18 #if defined(_MSC_VER) || defined(__MINGW32__) 40 static const char DEFAULT_FILE_NAME[] =
"output.jpg";
41 static const ossim_int32 DEFAULT_JPEG_QUALITY = 100;
42 static ossimTrace traceDebug(
"ossimJpegWriter:debug");
46 theQuality(DEFAULT_JPEG_QUALITY),
47 theOutputFilePtr(NULL)
60 static const char MODULE[] =
"ossimJpegWriter::writeFile";
67 bool bandsDontMatch =
false;
71 if (components != 1 && components != 3)
73 bandsDontMatch =
true;
78 else if(components > 3)
94 << MODULE <<
" ERROR:" 96 <<
"\nReturning from method." << endl;
131 ossim_uint32 buf_size = tileHeight*image_width*outputComponents;
135 <<
"\nbuf_size: " << buf_size
139 std::vector<ossim_uint8> buf(buf_size);
147 std::vector<ossim_uint8> tempBuf;
162 struct jpeg_compress_struct cinfo;
163 struct jpeg_error_mgr jerr;
164 JSAMPROW row_pointer[1];
167 int row_stride = image_width * outputComponents;
169 cinfo.err = jpeg_std_error(&jerr);
170 jpeg_create_compress(&cinfo);
172 cinfo.image_width = image_width;
173 cinfo.image_height = image_height;
174 cinfo.input_components = outputComponents;
177 if (outputComponents == 3)
179 cinfo.in_color_space = JCS_RGB;
183 cinfo.in_color_space = JCS_GRAYSCALE;
186 jpeg_set_defaults(&cinfo);
188 jpeg_start_compress(&cinfo,
TRUE);
195 double tileCount = 0.0;
206 buf_rect.
set_lry(buf_rect.
ul().
y + tileHeight - 1);
222 memcpy(tempTile->
getBuf(),
257 min( (buf_rect.
lr().
y-buf_rect.
ul().
y+1),
264 <<
"buf_rect: " << buf_rect
265 <<
"lines_to_copy: " << lines_to_copy << endl;
272 for (
ossim_int32 line=0; line<lines_to_copy; ++line)
274 row_pointer[0] = &buf[buf_offset];
275 jpeg_write_scanlines(&cinfo, row_pointer, 1);
276 buf_offset += row_stride;
285 jpeg_finish_compress(&cinfo);
291 jpeg_destroy_compress(&cinfo);
299 if(savedInput.
valid())
312 const char* prefix)
const 338 static const char MODULE[] =
"ossimJpegWriter::setQuality";
341 if (quality > 0 && quality < 101)
350 << MODULE <<
" DEBUG:" 351 <<
"\nquality out of range: " << quality
352 <<
"\nquality has been set to default: " 353 << DEFAULT_JPEG_QUALITY
354 <<
"\nvalid range: 1 to 100 with 100 being best." 364 << MODULE <<
" DEBUG:" 365 <<
"\nQuality set to: " 414 if((imageType ==
"image/jpeg")||
415 (imageType ==
"image/jpg"))
425 if ( property.
valid() )
430 property->valueToString(stringValue);
459 propertyNames.push_back(name);
Will set the property whose name matches the argument "property->getName()".
void set_uly(ossim_int32 y)
virtual void slaveProcessTiles()
virtual ossim_uint32 getTileWidth() const
Returns the default processing tile width.
ossimString theOutputImageType
bool needsAborting() const
virtual bool isMaster() const
virtual void setToStartOfSequence()
static const ossimErrorCode OSSIM_OK
ossim_int64 getNumberOfTiles() const
virtual ossimRefPtr< ossimImageData > getNextTile(ossim_uint32 resLevel=0)
ossimIrect theAreaOfInterest
Numeric to string methods.
const ossimIpt & ul() const
Pushes this's names onto the list of property names.
virtual ossimString getExtension() const
Returns a 3-letter extension from the image type descriptor (theOutputImageType) that can be used for...
Pure virtual base class for image file writers.
virtual void initialize()
Initialize the data buffer.
virtual void setQuality(ossim_int32 quality)
Sets the jpeg compression quality.
virtual ossim_uint32 getSizePerBandInBytes() const
Returns the number of bytes in single band of the tile.
ossim_int32 toInt32() const
#define RTTI_DEF1_INST(cls, name, b1)
bool hasImageType(const ossimString &imageType) const
bool hasImageType(const ossimString& imageType) const
virtual void setAreaOfInterest(const ossimIrect &areaOfInterest)
virtual void getImageTypeList(std::vector< ossimString > &imageTypeList) const
void getImageTypeList(std::vector<ossimString>& imageTypeList)const
virtual void setNumericType(ossimNumericPropertyType type)
ossimRefPtr< ossimImageSourceSequencer > theInputConnection
ossimFilename theFilename
unsigned int ossim_uint32
virtual ossimIrect getImageRectangle() const
const ossimIpt & lr() const
virtual void unloadTile(void *dest, const ossimIrect &dest_rect, ossimInterleaveType il_type) const
virtual ossim_int32 connectMyInputTo(ossimConnectableObject *inputObject, bool makeOutputConnection=true, bool createEventFlag=true)
Will try to connect this objects input to the passed in object.
virtual bool isOpen() const
virtual bool hasImageType(const ossimString &imageType) const
virtual void setOrigin(const ossimIpt &origin)
ossim_int64 getNumberOfTilesHorizontal() const
virtual ossim_uint32 getTileHeight() const
Returns the default processing tile height.
void set_lry(ossim_int32 y)
virtual ossimErrorCode getErrorStatus() const
virtual void setWriteExternalGeometryFlag(bool flag)
static const char * COMPRESSION_QUALITY_KW
virtual bool writeFile()
Write out the file.
const char * c_str() const
Returns a pointer to a null-terminated array of characters representing the string's contents...
virtual void setDataObjectStatus(ossimDataObjectStatus status) const
Full list found in ossimConstants.h.
virtual void setPercentComplete(double percentComplete)
virtual ~ossimJpegWriter()
virtual destructor
ossimJpegWriter()
default constructor
virtual const ossimIpt & getOrigin() const
ossim_int64 getNumberOfTilesVertical() const
saves the state of the object.
const ossimString & getName() const
