThatMatch(), ossimFilename::setExtension(), ossimFilename::setFile(), ossimSensorModel::theGSD, ossimRpcModel::theHgtOffset, ossimRpcModel::theHgtScale, ossimSensorModel::theImageClipRect, ossimSensorModel::theImageID, ossimSensorModel::theImageSize, ossimRpcModel::theLatOffset, ossimRpcModel::theLatScale, ossimRpcModel::theLineDenCoef, ossimRpcModel::theLineNumCoef, ossimRpcModel::theLineOffset, ossimRpcModel::theLineScale, ossimRpcModel::theLonOffset, ossimRpcModel::theLonScale, ossimRpcModel::thePolyType, ossimRpcModel::theSampDenCoef, ossimRpcModel::theSampNumCoef, ossimRpcModel::theSampOffset, ossimRpcModel::theSampScale, ossimSensorModel::theSensorID, and theSupportData.
protected |
protected |
Extends base-class implementation. Dumps contents of object to ostream.
Definition at line 105 of file ossimPleiadesModel.cpp.
References ossimRpcModel::print(), ossimSensorModel::theImageID, ossimSensorModel::theImageSize, ossimSensorModel::theRefGndPt, ossimSensorModel::theRefImgPt, and theSupportData.
Fulfills ossimObject base-class pure virtuals. Loads and saves geometry KWL files. Returns true if successful.
Definition at line 133 of file ossimPleiadesModel.cpp.
References ossimKeywordlist::add(), ossimRpcModel::saveState(), ossimSensorModel::theSensorID, and theSupportData.
inline |
Definition at line 81 of file ossimPleiadesModel.h.
protected |
Definition at line 107 of file ossimPleiadesModel.h.
protected |
Definition at line 105 of file ossimPleiadesModel.h.
Referenced by loadState(), open(), print(), saveState(), and ~ossimPleiadesModel().
