ossimHdfReader.cpp
Go to the documentation of this file.
1 //----------------------------------------------------------------------------
2 //
3 // License: LGPL
4 //
5 // See LICENSE.txt file in the top level directory for more details.
6 //
7 // Description: Class definition for HDF reader.
8 //
9 //----------------------------------------------------------------------------
10 // $Id: ossimHdfReader.cpp 2645 2011-05-26 15:21:34Z oscar.kramer $
11
12 //Std includes
13 #include <set>
14
15 //ossim includes
16 #include <ossimHdfReader.h>
18 #include <ossim/base/ossimTrace.h>
22
23 #ifdef OSSIM_ID_ENABLED
24 static const char OSSIM_ID[] = "$Id";
25 #endif
26
27 static ossimTrace traceDebug("ossimHdfReader:debug");
28
30
32 {
33  return (fabs(left - right) < epsilon);
34 }
35
38  m_gdalTileSource(0),
39  m_entryFileList(),
40  m_numberOfBands(0),
41  m_scalarType(OSSIM_SCALAR_UNKNOWN),
42  m_currentEntryRender(0),
43  m_tile(0)
44 {
45 }
46
48 {
49  close();
51 }
52
54 {
55  return ossimString("ossim_hdf_reader");
56 }
57
59 {
60  return ossimString("ossim hdf reader");
61 }
62
64 {
65  return ossimString("ossimHdfReader");
66 }
67
69  ossim_uint32 resLevel) const
70 {
71  ossim_uint32 result = 0;
72  if (resLevel == 0)
73  {
74  if (m_gdalTileSource.valid())
75  {
76  result = m_gdalTileSource->getNumberOfLines(resLevel);
77  }
78  }
79  else if (theOverview.valid())
80  {
81  result = theOverview->getNumberOfSamples(resLevel);
82  }
83  return result;
84 }
85
87  ossim_uint32 resLevel) const
88 {
89  ossim_uint32 result = 0;
90  if (resLevel == 0)
91  {
92  if (m_gdalTileSource.valid())
93  {
94  result = m_gdalTileSource->getNumberOfSamples(resLevel);
95  }
96  }
97  else if (theOverview.valid())
98  {
99  result = theOverview->getNumberOfSamples(resLevel);
100  }
101  return result;
102 }
103
105 {
106  static const char MODULE[] = "ossimHdfReader::open";
107
108  if (traceDebug())
109  {
111  << MODULE << " entered...\n"
112  << "image: " << theImageFile << "\n";
113  }
114
115  bool result = false;
116
117  if (!isSupportedExtension())
118  {
119  return false;
120  }
121
122  if (m_entryFileList.size() == 0)
123  {
124  if(isOpen())
125  {
126  close();
127  }
128
131
132  if ( m_gdalTileSource->open() == false )
133  {
134  m_gdalTileSource = 0;
135  return false;
136  }
137
138  std::vector<ossimString> entryStringList;
139  if (m_gdalTileSource )
140  {
141  m_gdalTileSource->getEntryNames(entryStringList);
142  }
143
144  // bool isSwathImage = false;
145  if (entryStringList.size() > 0)
146  {
147  for (ossim_uint32 i = 0; i < entryStringList.size(); i++)
148  {
149  m_entryFileList.push_back(i);
150  }
151  }
152  else
153  {
154  result = false;
155  }
156  }
157
158  //set entry id for the gdal tile source
160  {
161
164
166  m_tile->initialize();
167
168  completeOpen();
169  result = true;
170  }
171  else
172  {
173  result = false;
174  }
175
176  if (result == false)
177  {
178  close();
179  }
180
181  if (traceDebug())
182  {
184  << MODULE << " exit status = " << (result?"true":"false\n")
185  << std::endl;
186  }
187
188  return result;
189 }
190
192 {
193  std::vector<ossimString> fileList = fileName.split(":");
194  if (fileList.size() > 0)
195  {
196  ossimString subName = fileList[0];
197  if (subName.contains("_SDS"))
198  {
199  return true;
200  }
201  }
202  return false;
203 }
204
206 {
207  return m_gdalTileSource.get();
208 }
209
211 {
212  m_tile = 0;
213
214  if (m_gdalTileSource.valid())
215  {
216  m_gdalTileSource = 0;
217  }
218  m_entryFileList.clear();
219 }
220
222  ossim_uint32 resLevel)
223 {
224  if (m_tile.valid())
225  {
226  // Image rectangle must be set prior to calling getTile.
227  m_tile->setImageRectangle(tile_rect);
228
229  if ( getTile( m_tile.get(), resLevel ) == false )
230  {
232  {
233  m_tile->makeBlank();
234  }
235  }
236  }
237
238  return m_tile;
239 }
240
242  ossim_uint32 resLevel)
243 {
244  bool status = false;
245
246  //---
247  // Not open, this tile source bypassed, or invalid res level,
248  // return a blank tile.
249  //---
250  if( isOpen() && isSourceEnabled() && isValidRLevel(resLevel) &&
251  result && (result->getNumberOfBands() == getNumberOfOutputBands()) )
252  {
253  result->ref(); // Increment ref count.
254
255  //---
256  // Check for overview tile. Some overviews can contain r0 so always
257  // call even if resLevel is 0. Method returns true on success, false
258  // on error.
259  //---
260  status = getOverviewTile(resLevel, result);
261
262  if (!status) // Did not get an overview tile.
263  {
264  status = true;
265
266  ossimIrect tile_rect = result->getImageRectangle();
267
268  if (getImageRectangle().intersects(tile_rect))
269  {
270  // Make a clip rect.
271  ossimIrect clipRect = tile_rect.clipToRect(getImageRectangle());
272
273  if (tile_rect.completely_within(clipRect) == false)
274  {
275  // Not filling whole tile so blank it out first.
276  result->makeBlank();
277  }
278
279  if (m_gdalTileSource.valid())
280  {
281  ossimRefPtr<ossimImageData> imageData =
282  m_gdalTileSource->getTile(tile_rect, resLevel);
283  result->loadTile(imageData->getBuf(), tile_rect, clipRect, OSSIM_BSQ);
284  }
285
286  }
287  else // No intersection...
288  {
289  result->makeBlank();
290  }
291  }
292  result->validate();
293
294  result->unref(); // Decrement ref count.
295  }
296
297  return status;
298 }
299
301 {
302  ossimString ext = theImageFile.ext();
303  ext.downcase();
304
305  if ( ext == "hdf" || ext == "h4" || ext == "hdf4" ||
306  ext == "he4" || ext == "hdf5" || ext == "he5" || ext == "h5" ||
307  ext == "l1r")
308  {
309  return true;
310  }
311  return false;
312 }
313
315 {
316  return m_numberOfBands;
317 }
318
320 {
321  return m_numberOfBands;
322 }
323
325 {
326  ossim_uint32 result = 128;
327  if (m_gdalTileSource.valid())
328  {
330  }
331  return result;
332 }
333
335 {
336  ossim_uint32 result = 128;
337  if (m_gdalTileSource.valid())
338  {
340  }
341  return result;
342 }
343
345 {
346  if (m_gdalTileSource.valid())
347  {
349  }
350  return m_scalarType;
351 }
352
354 {
355  if ( !theGeometry )
356  {
357  // Check the internal geometry first to avoid a factory call.
358  if ( m_gdalTileSource.valid() )
359  {
361  }
362  }
363  return theGeometry;
364 }
365
366 bool ossimHdfReader::loadState(const ossimKeywordlist& kwl, const char* prefix)
367 {
368  bool result = false;
369  if ( ossimImageHandler::loadState(kwl, prefix) )
370  {
371  result = open();
372  }
373  return result;
374 }
375
377 {
378  if (m_currentEntryRender == entryIdx)
379  {
380  return true; // Nothing to do...
381  }
382  theDecimationFactors.clear();
383  theGeometry = 0;
384  theOverview = 0;
386  m_currentEntryRender = entryIdx;
387  return open();
388 }
389
391 {
392  return m_entryFileList.size();
393 }
394
395 void ossimHdfReader::getEntryList(std::vector<ossim_uint32>& entryList) const
396 {
397  entryList.clear();
398  for (ossim_uint32 i = 0; i < m_entryFileList.size(); i++)
399  {
400  entryList.push_back(m_entryFileList[i]);
401  }
402 }
403
405 {
406  if (m_gdalTileSource.valid())
407  {
408  std::vector<ossimString> entryStringList;
409  m_gdalTileSource->getEntryNames(entryStringList);
410  if (entryId < entryStringList.size())
411  {
412  return entryStringList[entryId];
413  }
414  }
415  return "";
416 }
417
419 {
420  ossimString result = "";
421  if (m_gdalTileSource.valid())
422  {
423  GDALDriverH driver = m_gdalTileSource->getDriver();
424  if (driver)
425  {
426  result = GDALGetDriverShortName(driver);
427  }
428  }
429  return result;
430 }
431
432 bool ossimHdfReader::setOutputBandList(const vector<ossim_uint32>& outputBandList)
433 {
434  if (outputBandList.size() && m_gdalTileSource )
435  {
436  m_gdalTileSource->setOutputBandList(outputBandList);
437  open();
438  return true;
439  }
440  return false;
441 }
bool isSDSDataset(ossimString fileName)
void clear()
Erases the entire container.
Definition: ossimString.h:432
virtual ossimString getShortName() const
Returns short name.
ossimRefPtr< ossimImageGeometry > theGeometry
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
bool doubleEquals(ossim_float64 left, ossim_float64 right, ossim_float64 epsilon)
virtual ossimString getClassName() const
Returns class name.
virtual void getEntryNames(std::vector< ossimString > &entryStringList) const
ossimFilename theImageFile
virtual ossimString getLongName() const
Returns long name.
ossimRefPtr< ossimImageData > m_tile
bool valid() const
Definition: ossimRefPtr.h:75
std::vector< ossimDpt > theDecimationFactors
virtual bool setOutputBandList(const std::vector< ossim_uint32 > &band_list)
If the image handler "isBandSeletor()" then the band selection of the output chip can be controlled...
virtual ossim_uint32 getNumberOfEntries() const
bool contains(char aChar) const
Definition: ossimString.h:58
virtual ossim_uint32 getImageTileWidth() const
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const
Gets number of lines for res level.
virtual bool open()
Open method.
virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level=0) const
Returns the number of bands in the image.
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const
Gets the number of samples for res level.
ossimScalarType m_scalarType
void ref() const
increment the reference count by one, indicating that this object has another pointer which is refere...
virtual void initialize()
Initialize the data buffer.
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
bool completely_within(const ossimIrect &rect) const
Definition: ossimIrect.cpp:425
double ossim_float64
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
#define RTTI_DEF1_INST(cls, name, b1)
Definition: ossimRtti.h:481
ossimRefPtr< ossimGdalTileSource > m_gdalTileSource
virtual bool getOverviewTile(ossim_uint32 resLevel, ossimImageData *result)
Method to get an overview tile.
virtual ossim_uint32 getImageTileHeight() const
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level=0) const
Returns the number of bands available from an image.
virtual ossim_uint32 getNumberOfInputBands() const
virtual void setFilename(const ossimFilename &filename)
Sets the filename.
unsigned int ossim_uint32
bool isSupportedExtension()
virtual void close()
Method to close current entry.
virtual ossimIrect getImageRectangle() const
virtual ~ossimHdfReader()
virtural destructor
ossim_uint32 m_currentEntryRender
virtual ossimIrect getImageRectangle(ossim_uint32 resLevel=0) const
Returns zero-based bounding rectangle of the image.
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tileRect, ossim_uint32 resLevel=0)
Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab fr...
virtual void getEntryList(std::vector< ossim_uint32 > &entryList) const
ossimScalarType
void unref() const
decrement the reference count by one, indicating that a pointer to this object is referencing it...
virtual bool setCurrentEntry(ossim_uint32 entryIdx)
return status
virtual void makeBlank()
virtual void completeOpen()
Will complete the opening process.
ossimRefPtr< ossimImageHandler > theOverview
This class defines an abstract Handler which all image handlers(loaders) should derive from...
ossimString getDriverName()
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &rect, ossim_uint32 resLevel=0)
Method to grab a tile(rectangle) from image.
std::vector< ossim_uint32 > m_entryFileList
ossimString getEntryString(ossim_uint32 entryId) const
ossim_uint32 m_numberOfBands
ossimFilename theOverviewFile
ossimString ext() const
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
virtual bool isOpen() const
Method to test for open file stream.
ossimHdfReader()
default construtor
