25 "ossimMetadataFileWriter",
30 static ossimTrace traceDebug(
"ossimMetadataFileWriter:debug");
36 theInputConnection(NULL),
142 <<
"ossimMetadataFileWriter::execute DEBUG:\n" 143 <<
"theInputConnection is null!" 155 <<
"ossimMetadataFileWriter::execute DEBUG:\n" 156 <<
"theFilename is not set!" 174 <<
"ossimMetadataFileWriter::execute DEBUG:\n" 175 <<
"theAreaOfInterest is not set!" 193 <<
"ossimMetadataFileWriter::execute DEBUG:\n" 194 << (result?
"successful":
"unsuccessful") <<
" write of file: " 243 if(!property.
valid())
return;
virtual void valueToString(ossimString &valueResult) const =0
virtual bool addListener(ossimListener *listener)
This will return the bounding rect of the source.
static const ossimFilename NIL
This was taken from Wx widgets for performing touch and access date stamps.
bool contains(char aChar) const
virtual void setPercentComplete(double percentComplete)
virtual void setProcessStatus(ossimProcessStatus processStatus)
virtual void fireEvent(ossimEvent &event)
ConnectableObjectList theInputObjectList
Holds a list of input objects.
void setIoType(ossimFilenamePropertyIoType ioType)
static const char * PIXEL_TYPE_KW
bool theInputListIsFixedFlag
Indicates whether the theInputObjectList is fixed.
bool theOutputListIsFixedFlag
Indicates whether the theOutputObjectList is fixed.
static const char * FILENAME_KW
virtual bool removeListener(ossimListener *listener)
