ossimImageHistogramSource.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: See LICENSE.txt file in the top level directory.
4 //
5 // Author: Garrett Potts
6 //
7 //*************************************************************************
8 // $Id: ossimImageHistogramSource.cpp 22737 2014-04-16 18:53:57Z gpotts $
9
15 #include <ossim/base/ossimNotify.h>
16 #include <ossim/base/ossimTrace.h>
17
18 static ossimTrace traceDebug("ossimImageHistogramSource:debug");
19
21
23  :ossimHistogramSource(owner,
24  1, // one input
25  0, // no outputs
26  true, // input list is fixed
27  false),// output can still grow though
28  theHistogramRecomputeFlag(true),
29  theMaxNumberOfResLevels(1),
30  theComputationMode(OSSIM_HISTO_MODE_NORMAL)
31  // theNumberOfTilesToUseInFastMode(100)
32 {
35
39 }
40
42 {
44 }
45
47 {
48  return this;
49 }
50
52 {
53  return this;
54 }
55
57 {
58  if(rect != theAreaOfInterest)
59  {
61  }
62  theAreaOfInterest = rect;
63 }
64
66 {
67  return theAreaOfInterest;
68 }
69
71 {
72  rect = theAreaOfInterest;
73 }
74
76 {
78 }
79
81 {
82  if(number != theMaxNumberOfResLevels)
83  {
85  }
86  theMaxNumberOfResLevels = number;
87 }
88
90 {
91  if((theAreaOfInterest != rect)||
93  {
94  theAreaOfInterest = rect;
96  }
97
98  return getHistogram();
99 }
100
102 {
103  if(!isSourceEnabled())
104  {
105  return theHistogram.valid();
106  }
107
110  {
112  {
114  if(interface)
115  {
116  theAreaOfInterest = interface->getBoundingRect();
117  }
118  }
119
120  switch(theComputationMode)
121  {
123  {
125  break;
126  }
128  default:
129  {
131  break;
132  }
133  }
134  }
135
136  if (needsAborting())
137  {
140  }
141  else
142  {
144  }
145
146  return true;
147 }
148
150  const ossimConnectableObject* object)const
151 {
152  return ((myInputIndex==0)&&PTR_CAST(ossimImageSource,
153  object));
154 }
155
157 {
158  theNumberOfBinsOverride = numberOfBinsOverride;
159 }
160
162 {
163  theMinValueOverride = minValueOverride;
164 }
166 {
167  theMaxValueOverride = maxValueOverride;
168 }
169
171 {
172  return theComputationMode;
173 }
174
176 {
177  theComputationMode = mode;
178 }
179
181 {
183 }
184
186 {
188 }
189
191 {
192  execute();
193  return theHistogram;
194 }
195
197  ossim_float64& minValue,
198  ossim_float64& maxValue,
199  ossim_uint32 band)const
200 {
201  numberOfBins = 0;
202  minValue = 0;
203  maxValue = 0;
204
206  if(input)
207  {
208  minValue = input->getMinPixelValue(band);
209  maxValue = input->getMaxPixelValue(band);
210  switch(input->getOutputScalarType())
211  {
212  case OSSIM_UINT8:
213  {
214  minValue = 0;
215  maxValue = OSSIM_DEFAULT_MAX_PIX_UCHAR;
216  numberOfBins = 256;
217
218  break;
219  }
220  case OSSIM_USHORT11:
221  {
222  minValue = 0;
223  maxValue = OSSIM_DEFAULT_MAX_PIX_UINT11;
224  numberOfBins = OSSIM_DEFAULT_MAX_PIX_UINT11 + 1;
225
226  break;
227  }
228  case OSSIM_USHORT12:
229  {
230  minValue = 0;
231  maxValue = OSSIM_DEFAULT_MAX_PIX_UINT12;
232  numberOfBins = OSSIM_DEFAULT_MAX_PIX_UINT12 + 1;
233
234  break;
235  }
236  case OSSIM_USHORT13:
237  {
238  minValue = 0;
239  maxValue = OSSIM_DEFAULT_MAX_PIX_UINT13;
240  numberOfBins = OSSIM_DEFAULT_MAX_PIX_UINT13 + 1;
241
242  break;
243  }
244  case OSSIM_USHORT14:
245  {
246  minValue = 0;
247  maxValue = OSSIM_DEFAULT_MAX_PIX_UINT14;
248  numberOfBins = OSSIM_DEFAULT_MAX_PIX_UINT14 + 1;
249
250  break;
251  }
252  case OSSIM_USHORT15:
253  {
254  minValue = 0;
255  maxValue = OSSIM_DEFAULT_MAX_PIX_UINT15;
256  numberOfBins = OSSIM_DEFAULT_MAX_PIX_UINT15 + 1;
257
258  break;
259  }
260  case OSSIM_UINT16:
261  {
262  minValue = 0;
263  maxValue = OSSIM_DEFAULT_MAX_PIX_UINT16;
264  numberOfBins = OSSIM_DEFAULT_MAX_PIX_UINT16 + 1;
265
266  break;
267  }
268  case OSSIM_SINT16:
269  {
270  minValue = OSSIM_DEFAULT_MIN_PIX_SINT16;
271  maxValue = OSSIM_DEFAULT_MAX_PIX_SINT16;
273  break;
274  }
275  case OSSIM_SINT32:
276  case OSSIM_UINT32:
277  {
278  numberOfBins = OSSIM_DEFAULT_MAX_PIX_UINT16+1;
279  break;
280  }
281  case OSSIM_FLOAT32:
282  case OSSIM_FLOAT64:
283  {
284  numberOfBins = OSSIM_DEFAULT_MAX_PIX_UINT16+1;
285  break;
286  }
289  {
290  minValue = 0;
291  maxValue = 1.0;
292  numberOfBins = OSSIM_DEFAULT_MAX_PIX_UINT16+1;
293  break;
294  }
295  default:
296  {
297  if(traceDebug())
298  {
300  << "Unsupported scalar type in ossimImageHistogramSource::computeHistogram()" << endl;
301  }
302  return;
303  }
304  }
305  }
306
307  if(ossim::isnan(theMinValueOverride) == false)
308  {
309  minValue = (float)theMinValueOverride;
310  }
311  if(ossim::isnan(theMaxValueOverride) == false)
312  {
313  maxValue = (float)theMaxValueOverride;
314  }
316  {
317  numberOfBins = theNumberOfBinsOverride;
318  }
319 }
320
322 {
323  // ref ptr, not a leak.
325
327  if(!input)
328  {
329  setPercentComplete(100.0);
330  return;
331  }
332
333  if(getInput(0))
334  {
335  // sum up all tiles needing processing. We will use the sequencer.
336  // ossim_uint32 numberOfResLevels = input->getNumberOfDecimationLevels();
337  ossim_uint32 index = 0;
338  double tileCount = 0.0;
339  double totalTiles = 0.0;
340  ossim_uint32 numberOfBands = input->getNumberOfOutputBands();
341  ossim_uint32 numberOfBins = 0;
342  ossim_float64 minValue = 0;
343  ossim_float64 maxValue = 0;
344  getBinInformation(numberOfBins, minValue, maxValue, 0);
345
347  sequencer->connectMyInputTo(0, getInput(0));
348  sequencer->initialize();
349
350  vector<ossimDpt> decimationFactors;
351  input->getDecimationFactors(decimationFactors);
352  if ( !decimationFactors.size() )
353  {
355  << "ossimImageHistogramSource::computeNormalModeHistogram WARNING:"
356  << "\nNo decimation factors from input. returning..." << std::endl;
357  return;
358  }
359
361  (ossim_uint32)decimationFactors.size());
362
363  if( decimationFactors.size() < theMaxNumberOfResLevels)
364  {
365  ossimNotify(ossimNotifyLevel_WARN) << "Number Decimations is smaller than the request number of r-levels defaulting to the smallest of the 2 numbers" << endl;
366  }
367
368  theHistogram->create(resLevelsToCompute);
369  for(index = 0; index < resLevelsToCompute; ++index)
370  {
371  sequencer->setAreaOfInterest(theAreaOfInterest*decimationFactors[index]);
372
373  totalTiles += sequencer->getNumberOfTiles();
374  }
375
376
377  if(numberOfBins > 0)
378  {
379  setPercentComplete(0.0);
380  for(index = 0;
381  (index < resLevelsToCompute);
382  ++index)
383  {
384  // Check for abort request.
385  if (needsAborting())
386  {
387  setPercentComplete(100);
388  break;
389  }
390
391  //sequencer->setAreaOfInterest(input->getBoundingRect(index));
392  sequencer->setAreaOfInterest(theAreaOfInterest*decimationFactors[index]);
393
394  sequencer->setToStartOfSequence();
395
396  theHistogram->getMultiBandHistogram(index)->create(numberOfBands,
397  numberOfBins,
398  minValue,
399  maxValue);
400
401  ossimRefPtr<ossimImageData> data = sequencer->getNextTile(index);
402  ++tileCount;
403  setPercentComplete((100.0*(tileCount/totalTiles)));
404
405  ossim_uint32 resLevelTotalTiles = sequencer->getNumberOfTiles();
406  for (ossim_uint32 resLevelTileCount = 0;
407  resLevelTileCount < resLevelTotalTiles;
408  ++resLevelTileCount)
409  {
410  if(data.valid()&&data->getBuf()&&(data->getDataObjectStatus() != OSSIM_EMPTY))
411  {
413  }
414
415  // Check for abort request.
416  if (needsAborting())
417  {
418  setPercentComplete(100);
419  break;
420  }
421
422
423  data = sequencer->getNextTile(index);
424  ++tileCount;
425  setPercentComplete((100.0*(tileCount/totalTiles)));
426  }
427  }
428  }
429  sequencer->disconnect();
430  sequencer = 0;
431  }
432 }
433
435 {
436  // Compute at most 9 x 9 tiles of 16 x 16 tile size.
437
438  ossim_uint32 resLevelsToCompute = 1;
439
440  // ref ptr, not a leak.
442  theHistogram->create(resLevelsToCompute);
444  if(!input)
445  {
446  setPercentComplete(100.0);
447  return;
448  }
449  // sum up all tiles needing processing. We will use the sequencer.
450  // ossim_uint32 numberOfResLevels = input->getNumberOfDecimationLevels();
451  double tileCount = 0.0;
452  double totalTiles = 0.0;
453  ossim_uint32 numberOfBands = input->getNumberOfOutputBands();
454  ossim_uint32 numberOfBins = 0;
455  ossim_float64 minValue = 0;
456  ossim_float64 maxValue = 0;
457  getBinInformation(numberOfBins, minValue, maxValue, 0);
458
459  // Fixed 16 x 16 tile size:
460  ossimIpt tileSize( 16, 16 );
461
462  ossimIrect tileBoundary = theAreaOfInterest;
463  tileBoundary.stretchToTileBoundary(tileSize);
464
465  // Max of 9 x 9 tiles accross the image.
466  const ossim_uint32 MAX_TILES_WIDE = 9;
467
468  ossim_uint32 tilesWide = ossim::min( (ossim_uint32)(tileBoundary.width()/tileSize.x),
469  MAX_TILES_WIDE);
470  ossim_uint32 tilesHigh = ossim::min( (ossim_uint32)(tileBoundary.height()/tileSize.y),
471  MAX_TILES_WIDE);
472
473  totalTiles = tilesWide*tilesHigh;
474
475  if(numberOfBins > 0)
476  {
477  ossimIpt origin = theAreaOfInterest.ul();
478
479  ossim_uint32 xTileOffset = tileBoundary.width() / tilesWide;
480  ossim_uint32 yTileOffset = tileBoundary.height() / tilesHigh;
481
482  theHistogram->getMultiBandHistogram(0)->create(numberOfBands,
483  numberOfBins,
484  minValue,
485  maxValue);
486  ossim_uint32 x = 0;
487  ossim_uint32 y = 0;
488  tileCount = 0;
489  totalTiles = tilesWide*tilesHigh;
490
491  for(y = 0; y < tilesHigh; ++y)
492  {
493  for(x = 0; x < tilesWide; ++x)
494  {
495  ossimIpt ul( origin.x + (x*xTileOffset), origin.y + (y*yTileOffset) );
496  ossimIrect tileRect(ul.x, ul.y, ul.x + tileSize.x-1, ul.y + tileSize.y-1);
497
498  ossimRefPtr<ossimImageData> data = input->getTile(tileRect);
499
500  if(data.valid()&&data->getBuf()&&(data->getDataObjectStatus() != OSSIM_EMPTY))
501  {
503  }
504
505  // Check for abort request.
506  if (needsAborting())
507  {
508  break;
509  }
510
511  ++tileCount;
512  }
513
514  // Check for abort request.
515  if (needsAborting())
516  {
517  setPercentComplete(100);
518  break;
519  }
520
521  setPercentComplete((100.0*(tileCount/totalTiles)));
522  }
523  }
524
525 #if 0 /* drb - old code was not working... */
526
527  // We will only compute a full res histogram in fast mode. and will only do a MAX of 100 tiles.
528  //
529  ossim_uint32 resLevelsToCompute = 1;
530
531  // ref ptr, not a leak.
533  theHistogram->create(resLevelsToCompute);
535  if(!input)
536  {
537  setPercentComplete(100.0);
538  return;
539  }
540  // sum up all tiles needing processing. We will use the sequencer.
541  // ossim_uint32 numberOfResLevels = input->getNumberOfDecimationLevels();
542  double tileCount = 0.0;
543  double totalTiles = 0.0;
544  ossim_uint32 numberOfBands = input->getNumberOfOutputBands();
545  ossim_uint32 numberOfBins = 0;
546  ossim_float64 minValue = 0;
547  ossim_float64 maxValue = 0;
548  getBinInformation(numberOfBins, minValue, maxValue, 0);
549
550  ossimIrect tileBoundary = theAreaOfInterest;
551  // ossimIpt tileSize(ossim::max((ossim_uint32)input->getTileWidth(), (ossim_uint32)64),
552  // ossim::max((ossim_uint32)input->getTileHeight(), (ossim_uint32)64));
553
554  ossimIpt tileSize(ossim::max<ossim_uint32>(input->getTileWidth(), (ossim_uint32)64),
556
557  tileBoundary.stretchToTileBoundary(tileSize);
558  ossim_uint32 tilesWide = (tileBoundary.width()/tileSize.x);
559  ossim_uint32 tilesHigh = (tileBoundary.height()/tileSize.y);
560  totalTiles = tilesWide*tilesHigh;
561
562  if(totalTiles > theNumberOfTilesToUseInFastMode)
563  {
564  ossim_uint32 testTiles = (ossim_uint32) (std::sqrt((double)theNumberOfTilesToUseInFastMode)+.5);
565  tilesWide = testTiles>tilesWide?tilesWide:testTiles;
566  tilesHigh = testTiles>tilesHigh?tilesHigh:testTiles;
567  }
568  if(numberOfBins > 0)
569  {
570  ossimIpt origin = theAreaOfInterest.ul();
571
572  ossim_uint32 widthWithExcess = (ossim_uint32)(((ossim_float64)tileBoundary.width()/(tilesWide*tileSize.x))*tileSize.x);
573  ossim_uint32 heightWithExcess = ((ossim_uint32)((ossim_float64)tileBoundary.height()/(tilesHigh*tileSize.y))*tileSize.y);
574  theHistogram->getMultiBandHistogram(0)->create(numberOfBands,
575  numberOfBins,
576  minValue,
577  maxValue);
578
579  ossim_uint32 x = 0;
580  ossim_uint32 y = 0;
581  tileCount = 0;
582  totalTiles = tilesWide*tilesHigh;
583  for(y = 0; y < tilesHigh; ++y)
584  {
585  for(x = 0; x < tilesWide; ++x)
586  {
587  ossimIpt ul(origin.x + (x*widthWithExcess),
588  origin.y + (y*heightWithExcess));
589  ossimIrect tileRect(ul.x, ul.y, ul.x + tileSize.x-1, ul.y + tileSize.y-1);
590  ossimRefPtr<ossimImageData> data = input->getTile(tileRect);
591
592  if(data.valid()&&data->getBuf()&&(data->getDataObjectStatus() != OSSIM_EMPTY))
593  {
595  }
596  ++tileCount;
597  setPercentComplete((100.0*(tileCount/totalTiles)));
598  }
599  }
600  }
601
602 #endif
603 }
604
606  const char* prefix)
607 {
608  ossimHistogramSource::loadState(kwl, prefix);
610  ossimString rect = kwl.find(prefix, "rect");
611
612  if(!rect.empty())
613  {
614  loadState(kwl, prefix);
615  }
616  else
617  {
618  ossimString newPrefix = ossimString(prefix) + "area_of_interest.";
619  theAreaOfInterest.loadState(kwl, newPrefix);
620  }
621
622  ossimString mode = kwl.find(prefix, "mode");
623  mode = mode.downcase();
624  if(mode == "normal")
625  {
627  }
628  else if(mode == "fast")
629  {
631  }
632  if(getNumberOfInputs()!=1)
633  {
635  }
636
637  // ossimString numberOfTiles = kwl.find(prefix, "number_of_tiles");
638  // if(!numberOfTiles.empty())
639  // {
640  // theNumberOfTilesToUseInFastMode = numberOfTiles.toUInt32();
641  // }
642
644  theOutputListIsFixedFlag = false;
645
646  return true;
647 }
648
650  const char* prefix)const
651 {
652  bool result = ossimHistogramSource::saveState(kwl, prefix);
653  if(result)
654  {
655  ossimString newPrefix = ossimString(prefix) + "area_of_interest.";
656  theAreaOfInterest.saveState(kwl, newPrefix);
657  }
658  return result;
659 }
virtual void setNumberOfInputs(ossim_int32 numberOfInputs)
Will set the number of inputs.
#define OSSIM_DEFAULT_MAX_PIX_UINT16
ossim_uint32 x
virtual bool addListener(ossimListener *listener)
ossimImageHistogramSource(ossimObject *owner=0)
virtual ossim_uint32 getMaxNumberOfRLevels() const
ossimHistogramMode
T max(T a, T b)
Definition: ossimCommon.h:236
void setComputationMode(ossimHistogramMode mode)
64 bit floating point
16 bit unsigned integer
bool saveState(ossimKeywordlist &kwl, const char *prefix=0) const
Definition: ossimIrect.cpp:589
virtual void disconnect(ossimConnectableObject *object=0)
Will disconnect the object passed in.
void setNumberOfBinsOverride(ossim_int32 numberOfBinsOverride)
virtual void populateHistogram(ossimRefPtr< ossimMultiBandHistogram > histo)
virtual bool canConnectMyInputTo(ossim_int32 myInputIndex, const ossimConnectableObject *object) const
required to be overriden by derived classes
ossim_uint32 y
bool valid() const
Definition: ossimRefPtr.h:75
#define OSSIM_DEFAULT_MAX_PIX_UCHAR
ossimHistogramMode getComputationMode() const
float ossim_float32
double nan()
Definition: ossimCommon.h:135
ossim_uint32 height() const
Definition: ossimIrect.h:487
virtual ossimRefPtr< ossimImageData > getNextTile(ossim_uint32 resLevel=0)
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
16 bit signed integer
virtual void setPercentComplete(double percentComplete)
const ossimIpt & ul() const
Definition: ossimIrect.h:274
void create(ossim_uint32 numberOfResLevels)
32 bit floating point
32 bit unsigned integer
virtual void setProcessStatus(ossimProcessStatus processStatus)
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
virtual ossimRefPtr< ossimMultiResLevelHistogram > getHistogram()
void getBinInformation(ossim_uint32 &numberOfBins, ossim_float64 &minValue, ossim_float64 &maxValue, ossim_uint32 band) const
double ossim_float64
virtual void propertyEvent(ossimPropertyEvent &event)
ossimRefPtr< ossimMultiResLevelHistogram > theHistogram
virtual void setAreaOfInterest(const ossimIrect &areaOfInterest)
#define OSSIM_DEFAULT_MAX_PIX_UINT12
#define OSSIM_DEFAULT_MIN_PIX_SINT16
RTTI_DEF3(ossimImageHistogramSource, "ossimImageHistogramSource", ossimHistogramSource, ossimConnectableObjectListener, ossimProcessInterface)
bool loadState(const ossimKeywordlist &kwl, const char *prefix=0)
Definition: ossimIrect.cpp:641
32 bit signed integer
#define OSSIM_DEFAULT_MAX_PIX_UINT15
unsigned int ossim_uint32
#define PTR_CAST(T, p)
Definition: ossimRtti.h:321
#define OSSIM_DEFAULT_MAX_PIX_UINT13
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
T min(T a, T b)
Definition: ossimCommon.h:203
ossim_uint32 width() const
Definition: ossimIrect.h:500
#define OSSIM_DEFAULT_MAX_PIX_SINT16
void setMaxValueOverride(ossim_float32 maxValueOverride)
#define OSSIM_DEFAULT_MAX_PIX_UINT14
ossim_int32 y
Definition: ossimIpt.h:142
void makeNan()
Definition: ossimIrect.h:329
#define OSSIM_DEFAULT_MAX_PIX_UINT11
virtual ossim_uint32 getNumberOfInputs() const
Returns the number of input objects.
bool theInputListIsFixedFlag
Indicates whether the theInputObjectList is fixed.
bool empty() const
Definition: ossimString.h:411
void stretchToTileBoundary(const ossimIpt &tileWidthHeight)
Definition: ossimIrect.cpp:212
bool hasNans() const
Definition: ossimIrect.h:337
virtual void setMaxNumberOfRLevels(ossim_uint32 number)
ossim_int32 x
Definition: ossimIpt.h:141
8 bit unsigned integer
bool theOutputListIsFixedFlag
Indicates whether the theOutputObjectList is fixed.
void setAreaOfInterest(const ossimIrect &rect)
void setMinValueOverride(ossim_float32 minValueOverride)
ossimRefPtr< ossimMultiBandHistogram > getMultiBandHistogram(ossim_uint32 resLevel) const
void create(const ossimImageSource *input)
virtual void getDecimationFactors(std::vector< ossimDpt > &decimations) const
Will return an array of all decimations for each resolution level.
virtual void connectInputEvent(ossimConnectionEvent &event)
int ossim_int32
bool isnan(const float &v)
Definition: ossimCommon.h:91
virtual bool removeListener(ossimListener *listener)
