45 #include <gdal_priv.h> 46 #include <cpl_string.h> 53 static ossimTrace traceDebug(
"ossimGdalTileSource:debug");
55 static const char DRIVER_SHORT_NAME_KW[] =
"driver_short_name";
56 static const char PRESERVE_PALETTE_KW[] =
"preserve_palette";
59 using namespace ossim;
74 theEntryNumberToRender(0),
76 theIsComplexFlag(false),
77 theAlphaChannelFlag(false),
78 m_preservePaletteIndexesFlag(false),
136 <<
"ossimGdalTileSource::open() DEBUG: entered ..." 165 <<
"ossimGdalTileSource::open DEBUG:" 166 <<
"\nOpened image: " 173 GDALDriverH driverTmp = GDALGetDatasetDriver(
theDataset);
177 driverNameTmp =
ossimString(GDALGetDriverShortName(driverTmp));
178 driverNameTmp = driverNameTmp.
upcase();
179 if (driverNameTmp ==
"NITF")
186 char** papszMetadata = GDALGetMetadata(
theDataset,
"SUBDATASETS" );
187 if( CSLCount(papszMetadata) > 0 )
191 for(
int i = 0; papszMetadata[i] != 0; ++i )
205 if ( subDataset != 0 )
210 ossimString nitfIcatTag( GDALGetMetadataItem( subDataset,
"NITF_ICAT",
211 if ( nitfIcatTag.
contains(
"CLOUD") == false )
216 GDALClose(subDataset);
228 <<
"ossimGdalTileSource::open DEBUG:" << std::endl;
232 <<
"Sub_data_set[" << idx <<
"] " 256 <<
"ossimGdalTileSource::open DEBUG:" 257 <<
"\nOpened sub data set: " 278 <<
"ossimGdalTileSource::open DEBUG:" 279 <<
"\nOpened sub data set: " 293 <<
"ossimGdalTileSource::open Driver: " 295 <<
"/" << GDALGetDriverLongName(
theDriver ) << std::endl;
303 if(CSLCount(GDALGetMetadata(
theDataset,
"SUBDATASETS")))
306 <<
"ossimGdalTileSource::open WARNING:" 307 <<
"\nHas multiple sub datasets and need to set the data before" 308 <<
" we can get to the bands" << std::endl;
313 <<
"ossimGdalTileSource::open WARNING:" 314 <<
"\nNo band data present in ossimGdalTileSource::open" << std::endl;
319 GDALRasterBandH bBand = GDALGetRasterBand(
theDataset, 1 );
324 char** papszMetadata = GDALGetMetadata( bBand, NULL );
325 if (CSLCount(papszMetadata) > 0)
327 for(
int i = 0; papszMetadata[i] != NULL; i++ )
330 if (metaStr.
contains(
"AREA_OR_POINT"))
334 if (pixel_is_point_or_area.
contains(
"area"))
343 for(i = 0; i < GDALGetRasterCount(
theDataset); ++i)
349 <<
"ossimGdalTileSource::open WARNING" 350 <<
"\nWe currently do not support different scalar type bands." 437 <<
"ossimGdalTileSoruce::open\n" 453 int xSize=0, ySize=0;
454 GDALGetBlockSize(GDALGetRasterBand(
theDataset, 1 ),
505 throw ossimException( std::string(
"ossimGdalTileSource::getTile ERROR: Accessing reduced resolution level with the preservePaletteIndexesFlag set!") );
523 GDALRasterBandH band = GDALGetRasterBand(
theDataset, 1);
524 if(static_cast<int>(resLevel) > GDALGetOverviewCount(band))
559 for(
ossim_uint32 aBandIndex =1; aBandIndex <= rasterCount; ++aBandIndex)
568 aGdalBandIndex = aBandIndex;
576 bReadSuccess = (GDALRasterIO(aBand
587 , 0 ) == CE_None) ?
true :
false;
589 if ( bReadSuccess ==
true )
598 clipRect, anOssimBandIndex);
599 anOssimBandIndex += 1;
610 anOssimBandIndex += 1;
639 bReadSuccess = (GDALRasterIO(aBand
650 , 0 ) == CE_None) ?
true :
false;
651 if ( bReadSuccess ==
true )
659 for(idx = 0; idx < idxMax; ++idx)
661 memcpy(outBufPtr, complexBufPtr, byteSize);
662 complexBufPtr += byteSize2;
663 outBufPtr += byteSize;
671 for(idx = 0; idx < idxMax; ++idx)
673 memcpy(outBufPtr, complexBufPtr, byteSize);
674 complexBufPtr += byteSize2;
675 outBufPtr += byteSize;
684 anOssimBandIndex += 2;
711 int xSize=0, ySize=0;
733 for(;
x < maxx;
x+=xSize)
735 for(;
y < maxy;
y+=ySize)
741 if(!cacheTile.
valid())
743 ossimIrect rect(origin.
x,origin.
y,origin.
x+xSize-1, origin.
y+ySize-1);
749 for(
758 aGdalBandIndex = aBandIndex;
938 if (
x > 0 && x0 > 0 )
940 result.
x = ((double)
x) / x0;
944 result.
x = 1.0 / (1<<resLevel);
960 const char* prefix)
const 980 <<
"\nossimGdalTileSource::saveState keywordlist:\n" 998 const char* lookup = kwl.
find(prefix,
"entry");
1007 lookup = kwl.
find(prefix, PRESERVE_PALETTE_KW);
1083 if ( fgdcXmlDoc->
open(xmlFile) )
1104 static const char MODULE[] =
"ossimGdalTileSource::getImageGeometry";
1115 const char* wkt = GDALGetProjectionRef(
theDataset );
1121 CLOG <<
"WKT PROJECTION STRING = " << wkt << std::endl;
1131 <<
"GDALGetGCPCount = " << gcpCount << std::endl;
1149 if (projGcp.
valid())
1152 if (mapProj.
valid())
1161 const GDAL_GCP* gcpList = GDALGetGCPs(
theDataset);
1165 for(idx = 0; idx < gcpCount; ++idx)
1173 if ((gcpCount < 40) || (idx%10 == 0))
1175 ossimDpt dpt(gcpList[idx].dfGCPPixel, gcpList[idx].dfGCPLine);
1179 ossimDpt dptEastingNorthing(gcpList[idx].dfGCPX, gcpList[idx].dfGCPY);
1180 gpt = projGcp->
inverse(dptEastingNorthing);
1181 gpt.
hgt = gcpList[idx].dfGCPZ;
1185 gpt =
ossimGpt(gcpList[idx].dfGCPY, gcpList[idx].dfGCPX, gcpList[idx].dfGCPZ);
1193 <<
"Added tie point for gcp[" << idx <<
"]: " 1194 << dpt <<
", " << gpt << std::endl;
1210 double geoTransform[6];
1211 bool transOk = GDALGetGeoTransform(
theDataset, geoTransform ) == CE_None;
1217 << MODULE <<
"DEBUG: GDALGetGeoTransform failed..." << std::endl;
1224 << geoTransform[0] <<
", " << geoTransform[1] <<
", " << geoTransform[2] <<
", " 1225 << geoTransform[3] <<
", " << geoTransform[5] <<
">" 1238 if(transOk&&(driverName==
"AAIGrid"))
1243 << geoTransform[0] <<
", " 1244 << geoTransform[3] <<
">" 1247 if((std::fabs(geoTransform[0]) < (180.0+
FLT_EPSILON))&&
1248 (std::fabs(geoTransform[3]) < (90.0 +
FLT_EPSILON)))
1257 geoTransform[0] + ul.
x*geoTransform[1] + ul.
y*geoTransform[2]),
1261 geoTransform[0] + ur.
x*geoTransform[1] + ur.
y*geoTransform[2]),
1265 geoTransform[0] + lr.
x*geoTransform[1] + lr.
y*geoTransform[2]),
1269 geoTransform[0] + ll.
x*geoTransform[1] + ll.
y*geoTransform[2]),
1289 << MODULE <<
"DEBUG: wktTranslator.toOssimKwl failed..." << std::endl;
1297 const char* prefix = 0;
1302 ossimDpt gsd(fabs(geoTransform[1]), fabs(geoTransform[5]));
1313 if(driverName ==
"AIG")
1316 ossimDpt tie(geoTransform[0], geoTransform[3]);
1324 geoTransform[0] = tie.
x;
1325 geoTransform[3] = tie.
y;
1327 if(proj_type ==
"ossimLlxyProjection" ||
1328 proj_type ==
"ossimEquDistCylProjection")
1346 <<
" " << 0 <<
" " << 0 <<
" " << 1 <<
" " << 0
1347 <<
" " << 0 <<
" " << 0 <<
" " << 0 <<
" " << 1;
1355 if(driverName ==
"AIG" && datum_type.
contains(
"OGB"))
1371 "ossimBngProjection",
true);
1377 if(datum ==
"OGB_A")
1379 else if(datum ==
"OGB_B")
1381 else if(datum ==
"OGB_C")
1383 else if(datum ==
"OGB_D")
1385 else if(datum ==
"OGB_M")
1387 else if(datum ==
"OGB_7")
1401 <<
"\nUnable to accurately support ArcGrid due to missing" 1402 <<
" prj.adf file." << std::endl;
1411 << MODULE <<
" DEBUG:" 1412 <<
"\nwktTranslator keyword list:\n" 1458 <<
"ossimGdalTileSource::getOutputScalarType debug:" 1459 <<
"\nOutput scalar: " << result << std::endl;
1545 <<
"ossimGdalTileSource::getInputScalarType debug:" 1547 <<
"\nInput scalar: " << result << std::endl;
1642 for(i = 0; i < 3; ++i)
1669 GDALRasterBandH aBand=0;
1671 aBand = GDALGetRasterBand(
theDataset, band+1);
1692 if ( driverName.
contains(
"JP2KAK") ||
1746 GDALRasterBandH band = GDALGetRasterBand(
theDataset, 1);
1747 if(GDALGetOverviewCount(band))
1749 result += (GDALGetOverviewCount(band));
1828 << __FILE__ << __LINE__
1829 <<
" ossimGdalTileSource::loadIndexTo3BandTile WARNING!\n" 1830 <<
"Unsupported scalar types:\nInupt scalar: " << inScalar
1831 <<
"\nOutput scalar: " << outScalar
1836 template<
class InputType,
class OutputType>
1844 GDALRasterBandH aBand=0;
1845 aBand = GDALGetRasterBand(
theDataset, aGdalBandStart);
1846 GDALColorTableH table = GDALGetRasterColorTable(aBand);
1861 s += (clipRect.
ul().
y - src_rect.
ul().
y) * s_width +
1862 clipRect.
ul().
x - src_rect.
ul().
x;
1867 d[0]=
static_cast<OutputType*
theTile->
getBuf(anOssimBandStart));
1868 d[1]=
theTile->
getBuf(anOssimBandStart + 1));
1869 d[2]=
theTile->
getBuf(anOssimBandStart + 2));
1884 clipRect.
ul().
x - img_rect.
ul().
x;
1891 GDALPaletteInterp interp = GDALGetPaletteInterpretation(table);
1895 for (
ossim_uint32 sample = 0; sample < clipWidth; ++sample)
1897 GDALColorEntry entry;
1898 if(GDALGetColorEntryAsRGB(table, s[sample], &entry))
1900 if(interp == GPI_RGB)
1911 d[0][sample] = entry.c1==np[0]?minp[0]:entry.c1;
1912 d[1][sample] = entry.c2==np[1]?minp[1]:entry.c2;
1913 d[2][sample] = entry.c3==np[2]?minp[2]:entry.c3;
1915 d[0][sample] = entry.c1;
1916 d[1][sample] = entry.c2;
1917 d[2][sample] = entry.c3;
1923 d[0][sample] = entry.c1;
1924 d[1][sample] = entry.c2;
1925 d[2][sample] = entry.c3;
1946 GDALRasterBandH band = GDALGetRasterBand(
theDataset, bandNumber);
1947 if(GDALGetRasterColorInterpretation(band)==GCI_PaletteIndex)
1949 GDALColorTableH table = GDALGetRasterColorTable(band);
1950 GDALPaletteInterp interp = GDALGetPaletteInterpretation(table);
1951 if( (interp == GPI_RGB) ||
1952 (interp == GPI_HLS)||
1953 (interp == GPI_CMYK))
1964 GDALRasterBandH band = GDALGetRasterBand(
1965 if(GDALGetRasterColorInterpretation(band)==GCI_PaletteIndex)
1967 GDALColorTableH table = GDALGetRasterColorTable(band);
1968 GDALPaletteInterp interp = GDALGetPaletteInterpretation(table);
1969 if(interp == GPI_Gray)
1982 GDALRasterBandH band = GDALGetRasterBand(
1983 if(GDALGetRasterColorInterpretation(band)==GCI_PaletteIndex)
1985 GDALColorTableH table = GDALGetRasterColorTable(band);
1986 GDALPaletteInterp interp = GDALGetPaletteInterpretation(table);
2008 if(aGdalBandNumber <= GDALGetRasterCount(
theDataset))
2010 GDALRasterBandH band = GDALGetRasterBand(
theDataset, aGdalBandNumber);
2011 if(!band)
return false;
2012 if(GDALGetRasterColorInterpretation(band)==GCI_PaletteIndex)
2036 int aGdalBandIndex = 0;
2045 maxX = rect.
width();
2051 for(aGdalBandIndex=1;
2052 (int)aGdalBandIndex <= (
int)GDALGetRasterCount(
theDataset);
2058 maxY = ossim::max<int>((int)GDALGetRasterBandYSize(aBand), maxY);
2059 maxX = ossim::max<int>((int)GDALGetRasterBandXSize(aBand), maxX);
2069 int aGdalBandIndex )
const 2071 GDALRasterBandH aBand = GDALGetRasterBand(
theDataset, aGdalBandIndex );
2075 int overviewIndex = resLevel-1;
2077 GDALRasterBandH overviewBand = GDALGetOverview( aBand, overviewIndex );
2080 aBand = overviewBand;
2092 const char* driver = GDALGetDriverShortName(
theDriver);
2144 entryList.push_back(i);
2149 entryList.push_back(0);
2171 bool atStart =
false;
2174 if ( *(subString.
begin()+pos) ==
2202 GDALColorTableH aTable = GDALGetRasterColorTable(GDALGetRasterBand(
theDataset, 1 ));
2203 GDALPaletteInterp interp = GDALGetPaletteInterpretation(aTable);
2204 if(aTable && ( (interp == GPI_Gray) || (interp == GPI_RGB)))
2206 GDALColorEntry colorEntry;
2207 ossim_uint32 numberOfElements = GDALGetColorEntryCount(aTable);
2209 if(numberOfElements)
2218 bool nullSet =
false;
2219 for(idx = 0; idx < numberOfElements; ++idx)
2225 if(GDALGetColorEntryAsRGB(aTable, idx, &colorEntry))
2227 (*theLut)[idx][0] = colorEntry.c1;
2228 (*theLut)[idx][1] = colorEntry.c2;
2229 (*theLut)[idx][2] = colorEntry.c3;
2230 (*theLut)[idx][3] = colorEntry.c4;
2237 if ( (*
theLut)[idx][3] == 0 )
2251 if ( ( (*
theLut)[idx][0] == 0 ) &&
2252 ( (*
theLut)[idx][1] == 0 ) &&
2253 ( (*
theLut)[idx][2] == 0 ) )
2263 (*theLut)[idx][0] = 0;
2264 (*theLut)[idx][1] = 0;
2265 (*theLut)[idx][2] = 0;
2266 (*theLut)[idx][3] = 0;
2271 if ( (*
2281 const GDALColorEntry* constEntry = GDALGetColorEntry(aTable, idx);
2284 (*theLut)[idx][0] = constEntry->c1;
2288 (*theLut)[idx][0] = 0;
2302 for(
ossim_uint32 aGdalBandIndex=1; aGdalBandIndex <= rasterCount; ++aGdalBandIndex)
2304 GDALRasterBandH aBand = GDALGetRasterBand(
2307 GDALRasterAttributeTableH hRAT = GDALGetDefaultRAT(aBand);
2308 int colCount = GDALRATGetColumnCount(hRAT);
2311 const char* colName = GDALRATGetNameOfCol(hRAT, col);
2314 if (strcmp(colName,
"Class_Names") == 0)
2316 std::vector<ossimString> entryLabels;
2320 const char* className = GDALRATGetValueAsString(hRAT, row, col);
2322 entryLabels.push_back(entryLabel);
2335 if ( property->
getName() == PRESERVE_PALETTE_KW )
2338 property->valueToString(s);
2353 if( (name == DRIVER_SHORT_NAME_KW) &&
isOpen() )
2358 else if ( (name ==
"imag") &&
isOpen() )
2363 if (!nitfImagTag.
empty())
2369 else if ( name == PRESERVE_PALETTE_KW )
2382 propertyNames.push_back(DRIVER_SHORT_NAME_KW);
2383 propertyNames.push_back(PRESERVE_PALETTE_KW);
2390 if (outputBandList.size())
2393 for (
ossim_uint32 i = 0; i < outputBandList.size(); i++)
2395 if (outputBandList[i] > bandCount)
2416 if (
isOpen() && stateChanged )
2435 if ( nullIndex > -1 )
2485 int xSize=0, ySize=0;
2487 for(idx =0; idx < nLevels; ++idx)
virtual void deleteCache(ossimAppFixedCacheId cacheId)
virtual void loadBand(const void *src, const ossimIrect &src_rect, ossim_uint32 band)
void setPreservePaletteIndexesFlag(bool flag)
Sets preserve palette indexes flag.
void clear()
Erases the entire container.
virtual ossimIrect getImageRectangle(ossim_uint32 reduced_res_level=0) const
Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in...
static ossimImageGeometryRegistry * instance()
ossimRefPtr< ossimImageGeometry > theGeometry
virtual ossimRefPtr< ossimImageGeometry > getImageGeometry()
Returns the image geometry object associated with this tile source or NULL if non defined...
void setProjection(ossimProjection *projection)
Sets the projection to be used for local-to-world coordinate transformation.
ossimFilename noExtension() const
static ossimString upcase(const ossimString &aString)
Set propterty method.
std::basic_stringstream< char > stringstream
Class for char mixed input and output memory streams.
static const char * DATUM_KW
virtual void getEntryNames(std::vector< ossimString > &entryStringList) const
ossimRefPtr< ossimImageData > theSingleBandTile
ossimFilename theImageFile
ossimScalarType getInputScalarType() const
Gets the input scalar type of the tile source.
ossim_uint32 getIndexBandOutputNumber(int bandNumber) const
bool addFile(const char *file)
std::vector< ossimDpt > theDecimationFactors
void setEntryLables(ossim_uint32 band, std::vector< ossimString > entryLabels)
virtual void getEntryNames(std::vector< ossimString > &entryNames) const
virtual bool setOutputBandList(const std::vector< ossim_uint32 > &band_list)
If the image handler "isBandSeletor()" then the band selection of the output chip can be controlled...
void loadIndexTo3BandTileTemplate(InputType in, OutputType out, const ossimIrect &clipRect, ossim_uint32 aGdalBandStart=1, ossim_uint32 anOssimBandStart=0)
virtual ossim_uint32 getNumberOfLines(ossim_uint32 resLevel=0) const =0
Pure virtual, derived classes must implement.
This code was derived from https://gist.github.com/mshockwave.
static const char * IMAGE_MODEL_TRANSFORM_MATRIX_KW
ossim_uint32 height() const
bool contains(char aChar) const
virtual ossimGpt inverse(const ossimDpt &pp) const
Numeric to string methods.
virtual bool isGeographic() const
const ossimIpt & ul() const
virtual void getDecimationFactor(ossim_uint32 resLevel, ossimDpt &result) const
virtual ossim_int32 getEntryNumber(const char *entry_string, bool case_insensitive=true) const
virtual bool isOpen() const
ossim_float64 hgt
Height in meters above the ellipsiod.
std::vector< ossimString > theSubDatasets
bool isIndexTo1Band(int bandNumber=1) const
ossim_uint32 toUInt32() const
virtual ossim_uint32 getNumberOfDecimationLevels() const
Returns the number of reduced resolution data sets (rrds).
virtual ossim_uint32 getNumberOfLines(ossim_uint32 reduced_res_level=0) const
Returns the number of bands in the image.
bool intersects(const ossimIrect &rect) const
unsigned short ossim_uint16
virtual ossim_uint32 getImageTileWidth() const
const ossimIpt & ll() const
Retuns the min pixel value.
static const char * TYPE_KW
virtual void initialize()
Initialize the data buffer.
static ossimAppFixedTileCache * instance(ossim_uint32 maxSize=0)
virtual double optimizeFit(const ossimTieGptSet &tieSet, double *targetVariance=0)
ossimPixelType thePixelType
virtual ossim_uint32 getSizePerBandInBytes() const
Returns the number of bytes in single band of the tile.
This returns the total number of decimation levels.
Get propterty names.
virtual bool isValidRLevel(ossim_uint32 resLevel) const
Determines if the passed in reslution level is valid.
bool completely_within(const ossimIrect &rect) const
static const char * PIXEL_SCALE_XY_KW
void push_back(char c)
Equivalent to insert(end(), c).
virtual void getEntryList(std::vector< ossim_uint32 > &entryList) const
virtual void loadTile(const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type)
vector< ossim_uint32 > m_outputBandList
OSSIM_DLL double defaultMin(ossimScalarType scalarType)
ossimRefPtr< ossimImageData > getTileBlockRead(const ossimIrect &tileRect, ossim_uint32 resLevel)
bool getPreservePaletteIndexesFlag() const
ossimProjection * createProjection(const ossimFilename &filename, ossim_uint32 entryIdx) const
ossimRefPtr< ossimImageData > getTile(ossimAppFixedCacheId cacheId, const ossimIpt &origin)
const char * findPreference(const char *key) const
static const char * TIE_POINT_XY_KW
void loadIndexTo3BandTile(const ossimIrect &clipRect, ossim_uint32 aGdalBandStart=1, ossim_uint32 anOssimBandStart=0)
virtual ossim_uint32 getNumberOfSamples(ossim_uint32 reduced_res_level=0) const
Returns the number of bands available from an image.
signed short ossim_sint16
virtual ossim_uint32 getNumberOfInputBands() const
std::string::size_type size() const
bool toBool() const
String to numeric methods.
std::string::iterator begin()
OSSIM_DLL double defaultNull(ossimScalarType scalarType)
virtual void nullTileAlpha(const ossim_uint8 *src, const ossimIrect &src_rect, bool mutliplyAlphaFlag=false)
ossim_uint32 getNumberOfEntries() const
unsigned int ossim_uint32
virtual const ossim_float64 * getNullPix() const
bool isIndexTo3Band(int bandNumber=1) const
ossimRefPtr< ossimImageGeometry > getExternalImageGeometryFromXml() const
Class for FGDC XML doc parsing.
virtual ossimIrect getImageRectangle() const
GDALRasterBandH resolveRasterBand(ossim_uint32 resLevel, int gdalBandIndex) const
For the given resolution level and GDAL band index, return a corresponding GDAL raster band...
OSSIM_DLL ossim_uint32 scalarSizeInBytes(ossimScalarType scalarType)
const ossimIpt & lr() const
static const char * IMAGE_MODEL_TRANSFORM_UNIT_KW
virtual ossimIrect getImageRectangle(ossim_uint32 resLevel=0) const
Returns zero-based bounding rectangle of the image.
bool isBlocked(int band) const
virtual ossimRefPtr< ossimImageData > getTile(const ossimIrect &tileRect, ossim_uint32 resLevel=0)
Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab fr...
virtual ossimString getShortName() const
ossim_uint32 width() const
void initImageParameters(ossimImageGeometry *geom) const
Convenience method to set things needed in the image geometry from the image handler.
virtual bool hasMetaData() const
static ossimPreferences * instance()
void setIndexedFlag(bool flag)
Sets the indexed flag.
const ossimIpt & ur() const
std::vector< ossim_uint8 > theGdalBuffer
virtual ossim_uint32 getTileWidth() const
Returns the width of the output tile.
storage class for tie point between ground and image based on ossimGpt
virtual ossimRefPtr< ossimImageGeometry > getInternalImageGeometry() const
virtual ossimString getLongName() const
static ossimProjectionFactoryRegistry * instance()
virtual const ossim_float64 * getMinPix() const
virtual bool isIndexedData() const
Indicated data is indexed.
virtual ossimRefPtr< ossimImageGeometry > getExternalImageGeometry() const
static const char * UNITS_KW
ossimRefPtr< ossimProjection > getProjection()
Gets projection from document.
virtual void makeBlank()
virtual ossim_uint32 getTileHeight() const
Returns the height of the output tile.
virtual void completeOpen()
Will complete the opening process.
void addTiePoint(ossimRefPtr< ossimTieGpt > aTiePt)
operations
ossim_uint32 theEntryNumberToRender
std::vector< ossimAppFixedTileCache::ossimAppFixedCacheId > m_rlevelBlockCache
ossimImageMetaData theMetaData
ossimString toString(ossim_uint32 precision=15) const
OSSIM_DLL double defaultMax(ossimScalarType scalarType)
ossimRefPtr< ossimImageHandler > theOverview
This class defines an abstract Handler which all image handlers(loaders) should derive from...
Get propterty method.
storage class for a set of geographic tie points, between master and slave images ...
virtual void close()
void setNullPixelIndex(ossim_int32 idx)
Allows you to specify which entry is to be designated as an invalid entry.
virtual ossim_uint32 getCurrentEntry() const
const char * c_str() const
Returns a pointer to a null-terminated array of characters representing the string's contents...
class ossimNBandLutDataObject
void stretchToTileBoundary(const ossimIpt &tileWidthHeight)
ossimFilename theOverviewFile
GDALDataType theOutputGdtType
virtual ossim_uint32 getImageTileHeight() const
bool open(const ossimFilename &xmlFileName)
Open method.
ossim_int32 getNullPixelIndex() const
bool toOssimKwl(const ossimString &wktString, ossimKeywordlist &kwl, const char *prefix=NULL) const
ossimRefPtr< ossimNBandLutDataObject > theLut
virtual ossimString getClassName() const
#define RTTI_DEF1(cls, name, b1)
bool isIndexed(int aGdalBandNumber=1) const
virtual void setScalarType(ossimScalarType type)
See ossimScalarType in ossimConstants for a full list.
virtual ~ossimGdalTileSource()
static ossimUnitTypeLut * instance()
Returns the static instance of an ossimUnitTypeLut object.
ossimAppFixedCacheId newTileCache(const ossimIrect &tileBoundaryRect, const ossimIpt &tileSize=ossimIpt(0, 0))
void getDefaults()
Checks prefences for default settings.
double * theNullPixValues
ossim_int32 getFirstNullAlphaIndex() const
ossimFilename path() const
void getMaxSize(ossim_uint32 resLevel, int &maxX, int &maxY) const
unsigned char ossim_uint8
virtual bool setCurrentEntry(ossim_uint32 entryIdx)
bool m_preservePaletteIndexesFlag
ossimRefPtr< ossimImageData > addTile(ossimAppFixedCacheId cacheId, ossimRefPtr< ossimImageData > data, bool duplicateData=true)
static const char * PIXEL_SCALE_UNITS_KW
static const char * TIE_POINT_UNITS_KW
const ossimString & getName() const
ossimString filterSubDatasetsString(const ossimString &subString) const
Filters string from "GDALGetMetadata( theDataset, "SUBDATASETS" )
